  4. Homematic RPC Adapter - CCU3 hängt sich auf
    5.4k
17 Beiträge 4 Kommentatoren 1.7k Aufrufe 3 Beobachtet
    @dy-namic was steht im (debug-) Log und im SysLog der CCU?
    Dy NamicD Offline
    Dy NamicD Offline
    Dy Namic
    Es ist alles voll mit Warnings:
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: CallGetValue failed; sVal = 0.000000 [ReadValue():iseDOMdpHSS.cpp:124]
    Apr 19 10:44:16 CCU3 local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E5F29B4A279:1","FROST_PROTECTION"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: FROST_PROTECTION"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2608]
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: XMLRPC 'getValue' call failed (interface: 1009, params: {"000E5F29B4A279:1","FROST_PROTECTION"}) [CallGetValue():iseXmlRpc.cpp:1435]
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: CallGetValue failed; sVal = 0 [ReadValue():iseDOMdpHSS.cpp:124]
    Apr 19 10:44:16 CCU3 local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E5F29B4A279:1","PARTY_TIME_END"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: PARTY_TIME_END"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2608]
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: XMLRPC 'getValue' call failed (interface: 1009, params: {"000E5F29B4A279:1","PARTY_TIME_END"}) [CallGetValue():iseXmlRpc.cpp:1435]
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: CallGetValue failed; sVal =  [ReadValue():iseDOMdpHSS.cpp:124]
    Apr 19 10:44:16 CCU3 local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E5F29B4A279:1","HUMIDITY"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: HUMIDITY"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2608]
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: XMLRPC 'getValue' call failed (interface: 1009, params: {"000E5F29B4A279:1","HUMIDITY"}) [CallGetValue():iseXmlRpc.cpp:1435]
    Apr 19 10:44:16 CCU3 local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E9F29B48095:1","PARTY_TIME_START"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: PARTY_TIME_START"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2608]
    Apr 19 10:44:16 CCU3 local0.err ReGaHss: ERROR: XMLRPC 'getValue' call failed (interface: 1009, params: {"000E9F29B48095:1","PARTY_TIME_START"}) [CallGetValue():iseXmlRpc.cpp:1435]
    Apr 19 10:44:16 CCU3 local0.warn ReGaHss: WARNING: XMLRPC 'getValue': rpcClient.isFault() failed (url: xmlrpc://127.0.0.1:32010, params: {"000E9F29B48095:1","PARTY_SET_POINT_TEMPERATURE"}, result: [faultCode:-5,faultString:"Unknown Parameter value for value key: PARTY_SET_POINT_TEMPERATURE"]) [CallXmlrpcMethod():iseXmlRpc.cpp:2608]
    Dy NamicD HomoranH 2 Antworten Letzte Antwort
    • Dy NamicD Dy Namic
      Dy NamicD Offline
      Dy NamicD Offline
      Dy Namic
      CCU
      Firmware: 3.69.7
      Firewall:
      Was ist mit dem Punkt: Authetifizierung gemeint?
      ioBroker:
      RPC
      REGA
        CCU
        Firmware: 3.69.7
        Firewall:
        ioBroker:
        RPC
        REGA
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @dy-namic sagte in Homematic RPC Adapter - CCU3 hängt sich auf:
        Einstellungen.Systemsteuerung.Sicherheit
        Da du alle Ports auf der ccu offen hast müsste es eigentlich gehen.
        Ist zwar nicht so wie ich es machen würde, müsste aber klappen.
        Bei mir so:
        Danke.
        Dy NamicD 1 Antwort Letzte Antwort
          wie schnell versuchst du abzufragen?
          das sind ja "hunderte" Abfragen pro Sekunde.
          da ist der DC bestimmt längst überschritten.
          und was fragst du da ab?
          z.B. : > Unknown Parameter value for value key: PARTY_TIME_START
          • bahnuhrB bahnuhr
            Bei mir so:
            Dy NamicD Offline
            Dy NamicD Offline
            Dy Namic
            @bahnuhr
            ich musste die Ports öffnen damit Cloudmatic bei mir funktioniert. Ansonsten hätte ich diese auch gerne geschlossen gehabt.
              Dy NamicD Offline
              Dy NamicD Offline
              Dy Namic
              schrieb am zuletzt editiert von Dy Namic
              alle Einstellungen sind default. Die Abfrage macht der RPC ich habe ihn nur eingeschaltet.
                kein Script oder vis o.ä.?
                  Dy NamicD Offline
                  Dy NamicD Offline
                  Dy Namic
                  du meinst ob neben dem Homematic Adaptern noch etwas läuft auf dem ioBroker?
                    ...was auf hm-rega zugreifen könnte.
                      Dy NamicD Offline
                      Dy NamicD Offline
                      Dy Namic
                      da ich nicht weiß ob der Rega oder RPC die CCU abstürzen lässt habe ich aktuell nur den RPC laufen.
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        Und wieder so ein Spezi.
                        Warum kommt diese Info erst jetzt?
                        Und warum zeigst du mir oben die Einstellungen von rega?
                        Dass deine Firewall Einstellungen auf der ccu nicht passen können, hast du ja mit meinen verglichen.
                        Ansonsten hättest du ja ne Frage gestellt !
                        richtig?
                        Fazit:
                        Hast du die Firewall Einstellungen angepasst ?
                        Ich bin jetzt hier raus.
                        Wenn die Infos so lückenhaft und falsch kommen (rega), warum sollte man sich dann die Mühe machen.
                        Danke.
                        Dy NamicD bahnuhrB 2 Antworten Letzte Antwort
                        -2
                        • bahnuhrB bahnuhr
                          richtig?
                          Fazit:
                          Dy NamicD Offline
                          Dy NamicD Offline
                          Dy Namic
                          @bahnuhr
                          ich habe nicht daran gedacht das dies relevant sein könnte da ich ja in diesem Thread explizit mir den RPC anschaue. Aber du hast recht die Informationen waren am Anfang nicht klar gegeben.
                          Warum ich die Einstellungen zeige? Du hattest danach gefragt.
                          Ich habe kein Problem damit meine Firewall Einstellungen anzupassen. Aber technisch verstehe ich nicht wie diese hier helfen können. Gerne kannst du mir das noch einmal erklären. Aktuell sieht es für mich so aus das dein System mit restriktiveren Einstellungen auch funktioniert. Aber da meine mehr Freiheiten geben sollte die Firewall nicht das Problem sein oder?
                          Ich würde mich freuen wenn du trotzdem weiter unterstützen könntest.
                          • bahnuhrB bahnuhr
                            richtig?
                            Fazit:
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            @bahnuhr sagte in Homematic RPC Adapter - CCU3 hängt sich auf:
                            Danke.
