  4. "Läuft" der "dasWetter" Adapter bei euch ?
    5.4k
14 Beiträge 4 Kommentatoren 373 Aufrufe 1 Beobachtet
  • Dr.PieD Offline
    Dr.PieD Offline
    Dr.Pie
    Moin
    bei mir kommen Fehler ohne Ende:
    host.raspberrypi
    	2023-04-21 21:31:08.612	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
    host.raspberrypi
    daswetter.0
    	2023-04-21 21:31:08.584	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.Hour_10.wind_symbolB: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_10.wind_symbolB": Connection is closed.]
    daswetter.0
    daswetter.0
    	2023-04-21 21:31:08.577	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_10.wind_symbolB": Connection is closed.
    daswetter.0
    daswetter.0
    	2023-04-21 21:31:08.570	error	exception in await insertIntoList [Error: DB closed]
    daswetter.0
    daswetter.0
    	2023-04-21 21:31:08.537	error	exception in await insertIntoList [Error: DB closed]
    daswetter.0
    daswetter.0
    	2023-04-21 21:31:08.020	error	force terminate
    daswetter.0
    host.raspberrypi
    	2023-04-21 21:31:06.247	error	instance system.adapter.daswetter.1 terminated with code 15 (UNKNOWN_ERROR)
    host.raspberrypi
    daswetter.1
    	2023-04-21 21:31:06.205	error	Cannot check object existence of "daswetter.1.NextHours.Location_1.Day_2.pressure_value": Connection is closed.
    daswetter.1
    daswetter.1
    	2023-04-21 21:31:06.195	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.1.NextHours.Location_1.Day_2.humidity_value: Cannot check object existence of "daswetter.1.NextHours.Location_1.Day_2.humidity_value": Connection is closed.]
    daswetter.1
    daswetter.1
    	2023-04-21 21:31:06.187	error	Cannot check object existence of "daswetter.1.NextHours.Location_1.Day_2.humidity_value": Connection is closed.
    daswetter.1
    daswetter.1
    	2023-04-21 21:31:06.181	error	exception in await insertIntoList [Error: DB closed]
    daswetter.1
    daswetter.1
    	2023-04-21 21:31:06.154	error	exception in await insertIntoList [Error: DB closed]
    daswetter.1
    daswetter.1
    	2023-04-21 21:31:05.638	error	force terminate
    daswetter.1
    Das ist nur ein Auszug.
    Wo klemmt es denn da ??
    • Dr.PieD Dr.Pie
      Moin
      host.raspberrypi
      host.raspberrypi
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      daswetter.0
      host.raspberrypi
      host.raspberrypi
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      daswetter.1
      haselchenH Offline
      haselchenH Offline
      haselchen
      @dr-pie
      warum hast du 2 Instanzen?
      Wann rufst Du die ab?
      Dr.PieD 1 Antwort Letzte Antwort
      • Ro75R Offline
        Ro75R Offline
        Ro75
        @dr-pie ändere im Adapter ggf. mal aud diesen Wert. Eventuell sogar noch höher setzen.
        • haselchenH haselchen
          @dr-pie
          Dr.PieD Offline
          Dr.PieD Offline
          Dr.Pie
          @haselchen sagte in "Läuft" der "dasWetter" Adapter bei euch ?:
          @dr-pie
          ich habe eine zweite Instanz da ich 2 verschieden Orte abfragen muss.
          • Ro75R Ro75
            Dr.PieD Offline
            Dr.PieD Offline
            Dr.Pie
            @ro75 sagte in "Läuft" der "dasWetter" Adapter bei euch ?:
            Das stand bei mir auf 60.
            Mal sehen ob es besser wird mit 300.
            • Dr.PieD Dr.Pie
              @dr-pie
              haselchenH Offline
              haselchenH Offline
              haselchen
              @dr-pie
              Frage 1 wäre beantwortet.
              Ist natürlich logisch , dass du beide Instanzen zu unterschiedlichen Zeiten abrufen solltest.
                @dr-pie
                Dr.PieD Offline
                Dr.PieD Offline
                Dr.Pie
                @haselchen Die erste steht auf 300 und die zweite auf 310.
                Mal sehen ob das reicht.
                Ro75R haselchenH 2 Antworten Letzte Antwort
                • Dr.PieD Dr.Pie
                  Ro75R Offline
                  Ro75R Offline
                  Ro75
                  @dr-pie Die 300 haben nichts mit unterschiedlichen Abrufzeiten zu tun. Das ist die zugesicherte Zeit vom Download bis zur abschließenden Verarbeitung.
                  Hier kannst du jeder Instanz unterschiedliche Zeiten einstellen. Bei mir, jeweils 6, 26 und 46 Minute je Stunde.
                  • Dr.PieD Dr.Pie
                    haselchenH Offline
                    haselchenH Offline
                    haselchen
                    @dr-pie
                    Auf jedenfall beobachten.
                    Keine Ahnung wie der Server reagiert , wenn in 10sek die Zweite Abfrage mit der gleichen IP gemacht wird.
                      @dr-pie
                      Dr.PieD Offline
                      Dr.PieD Offline
                      Dr.Pie
                      @haselchen ok ... werd ich beobachten.
                      Habe den ersten Adapter nun auf 5,15,25,35,45,55 gestellt.
                      Den zweiten Adapter auf 0,10,20,30,40,50 eingestellt.
                      Wobei ich denke das man sooo oft gar nicht abrufen muss.
                      • Dr.PieD Dr.Pie
                        Ro75R Offline
                        Ro75R Offline
                        Ro75
                        @dr-pie 20 bis 30 Minuten reichen.
                        • Dr.PieD Dr.Pie
                          haselchenH Offline
                          haselchenH Offline
                          haselchen
                          @dr-pie
                          Alle 10min ?
                          Naja.
                          Bisschen übertrieben.
                            @dr-pie
                            Alle 10min ?
                            Naja.
                            Dr.PieD Offline
                            Dr.PieD Offline
                            Dr.Pie
                            @haselchen Ja das denk ich auch.
                            Habe den ersten auf 15 und 45 Minuten und den zweiten auf 0 und 30 Minuten gestellt.
                            Soooo oft ändert sich das Wetter ja auch nicht innerhalb einer Stunden.
                            • Dr.PieD Dr.Pie
                              @dr-pie sagte: auf 0 und 30 Minuten gestellt.
                              Zur vollen Stunde fragen viele Nutzer ab. Dadurch kann der Server überlastet werden (Bad Gateway). Wähle besser andere Zeiten.
