<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ?]]></title><description><![CDATA[<p dir="auto">Moin<br />
bei mir kommen Fehler ohne Ende:</p>
<pre><code>host.raspberrypi
	2023-04-21 21:31:08.612	error	instance system.adapter.daswetter.0 terminated with code 15 (UNKNOWN_ERROR)
host.raspberrypi
daswetter.0
	2023-04-21 21:31:08.584	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.0.NextHours.Location_1.Day_2.Hour_10.wind_symbolB: Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_10.wind_symbolB": Connection is closed.]
daswetter.0
daswetter.0
	2023-04-21 21:31:08.577	error	Cannot check object existence of "daswetter.0.NextHours.Location_1.Day_2.Hour_10.wind_symbolB": Connection is closed.
daswetter.0
daswetter.0
	2023-04-21 21:31:08.570	error	exception in await insertIntoList [Error: DB closed]
daswetter.0
daswetter.0
	2023-04-21 21:31:08.537	error	exception in await insertIntoList [Error: DB closed]
daswetter.0
daswetter.0
	2023-04-21 21:31:08.020	error	force terminate
daswetter.0
host.raspberrypi
	2023-04-21 21:31:06.247	error	instance system.adapter.daswetter.1 terminated with code 15 (UNKNOWN_ERROR)
host.raspberrypi
daswetter.1
	2023-04-21 21:31:06.205	error	Cannot check object existence of "daswetter.1.NextHours.Location_1.Day_2.pressure_value": Connection is closed.
daswetter.1
daswetter.1
	2023-04-21 21:31:06.195	error	exception in await insertIntoList [Error: Could not check object existence of daswetter.1.NextHours.Location_1.Day_2.humidity_value: Cannot check object existence of "daswetter.1.NextHours.Location_1.Day_2.humidity_value": Connection is closed.]
daswetter.1
daswetter.1
	2023-04-21 21:31:06.187	error	Cannot check object existence of "daswetter.1.NextHours.Location_1.Day_2.humidity_value": Connection is closed.
daswetter.1
daswetter.1
	2023-04-21 21:31:06.181	error	exception in await insertIntoList [Error: DB closed]
daswetter.1
daswetter.1
	2023-04-21 21:31:06.154	error	exception in await insertIntoList [Error: DB closed]
daswetter.1
daswetter.1
	2023-04-21 21:31:05.638	error	force terminate
daswetter.1
</code></pre>
<p dir="auto">Das ist nur ein Auszug.<br />
Wo klemmt es denn da  ??</p>
<p dir="auto">Danke</p>
]]></description><link>https://forum.iobroker.net/topic/64819/läuft-der-daswetter-adapter-bei-euch</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 16:14:39 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/64819.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Apr 2023 19:41:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 20:17:22 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie sagte: auf 0 und 30 Minuten gestellt.</p>
<p dir="auto">Zur vollen Stunde fragen viele Nutzer ab. Dadurch kann der Server überlastet werden (Bad Gateway). Wähle besser andere Zeiten.</p>
]]></description><link>https://forum.iobroker.net/post/981684</link><guid isPermaLink="true">https://forum.iobroker.net/post/981684</guid><dc:creator><![CDATA[paul53]]></dc:creator><pubDate>Fri, 21 Apr 2023 20:17:22 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 20:09:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> Ja das denk ich auch.<br />
Habe den ersten auf 15 und 45 Minuten und den zweiten auf 0 und 30 Minuten gestellt.<br />
Soooo oft ändert sich das Wetter ja auch nicht innerhalb einer Stunden.</p>
]]></description><link>https://forum.iobroker.net/post/981679</link><guid isPermaLink="true">https://forum.iobroker.net/post/981679</guid><dc:creator><![CDATA[Dr.Pie]]></dc:creator><pubDate>Fri, 21 Apr 2023 20:09:21 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 20:03:42 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie</p>
<p dir="auto">Alle 10min ?<br />
Naja.<br />
Bisschen übertrieben.</p>
]]></description><link>https://forum.iobroker.net/post/981676</link><guid isPermaLink="true">https://forum.iobroker.net/post/981676</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 21 Apr 2023 20:03:42 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 20:03:33 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie 20 bis 30 Minuten reichen.</p>
]]></description><link>https://forum.iobroker.net/post/981675</link><guid isPermaLink="true">https://forum.iobroker.net/post/981675</guid><dc:creator><![CDATA[Ro75]]></dc:creator><pubDate>Fri, 21 Apr 2023 20:03:33 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 20:02:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> ok ... werd ich beobachten.<br />
Habe den ersten Adapter nun auf 5,15,25,35,45,55 gestellt.<br />
Den zweiten Adapter auf 0,10,20,30,40,50 eingestellt.</p>
<p dir="auto">Wobei ich denke das man sooo oft gar nicht abrufen muss.</p>
]]></description><link>https://forum.iobroker.net/post/981674</link><guid isPermaLink="true">https://forum.iobroker.net/post/981674</guid><dc:creator><![CDATA[Dr.Pie]]></dc:creator><pubDate>Fri, 21 Apr 2023 20:02:25 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:57:48 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie</p>
<p dir="auto">Auf jedenfall beobachten.<br />
Keine Ahnung wie der Server reagiert , wenn in 10sek die Zweite Abfrage mit der gleichen IP gemacht wird.</p>
]]></description><link>https://forum.iobroker.net/post/981672</link><guid isPermaLink="true">https://forum.iobroker.net/post/981672</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:57:07 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie Die 300 haben nichts mit unterschiedlichen Abrufzeiten zu tun. Das ist die zugesicherte Zeit vom Download bis zur abschließenden Verarbeitung.</p>
<p dir="auto"><img src="/assets/uploads/files/1682106980865-d81a06bc-5fac-456e-9ebc-f9daf5b105e1-image.png" alt="d81a06bc-5fac-456e-9ebc-f9daf5b105e1-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Hier kannst du jeder Instanz unterschiedliche Zeiten einstellen. Bei mir, jeweils 6, 26 und 46 Minute je Stunde.</p>
]]></description><link>https://forum.iobroker.net/post/981670</link><guid isPermaLink="true">https://forum.iobroker.net/post/981670</guid><dc:creator><![CDATA[Ro75]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:57:07 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:53:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> Die erste steht auf 300 und die zweite auf 310.<br />
Mal sehen ob das reicht.</p>
]]></description><link>https://forum.iobroker.net/post/981667</link><guid isPermaLink="true">https://forum.iobroker.net/post/981667</guid><dc:creator><![CDATA[Dr.Pie]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:53:32 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:52:07 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie</p>
<p dir="auto">Frage 1 wäre beantwortet.</p>
<p dir="auto">Ist natürlich logisch , dass du beide Instanzen zu unterschiedlichen Zeiten abrufen solltest.</p>
]]></description><link>https://forum.iobroker.net/post/981666</link><guid isPermaLink="true">https://forum.iobroker.net/post/981666</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:52:07 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:50:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ro75" aria-label="Profile: ro75">@<bdi>ro75</bdi></a> sagte in <a href="/post/981662">"Läuft" der "dasWetter" Adapter bei euch ?</a>:</p>
<blockquote>
<p dir="auto">@dr-pie ändere im Adapter ggf. mal aud diesen Wert. Eventuell sogar noch höher setzen.</p>
<p dir="auto"><img src="/assets/uploads/files/1682106464404-fdd25a41-ba3c-461f-a7ac-984923d4f032-image.png" alt="fdd25a41-ba3c-461f-a7ac-984923d4f032-image.png" class=" img-fluid img-markdown" /></p>
</blockquote>
<p dir="auto">Das stand bei mir auf 60.<br />
Mal sehen ob es besser wird mit 300.</p>
]]></description><link>https://forum.iobroker.net/post/981665</link><guid isPermaLink="true">https://forum.iobroker.net/post/981665</guid><dc:creator><![CDATA[Dr.Pie]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:50:50 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:50:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/haselchen" aria-label="Profile: haselchen">@<bdi>haselchen</bdi></a> sagte in <a href="/post/981660">"Läuft" der "dasWetter" Adapter bei euch ?</a>:</p>
<blockquote>
<p dir="auto">warum hast du 2 Instanzen?<br />
Wann rufst Du die ab?</p>
</blockquote>
<p dir="auto">ich habe eine zweite Instanz da ich 2 verschieden Orte abfragen muss.</p>
]]></description><link>https://forum.iobroker.net/post/981664</link><guid isPermaLink="true">https://forum.iobroker.net/post/981664</guid><dc:creator><![CDATA[Dr.Pie]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:50:07 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:47:48 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie ändere im Adapter ggf. mal aud diesen Wert. Eventuell sogar noch höher setzen.</p>
]]></description><link>https://forum.iobroker.net/post/981662</link><guid isPermaLink="true">https://forum.iobroker.net/post/981662</guid><dc:creator><![CDATA[Ro75]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:47:48 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Läuft&quot; der &quot;dasWetter&quot; Adapter bei euch ? on Fri, 21 Apr 2023 19:48:55 GMT]]></title><description><![CDATA[<p dir="auto">@dr-pie</p>
]]></description><link>https://forum.iobroker.net/post/981660</link><guid isPermaLink="true">https://forum.iobroker.net/post/981660</guid><dc:creator><![CDATA[haselchen]]></dc:creator><pubDate>Fri, 21 Apr 2023 19:48:55 GMT</pubDate></item></channel></rss>
