  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • mickymM mickym
    @damrak2022 Ja mit sudo - hatte ich vergessen
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #172
    @mickym
    Andy@homebridge:~ $ sudo systemctl disable influxdb
    Andy@homebridge:~ $
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      @mickym
      Andy@homebridge:~ $
      mickymM Offline
      mickymM Offline
      mickym
      #173
      @damrak2022 Ok vorher ist es ja gelaufen.
      NOchmal schauen was
      systemctl status influxdb
      zeigt.
      • mickymM mickym
        NOchmal schauen was
        zeigt.
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #174
        @mickym sagte in Influxdb2 Backitup:
        Andy@homebridge:~ $ systemctl status influxdb
        ● influxdb.service - InfluxDB is an open-source, distributed, time series database
             Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor preset: enabled)
             Active: active (running) since Thu 2023-04-20 02:15:56 CEST; 17min ago
               Docs: https://docs.influxdata.com/influxdb/
           Main PID: 718 (influxd)
              Tasks: 9 (limit: 3932)
                CPU: 2.329s
             CGroup: /system.slice/influxdb.service
                     └─718 /usr/bin/influxd
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.631155Z lvl=info msg="Open store (end)" log_id=0hJ0>
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632101Z lvl=info msg="Starting retention policy enf>
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.632359Z lvl=info msg="Starting precreation service">
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[715]: InfluxDB API at http://localhost:8086/ready unavailable after 1 attempts...
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" lo>
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statemen>
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 se>
        Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 s>
        Apr 20 02:15:56 homebridge influxd-systemd-start.sh[715]: InfluxDB started
        Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
        lines 1-20/20 (END)
        Mit besten Grüßen
        Andy
                  CPU: 2.329s
          lines 1-20/20 (END)
          mickymM Offline
          mickymM Offline
          mickym
          #175
          @damrak2022 Witzig ist dass der Service nun wieder aktiv gezeigt wird.
          mach nochmal
          sudo systemctl stop influxdb
          und dann nochmal
               Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
               Active: inactive (dead) since Thu 2023-04-20 02:36:24 CEST; 3s ago
              Process: 563 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
             Main PID: 572 (code=killed, signal=TERM)
                  CPU: 29.183s
          Bei aktiv muss dead stehen und dann Maschine neu starten - dann sollte mit dem disable nichts mehr stehen.
          • mickymM mickym
            mach nochmal
            und dann nochmal
                    CPU: 29.183s
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #176
            Andy@homebridge:~ $ sudo systemctl stop influxdb
            ● influxdb.service - InfluxDB is an open-source, distributed, time series datab>
                 Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pre>
                 Active: inactive (dead) since Thu 2023-04-20 02:43:04 CEST; 15s ago
               Main PID: 718 (code=killed, signal=TERM)
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:5>
            Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, dist>
            Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, dis>
            Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Succeeded.
            Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
            Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Consumed 2.842s CPU ti>
            lines 1-17/17 (END)
                 Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor prese>
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.>
            Apr 20 02:15:56 homebridge systemd[1]: Started InfluxDB is an open-source, distri>
            Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, distr>
            Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, distri>
            Apr 20 02:43:04 homebridge systemd[1]: influxdb.service: Consumed 2.842s CPU time.
            lines 1-17/17 (END)
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ0>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697134Z lvl=info msg=Starting log_id=0hJ07gPl000 service=telemetry interval=8h
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=>
            Apr 20 02:43:04 homebridge systemd[1]: Stopping InfluxDB is an open-source, distributed, time series database...
            Apr 20 02:43:04 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
            lines 1-17/17 (END)
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 ma>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.697799Z lvl=info msg=Listening log_id=0hJ07gPl000 service=tcp-listener transport=http addr=:8086 port=8086
            lines 1-17/17 (END)
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initi>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_sele>
            lines 1-17/17 (END)
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initial_me>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_select_po>
            lines 1-17/17 (END)
                    CPU: 2.842s
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.640169Z lvl=info msg="Starting query controller" log_id=0hJ07gPl000 service=storage-reads concurrency_quota=1024 initial_mem>
            Apr 20 02:15:55 homebridge influxd-systemd-start.sh[718]: ts=2023-04-20T00:15:55.667478Z lvl=info msg="Configuring InfluxQL statement executor (zeros indicate unlimited)." log_id=0hJ07gPl000 max_select_poi>
            lines 1-17/17 (END)
            Mit besten Grüßen
            Andy
                      CPU: 2.842s
              lines 1-17/17 (END)
                      CPU: 2.842s
              lines 1-17/17 (END)
                      CPU: 2.842s
              lines 1-17/17 (END)
                      CPU: 2.842s
              lines 1-17/17 (END)
                      CPU: 2.842s
              lines 1-17/17 (END)
                      CPU: 2.842s
              lines 1-17/17 (END)
                      CPU: 2.842s
              lines 1-17/17 (END)
              mickymM Offline
              mickymM Offline
              mickym
              #177
              @damrak2022 Ok - dann ist das Teil nun inaktiv.
              Jetzt die beiden Verzeichnisse weg machen:
              Andy@homebridge:~ $ sudo rm -R /var/lib/influxdb
              Andy@homebridge:~ $ sudo rm -R /etc/influxdb
              Nochmal
              sudo apt purge influxdb
              und Ausgabe zeigen:
              • mickymM mickym
                Nochmal
                und Ausgabe zeigen:
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #178
                Die sind garnicht da:
                rm: das Entfernen von '/var/lib/influxdb' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                rm: das Entfernen von '/etc/influxdb' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                Andy@homebridge:~ $
                Mit besten Grüßen
                Andy
                  Andy@homebridge:~ $
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #179
                  @damrak2022 Gut und
                  sudo apt purge influxdb2
                  zeigt auch nichts mehr?
                  EDIT muss influxdb2 heißen
                  • mickymM mickym
                    @damrak2022 Gut und
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #180
                    Andy@homebridge:~ $ sudo apt purge influxdb
                    Paket »influxdb« ist nicht installiert, wird also auch nicht entfernt.
                    Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
                      influxdb2-cli
                    Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
                    0 aktualisiert, 0 neu installiert, 0 zu entfernen und 1 nicht aktualisiert.
                    Andy@homebridge:~ $
                    Mit besten Grüßen
                    Andy
                        influxdb2-cli
                      Andy@homebridge:~ $
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #181
                      @damrak2022 Gut nun Maschine neu starten.
                      • mickymM mickym
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #182
                        @mickym Nein warte das müsste doch
                        heißen, oder?
                        Mit besten Grüßen
                        Andy
                          heißen, oder?
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #183
                          @damrak2022 Ja Du hast RECHT: ;)
                          • mickymM mickym
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #184
                            @mickym
                            Andy@homebridge:~ $ sudo apt purge influxdb2
                            Paket »influxdb2« ist nicht installiert, wird also auch nicht entfernt.
                              influxdb2-cli
                            Andy@homebridge:~ $
                            Was ist denn mit dem influxdb2-cli ?
                            Mit besten Grüßen
                            Andy
                              @mickym
                                influxdb2-cli
                              Andy@homebridge:~ $
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #185
                              @damrak2022 Ja das hätte ich gedacht, dass man drauf lassen kann, aber dann mach
                              sudo apt autoremove
                              • mickymM mickym
                                sudo apt autoremove
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #186
                                sudo apt autoremove
                                Ist weg, jetzt raspi Neustarten?
                                Mit besten Grüßen
                                Andy
                                  sudo apt autoremove
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #187
                                  @damrak2022 Ja
                                  • mickymM mickym
                                    @damrak2022 Ja
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #188
                                    @mickym So, neugestartet. Was nun zuerst?
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #189
                                      @damrak2022 sagte in Influxdb2 Backitup:
                                      Schauen ob der Service nun weg ist. 😁
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #190
                                             Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2mi>
                                            Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (>
                                                CPU: 2ms
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job,>
                                        Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, dist>
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated>
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'ex>
                                        Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sour>
                                        lines 1-12/12 (END)
                                        ● influxdb.service - InfluxDB is an open-source, distributed, time series databa>
                                             Loaded: loaded (/lib/systemd/system/influxdb.service; disabled; vendor pres>
                                             Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min>
                                            Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (c>
                                                CPU: 2ms
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, >
                                        Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distr>
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated >
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exi>
                                        Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-sourc>
                                        lines 1-12/12 (END)
                                             Active: failed (Result: exit-code) since Thu 2023-04-20 02:53:49 CEST; 2min 49s ago
                                            Process: 727 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=203/EXEC)
                                                CPU: 2ms
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
                                        Apr 20 02:53:49 homebridge systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Start request repeated too quickly.
                                        Apr 20 02:53:49 homebridge systemd[1]: influxdb.service: Failed with result 'exit-code'.
                                        Apr 20 02:53:49 homebridge systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
                                        lines 1-12/12 (END)
                                                CPU: 2ms
                                        lines 1-12/12 (END)
                                                CPU: 2ms
                                        lines 1-12/12 (END)
                                                CPU: 2ms
                                        lines 1-12/12 (END)
                                        Nochmal weil Start zu schnell?
                                        Mit besten Grüßen
                                        Andy
                                                  CPU: 2ms
                                          lines 1-12/12 (END)
                                                  CPU: 2ms
                                          lines 1-12/12 (END)
                                                  CPU: 2ms
                                          lines 1-12/12 (END)
                                                  CPU: 2ms
                                          lines 1-12/12 (END)
                                                  CPU: 2ms
                                          lines 1-12/12 (END)
                                                  CPU: 2ms
                                          lines 1-12/12 (END)
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #191
                                          @damrak2022 man könnte die Datei einfach löschen.
                                          Gut wir löschen den Service das geht:
                                          sudo rm /etc/systemd/system/influxdb.service
                                          sudo rm /lib/systemd/system/influxdb.service
