  4. Problem mit Adapter "javascript"
adapter
16 Beiträge 2 Kommentatoren 693 Aufrufe 2 Beobachtet
    @bahnuhr sagte in Problem mit Adapter "javascript":
    Ist aber doch nicht normal.
    Nein, ist es nicht.
    iob diag
    sagt?
    Und
    cd /opt/iobroker
    npm ls
    schaut wie aus?
    bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    Danke für deine schnelle Antwort.
    anbei:
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Architecture    : x86_64
    Docker          : false
    Virtualization  : kvm
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     19:14:07 up 2 days, 16:03,  1 user,  load average: 2.06, 1.57, 1.43
    CPU threads: 8
    *** Time and Time Zones ***
                   Local time: Mon 2023-04-17 19:14:08 CEST
               Universal time: Mon 2023-04-17 17:14:08 UTC
                     RTC time: Mon 2023-04-17 17:14:08
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    dieter
    /home/dieter
    dieter cdrom floppy sudo audio dip video plugdev netdev iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            5.9G        3.9G        206M        0.0K        1.8G        1.8G
    Swap:           974M         49M        925M
    Total:          6.9G        3.9G        1.1G
             5940 M total memory
             3899 M used memory
              650 M active memory
             4682 M inactive memory
              206 M free memory
              200 M buffer memory
             1634 M swap cache
              974 M total swap
               49 M used swap
              925 M free swap
    *** FILESYSTEM ***
    Filesystem                Type      Size  Used Avail Use% Mounted on
    udev                      devtmpfs  2.9G     0  2.9G   0% /dev
    tmpfs                     tmpfs     595M  500K  594M   1% /run
    /dev/sda1                 ext4       31G   12G   18G  39% /
    tmpfs                     tmpfs     3.0G     0  3.0G   0% /dev/shm
    tmpfs                     tmpfs     5.0M     0  5.0M   0% /run/lock
    //192.168.243.100/1_Sound cifs      238G  123G  115G  52% /mnt
    tmpfs                     tmpfs     595M     0  595M   0% /run/user/1000
    [Sat Apr 15 03:10:34 2023] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Apr 15 03:10:34 2023] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
    TARGET SOURCE                    FSTYPE OPTIONS
    /      /dev/sda1                 ext4   rw,relatime,errors=remount-ro
    `-/mnt //192.168.243.100/1_Sound cifs   rw,relatime,vers=3.1.1,cache=strict,username=Dieter,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.243.100,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    2.0G    /var/
    1.2G    /var/log/journal/4ef936d6ff8a4b6ab4f50f3038582f64
    1.2G    /var/log
    560M    /var/cache
    Archived and active journals take up 104.0M in the file system.
    /opt/iobroker/backups:
    2.6G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.1G    /opt/iobroker/iobroker-data/
    638M    /opt/iobroker/iobroker-data/files
    298M    /opt/iobroker/iobroker-data/files/vis.0
    248M    /opt/iobroker/iobroker-data/files/vis.0/wav
    222M    /opt/iobroker/iobroker-data/sqlite
    222M    /opt/iobroker/iobroker-data/sqlite/sqlite.db
    154M    /opt/iobroker/iobroker-data/files/vis.0/wav/starker-regen-mit-gewitter-im.wav
    47M     /opt/iobroker/iobroker-data/states.jsonl
    40M     /opt/iobroker/iobroker-data/objects.jsonl
    34M     /opt/iobroker/iobroker-data/files/vis.0/wav/hagelschauer-im-sommer.wav
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v18.16.0
    /usr/bin/node           v18.16.0
    /usr/bin/npm            9.5.1
    /usr/bin/npx            9.5.1
    nodejs:
      Installed: 18.16.0-deb-1nodesource1
      Candidate: 18.16.0-deb-1nodesource1
      Version table:
     *** 18.16.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_18.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   8
    Adapter State
      system.adapter.alias-manager.0          : alias-manager         : iobroker                                 - disabled
    + system.adapter.asterisk.0               : asterisk              : iobroker                                 -  enabled, port: 5038
    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
    + system.adapter.bmw.0                    : bmw                   : iobroker                                 -  enabled
    + system.adapter.bosch-ebike.0            : bosch-ebike           : iobroker                                 -  enabled
    + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
    + system.adapter.contact.0                : contact               : iobroker                                 -  enabled, port: 8096
      system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
      system.adapter.doorio.0                 : doorio                : iobroker                                 - disabled, port: 4444
      system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
      system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
      system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
    + system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
    + system.adapter.hm-rpc.2                 : hm-rpc                : iobroker                                 -  enabled, port: 0
      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
    + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
    + system.adapter.komoot.0                 : komoot                : iobroker                                 -  enabled
    + system.adapter.libre.0                  : libre                 : iobroker                                 -  enabled
      system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
    + system.adapter.logparser.0              : logparser             : iobroker                                 -  enabled
    + system.adapter.mbus.0                   : mbus                  : Pi-Strom-Wasser                          -  enabled, port: 3493
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
      system.adapter.mihome.0                 : mihome                : iobroker                                 - disabled, port: 9898, bind: 192.168.243.12
    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.mqtt.2                   : mqtt                  : iobroker                                 -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.musiccast.0              : musiccast             : iobroker                                 -  enabled
    + system.adapter.octoprint.0              : octoprint             : iobroker                                 -  enabled
    + system.adapter.openligadb.0             : openligadb            : iobroker                                 -  enabled
    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
    + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
    + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
      system.adapter.rest-api.0               : rest-api              : iobroker                                 - disabled, port: 8093, bind: 0.0.0.0, run as: admin
    + system.adapter.rssfeed.0                : rssfeed               : iobroker                                 -  enabled
    + system.adapter.sayit.2                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.3                  : sayit                 : iobroker                                 -  enabled, port: 0
    + system.adapter.sayit.4                  : sayit                 : iobroker                                 -  enabled, port: 0
      system.adapter.sayit.5                  : sayit                 : iobroker                                 - disabled, port: 0
      system.adapter.shelly.0                 : shelly                : iobroker                                 - disabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.smartmeter.0             : smartmeter            : Pi-Strom-Wasser                          -  enabled
    + system.adapter.smartmeter.1             : smartmeter            : Pi-Strom-Wasser                          -  enabled
      system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
    + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      system.adapter.tuya.0                   : tuya                  : iobroker                                 - disabled
    + system.adapter.viessmann.0              : viessmann             : iobroker                                 -  enabled, port: 3002
      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker                                 - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
      system.adapter.vis-history.0            : vis-history           : iobroker                                 - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
      system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 - disabled
      system.adapter.vis-keyboard.0           : vis-keyboard          : iobroker                                 - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
      system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
      system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
      system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker                                 - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
    + system.adapter.web.1                    : web                   : iobroker                                 -  enabled, port: 20020, bind: 0.0.0.0, run as: admin
      system.adapter.wiobrowser.0             : wiobrowser            : iobroker                                 - disabled, port: 5000
    + system.adapter.ws.0                     : ws                    : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.yamaha.0                 : yamaha                : iobroker                                 -  enabled
    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.243.114:6638
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "asterisk"     : 1.0.6    , installed 1.0.6
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "bmw"          : 2.5.7    , installed 2.5.7
    Adapter    "bosch-ebike"  : 0.0.3    , installed 0.0.3
    Adapter    "cloud"        : 4.3.0    , installed 4.3.1
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "doorio"       : 2.1.4    , installed 2.1.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.12.0
    Adapter    "fritzbox"     : 0.2.1    , installed 0.2.1
    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.20
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "libre"        : 0.0.4    , installed 0.0.4
    Adapter    "linux-control": 1.1.3    , installed 1.1.3
    Adapter    "logparser"    : 2.1.1    , installed 2.1.1
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "musiccast"    : 0.1.5    , installed 1.0.6
    Adapter    "octoprint"    : 4.0.0    , installed 4.0.0
    Adapter    "openligadb"   : 1.2.4    , installed 1.2.4
    Adapter    "parser"       : 1.1.8    , installed 1.1.8
    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
    Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
    Adapter    "rest-api"     : 1.0.4    , installed 1.0.4
    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "socketio"     : 4.2.0    , installed 6.1.4
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "tuya"         : 3.13.1   , installed 3.13.1
    Adapter    "viessmann"    : 1.4.3    , installed 1.4.3
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.93.0   , installed 0.93.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "web"          : 4.3.0    , installed 5.2.0
    Adapter    "wiobrowser"   : 2.0.1    , installed 2.0.1
    Adapter    "ws"           : 1.3.0    , installed 2.3.4
    Adapter    "yamaha"       : 0.5.3    , installed 0.5.3
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        23146
    States:         18938
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 https://deb.nodesource.com/node_18.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       1576003    93575/iobroker.js-c
    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       1575992    93575/iobroker.js-c
    tcp        0      0 0.0.0.0:5038            0.0.0.0:*               LISTEN      108        15548      380/asterisk
    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          11357      1/init
    tcp        0      0 192.168.243.10:2001     0.0.0.0:*               LISTEN      1001       1576184    93741/io.hm-rpc.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14414      457/sshd: /usr/sbin
    tcp        0      0 192.168.243.10:2010     0.0.0.0:*               LISTEN      1001       1576223    93870/io.hm-rpc.2
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1579378    93921/io.mqtt.0
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1579456    93980/io.mqtt.2
    tcp        0      0 192.168.243.10:8701     0.0.0.0:*               LISTEN      1001       1571405    93853/io.hm-rpc.1
    tcp6       0      0 :::111                  :::*                    LISTEN      0          10204      1/init
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1571205    93606/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1580315    95430/io.web.0
    tcp6       0      0 :::20020                :::*                    LISTEN      1001       1580529    95642/io.web.1
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       1580251    95531/io.ws.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14425      457/sshd: /usr/sbin
    tcp6       0      0 :::8087                 :::*                    LISTEN      1001       1581081    95294/io.simple-api
    udp        0      0 0.0.0.0:50276           0.0.0.0:*                           108        15557      380/asterisk
    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          12399      1/init
    udp        0      0 0.0.0.0:41100           0.0.0.0:*                           1001       1583133    95219/io.musiccast.
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       1597724    102434/io.mihome-va
    udp        0      0 0.0.0.0:4569            0.0.0.0:*                           108        12777      380/asterisk
    udp        0      0 0.0.0.0:5060            0.0.0.0:*                           108        12776      380/asterisk
    udp6       0      0 :::43642                :::*                                108        15558      380/asterisk
    udp6       0      0 :::111                  :::*                                0          1329       1/init
    2023-04-17 19:14:00.087  - info: javascript.0 (103023) script.js.Scripte.Geraete.Maehroboter: Timer.next: date und time nicht gesetzt - Diese Werte sind im json nicht vorhanden.
    2023-04-17 19:14:07.083  - info: javascript.0 (103023) script.js.Scripte.Sonstige.Sonne: Auslöser Lichtsensor
    2023-04-17 19:14:07.792  - info: javascript.0 (103023) script.js.Scripte.Geraete.Spuelmaschine: Auslöser Spülmaschine
    2023-04-17 19:14:28.275  - info: javascript.0 (103023) script.js.Scripte.Geraete.Spuelmaschine: Auslöser Spülmaschine
    2023-04-17 19:14:32.878  - info: javascript.0 (103023) script.js.Scripte.Geraete.Kombisensor_-_Windrose: Auslöser Windrichtung
    2023-04-17 19:14:32.900  - info: javascript.0 (103023) script.js.Scripte.Geraete.Kombisensor: Auslöser Duration geändert
    2023-04-17 19:14:44.261  - info: javascript.0 (103023) script.js.Scripte.Geraete.Spuelmaschine: Auslöser Spülmaschine
    2023-04-17 19:15:00.058  - info: javascript.0 (103023) script.js.Scripte.System.Drucker_3D: 3D Drucker ist per Ping nicht erreichbar !
    2023-04-17 19:15:00.119  - info: javascript.0 (103023) script.js.Scripte.System.View_wechseln: View auf 'Titel' gewechselt.
    2023-04-17 19:15:00.139  - info: javascript.0 (103023) script.js.Scripte.Heizung.Bad_EG: Auslöser Schedule
    2023-04-17 19:15:00.141  - info: javascript.0 (103023) script.js.Scripte.Heizung.Bad_EG: Heizung wird auf 5°C gesetzt.
    2023-04-17 19:15:00.234  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Lautstärke ist: 80 %.
    2023-04-17 19:15:00.237  - info: host.iobroker instance system.adapter.dwd.0 started with pid 104725
    2023-04-17 19:15:00.243  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktuelle Helligkeit ist: 90 %.
    2023-04-17 19:15:00.287  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Lautstärke ist: 90 %.
    2023-04-17 19:15:00.317  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktuelle Helligkeit ist: 100 %.
    2023-04-17 19:15:00.405  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Surface: aktueller Akkustand ist: 100 %.
    2023-04-17 19:15:00.416  - info: javascript.0 (103023) script.js.Scripte.Geraete.Tablet: Tablet Chuwi: aktueller Akkustand ist: 51 %.
    2023-04-17 19:15:04.537  - info: host.iobroker instance system.adapter.daswetter.0 started with pid 104744
    2023-04-17 19:15:07.254  - info: dwd.0 (104725) starting. Version 2.8.3 in /opt/iobroker/node_modules/iobroker.dwd, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 19:15:09.887  - info: daswetter.0 (104744) starting. Version 3.1.7 in /opt/iobroker/node_modules/iobroker.daswetter, node: v18.16.0, js-controller: 4.0.24
    2023-04-17 19:15:15.633  - info: dwd.0 (104725) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-04-17 19:15:16.214  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-04-17 19:15:32.365  - info: ws.0 (95531) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
    2023-04-17 19:15:32.367  - info: ws.0 (95531) <== Disconnect system.user.admin from ::ffff:192.168.243.100 flot
    iob diag has finished.
    Press any key for a summary
                         v.2023-04-16
    Operatingsystem:        Debian GNU/Linux 11 (bullseye)
    Kernel:                 5.10.0-21-amd64
    Installation:           kvm
    User-ID:                1000
    X-Server:               false
    Pending OS-Updates:     0
    Pending iob updates:    0
    Nodejs-Installation:    /usr/bin/nodejs         v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
    Recommended versions are nodejs 18.x.y and npm 9.x.y
    MEMORY:
    Mem:            5.9G        3.9G        348M        0.0K        1.7G        1.8G
    Swap:           974M         49M        925M
    Total:          6.9G        3.9G        1.3G
    Active iob-Instances:   51
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Objects:                23146
    States:                 18935
    Size of iob-Database:
    51M     /opt/iobroker/iobroker-data/states.jsonl
    dieter@iobroker:~$ cd /opt/iobroker
    dieter@iobroker:/opt/iobroker$ npm ls
    iobroker.inst@3.0.0 /opt/iobroker
    ├── @types/caseless@0.12.2 extraneous
    ├── @types/request@2.48.8 extraneous
    ├── @types/tough-cookie@4.0.2 extraneous
    ├── coffeescript@1.12.7 extraneous
    ├── iobroker.admin@6.3.5
    ├── iobroker.alias-manager@1.2.4
    ├── iobroker.asterisk@1.0.6
    ├── iobroker.backitup@2.6.16
    ├── iobroker.bmw@2.5.7
    ├── iobroker.bosch-ebike@0.0.3 (git+ssh://git@github.com/TA2k/ioBroker.bosch-ebike.git#6574234e8316a5047908dab12baac363e9f505c3)
    ├── iobroker.cloud@4.3.1 (git+ssh://git@github.com/ioBroker/ioBroker.cloud.git#4e96866d5c7e012cb8890b2d0a9721162bfe650f)
    ├── iobroker.contact@1.1.3 (git+ssh://git@github.com/WLAN-Kabel/ioBroker.contact.git#006a1ab146246cbaf729609c46855bcd65cf5aaf)
    ├── iobroker.daswetter@3.1.7
    ├── iobroker.doorio@2.1.4
    ├── iobroker.dwd@2.8.3
    ├── iobroker.email@1.1.4
    ├── iobroker.feiertage@1.1.0
    ├── iobroker.flot@1.12.0
    ├── iobroker.fritzbox@0.2.1
    ├── iobroker.fritzdect@2.2.6
    ├── iobroker.hm-rega@3.0.46
    ├── iobroker.hm-rpc@1.15.16
    ├── iobroker.ical@1.13.2
    ├── iobroker.icons-material-png@0.1.0
    ├── iobroker.icons-mfd-png@1.1.0
    ├── iobroker.icons-open-icon-library-png@0.1.2
    ├── iobroker.info@1.9.20 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.info.git#681b473b9602d3f4b9eed91338041b616a25a305)
    ├── iobroker.javascript@6.1.4
    ├── iobroker.js-controller@4.0.24
    ├── iobroker.komoot@0.3.7 (git+ssh://git@github.com/basti4557/ioBroker.komoot.git#eb2838cfd6c926a61a9262d4e8417d6315018d1f)
    ├── iobroker.libre@0.0.4 (git+ssh://git@github.com/TA2k/ioBroker.libre.git#ee0908307e3320d06b4b62987b85777e33e2f918)
    ├── iobroker.linux-control@1.1.3
    ├── iobroker.logparser@2.1.1
    ├── iobroker.mihome-vacuum@3.9.5
    ├── iobroker.mihome@1.4.0
    ├── iobroker.modbus@5.0.11
    ├── iobroker.mqtt@4.0.7
    ├── iobroker.musiccast@1.0.6 (git+ssh://git@github.com/foxthefox/ioBroker.musiccast.git#33b1029dd22b9dbd351b9cf70074df54c6fdbaed)
    ├── iobroker.octoprint@4.0.0
    ├── iobroker.openligadb@1.2.4
    ├── iobroker.parser@1.1.8
    ├── iobroker.ping@1.5.3
    ├── iobroker.pollenflug@1.0.6
    ├── iobroker.proxmox@1.3.4
    ├── iobroker.rest-api@1.0.4
    ├── iobroker.rssfeed@2.6.1
    ├── iobroker.sayit@1.12.3 (git+ssh://git@github.com/Jey-Cee/ioBroker.sayit.git#8b613efce437d18ba4f4c320655c7b8323d25270)
    ├── iobroker.shelly@6.3.1
    ├── iobroker.simple-api@2.7.2
    ├── iobroker.sourceanalytix@0.4.14
    ├── iobroker.sql@2.2.0
    ├── iobroker.tankerkoenig@3.3.7
    ├── iobroker.telegram@1.15.2
    ├── iobroker.tr-064@4.2.18
    ├── iobroker.tuya@3.13.1
    ├── iobroker.viessmann@1.4.3
    ├── iobroker.vis-bars@0.1.4
    ├── iobroker.vis-canvas-gauges@1.0.1
    ├── iobroker.vis-colorpicker@1.2.0
    ├── iobroker.vis-fancyswitch@1.1.0
    ├── iobroker.vis-google-fonts@1.0.4
    ├── iobroker.vis-history@1.0.0
    ├── iobroker.vis-hqwidgets@1.3.0
    ├── iobroker.vis-icontwo@0.93.0
    ├── iobroker.vis-inventwo@3.3.1
    ├── iobroker.vis-jqui-mfd@1.0.12
    ├── iobroker.vis-justgage@1.0.2
    ├── iobroker.vis-keyboard@0.0.2
    ├── iobroker.vis-lcars@1.0.4
    ├── iobroker.vis-map@1.0.4
    ├── iobroker.vis-metro@1.2.0
    ├── iobroker.vis-players@0.1.6
    ├── iobroker.vis-plumb@1.0.2
    ├── iobroker.vis-rgraph@0.0.2
    ├── iobroker.vis-timeandweather@1.2.2
    ├── iobroker.vis@1.4.16
    ├── iobroker.web@5.2.0
    ├── iobroker.wiobrowser@2.0.1
    ├── iobroker.ws@2.3.4
    ├── iobroker.yamaha@0.5.3
    ├── iobroker.zigbee@1.8.10
    ├── javascript@1.0.0
    ├── jsonata@1.8.6 extraneous
    ├── node-inspect@2.0.0 extraneous
    ├── picocolors@1.0.0 extraneous
    ├── production@0.0.2
    ├── suncalc2@1.8.1 extraneous
    ├── typescript@4.7.4 extraneous
    ├── virtual-tsc@0.6.2 extraneous
    ├── wake_on_lan@1.0.0 extraneous
    └── which@2.0.2
    Danke.
    • bahnuhrB bahnuhr
      anbei:
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 8
                    NTP service: active
                RTC in local TZ: no
      dieter
      /home/dieter
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:           974M         49M        925M
               5940 M total memory
               3899 M used memory
                650 M active memory
                206 M free memory
                200 M buffer memory
               1634 M swap cache
                974 M total swap
                 49 M used swap
                925 M free swap
      *** FILESYSTEM ***
      /var:
      2.0G    /var/
      1.2G    /var/log
      560M    /var/cache
      /usr/bin/npm            9.5.1
      /usr/bin/npx            9.5.1
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      javascript:     6.1.4
      Adapter State
      + instance is alive
      Objects and States
      Objects:        23146
      States:         18938
      Pending Updates: 0
                           v.2023-04-16
      Installation:           kvm
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
      MEMORY:
      Swap:           974M         49M        925M
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects:                23146
      States:                 18935
      └── which@2.0.2
      Thomas BraunT Offline
      @bahnuhr
      Das gehört da nicht hin:
      javascript@1.0.0
        @bahnuhr
        javascript@1.0.0
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        Und was tun.
        cd /opt/iobroker
        npm uninstall javascript@1.0.0
        richtig ?
        Danke.
        • bahnuhrB bahnuhr
          Und was tun.
          cd /opt/iobroker
          richtig ?
          @bahnuhr Ja, würde ich sagen.
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            Hab ich gemacht.
            ist auch durchgelaufen
            Bei npm ls ist es aber noch da:
            └── which@2.0.2
            Danke.
            • bahnuhrB bahnuhr
              Hab ich gemacht.
              └── which@2.0.2
              @bahnuhr
              Alles was nicht mit iobroker. anfängt gehört da nicht hin.
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                Und wo kommt dieser Kram her ?
                └── which@2.0.2
                Und wie bekomme ich den weg ?
                Danke.
                Thomas BraunT bahnuhrB 2 Antworten Letzte Antwort
                • bahnuhrB bahnuhr
                  └── which@2.0.2
                  @bahnuhr
                  Woher soll ich das wissen? Das System wird von dir administriert.
                  • bahnuhrB bahnuhr
                    └── which@2.0.2
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    Danke.
                    • bahnuhrB bahnuhr
                      @bahnuhr
                      Mit
                      npm uninstall MODULNAME
                      geht es nicht?
                        @bahnuhr
                        Mit
                        geht es nicht?
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        hab ich ja probiert. Deinstall läuft durch.
                        Aber wird weiterhin angezeigt.
                        Soll ich es mit den anderen auch mal probieren, also
                        npm uninstall production@0.0.2
                        npm uninstall which@2.0.2
                        Danke.
                        • bahnuhrB bahnuhr
                          @bahnuhr Jo, mach mal.
                          Ich weiß nicht man auch mehrere Module in einem Kommando rauswerfen kann.
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            so, das lief auch durch:
                            dieter@iobroker:/opt/iobroker$ npm uninstall production@0.0.2
                            up to date in 16s
                            158 packages are looking for funding
                              run `npm fund` for details
                            dieter@iobroker:/opt/iobroker$ npm uninstall which@2.0.2
                            up to date in 17s
                            Und bei npm ls kommt:
                            └── which@2.0.2
                            Fazit: immer noch da !?
                            komisch
                            Danke.
                              bahnuhrB Online
                              bahnuhrB Online
                              bahnuhr
                              nun isses weg.
                              falsch war: npm uninstall production@0.0.2
                              richtig war: npm uninstall production
                              nun wird dies bei npm ls nicht mehr angezeigt.
                              Danke.
