  4. Node-Red
  5. aus Tabellen Werten ein Graphen darstellen
    6.5k
29 Beiträge 4 Kommentatoren 3.1k Aufrufe 2 Beobachtet
  • S Saranger
    @mickym ich hab das mal eingefügt, allerdings bleibt der Chart leer. Wenn ich die debug aber an die inject node hänge wird beim neu laden die debug node gfüllt.
    mickymM Offline
    mickymM Offline
    mickym
    @saranger
    So hier nochmal mit Inject- Node:
           "id": "9dedd3abd6ec8e15",
           "type": "inject",
           "z": "1983aa28392732ca",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "[{\"Time\":\"2023-04-17 06:19:59\",\"Power\":\"0,000\"},{\"Time\":\"2023-04-17 07:00:00\",\"Power\":\"0,263\"},{\"Time\":\"2023-04-17 08:00:00\",\"Power\":\"0,635\"},{\"Time\":\"2023-04-17 09:00:00\",\"Power\":\"0,895\"},{\"Time\":\"2023-04-17 10:00:00\",\"Power\":\"1,489\"},{\"Time\":\"2023-04-17 11:00:00\",\"Power\":\"2,020\"},{\"Time\":\"2023-04-17 12:00:00\",\"Power\":\"2,105\"},{\"Time\":\"2023-04-17 13:00:00\",\"Power\":\"2,080\"},{\"Time\":\"2023-04-17 14:00:00\",\"Power\":\"1,999\"},{\"Time\":\"2023-04-17 15:00:00\",\"Power\":\"1,965\"},{\"Time\":\"2023-04-17 16:00:00\",\"Power\":\"1,942\"},{\"Time\":\"2023-04-17 17:00:00\",\"Power\":\"1,676\"},{\"Time\":\"2023-04-17 18:00:00\",\"Power\":\"0,633\"},{\"Time\":\"2023-04-17 19:00:00\",\"Power\":\"0,328\"},{\"Time\":\"2023-04-17 20:00:00\",\"Power\":\"0,098\"},{\"Time\":\"2023-04-17 20:06:30\",\"Power\":\"0,000\"},{\"Time\":\"2023-04-18 06:18:04\",\"Power\":\"0,000\"},{\"Time\":\"2023-04-18 07:00:00\",\"Power\":\"0,425\"},{\"Time\":\"2023-04-18 08:00:00\",\"Power\":\"0,844\"},{\"Time\":\"2023-04-18 09:00:00\",\"Power\":\"0,962\"},{\"Time\":\"2023-04-18 10:00:00\",\"Power\":\"1,071\"}]",
           "payloadType": "json",
           "x": 330,
           "y": 2440,
           "wires": [
                   "fd717360f0186d05"
           "id": "fd717360f0186d05",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "[\t   {\t       \"series\":[\"Power\"],\t       \"data\": [\t           [\t               payload.{\t                   \"x\": $toMillis(Time,'[Y]-[M]-[D] [H]:[m]:[s]'),\t                   \"y\" : Power ~> $replace(\",\",\".\") ~> $number()\t                }\t            ]\t       ]\t}\t]",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 530,
           "y": 2440,
           "wires": [
                   "9703d36ee0f5ad21"
           "id": "9703d36ee0f5ad21",
           "type": "ui_chart",
           "name": "",
           "group": "2ac8e3fa.8b8584",
           "order": 5,
           "width": "12",
           "height": "11",
           "label": "",
           "chartType": "line",
           "legend": "false",
           "xformat": "HH:mm:ss",
           "interpolate": "linear",
           "nodata": "",
           "dot": false,
           "ymin": "",
           "ymax": "",
           "removeOlder": 1,
           "removeOlderPoints": "",
           "removeOlderUnit": "3600",
           "cutout": 0,
           "useOneColor": false,
           "useUTC": false,
           "colors": [
               "#1f77b4",
               "#aec7e8",
               "#ff7f0e",
               "#2ca02c",
               "#98df8a",
               "#d62728",
               "#ff9896",
               "#9467bd",
               "#c5b0d5"
           "outputs": 1,
           "useDifferentColor": false,
           "className": "",
           "x": 710,
           "y": 2440,
           "wires": [
           "id": "2ac8e3fa.8b8584",
           "type": "ui_group",
           "name": "Default",
           "tab": "ebb1ed1c.5ebe2",
           "order": 1,
           "disp": true,
           "width": "12",
           "collapse": false
           "id": "ebb1ed1c.5ebe2",
           "type": "ui_tab",
           "name": "Charts",
           "icon": "dashboard",
           "disabled": false,
           "hidden": false
    Jetzt müsstest Du in jedem Fall was sehen. Wenn das Array in der Inject Node anders ist, als was aus Deinem Datenpunkt kommt - musst ggf. noch eine JSON Node dazwischenschalten.
    • mickymM Offline
      mickymM Offline
      mickym
      das Einzige was nicht stimmt ist die Zeit, da das Teil denkt es ist UTC Zeit die eingegeben wurde und dann 2 Stunden draufrechnet.
      Um die Zeit also anzupassen:
      den JSONATA Code noch wie folgt ändern:
             "series":["Power"],
             "data": [
                     payload.{
                         "x": $toMillis(Time & " GMT+2:00",'[Y]-[M]-[D] [H]:[m]:[s] [z]'),
                         "y" : Power ~> $replace(",",".") ~> $number()
      Die Formatierung bzgl. der Zeitformate entnimmst Du bitte hier:
      https://www.w3.org/TR/xpath-functions-31/#func-format-date
      • mickymM Offline
        mickymM Offline
        mickym
        Um sich nicht mit Zeitzonen rum zu quälen, ist die Moments Bibliothek besser. Also Du kannst die Change Node wie folgt abändern (warum das valueOf() für die Umwandlung in ms nicht funktioniert - weiß ich nicht).
               "series":["Power"],
               "data": [
                       payload.{
                           "x": $moment(Time,("YYYY-MM-DD HH:mm:ss")).unix()*1000,
        Funktioniert es denn nun?
        • mickymM mickym
                 "series":["Power"],
                 "data": [
                         payload.{
          Saranger
          @mickym ich rätsel gerade wo ich das in der change node einfüge das nicht so einfach für mich^^.
          • S Saranger
            mickymM Offline
            mickymM Offline
            mickym
            @saranger Dann zeig halt mal Deinen ganzen Flow (bzw. mach halt einen Screenshot) - und wo dieses Objekt dass Du oben gepostet hast, rauskommt. Funktioniert denn der Chart mit meiner Inject Node?
            @saranger sagte in aus Tabellen Werten ein Graphen darstellen:
            Im Prinzip, wenn das Array mit den Datenpunkten so rauskommt, wie oben - einfach vor die Chart Node. Wenn Du mein Flow importiert hast, brauchst doch nur die Inject Node ersetzen?
            • S Saranger
              @liv-in-sky ja sorry hab ich leider zu spät gesehen, dacht ich war im nodered forum.
              im Titel wäre besser. Die Breadcrumbs übersieht man meist
                mickymM Offline
                mickymM Offline
                mickym
                @homoran Na ich nicht ;) - Sonst wüsste ich ja nicht, wann ich puzzeln muss oder Nodes zeichnen darf. ;) Ich hab mich dann meist entschuldigt, wenn ich festgestellt habe, dass ich mich im falschen Unterforum befinde. ;) Und die meisten Blocklies schreiben auch nicht immer Blockly in die Überschrift. Oder müssen sich hier Minderheiten besonderen Regeln unterwerfen? 😁
                • mickymM mickym
                  @mickym sagte in aus Tabellen Werten ein Graphen darstellen:
                  wievielfache Negation ist das denn 😂
                  Wäre aber schön!
                  Ich gehe immer über Unread und nie über die Kategorie in einen Post
                  S mickymM 2 Antworten Letzte Antwort
                    Wäre aber schön!
                    Saranger
                    @homoran ich werde bei nächsten mal das genauer schreiben :-)
                      Wäre aber schön!
                      mickymM Offline
                      mickymM Offline
                      mickym
                      @homoran sagte in aus Tabellen Werten ein Graphen darstellen:
                      Wäre aber schön!
                      Na ich gehe auch nur immer über Unread oder neueste Themen in einen Post, aber als Minderheit habe ich einen geschärften Blick für das Forum, in dem sich der Thread befindet. - Tja das scheint wohl unser Schicksal zu sein - wenn die Mehrheiten immer Dinge für selbstverständlich nehmen. ;)
                      • mickymM mickym
                        Saranger
                        @mickym
                        schaut so aus
                               "id": "9ecdae960fb1ba35",
                               "type": "ioBroker in",
                               "z": "2c0306d707fdc5d0",
                               "name": "PV Today",
                               "topic": "pvforecast.0.plants.süd.JSONTable",
                               "payloadType": "value",
                               "onlyack": "",
                               "func": "all",
                               "gap": "",
                               "fireOnStart": "true",
                               "outFormat": "MQTT",
                               "x": 120,
                               "y": 740,
                               "wires": [
                                       "ca31e8e8970bc051",
                                       "a43328d1fc72822f"
                               "id": "ca31e8e8970bc051",
                               "type": "debug",
                               "name": "debug 63",
                               "active": true,
                               "tosidebar": true,
                               "console": false,
                               "tostatus": false,
                               "complete": "false",
                               "statusVal": "",
                               "statusType": "auto",
                               "x": 300,
                               "y": 640,
                               "wires": []
                               "id": "a43328d1fc72822f",
                               "type": "change",
                               "name": "",
                               "rules": [
                                       "t": "set",
                                       "p": "payload",
                                       "pt": "msg",
                                       "to": "[\t   {\t       \"series\":[\"Power\"],\t       \"data\": [\t           [\t               payload.{\t                   \"x\": $moment(Time,(\"YYYY-MM-DD HH:mm:ss\")).unix()*1000,\t                   \"y\" : Power ~> $replace(\",\",\".\") ~> $number()\t                }\t            ]\t       ]\t}\t]",
                                       "tot": "jsonata"
                               "action": "",
                               "property": "",
                               "from": "",
                               "to": "",
                               "reg": false,
                               "x": 430,
                               "y": 740,
                               "wires": [
                                       "ad72ed9b6215e0c3"
                               "id": "ad72ed9b6215e0c3",
                               "type": "ui_chart",
                               "name": "",
                               "order": 5,
                               "width": "12",
                               "height": "11",
                               "label": "",
                               "legend": "false",
                               "nodata": "",
                               "dot": false,
                               "ymin": "",
                               "ymax": "",
                               "removeOlder": 1,
                               "cutout": 0,
                               "useUTC": false,
                               "colors": [
                                   "#1f77b4",
                                   "#aec7e8",
                                   "#ff7f0e",
                                   "#2ca02c",
                                   "#98df8a",
                                   "#d62728",
                                   "#ff9896",
                                   "#9467bd",
                                   "#c5b0d5"
                               "outputs": 1,
                               "className": "",
                               "x": 630,
                               "y": 740,
                               "wires": [
                               "type": "ui_group",
                               "name": "Default",
                               "order": 1,
                               "disp": true,
                               "width": "12",
                               "collapse": false
                               "type": "ui_tab",
                               "name": "Charts",
                               "disabled": false,
                               "hidden": false
                        • S Saranger
                          @mickym
                          schaut so aus
                                 "name": "PV Today",
                                 "onlyack": "",
                                 "func": "all",
                                 "gap": "",
                                 "x": 120,
                                 "y": 740,
                                 "wires": [
                                         "ca31e8e8970bc051",
                                         "a43328d1fc72822f"
                                 "type": "debug",
                                 "name": "debug 63",
                                 "active": true,
                                 "tosidebar": true,
                                 "console": false,
                                 "tostatus": false,
                                 "statusVal": "",
                                 "x": 300,
                                 "y": 640,
                                 "wires": []
                                 "type": "change",
                                 "name": "",
                                 "rules": [
                                         "t": "set",
                                         "p": "payload",
                                         "pt": "msg",
                                         "tot": "jsonata"
                                 "action": "",
                                 "property": "",
                                 "from": "",
                                 "to": "",
                                 "reg": false,
                                 "x": 430,
                                 "y": 740,
                                 "wires": [
                                         "ad72ed9b6215e0c3"
                                 "type": "ui_chart",
                                 "name": "",
                                 "order": 5,
                                 "width": "12",
                                 "height": "11",
                                 "label": "",
                                 "legend": "false",
                                 "nodata": "",
                                 "dot": false,
                                 "ymin": "",
                                 "ymax": "",
                                 "removeOlder": 1,
                                 "cutout": 0,
                                 "useUTC": false,
                                 "colors": [
                                     "#1f77b4",
                                     "#aec7e8",
                                     "#ff7f0e",
                                     "#2ca02c",
                                     "#98df8a",
                                     "#d62728",
                                     "#ff9896",
                                     "#9467bd",
                                     "#c5b0d5"
                                 "outputs": 1,
                                 "className": "",
                                 "x": 630,
                                 "y": 740,
                                 "wires": [
                                 "type": "ui_group",
                                 "name": "Default",
                                 "order": 1,
                                 "disp": true,
                                 "width": "12",
                                 "collapse": false
                                 "type": "ui_tab",
                                 "name": "Charts",
                                 "disabled": false,
                                 "hidden": false
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @saranger Ja wie gesagt - da kommt in der Debug Node ein String raus - Du musst Datenpunkte vom iobroker, wenn sie JSONs sind noch in Objekte wandeln. Klemm einfach noch eine JSON Node zwischen Deine iobrokerIN und die Change Node.
                          • mickymM mickym
                            Wäre aber schön!
                            auch auf dem Handy/Tablet?
                            bin zu 99.99% nur damit unterwegs.
                              mickymM Offline
                              mickymM Offline
                              mickym
                              Auf dem Handy schauts sogar noch klarer aus bei mir. ;)
                              • mickymM mickym
                                Saranger
                                @mickym perfekt jetzt gehts :-)
                                • S Saranger
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  Freut mich. 👍 👍 👍
                                  • mickymM mickym
                                    @mickym jetzt aber [/OT]
                                    da muss ich einfach mal ne neue Brille haben
                                    Ich werde versuchen mehr darauf zu achten
