  4. Abstürze vor allem beim dayly Backup
    5.3k
104 Beiträge 9 Kommentatoren 13.6k Aufrufe 6 Beobachtet
  • S searcher57
    @mickym
    Danke für die schnelle Antwort.
    Das habe ich gemacht, der ioBroker startet aber nicht mit der neuen SD Karte.
    searcher57
    #73
    @searcher57
    @searcher57 said in Abstürze vor allem beim dayly Backup:
    @mickym
    Skript v.2023-04-16
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture    : aarch64
    Docker          : false
    Virtualization  : none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     15:13:45 up  1:20,  1 user,  load average: 0.78, 0.62, 0.65
    CPU threads: 4
    Raspberry only:
    throttled=0x0
    Other values than 0x0 hint to temperature/voltage problems
    temp=45.2'C
    volt=0.9360V
    *** Time and Time Zones ***
                   Local time: Sun 2023-04-16 15:13:45 CEST
               Universal time: Sun 2023-04-16 13:13:45 UTC
                     RTC time: n/a
                  NTP service: active
              RTC in local TZ: no
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gp        io i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            1.8G        1.7G         45M        0.0K        141M        123M
    Swap:            99M         99M        0.0K
    Total:          1.9G        1.8G         45M
             1849 M total memory
             1662 M used memory
              625 M active memory
             1069 M inactive memory
               45 M free memory
                3 M buffer memory
              138 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    Raspberry only:
    oom events: 0
    *** FILESYSTEM ***
    /dev/root      ext4       29G  7.5G   21G  27% /
    devtmpfs       devtmpfs  667M     0  667M   0% /dev
    tmpfs          tmpfs     925M     0  925M   0% /dev/shm
    tmpfs          tmpfs     370M  1.2M  369M   1% /run
    /dev/mmcblk0p1 vfat      255M  243M   13M  96% /boot
    /dev/sda1      exfat      29G  274M   29G   1% /mnt/usb0
    tmpfs          tmpfs     185M     0  185M   0% /run/user/1000
    [Sun Apr 16 13:53:17 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0        snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.ena        ble_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=E4:5F:01:15:C8:D1 vc_mem.        mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty        1 root=PARTUUID=7eb6722d-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Apr 16 13:53:18 2023] EXT4-fs (mmcblk0p2): INFO: recovery required on reado        nly filesystem
    [Sun Apr 16 13:53:18 2023] EXT4-fs (mmcblk0p2): write access will be enabled dur        ing recovery
    [Sun Apr 16 13:53:22 2023] EXT4-fs (mmcblk0p2): recovery complete
    [Sun Apr 16 13:53:22 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered        data mode. Quota mode: none.
    [Sun Apr 16 13:53:22 2023] VFS: Mounted root (ext4 filesystem) readonly on devic        e 179:2.
    [Sun Apr 16 13:53:24 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET      SOURCE         FSTYPE OPTIONS
    /           /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    |-/boot     /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437        ,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/mnt/usb0 /dev/sda1      exfat  rw,nosuid,nodev,noexec,relatime,fmask=0000,dma        sk=0000,allow_utime=0022,iocharset=utf8,errors=remount-ro
    /var:
    3.0G    /var/
    1.8G    /var/lib
    1.7G    /var/lib/redis
    899M    /var/log
    889M    /var/log/journal/158d4a7beb094cc78fd7f1aba39dd6d6
    Archived and active journals take up 888.2M in the file system.
    /opt/iobroker/backups:
    822M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    501M    /opt/iobroker/iobroker-data/
    258M    /opt/iobroker/iobroker-data/history
    185M    /opt/iobroker/iobroker-data/files
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    48M     /opt/iobroker/iobroker-data/files/telegram.admin
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js.map
    13M     /opt/iobroker/iobroker-data/objects.jsonl
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfe        b1bf.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chun        k.js.map
    7.2M    /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors        -node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modu        les_io-1d9f06.44fe4a3f.chunk.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/local/bin/node             v18.14.2
    /usr/local/bin/npm              9.5.0
    /usr/local/bin/npx              9.5.0
    *** nodejs is NOT correctly installed ***
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    No problems detected
    *** ioBroker-Installation ***
    ioBroker Status
    At least one iobroker host is running.
    Objects type: redis
    States  type: redis
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.4.3
    javascript:     7.0.3
    Adapters from github:   0
    Adapter State
    + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
      system.adapter.devices.0                : devices               : raspberrypi                              - disabled
    + system.adapter.doorbird.0               : doorbird              : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 0
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
    + system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.scenes.0                 : scenes                : raspberrypi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : raspberrypi                              -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.text2command.0           : text2command          : raspberrypi                              -  enabled
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.4.3
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.6.16   , installed 2.6.16
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.46   , installed 3.0.46
    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "info"         : 1.9.19   , installed 1.9.26
    Adapter    "javascript"   : 6.1.4    , installed 7.0.3
    Adapter    "mqtt"         : 4.0.7    , installed 4.1.1
    Adapter    "shelly"       : 6.3.1    , installed 6.4.0
    Adapter    "socketio"     : 4.2.0    , installed 6.3.5
    Adapter    "telegram"     : 1.15.2   , installed 1.15.6
    Adapter    "text2command" : 2.3.0    , installed 3.0.2
    Adapter    "web"          : 4.3.0    , installed 5.5.3
    Adapter    "ws"           : 1.3.0    , installed 2.3.6
    Objects and States
    Objects:        6068
    States:         4708
    mickymM S 2 Antworten Letzte Antwort
    • S searcher57
      @searcher57
      @mickym
      Skript v.2023-04-16
      *** BASE SYSTEM ***
      Docker          : false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      Raspberry only:
      throttled=0x0
      temp=45.2'C
      volt=0.9360V
                       RTC time: n/a
                    NTP service: active
                RTC in local TZ: no
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         99M        0.0K
               1849 M total memory
               1662 M used memory
                625 M active memory
                 45 M free memory
                  3 M buffer memory
                138 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      Raspberry only:
      oom events: 0
      *** FILESYSTEM ***
      /var:
      3.0G    /var/
      1.8G    /var/lib
      1.7G    /var/lib/redis
      899M    /var/log
      nodejs:
        Version table:
      ioBroker Status
      Objects type: redis
      States  type: redis
      admin:          6.4.3
      javascript:     7.0.3
      Adapter State
      + instance is alive
      Objects and States
      Objects:        6068
      States:         4708
      mickymM Offline
      mickymM Offline
      mickym
      #74
      @searcher57 Na das sieht aber so aus, als ob Dein iobroker läuft und Du ggf. nur nicht auf die Weboberfläche kommst?
      • S searcher57
        @searcher57
        @mickym
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=45.2'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 1849 M total memory
                 1662 M used memory
                  625 M active memory
                   45 M free memory
                    3 M buffer memory
                  138 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.0G    /var/
        1.8G    /var/lib
        1.7G    /var/lib/redis
        899M    /var/log
        nodejs:
          Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        admin:          6.4.3
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6068
        States:         4708
        searcher57
        #75
        @searcher57
        @mickym
        Skript v.2023-04-16
        *** BASE SYSTEM ***
        Docker          : false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        Raspberry only:
        throttled=0x0
        temp=45.2'C
        volt=0.9360V
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        pi
        /home/pi
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M         99M        0.0K
                 1849 M total memory
                 1662 M used memory
                  625 M active memory
                   45 M free memory
                    3 M buffer memory
                  138 M swap cache
                   99 M total swap
                   99 M used swap
                    0 M free swap
        Raspberry only:
        oom events: 0
        *** FILESYSTEM ***
        /var:
        3.0G    /var/
        1.8G    /var/lib
        1.7G    /var/lib/redis
        899M    /var/log
        nodejs:
          Version table:
        ioBroker Status
        Objects type: redis
        States  type: redis
        admin:          6.4.3
        javascript:     7.0.3
        Adapter State
        + instance is alive
        Objects and States
        Objects:        6068
        States:         4708
        Kannst du mir sagen, wie es richtig mache?
        • mickymM mickym
          @searcher57 Nur der iobroker nicht oder das ganze System nicht?
          searcher57
          #76
          @mickym said in Abstürze vor allem beim dayly Backup:
          Das ganze System.
          • S searcher57
            Das ganze System.
            searcher57
            #77
            Das ganze System.
            Bitte entschuldigt, aber im Moment bekomme ich von drei Seiten Hilfe, wie schön!!
            S mickymM 2 Antworten Letzte Antwort
            • S searcher57
              Das ganze System.
              searcher57
              #78
              Das ganze System.
              Nein, nicht beim dayly Backup, sondern irgendwann morgens!
              • S searcher57
                Das ganze System.
                mickymM Offline
                mickymM Offline
                mickym
                #79
                @searcher57 sagte in Abstürze vor allem beim dayly Backup:
                Das ganze System.
                Ja - ich überlasse es nun den fachkundigen Forums- Systemspezialisten - ich hab mich nur gefragt, wie Du die Ausgabe hinbekommst, wenn Dein System nicht läuft?
                S Thomas BraunT 2 Antworten Letzte Antwort
                • mickymM mickym
                  Das ganze System.
                  searcher57
                  #80
                  @mickym
                  Das habe ich doch geschrieben. Nach Aus- und wieder Einschalten läuft das System fehlerfrei!! Bis zum nächsten Morgen.
                  • mickymM mickym
                    Das ganze System.
                    #81
                    @mickym sagte in Abstürze vor allem beim dayly Backup:
                    Das frage ich mich auch...
                    Irgendwie läuft hier einiges durcheinander.
                    Das System läuft doch, auch wenn der Arbeitsspeicher bis zum Rand gefüllt ist.
                      searcher57
                      #82
                      Warum ist der Arbeitsspeicher denn so voll? ich habe alle Skripte gestopt!
                      • S searcher57
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #83
                        @mickym
                        Nun nachdem Dein System jetzt ja wohl läuft, musst Du wohl das LOG überprüfen und dann liegt es auch nicht an der SD Karte, wenn Du nur über Nacht das System abstürzt. Wenn Du den Backit-Up um 2:00 morgens laufen hast, kannst Du denn sehen, wann die letzten Logeinträge waren?
                        • S searcher57
                          #84
                          @searcher57
                          Die boot-Partition ist auch rappeldicht:
                          Zum Vergleich auf meinem System:
                          /dev/sda1      vfat      255M   31M  225M  13% /boot
                          Mal mit 'rpi-update' da Kernel und Firmware 'upgedated'?
                          • mickymM mickym
                            @mickym
                            searcher57
                            #85
                            @mickym
                            Schade, im Moment ist der ioBroker wieder mal nicht erreichbar! Sonst hätte ich das Log gepostet. Ich komme aber auf die Konsole!
                              @searcher57
                              searcher57
                              #86
                              @thomas-braun said in Abstürze vor allem beim dayly Backup:
                              @searcher57
                              Nach dem Befehl kommt die Meldung !!! This tool must be run as root
                              • S searcher57
                                @searcher57
                                #87
                                @searcher57
                                Du sollst rpi-update nicht ausführen. Die Frage war, ob du in der Vergangenheit damit mal herum gespielt hast.
                                  @searcher57
                                  searcher57
                                  #88
                                  Tut mir leid, aber ich habe jetzt soviel probiert, da kann auch das dabei gewesen sein.
                                  • S searcher57
                                    searcher57
                                    #89
                                    @searcher57
                                    Wie gesagt, ich habe alle 2 Tage ein Backup zur Verfügung. Unter anderem bei Google. Sollte ich die neue SD Karte neu installieren und darauf ein Backup aufspielen?
                                    • S searcher57
                                      @searcher57
                                      searcher57
                                      #90
                                      @searcher57
                                      Eine saubere ioBroker Installation von Matthias Kleine könnte ich durchführen!
                                      • S searcher57
                                        @searcher57
                                        #91
                                        Vermutlich. Und lass die Finger vom 'rpi-update'. Das knallt nämlich die /boot-Partition so zu.
                                          searcher57
                                          #92
                                          OK, noch eine Frage: Wenn ich die SD Karte bis zum Adapter Backitup eingerichtet habe, kann ich dann mit Wiederherstellen die Skripte und Objekte wieder wie vorher nutzen?
