  4. [gelöst] Nach Upgrade/Update kein Webserver nicht mehr
    5.5k
61 Beiträge 4 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • jmeister79J jmeister79
    dann srell mal deinen Bildschirm hochkant: :-)
    Removing nodejs (16.19.1-deb-1nodesource1) ...
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/yallist' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/write-file-atomic' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wrappy' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wide-align' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wcwidth' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/walk-up-path' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-name' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-license' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/util-deprecate' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-slug' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-filename' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/treeverse' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tiny-relative-date' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/string_decoder' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ssri' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-expression-parse' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-correct' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/smart-buffer' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/signal-exit' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/set-blocking' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/node_modules/lru-cache' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safer-buffer' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safe-buffer' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf/node_modules/minimatch' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf/node_modules/glob' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf/node_modules/brace-expansion' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/readable-stream/lib/internal/streams' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json-fast' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-cmd-shim' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/qrcode-terminal' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promzard' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-retry' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-inflight' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-call-limit' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-all-reject-late' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/proc-log' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/postcss-selector-parser' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/parse-conflict-json' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/pacote' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-registry-fetch' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-profile' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-pick-manifest' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-packlist' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-package-arg' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-bundled' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-audit-report' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/normalize-package-data' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/nopt' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/minimatch' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/glob' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/brace-expansion' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/.github' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/negotiator' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mute-stream' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ms' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minizlib' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-sized' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-pipeline' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-json-stream' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-flush' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-fetch' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-collect' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/make-fetch-happen' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmversion' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmteam' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmsearch' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpublish/lib' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpack' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmorg' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmhook' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmfund' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmexec' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmdiff' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmaccess' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff-apply' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/jsonparse' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-stringify-nice' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-parse-even-better-errors' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/isexe' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-lambda' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-core-module' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-cidr' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/infer-owner' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ignore-walk' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/iconv-lite' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/humanize-ms' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-cache-semantics' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/hosted-git-info/lib' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has-unicode' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/gauge' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/function-bind' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs.realpath' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs-minipass' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fastest-levenshtein' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/err-code' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/encoding' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/emoji-regex' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/diff' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/depd' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/delegates' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/defaults' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/debug/node_modules/ms' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cssesc' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/console-control-strings' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/concat-map' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/common-ancestor-path' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-support' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-name' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-convert' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/clone' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-table3' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-columns' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cidr-regex' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cacache/lib/util' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/brace-expansion' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/bin-links' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/balanced-match' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/are-we-there-yet' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aproba' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/agentkeepalive' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@tootallnate/once' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/run-script' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/query' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/package-json' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/name-from-folder' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/move-file' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/metavuln-calculator' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/map-workspaces' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/installed-package-contents' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/git' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/cp' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/disparity-colors' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/config/lib' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@isaacs/string-locale-compare' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@gar/promisify' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@colors/colors' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/commands' not empty so not removed
    dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/output/commands' not empty so not removed
    @jmeister79
    Das ist okay.
    jmeister79J 1 Antwort Letzte Antwort
      @jmeister79
      Das ist okay.
      jmeister79J Offline
      jmeister79J Offline
      jmeister79
      @thomas-braun ok das hat schonmal geklappt.
      npm und node sind aktuell.
      aber ich habe mir offenbar den iobroker hart zerschossen.
      er versucht jetzt laufend die Adapter zu installieren und scheitert.
      ich versuche mal das Backup von heute morgen einzuspielen.
        @jmeister79
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
        sagt?
          @jmeister79 sagte in Nach Upgrade/Update kein Webserver nicht mehr:
          Mit welchen Meldungen? Werden da Module neugebaut?
            @jmeister79
            sagt?
            jmeister79J Offline
            jmeister79J Offline
            jmeister79
            @thomas-braun said in Nach Upgrade/Update kein Webserver nicht mehr:
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v18.15.0
            v18.15.0
            9.5.0
            9.5.0
              jmeister79J Offline
              jmeister79J Offline
              jmeister79
              Beispielsweise history. Jeder andere das gleiche.
              host.iobrokerpi
              2023-03-21 11:35:07.419	info	iobroker npm-install: exit 25
              host.iobrokerpi
              2023-03-21 11:35:06.388	error	iobroker npm-install: host.iobrokerpi Cannot install iobroker.history@2.2.4: 217
              host.iobrokerpi
              2023-03-21 11:34:52.248	info	iobroker npm-install: Installing iobroker.history@2.2.4... (System call)
              host.iobrokerpi
              2023-03-21 11:34:52.245	info	iobroker npm-install: NPM version: 9.5.0
              host.iobrokerpi
              2023-03-21 11:34:47.234	info	iobroker install history@2.2.4 using installedFrom
              host.iobrokerpi
              2023-03-21 11:34:47.233	warn	startInstance cannot find adapter "history@2.2.4". Try to install it... 1 attempt
                @thomas-braun hier aus dem forum.
                Offenbar sind keine der Adapter isntalliert, im logbuch versucht er das gerade und schafft es nicht.
                Wohl zerschossen.
                CodierknechtC Online
                Codierknecht
                hier aus dem forum
                @Thomas-Braun Ein echtes Problem, dass die Leute hier natürlich dutzende von Posts finden, viele davon aber einfach falsch oder schlicht veraltet sind.
                @jmeister79 In @Thomas-Braun 's Signatur sieht Du, wie es richtig gemacht wird. Das hat er nicht ohne Grund da reingeschrieben.
                HmIP|ZigBee|Tasmota|Unifi
                Zabbix Certified Specialist
                • jmeister79J Offline
                  jmeister79J Offline
                  jmeister79
                  Also im Wiki finde ich ejtzt folgenden Befehl:
                  curl -sLf https://iobroker.net/install.sh | bash -
                  Ich möchte gerne alles loswerden und neuch machen und dann ein abckup einspielen.
                  Ich denke ich hab mir alles kaputt gemacht gestern und heute.
                  pi@iobrokerpi:/opt/iobroker $ iob
                  node:internal/modules/cjs/loader:1078
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
                      at Module._load (node:internal/modules/cjs/loader:920:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      at node:internal/main/run_main_module:23:47 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  Node.js v18.15.0
                  ich glaub hier ist der zug abgefahren...
                      throw err;
                      requireStack: []
                    Node.js v18.15.0
                    @jmeister79
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                      @jmeister79
                      cd /opt/iobroker
                      jmeister79J Offline
                      jmeister79J Offline
                      jmeister79
                      Danke danke!
                      Installation ist durch und er isntalliert jetzt anch und nach alle adapter neu, diesmal gehts.
                      Danke euch beiden für die Tipps. Wieder viel gelernt!!!
                        Danke danke!
                        Codierknecht
                        @jmeister79
                        Wenn die Kiste dann wieder am Start ist:
                        Schau Dir regelmäßig den Speicherverbrauch des Systems an. Mir dünkt, dass die Kiste mit Deinen Zusatzdiensten möglicherweise überfordert ist.
                        Wenn's eng zu werden droht, solltest Du Dir überlegen, einige Dinge auszulagern.
                        • CodierknechtC Codierknecht
                          @jmeister79
                          jmeister79J Offline
                          jmeister79J Offline
                          jmeister79
                          @codierknecht Danke.
                          ich liebäugle mit was besserem als einem Raspi aber ich muss mich mal damit eingehend beschäftigen.
                          Nils
                            Nils
                            @jmeister79
                            Wenn du jetzt noch die vollständige Ausgabe von
                            iob diag
                            posten magst? Dann könnte man da auch mal drüber schauen.
                              @jmeister79
                              iob diag
                              jmeister79J Offline
                              jmeister79J Offline
                              jmeister79
                              Büdde!
                              Skript v.2023-01-02
                              *** BASE SYSTEM ***
                              Model           : Raspberry Pi 4 Model B Rev 1.2
                              Architecture:   aarch64
                              Docker:         false
                              Virtualization: none
                              Distributor ID: Raspbian
                              Description:    Raspbian GNU/Linux 11 (bullseye)
                              Release:        11
                              Codename:       bullseye
                              PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                              NAME="Raspbian GNU/Linux"
                              VERSION_ID="11"
                              VERSION="11 (bullseye)"
                              VERSION_CODENAME=bullseye
                              ID=raspbian
                              ID_LIKE=debian
                              HOME_URL="http://www.raspbian.org/"
                              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                              Systemuptime and Load:
                               15:38:23 up  5:23,  1 user,  load average: 0.59, 0.88, 1.86
                              CPU threads: 4
                              *** Time and Time Zones ***
                              Tue Mar 21 14:38:23 UTC 2023
                              Tue Mar 21 15:38:23 CET 2023
                              CET +0100
                              Europe/Berlin
                              *** User and Groups ***
                              pi
                              /home/pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            3.8G        1.4G        130M        0.0K        2.3G        2.4G
                              Swap:            99M          0B         99M
                              Total:          3.9G        1.4G        230M
                                       3794 M total memory
                                       1359 M used memory
                                       1465 M active memory
                                       1652 M inactive memory
                                        130 M free memory
                                        106 M buffer memory
                                       2197 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              Filesystem                                          Type      Size  Used Avail Use% Mounted on
                              /dev/root                                           ext4       59G   17G   39G  31% /
                              devtmpfs                                            devtmpfs  1.7G     0  1.7G   0% /dev
                              tmpfs                                               tmpfs     1.9G     0  1.9G   0% /dev/shm
                              tmpfs                                               tmpfs     759M  884K  759M   1% /run
                              tmpfs                                               tmpfs     5.0M  4.0K  5.0M   1% /run/lock
                              /dev/mmcblk0p1                                      vfat      253M   51M  202M  20% /boot
                              tmpfs                                               tmpfs     380M     0  380M   0% /run/user/1000
                              //192.168.178.70/iobroker_backup                    cifs      3.6T  1.9T  1.8T  52% /opt/iobroker/backups
                              //192.168.178.70/Intern_RAID1/Backups/iobroker_auto cifs      3.6T  1.9T  1.8T  52% /opt/iobroker/backups
                              Messages in dmesg:
                              [Tue Mar 21 10:14:52 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:34:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                              [Tue Mar 21 10:14:53 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Tue Mar 21 10:14:53 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Tue Mar 21 10:14:56 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              TARGET                    SOURCE                                              FSTYPE OPTIONS
                              /                         /dev/mmcblk0p2                                      ext4   rw,noatime
                              |-/boot                   /dev/mmcblk0p1                                      vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                              `-/opt/iobroker/backups   //192.168.178.70/iobroker_backup                    cifs   rw,relatime,vers=1.0,cache=strict,username=iobroker_backup,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.70,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                                `-/opt/iobroker/backups //192.168.178.70/Intern_RAID1/Backups/iobroker_auto cifs   rw,relatime,vers=1.0,cache=strict,username=iobroker_backup,uid=1001,noforceuid,gid=1001,noforcegid,addr=192.168.178.70,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=61440,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1,closetimeo=5
                              /var:
                              2.3G    /var/
                              2.0G    /var/log/journal/d894d73ccc4e4e4ea197a2ff3874f9bf
                              2.0G    /var/log
                              114M    /var/lib
                              /opt/iobroker/backups:
                              1.6G    /opt/iobroker/backups/
                              598M    /opt/iobroker/backups/iobroker-data
                              321M    /opt/iobroker/backups/iobroker-data/files
                              167M    /opt/iobroker/backups/iobroker_2023_02_07-02_00_20_iobroker_pi_backupiobroker.tar
                              166M    /opt/iobroker/backups/iobroker-data/backup-objects
                              /opt/iobroker/iobroker-data:
                              1.4G    /opt/iobroker/iobroker-data/
                              958M    /opt/iobroker/iobroker-data/history
                              391M    /opt/iobroker/iobroker-data/files
                              55M     /opt/iobroker/iobroker-data/files/material
                              52M     /opt/iobroker/iobroker-data/files/material/static
                              50M     /opt/iobroker/iobroker-data/objects.jsonl
                              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.90a1d068.js.map
                              33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                              19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.806bf48a.js.map
                              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.fe83292c.js.map
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v18.15.0
                              /usr/bin/node           v18.15.0
                              /usr/bin/npm            9.5.0
                              /usr/bin/npx            9.5.0
                              nodejs:
                                Installed: 18.15.0-deb-1nodesource1
                                Candidate: 18.15.0-deb-1nodesource1
                                Version table:
                               *** 18.15.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_18.x bullseye/main armhf Packages
                                   12.22.12~dfsg-1~deb11u3 500
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.3.5
                              javascript:     6.1.4
                              Adapters from github:   0
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobrokerpi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : iobrokerpi                               -  enabled
                              + system.adapter.bestway.0                : bestway               : iobrokerpi                               -  enabled
                              + system.adapter.ble.0                    : ble                   : iobrokerpi                               -  enabled
                              + system.adapter.chromecast.0             : chromecast            : iobrokerpi                               -  enabled
                                system.adapter.devices.0                : devices               : iobrokerpi                               - disabled
                              + system.adapter.discovery.0              : discovery             : iobrokerpi                               -  enabled
                              + system.adapter.ems-esp.0                : ems-esp               : iobrokerpi                               -  enabled
                                system.adapter.flot.0                   : flot                  : iobrokerpi                               - disabled
                              + system.adapter.fritzdect.0              : fritzdect             : iobrokerpi                               -  enabled
                                system.adapter.habpanel.0               : habpanel              : iobrokerpi                               - disabled
                              + system.adapter.history.0                : history               : iobrokerpi                               -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobrokerpi                               - disabled
                                system.adapter.icons-icons8.0           : icons-icons8          : iobrokerpi                               - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : iobrokerpi                               - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerpi                               - disabled
                              + system.adapter.info.0                   : info                  : iobrokerpi                               -  enabled
                              + system.adapter.iot.0                    : iot                   : iobrokerpi                               -  enabled
                              + system.adapter.javascript.0             : javascript            : iobrokerpi                               -  enabled
                                system.adapter.material.0               : material              : iobrokerpi                               - disabled
                              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerpi                               -  enabled, port: 54321
                                system.adapter.mobile.0                 : mobile                : iobrokerpi                               - disabled
                              + system.adapter.mqtt.0                   : mqtt                  : iobrokerpi                               -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.net-tools.0              : net-tools             : iobrokerpi                               -  enabled
                                system.adapter.philips-tv.0             : philips-tv            : iobrokerpi                               - disabled
                              + system.adapter.ping.0                   : ping                  : iobrokerpi                               -  enabled
                              + system.adapter.rpi2.0                   : rpi2                  : iobrokerpi                               -  enabled
                                system.adapter.sayit.0                  : sayit                 : iobrokerpi                               - disabled, port: 0
                                system.adapter.sayit.1                  : sayit                 : iobrokerpi                               - disabled, port: 0
                              + system.adapter.shelly.0                 : shelly                : iobrokerpi                               -  enabled, port: 1882, bind: 0.0.0.0
                                system.adapter.synology.0               : synology              : iobrokerpi                               - disabled, port: 5001
                              + system.adapter.telegram.0               : telegram              : iobrokerpi                               -  enabled, port: 8443, bind: 0.0.0.0
                                system.adapter.text2command.0           : text2command          : iobrokerpi                               - disabled
                              + system.adapter.tr-064.0                 : tr-064                : iobrokerpi                               -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerpi                               -  enabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerpi                               -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerpi                               -  enabled
                                system.adapter.vis-lcars.0              : vis-lcars             : iobrokerpi                               -  enabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerpi                               -  enabled
                                system.adapter.vis-metro.0              : vis-metro             : iobrokerpi                               -  enabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerpi                               -  enabled
                                system.adapter.vis.0                    : vis                   : iobrokerpi                               -  enabled
                              + system.adapter.web.0                    : web                   : iobrokerpi                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.ws.0                     : ws                    : iobrokerpi                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.zigbee.0                 : zigbee                : iobrokerpi                               -  enabled, port: /dev/ttyUSB0
                              + instance is alive
                              ioBroker-Repositories
                              online        : https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json
                              sources       : conf/sources-dist.json
                              latest        : http://iobroker.live/repo/sources-dist-latest.json
                              km            : https://github.com/frankjoke/ioBroker.km200
                              Active repo(s): stable
                              Installed ioBroker-Instances
                              Used repository: stable
                              Adapter    "backitup"     : 2.5.12   , installed 2.6.2
                              Adapter    "bestway"      : 0.0.3    , installed 0.0.3
                              Adapter    "ble"          : 0.13.0   , installed 0.13.2
                              Adapter    "chromecast"   : 2.3.1    , installed 3.0.3
                              Adapter    "devices"      : 1.1.2    , installed 1.1.2
                              Adapter    "ems-esp"      : 1.26.0   , installed 1.26.0
                              Adapter    "flot"         : 1.11.0   , installed 1.12.0
                              Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                              Adapter    "history"      : 2.2.4    , installed 2.2.4
                              Adapter    "info"         : 1.9.19   , installed 1.9.25
                              Adapter    "iot"          : 1.14.2   , installed 1.14.3
                              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                              Adapter    "material"     : 1.1.2    , installed 1.3.0
                              Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                              Adapter    "philips-tv"   : 0.5.3    , installed 0.5.2  [Updatable]
                              Adapter    "sayit"        : 1.12.3   , installed 1.12.6
                              Adapter    "shelly"       : 6.3.1    , installed 6.3.1
                              Adapter    "socketio"     : 4.2.0    , installed 6.3.3
                              Adapter    "synology"     : 2.1.13   , installed 2.1.13
                              Adapter    "telegram"     : 1.15.2   , installed 1.15.6
                              Adapter    "text2command" : 2.3.0    , installed 2.3.0
                              Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
                              Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                              Adapter    "web"          : 4.3.0    , installed 5.4.1
                              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                              Objects and States
                              Objects:        6617
                              States:         5099
                              Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Hit:3 https://deb.nodesource.com/node_18.x bullseye InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       243539     31435/iobroker.js-c
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       243546     31435/iobroker.js-c
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14685      547/sshd: /usr/sbin
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       244436     31540/io.mqtt.0
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       244435     31540/io.mqtt.0
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          14687      547/sshd: /usr/sbin
                              tcp6       0      0 :::21                   :::*                    LISTEN      110        14175      811/proftpd: (accep
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       246685     31927/io.ws.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       254777     358/io.web.0
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       245792     31453/io.admin.0
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       246106     31556/io.shelly.0
                              udp        0      0 0.0.0.0:36424           0.0.0.0:*                           108        12159      394/avahi-daemon: r
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12262      738/dhcpcd
                              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       246836     31534/io.mihome-vac
                              udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13236      -
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       244228     31521/io.chromecast
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12157      394/avahi-daemon: r
                              udp6       0      0 :::43007                :::*                                108        12160      394/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          12274      738/dhcpcd
                              udp6       0      0 :::51820                :::*                                0          13237      -
                              udp6       0      0 :::5353                 :::*                                108        12158      394/avahi-daemon: r
                              2023-03-21 15:39:42.552  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:42.572  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:45.084  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:45.552  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:45.574  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:47.922  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:47.989  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:47.990  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:47.995  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:48.548  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:48.557  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:48.612  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:48.615  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:48.617  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:48.626  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:49.020  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:50.548  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:50.586  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:39:55.086  - info: ws.0 (31927) ==> Connected system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:40:00.384  - info: javascript.0 (31491) script.js.Heizung.Fussbodenheizung_steuerung: ...
                              2023-03-21 15:40:01.223  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:40:01.289  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:40:01.359  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:40:01.363  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                              2023-03-21 15:40:01.365  - info: ws.0 (31927) <== Disconnect system.user.admin from ::ffff:192.168.178.41
                                Büdde!
                                Skript v.2023-01-02
                                *** BASE SYSTEM ***
                                Docker:         false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=raspbian
                                ID_LIKE=debian
                                CPU threads: 4
                                CET +0100
                                Europe/Berlin
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                         1359 M used memory
                                          130 M free memory
                                          106 M buffer memory
                                         2197 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                Messages in dmesg:
                                /var:
                                2.3G    /var/
                                2.0G    /var/log
                                114M    /var/lib
                                /usr/bin/npm            9.5.0
                                /usr/bin/npx            9.5.0
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                javascript:     6.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        6617
                                States:         5099
                                Pending Updates: 0
                                Mit den Einstellungen musst du aber höllisch aufpassen, dass du da nix doppelt in den Mountpunkt /opt/iobroker/backups knallst. Zumal der Backitup-Adapter da je nach Einstellung auch noch unabhängig von der fstab agiert.
                                Bzw. da ist schon was doppeltgemoppelt, iob diag zeigt ja auch etwas später die gemounteten Dateisysteme an.
                                Zu ioBroker-Repositories:
                                iobroker repo del online
                                iobroker repo del sources
                                iobroker repo del km
                                  jmeister79J Offline
                                  jmeister79J Offline
                                  jmeister79
                                  @thomas-braun ja, das mit dem backup ordner war ein versehen, was beim neuaufsetzen grad passiert war und schon behoben ist.
                                  die repos hatte ich für einen experimentellen adapter benutzt und habe ich auch grad entfernt.
                                  Beste Grüße
                                  Nils
                                  ps.: und jetzt ist er wieder schnell... seltsam
