  4. [gelöst] Nach Upgrade/Update kein Webserver nicht mehr
    5.5k
61 Beiträge 4 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • jmeister79J jmeister79
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
    npm ERR! invalid: iobroker.km200@2.0.3 /opt/iobroker/node_modules/iobroker.km200
    npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR!     /home/pi/.npm/_logs/2023-03-21T07_46_23_247Z-debug-0.log
    Adapters from github:   2
    npm und nodejs wollte ich ja eigentlich updaten, soweit bin ich noch nicht gekommen seit gestern.
    Liegt da evtl das Problem?
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     08:46:02 up 15:00,  1 user,  load average: 0.60, 0.73, 0.69
    CPU threads: 4
    *** Time and Time Zones ***
    Tue Mar 21 07:46:02 UTC 2023
    Tue Mar 21 08:46:02 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            3.8G        1.8G        316M        0.0K        1.7G        2.1G
    Swap:            99M          0B         99M
    Total:          3.9G        1.8G        416M
             3794 M total memory
             1777 M used memory
             1840 M active memory
             1126 M inactive memory
              316 M free memory
              540 M buffer memory
             1159 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G   16G   41G  29% /
    devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
    tmpfs          tmpfs     759M  872K  759M   1% /run
    /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
    Messages in dmesg:
    [Mon Mar 20 17:45:32 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:34:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Mon Mar 20 17:45:33 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
    [Mon Mar 20 17:45:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Mon Mar 20 17:45:36 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    2.7G    /var/
    2.0G    /var/log/journal/d894d73ccc4e4e4ea197a2ff3874f9bf
    2.0G    /var/log
    453M    /var/cache
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    959M    /opt/iobroker/iobroker-data/history
    575M    /opt/iobroker/iobroker-data/files
    166M    /opt/iobroker/iobroker-data/backup-objects
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.7
    javascript:     6.1.4
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobrokerpi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobrokerpi                               -  enabled
    + system.adapter.bestway.0                : bestway               : iobrokerpi                               -  enabled
    + system.adapter.ble.0                    : ble                   : iobrokerpi                               -  enabled
    + system.adapter.chromecast.0             : chromecast            : iobrokerpi                               -  enabled
      system.adapter.devices.0                : devices               : iobrokerpi                               - disabled
    + system.adapter.discovery.0              : discovery             : iobrokerpi                               -  enabled
    + system.adapter.ems-esp.0                : ems-esp               : iobrokerpi                               -  enabled
      system.adapter.flot.0                   : flot                  : iobrokerpi                               - disabled
    + system.adapter.fritzdect.0              : fritzdect             : iobrokerpi                               -  enabled
      system.adapter.habpanel.0               : habpanel              : iobrokerpi                               - disabled
    + system.adapter.history.0                : history               : iobrokerpi                               -  enabled
      system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobrokerpi                               - disabled
      system.adapter.icons-icons8.0           : icons-icons8          : iobrokerpi                               - disabled
      system.adapter.icons-material-png.0     : icons-material-png    : iobrokerpi                               - disabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerpi                               - disabled
    + system.adapter.info.0                   : info                  : iobrokerpi                               -  enabled
    + system.adapter.iot.0                    : iot                   : iobrokerpi                               -  enabled
    + system.adapter.javascript.0             : javascript            : iobrokerpi                               -  enabled
      system.adapter.material.0               : material              : iobrokerpi                               - disabled
    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerpi                               -  enabled, port: 54321
      system.adapter.mobile.0                 : mobile                : iobrokerpi                               - disabled
    + system.adapter.mqtt.0                   : mqtt                  : iobrokerpi                               -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.net-tools.0              : net-tools             : iobrokerpi                               -  enabled
    + system.adapter.philips-tv.0             : philips-tv            : iobrokerpi                               -  enabled
    + system.adapter.ping.0                   : ping                  : iobrokerpi                               -  enabled
    + system.adapter.rpi2.0                   : rpi2                  : iobrokerpi                               -  enabled
      system.adapter.sayit.0                  : sayit                 : iobrokerpi                               - disabled, port: 0
      system.adapter.sayit.1                  : sayit                 : iobrokerpi                               - disabled, port: 0
    + system.adapter.shelly.0                 : shelly                : iobrokerpi                               -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.sql.0                    : sql                   : iobrokerpi                               - disabled
      system.adapter.synology.0               : synology              : iobrokerpi                               - disabled, port: 5001
    + system.adapter.telegram.0               : telegram              : iobrokerpi                               -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : iobrokerpi                               -  enabled
    + system.adapter.tr-064.0                 : tr-064                : iobrokerpi                               -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerpi                               - disabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerpi                               -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerpi                               - disabled
      system.adapter.vis-lcars.0              : vis-lcars             : iobrokerpi                               - disabled
      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerpi                               - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerpi                               - disabled
      system.adapter.vis.0                    : vis                   : iobrokerpi                               -  enabled
    + system.adapter.web.0                    : web                   : iobrokerpi                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.ws.0                     : ws                    : iobrokerpi                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobrokerpi                               -  enabled, port: /dev/ttyUSB0
    + instance is alive
    ioBroker-Repositories
    online        : https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json
    sources       : conf/sources-dist.json
    latest        : http://iobroker.live/repo/sources-dist-latest.json
    km            : https://github.com/frankjoke/ioBroker.km200
    Active repo(s): latest
    Installed ioBroker-Instances
    Used repository: latest
    Adapter    "admin"        : 6.3.7    , installed 6.3.7
    Adapter    "backitup"     : 2.6.12   , installed 2.6.12
    Adapter    "bestway"      : 0.0.3    , installed 0.0.3
    Adapter    "ble"          : 0.13.3   , installed 0.13.2 [Updatable]
    Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "ems-esp"      : 1.29.0   , installed 1.29.0
    Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "iot"          : 1.14.5   , installed 1.14.5
    Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
    Adapter    "km200"        : 2.0.3    , installed 2.0.3
    Adapter    "material"     : 1.3.1    , installed 1.3.1
    Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
    Adapter    "sayit"        : 1.12.6   , installed 1.12.6
    Adapter    "shelly"       : 6.4.0    , installed 6.4.0
    Adapter    "socketio"     : 6.3.5    , installed 6.3.5
    Adapter    "synology"     : 2.1.13   , installed 2.1.13
    Adapter    "telegram"     : 1.15.6   , installed 1.15.6
    Adapter    "text2command" : 3.0.2    , installed 3.0.2
    Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "web"          : 5.5.3    , installed 5.5.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "ws"           : 2.3.6    , installed 2.3.6
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        6639
    States:         5120
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       146707     7921/io.mqtt.0
    tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       146708     7921/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       146452     7790/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       146445     7790/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13989      544/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       143242     7808/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       155126     9024/io.web.0
    tcp6       0      0 :::8084                 :::*                    LISTEN      1001       157854     9017/io.ws.0
    tcp6       0      0 :::21                   :::*                    LISTEN      110        15776      813/proftpd: (accep
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13991      544/sshd: /usr/sbin
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       143291     7876/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14583      429/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       146724     7980/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14650      734/dhcpcd
    udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       147481     7887/io.mihome-vacu
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          14808      -
    udp        0      0 0.0.0.0:50393           0.0.0.0:*                           108        14585      429/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14584      429/avahi-daemon: r
    udp6       0      0 :::41417                :::*                                108        14586      429/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12861      734/dhcpcd
    udp6       0      0 :::51820                :::*                                0          14809      -
    2023-03-21 08:45:29.284  - warn: chromecast.0 (7876) Google Homes - Client error: Error: connect ECONNREFUSED 192.168.178.49:32156
        at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
    2023-03-21 08:45:32.266  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:45:33.294  - warn: chromecast.0 (7876) Google Homes - Client error: Error: connect ECONNREFUSED 192.168.178.49:32156
    2023-03-21 08:45:37.272  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:45:42.325  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:45:47.379  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:45:52.431  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:45:57.522  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:02.573  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:07.621  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:12.629  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:17.677  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:22.733  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:27.782  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:32.831  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:37.882  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:42.933  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:47.986  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:53.240  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:46:58.292  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:47:03.320  - debug: philips-tv.0 (9231) The TV seems to be turned off
    2023-03-21 08:47:06.721  - warn: fritzdect.0 (8123) State value to set for "fritzdect.0.DECT_087610265658.celsius" has value "7.5" less than min "8"
    2023-03-21 08:47:08.370  - debug: philips-tv.0 (9231) The TV seems to be turned off
    CodierknechtC Online
    Codierknecht
    @jmeister79
    Gibt es einen bestimmten Grund, warum Du da mit dem Beta-Repo unterwegs bist?
    HmIP|ZigBee|Tasmota|Unifi
    Zabbix Certified Specialist
    • jmeister79J Offline
      jmeister79J Offline
      jmeister79
      @codierknecht Ich hatte seinerzeit Probleme mit dem Zigbee Adapter und deren Fix war nur in der Beta und ich brauchte schnell ne Lösung.
      Könnte ich mal wieder zurückstellen
        Codierknecht
        @jmeister79 sagte in Nach Upgrade/Update kein Webserver nicht mehr:
        Mach das. Beta ist halt Beta und sollte nur aus gutem Grund und nur für bestimmte Dinge verwendet werden.
        Dir werden sonst alle möglichen Updates angeboten, die Du für ein Produktivsystem mit ziemlicher Sicherheit gar nicht willst und auch nicht unbedingt gebrauchen kannst.
        jmeister79J 1 Antwort Letzte Antwort
        • CodierknechtC Codierknecht
          jmeister79J Offline
          jmeister79J Offline
          jmeister79
          schrieb am zuletzt editiert von jmeister79
          @codierknecht Danke Dir. Sehr guter Hinweis!
          http://download.iobroker.net/sources-dist.json als stable ist richtig?
            @jmeister79
            Und stell den debug-Modus bei Adaptern ab, wenn da nix mehr debuggt wird.
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Docker:         false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              CET +0100
              Europe/Berlin
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M          0B         99M
                       3794 M total memory
                       1777 M used memory
                        316 M free memory
                        540 M buffer memory
                       1159 M swap cache
                         99 M total swap
                          0 M used swap
                         99 M free swap
              *** FILESYSTEM ***
              Messages in dmesg:
              /var:
              2.7G    /var/
              2.0G    /var/log
              453M    /var/cache
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.7
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        6639
              States:         5120
              Pending Updates: 0
              Die beiden Adapter neuinstallieren:
                Node 16.19.1 und NPM 8.19.3 sind die aktuell empfohlenen Versionen.
                Da muss nix aktualisiert werden!
                @codierknecht sagte in Nach Upgrade/Update kein Webserver nicht mehr:
                Nope, seit neustem ist nodejs@18 und npm@9 die Empfehlung.
                  @jmeister79
                  Und was haste da für 'komische' Repos drin?
                    Codierknecht
                    @thomas-braun sagte in Nach Upgrade/Update kein Webserver nicht mehr:
                    Uuups - das ist aber dann brandneu.
                    Hatte nicht mitbekommen dass da die letzten Tests erfolgreich waren und das jetzt empfohlen wird.
                    Asche auf mein Haupt :-(
                      @codierknecht
                      https://forum.iobroker.net/topic/64032/update-nodejs-best-practise-supported-14-16-und-18
                      Ist nicht auf den ersten Blick ersichtlich, dass damit auch die Empfehlung zu nodejs@18 einhergeht.
                        jmeister79J Offline
                        jmeister79
                        ok, nach umstellung der repo hats geknallt und jetzt geht nix mehr.
                        Bei iob status sagt er iobroker is not Running on this host.
                        iob fix und das bereinigen der Ordner über den Einzeiler und reboot usw usw bringt grad nix.
                          Was haste denn gemacht und wie ist der Status jetzt?
                          iob repo list
                          sagt?
                            iob repo list
                            sagt?
                            jmeister79J Offline
                            jmeister79J Offline
                            jmeister79
                            pi@iobrokerpi:~ $ iob repo list
                            Active repo(s): stable
                            ich habe auf stable gestellt und dann unter adapter "Adapter auf updates Prüfen" gedrückt. Dann kam der Kreis.
                            Iob restart und reboot haben nichts gebracht
                            ich hab fix usw durchlaufen lassen, erst
                             curl -sL https://iobroker.net/install.sh | bash -
                            hat ein lebenszeichen gebracht.
                            npm ist nun auf 8 aber node auf 16 und will nicht updaten wg
                            pi@iobrokerpi:~ $ sudo apt-get install nodejs.
                            Reading package lists... Done
                            Note, selecting 'nodejs-legacy' for regex 'nodejs.'
                            Note, selecting 'nodejs-dev' for regex 'nodejs.'
                            Note, selecting 'nodejs-doc' for regex 'nodejs.'
                            Note, selecting 'nodejs' instead of 'nodejs-legacy'
                            Note, selecting 'nodejs' instead of 'nodejs-dev'
                            nodejs is already the newest version (16.19.1-deb-1nodesource1).
                            Some packages could not be installed. This may mean that you have
                            requested an impossible situation or if you are using the unstable
                            distribution that some required packages have not yet been created
                            or been moved out of Incoming.
                            The following information may help to resolve the situation:
                            The following packages have unmet dependencies:
                             nodejs : Conflicts: nodejs-doc
                            E: Unable to correct problems, you have held broken packages.
                            Aktueller stand ist jetzt das, bis auf Admin, backitup und discovery alle isntanzen rot sind und nicht starten
                              Vollkommen falsch. Wo hast du das her?
                                jmeister79J Offline
                                jmeister79J Offline
                                jmeister79
                                @thomas-braun hier aus dem forum.
                                Offenbar sind keine der Adapter isntalliert, im logbuch versucht er das gerade und schafft es nicht.
                                Wohl zerschossen.
                                Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                                  @jmeister79
                                  iob stop
                                  sudo apt purge --autoremove nodejs* npm node-*
                                  curl -fsSL https://deb.nodesource.com/setup_18.x | sudo -E bash -
                                  sudo apt update
                                  sudo apt install nodejs
                                  iob start
                                    Wohl zerschossen.
                                    @jmeister79
                                    Check mit:
                                    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                    type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v
                                      @jmeister79
                                      Check mit:
                                      jmeister79J Offline
                                      jmeister79J Offline
                                      jmeister79
                                      @thomas-braun beim remove der nodejs gitbs jede megne warnungen wg nicht leerer npm ordner
                                        @jmeister79
                                        Zeigen...
                                        Meine Glaskugel ist defekt.
                                          @jmeister79
                                          Zeigen...
                                          jmeister79J Offline
                                          jmeister79J Offline
                                          jmeister79
                                          dann srell mal deinen Bildschirm hochkant: :-)
                                          Removing nodejs (16.19.1-deb-1nodesource1) ...
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/yallist' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/write-file-atomic' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wrappy' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wide-align' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/which/bin' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/wcwidth' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/walk-up-path' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-name' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/validate-npm-package-license' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/util-deprecate' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-slug' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/unique-filename' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/treeverse' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tiny-relative-date' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/text-table' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/tar' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/string_decoder' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ssri' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-expression-parse' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/spdx-correct' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/socks' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/smart-buffer' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/signal-exit' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/set-blocking' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/semver/node_modules/lru-cache' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safer-buffer' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/safe-buffer' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf/node_modules/minimatch' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf/node_modules/glob' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/rimraf/node_modules/brace-expansion' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/retry' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/readable-stream/lib/internal/streams' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-package-json-fast' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/read-cmd-shim' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/qrcode-terminal' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promzard' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-retry' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-inflight' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-call-limit' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/promise-all-reject-late' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/proc-log' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/postcss-selector-parser' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/parse-conflict-json' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/pacote' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/once' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npmlog' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-user-validate' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-registry-fetch' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-profile' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-pick-manifest' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-packlist' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-package-arg' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-normalize-package-bin' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-install-checks' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-bundled' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/npm-audit-report' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/normalize-package-data' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/nopt' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/nopt' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/minimatch' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/glob' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/brace-expansion' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/node-gyp/.github' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/negotiator' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mute-stream' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ms' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/mkdirp' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minizlib' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-sized' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-pipeline' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-json-stream' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-flush' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-fetch' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minipass-collect' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/minimatch' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/make-fetch-happen' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/lru-cache' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmversion' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmteam' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmsearch' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpublish/lib' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmpack' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmorg' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmhook' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmfund' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmexec' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmdiff' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/libnpmaccess' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/just-diff-apply' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/jsonparse' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-stringify-nice' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/json-parse-even-better-errors' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/isexe' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-lambda' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-core-module' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/is-cidr' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/init-package-json' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ini' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inherits' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/inflight' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/infer-owner' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/ignore-walk' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/iconv-lite' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/humanize-ms' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/http-cache-semantics' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/hosted-git-info/lib' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/has-unicode' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/graceful-fs' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/glob' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/gauge' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/function-bind' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs.realpath' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fs-minipass' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/fastest-levenshtein' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/err-code' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/encoding' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/emoji-regex' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/diff' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/depd' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/delegates' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/defaults' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/debug/node_modules/ms' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cssesc' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/console-control-strings' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/concat-map' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/common-ancestor-path' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/columnify' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-support' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-name' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/color-convert' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cmd-shim' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/clone' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-table3' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cli-columns' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cidr-regex' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/chownr' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/cacache/lib/util' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/brace-expansion' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/bin-links' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/balanced-match' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/are-we-there-yet' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/archy' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/aproba' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/agentkeepalive' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/abbrev' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@tootallnate/once' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/run-script' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/query' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/promise-spawn/lib' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/package-json' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/name-from-folder' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/move-file' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/metavuln-calculator' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/map-workspaces' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/installed-package-contents' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/git' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/fs/lib/cp' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/disparity-colors' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/config/lib' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@isaacs/string-locale-compare' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@gar/promisify' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/node_modules/@colors/colors' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/man/man1' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/utils' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/lib/commands' not empty so not removed
                                          dpkg: warning: while removing nodejs, directory '/usr/lib/node_modules/npm/docs/output/commands' not empty so not removed
