  4. Shelly Adapter stürzt ab ENETUNREACH
    5.5k
23 Beiträge 7 Kommentatoren 3.5k Aufrufe 6 Beobachtet
  • R rockflopp
    @asgothian
    Nach allen updates besteht der Fehler weiterhin. Noch eine Idee oder nun den von dir beschriebenen Weg beschreiten?
    2022-05-24 06:32:30.727 - error: shelly.0 (28522) uncaught exception: send ENETUNREACH 192.168.0.24:5683
    2022-05-24 06:32:30.740 - error: shelly.0 (28522) Error: send ENETUNREACH 192.168.0.24:5683
    at doSend (dgram.js:714:16)
    at defaultTriggerAsyncIdScope (internal/async_hooks.js:452:18)
    at afterDns (dgram.js:660:5)
    at processTicksAndRejections (internal/process/task_queues.js:83:21)
    2022-05-24 06:32:30.741 - error: shelly.0 (28522) Exception-Code: ENETUNREACH: send ENETUNREACH 192.168.0.24:5683
    2022-05-24 06:32:30.818 - info: shelly.0 (28522) Closing Adapter
    2022-05-24 06:32:30.819 - info: shelly.0 (28522) terminating
    2022-05-24 06:32:30.822 - warn: shelly.0 (28522) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-05-24 06:32:30.988 - error: host.iobroker-pi Caught by controller[0]: Error: send ENETUNREACH 192.168.0.24:5683
    2022-05-24 06:32:30.996 - error: host.iobroker-pi Caught by controller[0]: at doSend (dgram.js:714:16)
    2022-05-24 06:32:30.996 - error: host.iobroker-pi Caught by controller[0]: at defaultTriggerAsyncIdScope (internal/async_hooks.js:452:18)
    2022-05-24 06:32:30.996 - error: host.iobroker-pi Caught by controller[0]: at afterDns (dgram.js:660:5)
    2022-05-24 06:32:30.997 - error: host.iobroker-pi Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:83:21)
    2022-05-24 06:32:30.998 - error: host.iobroker-pi instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-05-24 06:32:30.998 - info: host.iobroker-pi Restart adapter system.adapter.shelly.0 because enabled
    2022-05-24 06:32:32.158 - info: host.iobroker-pi instance system.adapter.shelly.0 started with pid 8151
    2022-05-24 06:32:34.562 - info: shelly.0 (8151) starting. Version 5.3.2 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.2, js-controller: 4.0.23
    2022-05-24 06:32:35.130 - info: shelly.0 (8151) Starting in CoAP mode.
    2022-05-24 06:32:35.207 - info: shelly.0 (8151) [CoAP] Listening for packets in the network
    Beste Grüße
    rockflopp
    Eine Suche bei den Github Issues gab es einen Lösungsvorschlag bei dem die maximale Stromentnahme hochgesetzt wird, das werde ich jetzt mal probieren.
    https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/65
    • R rockflopp
      @rockflopp
      Betreibst du denn einen WLAN-Stick an einem der USB-Ports? Der iobroker-Server sollte eigentlich immer per LAN-Kabel betrieben werden.
      R 1 Antwort Letzte Antwort
        @rockflopp
        rockflopp
        schrieb am zuletzt editiert von rockflopp
        @thomas-braun nein per LAN plus Zigbee Stick
        • R rockflopp
          @rockflopp
          Im Issue ging es um WLAN-Sticks, die zu wenig Saft über USB bekamen und dann Aussetzer im Netz verursacht haben.
            mbw
            Hi zusammen,
            gibt es hier etwas Neues? Ich habe auch das Problem mit dem abstürzenden Shelly-Adapter, alle paar Stunden wird bei mir nach dem gleichen Fehler die Instanz neue gestartet.
            Danke!
            da_WoodyD HomoranH 2 Antworten Letzte Antwort
            • M mbw
              Hi zusammen,
              Danke!
              da_WoodyD Online
              da_WoodyD Online
              @mbw was soll es neues geben? am shelly adapter liegts sicher nicht. seit 3 jahren COAP instanz am laufen, seit monaten eine 2. MQTT, kein einziger absturz trotz jeder beta.
              ich tipp da eher auf euer netzwerk.
              • da_WoodyD da_Woody
                mbw
                @da_woody ja, das kann ja sein, aber trotzdem wird ja hier eine Exception nicht behandelt weswegen der Adapter dann abstürzt.
                • M mbw
                  da_WoodyD Online
                  da_WoodyD Online
                  @mbw das mein ich ja, der adapter stürzt nich einfach ab. da muss was anderes sein im netzwerk.
                  hab da auch schon einiges drüber getippt.
                  igmp snooping... als tip
                  waren zwar keine abstürze, aber es kamen keine daten mehr.
                  • M mbw
                    Hi zusammen,
                    Danke!
                    @mbw sagte in Shelly Adapter stürzt ab ENETUNREACH:
                    wirklich identisch?
                    zeigen!
                    ist das so?
                      rockflopp
                      Hallo @da_woody, der Fehler tritt bei mir leider auch weiterhin mehr weniger regelmäßig auf. Sollen wir mal einen Bug Report direkt beim Adapter aufmachen? Oder konntest du inzwischen die Ursache lokalisieren?
                      Habe 50 WLAN IOT Geräte mit fixer IP und einen zusätzlichen WLAN Accesspoint.
                      Dass ein Shelly mal nicht erreichbar ist sollte nicht zum Absturz des Adapters führen. Zumindest suggeriert das ja die Fehlermeldung.
                      2023-03-21 06:05:03.095 - error: shelly.0 (866) uncaught exception: send ENETUNREACH 192.168.0.66:5683
                      2023-03-21 06:05:03.101 - error: shelly.0 (866) Error: send ENETUNREACH 192.168.0.66:5683
                      2023-03-21 06:05:03.102 - error: shelly.0 (866) Exception-Code: ENETUNREACH: send ENETUNREACH 192.168.0.66:5683
                      2023-03-21 06:05:03.130 - info: shelly.0 (866) terminating
                      2023-03-21 06:05:03.132 - warn: shelly.0 (866) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-03-21 06:05:03.266 - error: host.iobroker-pi Caught by controller[0]: Error: send ENETUNREACH 192.168.0.66:5683
                      2023-03-21 06:05:03.273 - error: host.iobroker-pi Caught by controller[0]: at doSend (dgram.js:714:16)
                      2023-03-21 06:05:03.274 - error: host.iobroker-pi Caught by controller[0]: at defaultTriggerAsyncIdScope (internal/async_hooks.js:452:18)
                      2023-03-21 06:05:03.274 - error: host.iobroker-pi Caught by controller[0]: at afterDns (dgram.js:660:5)
                      2023-03-21 06:05:03.275 - error: host.iobroker-pi Caught by controller[0]: at processTicksAndRejections (internal/process/task_queues.js:83:21)
                      2023-03-21 06:05:03.276 - error: host.iobroker-pi instance system.adapter.shelly.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      2023-03-21 06:05:03.276 - info: host.iobroker-pi Restart adapter system.adapter.shelly.0 because enabled
                      2023-03-21 06:05:04.431 - info: host.iobroker-pi instance system.adapter.shelly.0 started with pid 26157
                      2023-03-21 06:05:06.682 - info: shelly.0 (26157) starting. Version 6.3.1 in /opt/iobroker/node_modules/iobroker.shelly, node: v14.19.2, js-controller: 4.0.24
                      2023-03-21 06:05:07.363 - info: shelly.0 (26157) [firmwareUpdate] Auto-Update enabled - devices will be updated automatically
                      2023-03-21 06:05:07.365 - info: shelly.0 (26157) Starting in CoAP mode. Listening on 0.0.0.0:5683
                      2023-03-21 06:05:07.455 - info: shelly.0 (26157) [CoAP Server] Listening for packets in the network
                      [s=]
                      [/s]
                      • R rockflopp
                        [s=]
                        [/s]
                        da_WoodyD Online
                        da_WoodyD Online
                        @rockflopp ich bin sicher kein profi, arbeite aber seit 2019 fast ausschließlich mit shelly.
                        selbst bei problemen ist mir der shelly adapter nie abgestüzt. sind halt teilweise keine daten in die objekte gekommen.
                        siehe postings meinereiner über IGMP und mcast und unicast.
                        edith: zuwu bugreport? IMHO gibts da keine bugs, sondern probs in euren netzwerken.
                        @haus-automatisierung hat da alles soweit umgebaut, daß das alles funktioniert. tuts ja auch bei bei so gut wie allen usern.
                        keine ahnung, wieviele den adapter mit ioB verwenden. seltsam halt, wenn ein paar leute probleme haben.
                          rockflopp
                          @da_woody kannst du mir einen Tipp geben nach was ich in meinem Netzwerk Ausschau halten soll? Die iOT Geräte gehen entweder direkt per wlan auf den Vodafone Router oder indirekt über einen Access Point der mit Lan mit dem Router verbunden ist. Die Einstellmöglichkeiten beim Vodafone Router sind begrenzt von daher bin ich für nächste Schritte bei der Problembehebung dankbar. Der Adapter stürzt nun wieder häufiger ab… :-(
                          • R rockflopp
                            da_WoodyD Online
                            da_WoodyD Online
                            @rockflopp ist mit den "kastrierten" vodafone dingens schwer. ich kenn die dinger nicht, hab aber immer wieder über probleme gelesen.
                            darum ist bei mir die fritzbox rausgeflogen. da konnte ich, laut support beim provider, den routerteil nicht deaktivieren.
                            angeblich war das aus rechtlichen gründen für österreich von avm nicht freigegeben.
                            ich hab aber ein synology netzwerk mit router und einigen APs dahinter. 2 router hintereinander vertragen sich nicht.
                            hab dann vom provider eine andere box bekommen von technicolor, dort konnte ich umschalten auf reinen modembetrieb.
