  4. js-controller 4.0.24 Update (Stable)
    5.4k
108 Beiträge 36 Kommentatoren 24.9k Aufrufe 34 Beobachtet
  • S saeft_2003
    Seit dem update von 4.0.23 auf 4.0.24 bekomme ich jede Nacht um 0:01 diese Error vom worx Adapter.
    Wisst ihr warum?
    host.iobroker
    	2023-01-20 00:01:00.787	error	instance system.adapter.worx.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at processImmediate (node:internal/timers:466:21)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5919:53)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.emit (node:domain:489:12)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.emit (node:events:513:28)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.onStateChange (/opt/iobroker/node_modules/iobroker.worx/main.js:967:26)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: at Worx.changeMowerCfg (/opt/iobroker/node_modules/iobroker.worx/main.js:1305:32)
    host.iobroker
    	2023-01-20 00:01:00.787	error	Caught by controller[1]: TypeError: Cannot read properties of null (reading 'payload')
    host.iobroker
    	2023-01-20 00:01:00.786	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    worx.0
    	2023-01-20 00:01:00.178	error	Cannot read properties of null (reading 'payload')
    worx.0
    	2023-01-20 00:01:00.178	error	TypeError: Cannot read properties of null (reading 'payload') at Worx.changeMowerCfg (/opt/iobroker/node_modules/iobroker.worx/main.js:1305:32) at Worx.onStateChange (/opt/iobroker/node_modules/iobroker.worx/main.js:967:26) at Worx.emit (node:events:513:28) at Worx.emit (node:domain:489:12) at Immediate.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5919:53) at processImmediate (node:internal/timers:466:21)
    worx.0
    	2023-01-20 00:01:00.071	error	unhandled promise rejection: Cannot read properties of null (reading 'payload')
    worx.0
    	2023-01-20 00:01:00.064	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    #87
    @saeft_2003 Dann berichte das bitte beim Worx adapter. Hat mit dem js-controller nichts zu tun
      tcfigge
      schrieb am zuletzt editiert von tcfigge
      #88
      Hat sicher erledigt..... Oder wie löscht man Postings? 😬
      • T tcfigge
        DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        #89
        @tcfigge sagte in js-controller 4.0.24 Update (Stable):
        Am besten eigentlich gar nicht !
        Jetzt hast Du Deine Problemschilderung gelöscht und schreibst dann
        Hat sicher erledigt
        Damit hilfst Du anderen Hilfesuchenden ja mal überhaupt nicht.
        Lehrling seit 1975 !!!
        • DJMarc75D DJMarc75
          Hat sicher erledigt
          tcfigge
          #90
          Da gebe ich Dir grundsätzlich Recht!
          Wenn das Controller Update aber nach 10 Versuchen plötzlich klappt, und ich nicht sagen kann warum, hilft das auch keinem.... :man-shrugging: 😉
          • T tcfigge
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #91
            dann schreibt man sowas in einen neuen Beitrag und vielleicht kann dann erörtert werden warum es 9 mal nicht funktioniert hatte. Beiträge löschen oder bearbeiten ist immer die denkbar schlechteste Lösung - weil dann keine Lösung gefunden werden kann - und wenn bei Dir das Problem wieder besteht machst Du definitiv wieder einen Beitrag !
              Baumasta
              #92
              Hallo Leute!
              Ich führe genau lt. Anleitung folgende aus:
              •	iobroker stop
              •	iobroker update
              •	iobroker fix
              •	iobroker upgrade self
              •	iobroker start
              Fix läuft und bei upgrade self schreibt er auch brav:
              root@IOBroker:/opt/iobroker# iobroker upgrade self
              sudo: Hostname IOBroker kann nicht aufgelöst werden
              Update js-controller from @4.0.23 to @4.0.24
              Stopped Objects DB
              Stopped States DB
              NPM version: 8.19.3
              Installing iobroker.js-controller@4.0.24... (System call)
              Aber am Ende habe ich immer wieder die Version 4.0.23
              Thomas BraunT apollon77A 2 Antworten Letzte Antwort
              • B Baumasta
                Hallo Leute!
                •	iobroker stop
                •	iobroker update
                •	iobroker fix
                •	iobroker start
                Stopped Objects DB
                Stopped States DB
                NPM version: 8.19.3
                #93
                @baumasta
                Wie immer...
                Wir hampeln nicht als root herum...
                iob diag
                sagt zu dem ganzen Spiel?
                Das ist doch wieder was eingedostes da, oder?
                • B Baumasta
                  Hallo Leute!
                  •	iobroker stop
                  •	iobroker update
                  •	iobroker fix
                  •	iobroker start
                  Stopped Objects DB
                  Stopped States DB
                  NPM version: 8.19.3
                  #94
                  @baumasta bitte das kommando mal mit --debug aufrufen. Was ist dann die Ausgabe?
                    @baumasta
                    Wie immer...
                    iob diag
                    Baumasta
                    #95
                                         v.2023-01-02
                    Operatingsystem:        Debian GNU/Linux 9.13 (stretch)
                    Installation:
                    Timezone:               Etc/UTC
                    User-ID:                0
                    X-Server:               false
                    /home/iobroker/.diag.sh: line 235: systemctl: command not found
                    Boot Target:
                    Pending OS-Updates:     0
                    Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                                            /usr/bin/node           v16.19.1
                                            /usr/bin/npm            8.19.3
                                            /usr/bin/npx            8.19.3
                    ioBroker Core:          js-controller           4.0.23
                                            admin                   6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Status admin:
                    + system.adapter.admin.0                  : admin                 : IOBroker                                 -
                     enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    Pending iob updates:    1
                    Active repo(s): stable
                    Objects:                2187
                    States:                 1864
                    Size of iob-Database:
                    34M     /opt/iobroker/iobroker-data/objects.jsonl
                    4.0M    /opt/iobroker/iobroker-data/objects.json.migrated
                    4.0M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                    6.8M    /opt/iobroker/iobroker-data/states.jsonl
                    536K    /opt/iobroker/iobroker-data/states.json.migrated
                    536K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                    • B Baumasta
                                           v.2023-01-02
                      Installation:
                      Timezone:               Etc/UTC
                      User-ID:                0
                      X-Server:               false
                      Boot Target:
                                              /usr/bin/npm            8.19.3
                                              /usr/bin/npx            8.19.3
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Status admin:
                      Objects:                2187
                      States:                 1864
                      #96
                      @baumasta
                      Stretch ist schon mehrere Jahre tot.
                      Installier da was lebendiges.
                      Und setz dann das neue System in die richtige Zeitzone
                        @baumasta
                        Baumasta
                        #97
                        Ich bin leider IT mäßig nicht so gut drauf.
                        Was soll ich machen?
                        Wenn ich hier Sachen ausführe dann ohne es zu verstehen nur weil es irgendwer schreibt :-(
                        • B Baumasta
                          #98
                          @baumasta
                          Installier das Betriebssystem neu. Ist dann vermutlich der schnellste Weg zu einem aktuellen System zu kommen.
                          • B Baumasta
                            #99
                            @baumasta Ja was Thomas sagt ist korrekt ... aber ob Du das zur initialen Lösung des problems brauchst bezweifle ich eher. hast DU mal das gemacht was ich oben gefragt hab?
                            • apollon77A apollon77
                              toki1973
                              #100
                              Was bedeutet diese Meldung?
                              root@iobrokerNUC1:~# iobroker upgrade self
                              Stopped Objects DB
                              Stopped States DB
                              NPM version: 9.5.0
                              added 8 packages, removed 153 packages, and changed 28 packages in 4m
                              208 packages are looking for funding
                                run `npm fund` for details
                              NUC, PROXMOX, Grafana, Influx, Unify
                              CodierknechtC Thomas BraunT 2 Antworten Letzte Antwort
                              • T toki1973
                                Stopped Objects DB
                                Stopped States DB
                                NPM version: 9.5.0
                                CodierknechtC Offline
                                Codierknecht
                                #101
                                @toki1973
                                Welche? npm fund? Das ist Werbung um Spenden einzusammeln.
                                Du solltest im ioBroker nicht als root rumfummeln.
                                HmIP|ZigBee|Tasmota|Unifi
                                Zabbix Certified Specialist
                                • T toki1973
                                  Stopped Objects DB
                                  Stopped States DB
                                  NPM version: 9.5.0
                                  #102
                                  @toki1973 sagte in js-controller 4.0.24 Update (Stable):
                                  Das bedeutet, dass du den js-controller nun mit den falschen Rechten installiert hast.
                                  User anlegen, als root abmelden,
                                  iob fix
                                  ausführen, nicht mehr als root anmelden.
                                    iob fix
                                    toki1973
                                    #103
                                    Haben nun einen neuen User eingerichtet iobroker gestoppt und wollte dann iob fix ausführen. Irgendwie hat er nicht genug Rechte
                                    Leider darf der Benutzer iobrokernuc »/usr/bin/apt-get update« als root auf iobrokerNUC1 nicht ausführen.
                                    [sudo] Passwort für iobrokernuc:
                                    • T toki1973
                                      #104
                                      @toki1973
                                      groups
                                      als dieser User sagt?
                                      Vermutlich ist der noch nicht in den passenden Gruppen drin. Wäre 'adm', 'sudo' und 'iobroker' im Wesentlichen.
                                      Zur Orientierung mein Haupt-User auf einem Raspberry OS/Debian:
                                      echad@chet:~ $ groups
                                      echad adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                      echad@chet:~ $
                                      Nachdem die Gruppen hinzugefügt wurden einmal aus- und wieder einloggen.
                                        @toki1973
                                        groups
                                        echad@chet:~ $
                                        toki1973
                                        #105
                                        @thomas-braun said in js-controller 4.0.24 Update (Stable):
                                        @toki1973
                                        groups
                                        root@iobrokerNUC1:~# groups
                                        root
                                        $ groups
                                        iobrokernuc
                                        • T toki1973
                                          @toki1973
                                          groups
                                          root
                                          $ groups
                                          iobrokernuc
                                          #106
                                          @toki1973
                                          Ja, wie vermutet, bei dem Standarduser fehlen entsprechende Gruppenzugehörigkeiten.
                                          Musst du dem noch mitgeben.
                                          usermod -aG gruppe benutzername
                                          Wenn alle Gruppen eingerichtet sind
                                          exit
