  3. Einsteigerfragen
  4. Erstinstallation Ip Adresse nicht gefunden
    5.5k
111 Beiträge 5 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • DJMarc75D DJMarc75
    @pmther zeig nochmal die Ausgabe von
    iob diag
    bitte...
    Tippe drauf dass da jetzt schon kein Speicher mehr verfügbar ist.
    pmther
    #93
    @djmarc75
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model		: Raspberry Pi 3 Model A Plus Rev 1.0
    Architecture: 	aarch64
    Docker: 	false
    Virtualization: none
    Distributor ID:	Debian
    Description:	Debian GNU/Linux 11 (bullseye)
    Release:	11
    Codename:	bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:10:22 up  1:12,  1 user,  load average: 0.16, 0.22, 0.89
    CPU threads: 4
    *** Time and Time Zones ***
    Thu Mar 16 20:10:22 UTC 2023
    Thu Mar 16 21:10:22 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    paul
    /home/paul
    paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
    *** X-Server-Setup ***
    X-Server: 	false
    Desktop:
    Terminal: 	tty
    Boot Target: 	multi-user.target
    *** MEMORY ***
    Mem:            419M        253M         93M        0.0K         72M        113M
    Swap:            99M         95M        4.0M
    Total:          519M        348M         97M
              419 M total memory
              253 M used memory
               75 M active memory
              183 M inactive memory
               93 M free memory
                5 M buffer memory
               67 M swap cache
               99 M total swap
               95 M used swap
                4 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  2.2G   26G   8% /
    devtmpfs       devtmpfs   80M     0   80M   0% /dev
    tmpfs          tmpfs     210M     0  210M   0% /dev/shm
    tmpfs          tmpfs      84M 1020K   83M   2% /run
    /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
    tmpfs          tmpfs      42M     0   42M   0% /run/user/1000
    Messages in dmesg:
    [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    481M	/var/
    178M	/var/cache
    172M	/var/cache/apt
    147M	/var/lib
    122M	/var/lib/apt/lists
    /opt/iobroker/backups:
    4.0K	/opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    18M	/opt/iobroker/iobroker-data/
    15M	/opt/iobroker/iobroker-data/files
    13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    3.2M	/opt/iobroker/iobroker-data/objects.jsonl
    2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs 	v16.19.1
    /usr/bin/node 		v16.19.1
    /usr/bin/npm 		8.19.3
    /usr/bin/npx 		8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller: 	4.0.24
    admin: 		6.3.5
    javascript: 	"javascript" not found
    Adapters from github: 	0
    Adapter State
    + system.adapter.admin.0                  : admin                 : paul                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : paul                                     -  enabled
    + system.adapter.discovery.0              : discovery             : paul                                     -  enabled
    + system.adapter.hue.0                    : hue                   : paul                                     -  enabled, port: 443
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Objects and States
    Objects: 	164
    States: 	122
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30946      6898/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30939      6898/iobroker.js-co
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12810      483/sshd: /usr/sbin
    tcp6       0      0 :::22                   :::*                    LISTEN      0          12821      483/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41198      9258/io.admin.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12111      654/dhcpcd
    udp        0      0 0.0.0.0:58815           0.0.0.0:*                           108        9723       361/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9721       361/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          9776       654/dhcpcd
    udp6       0      0 :::55504                :::*                                108        9724       361/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        9722       361/avahi-daemon: r
    2023-03-16 20:59:37.383  - info: host.paul iobroker host.paul object system.adapter.hue.0.memHeapTotal created
    2023-03-16 20:59:37.404  - info: host.paul iobroker host.paul object system.adapter.hue.0.memRss created
    2023-03-16 20:59:37.423  - info: host.paul iobroker host.paul object system.adapter.hue.0.uptime created
    2023-03-16 20:59:37.444  - info: host.paul iobroker host.paul object system.adapter.hue.0.inputCount created
    2023-03-16 20:59:37.474  - info: host.paul iobroker host.paul object system.adapter.hue.0.outputCount created
    2023-03-16 20:59:37.492  - info: host.paul iobroker host.paul object system.adapter.hue.0.eventLoopLag created
    2023-03-16 20:59:37.523  - info: host.paul iobroker host.paul object system.adapter.hue.0.sigKill created
    2023-03-16 20:59:37.538  - info: host.paul iobroker host.paul object system.adapter.hue.0.logLevel created
    2023-03-16 20:59:37.551  - info: host.paul iobroker host.paul object hue.0.info created
    2023-03-16 20:59:37.565  - info: host.paul iobroker host.paul object hue.0.info.connection created
    2023-03-16 20:59:37.586  - info: host.paul iobroker host.paul Set default value of hue.0.info.connection: false
    2023-03-16 20:59:37.620  - info: host.paul iobroker host.paul object system.adapter.hue.0 created
    2023-03-16 20:59:37.949  - info: backitup.0 (9434) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
    2023-03-16 20:59:38.183  - info: backitup.0 (9434) [iobroker] backup was activated at 02:40 every 1 day(s)
    2023-03-16 20:59:38.778  - info: host.paul iobroker exit 0
    2023-03-16 20:59:40.678  - info: host.paul instance system.adapter.hue.0 started with pid 9457
    2023-03-16 20:59:40.852  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-03-16 20:59:44.837  - info: hue.0 (9457) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.1, js-controller: 4.0.24
    2023-03-16 20:59:44.897  - warn: hue.0 (9457) No bridge configured yet - please configure the adapter first
    2023-03-16 21:01:20.805  - error: hue.0 (9457) Error on browsing via NUPNP: Problems resolving hue bridges, Request failed with status code 429
    2023-03-16 21:01:26.662  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31
    2023-03-16 21:02:05.344  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
    2023-03-16 21:02:05.919  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
    2023-03-16 21:12:39.742  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
    2023-03-16 21:12:40.568  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
      iob diag
      bitte...
      pmther
      #94
      @djmarc75
      Habe gerade schon nach einem vierer geschaut. Meinst du, die 2gb Variante reicht oder ist das wieder nichts halbes und nichts ganzes?
      wendy2702W DJMarc75D 2 Antworten Letzte Antwort
      • P pmther
        @djmarc75
        wendy2702W Offline
        wendy2702W Offline
        #95
        @pmther Nichts halbes und nichts ganzes.
        Meine Meinung.
        P 1 Antwort Letzte Antwort
        • wendy2702W wendy2702
          Meine Meinung.
          pmther
          #96
          @wendy2702 okay, also gleich den 8er?
          • P pmther
            @djmarc75
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            #97
            @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
            Ich hab mal nen 2GB als Prodsystem genutzt - nach paar Wochen dann aber nen 8GB geholt mit dem ich mehr als zufrieden bin.
            Bedenke:
            Die Ansprüche wachsen mit der Zeit und dann sind 2GB eigentlich NIX ;)
            Lehrling seit 1975 !!!
              Bedenke:
              pmther
              #98
              @djmarc75 ja gut das stimmt natürlich. dann werde ich mir wohl einen 8 gb holen. Ist bei meinem jetzt das Problem der Arbeitsspeicher?
              • P pmther
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                #99
                Kurz und knapp: ja, wie am Anfang schon geschrieben ;)
                  pmther
                  #100
                  @djmarc75 okay, das heißt, dass ich mit dem rein gar nichts anfangen kann im Moment?
                  • P pmther
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    #101
                    naja, vll bissle üben was Linux angeht 😀
                      pmther
                      #102
                      @djmarc75 nagut okay, dann danke trotzdem für die ganze Hilfe. Ich werde dann mal schauen ob ich ihn verkauft kriege...
                      • P pmther
                        ja das mache ich beim nächsten mal.. danke.
                        jetzt zeigt der Biobroker mir langsame Verbindung an. Laut fritzbox wird er aber mit 390 mbit/s gespeist.. muss ich da noch etwas umstellen?
                        #103
                        Das bezieht sich auf den Speicher. Der Kleine ist schwer am kämpfen.
                          pmther
                          #104
                          @thomas-braun Ja, habe grad auch eine Meldung bekommen, dass nur 86 mb Arbeitsspeicher verfügbar sind.
                          • P pmther
                            #105
                            @pmther
                            Ja, mit 512 MB kannste halt ein paar Trockenübungen machen. Mit viel Geduld...
                              @pmther
                              pmther
                              #106
                              Die Visualisierung kann ich doch aber schonmal anfangen oder läuft das nur mit den entsprechenden Adaptern?
                              Worüber macht man die Visualisierung dann?
                              • P pmther
                                #107
                                Mit dem schmalen RAM ist da nix gescheites mit Vis. Der ist schon etwas hungriger.
                                  pmther
                                  #108
                                  Moin, ich habe nun den neuen Raspberry mit 8 GB RAM. Gestern habe ich mich dann mal an der Visualisierung versucht. Immer wenn ich die „fertige“ visualisierung aufrufe kommt ein Lizenzfehler.. Im Forum hab ich gelesen, dass es hilft eine ältere Version runterzuladen. Bei mir leider nicht.
                                  Könnt ihr mir da vielleicht helfen?
                                  lg
                                  Paul
                                  • P pmther
                                    lg
                                    Paul
                                    #109
                                    Off Topic.
                                    Neuen Thread und dann dort die genaue Fehlermeldung aus dem Logfile in Textform rein.
                                      @pmther
                                      Konfiguration
                                      VIS benötigt den WEB Adapter, dieser wird bei der Installation von VIS automatisch mit installiert. Bis auf die Eingabe der Lizenz, die unter https://iobroker.net/ zu beziehen ist, ist keine weitere Konfiguration notwendig. Bei privater Nutzung ist diese Lizenz kostenlos.
                                      Es kann nur eine VIS Instanz geben.
                                      #110
                                      @wendy2702
                                      Bitte hier antworten:
                                      https://forum.iobroker.net/topic/64097/visualisierung-lizenzfehler
                                        @wendy2702
                                        wendy2702W Offline
                                        wendy2702W Offline
                                        #111
                                        @thomas-braun Oh, nicht gesehen das es einen neuen Fred gibt.
                                        ich verschiebe
