  3. Einsteigerfragen
  4. Erstinstallation Ip Adresse nicht gefunden
    5.5k
111 Beiträge 5 Kommentatoren 12.0k Aufrufe 5 Beobachtet
  • P pmther
    @pmther iobroker natürlich..
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    #92
    @pmther zeig nochmal die Ausgabe von
    iob diag
    bitte...
    Tippe drauf dass da jetzt schon kein Speicher mehr verfügbar ist.
    Lehrling seit 1975 !!!
    P 2 Antworten Letzte Antwort
    • DJMarc75D DJMarc75
      iob diag
      bitte...
      pmther
      #93
      @djmarc75
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 3 Model A Plus Rev 1.0
      Architecture: 	aarch64
      Docker: 	false
      Virtualization: none
      Distributor ID:	Debian
      Description:	Debian GNU/Linux 11 (bullseye)
      Release:	11
      Codename:	bullseye
      PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
      NAME="Debian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=debian
      HOME_URL="https://www.debian.org/"
      SUPPORT_URL="https://www.debian.org/support"
      BUG_REPORT_URL="https://bugs.debian.org/"
      Systemuptime and Load:
       21:10:22 up  1:12,  1 user,  load average: 0.16, 0.22, 0.89
      CPU threads: 4
      *** Time and Time Zones ***
      Thu Mar 16 20:10:22 UTC 2023
      Thu Mar 16 21:10:22 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      paul
      /home/paul
      paul adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi
      *** X-Server-Setup ***
      X-Server: 	false
      Desktop:
      Terminal: 	tty
      Boot Target: 	multi-user.target
      *** MEMORY ***
      Mem:            419M        253M         93M        0.0K         72M        113M
      Swap:            99M         95M        4.0M
      Total:          519M        348M         97M
                419 M total memory
                253 M used memory
                 75 M active memory
                183 M inactive memory
                 93 M free memory
                  5 M buffer memory
                 67 M swap cache
                 99 M total swap
                 95 M used swap
                  4 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4       29G  2.2G   26G   8% /
      devtmpfs       devtmpfs   80M     0   80M   0% /dev
      tmpfs          tmpfs     210M     0  210M   0% /dev/shm
      tmpfs          tmpfs      84M 1020K   83M   2% /run
      /dev/mmcblk0p1 vfat      255M   32M  224M  13% /boot
      tmpfs          tmpfs      42M     0   42M   0% /run/user/1000
      Messages in dmesg:
      [Thu Mar 16 19:57:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c4a98718-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu Mar 16 19:57:27 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Thu Mar 16 19:57:27 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Thu Mar 16 19:57:31 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: commit=600. Quota mode: none.
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime,commit=600
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      481M	/var/
      178M	/var/cache
      172M	/var/cache/apt
      147M	/var/lib
      122M	/var/lib/apt/lists
      /opt/iobroker/backups:
      4.0K	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      18M	/opt/iobroker/iobroker-data/
      15M	/opt/iobroker/iobroker-data/files
      13M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
      6.3M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
      3.2M	/opt/iobroker/iobroker-data/objects.jsonl
      2.8M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
      1.6M	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
      652K	/opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v16.19.1
      /usr/bin/node 		v16.19.1
      /usr/bin/npm 		8.19.3
      /usr/bin/npx 		8.19.3
      nodejs:
        Installed: 16.19.1-deb-1nodesource1
        Candidate: 16.19.1-deb-1nodesource1
        Version table:
       *** 16.19.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.24
      admin: 		6.3.5
      javascript: 	"javascript" not found
      Adapters from github: 	0
      Adapter State
      + system.adapter.admin.0                  : admin                 : paul                                     -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : paul                                     -  enabled
      + system.adapter.discovery.0              : discovery             : paul                                     -  enabled
      + system.adapter.hue.0                    : hue                   : paul                                     -  enabled, port: 443
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "backitup"     : 2.5.12   , installed 2.5.12
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Objects and States
      Objects: 	164
      States: 	122
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       30946      6898/iobroker.js-co
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       30939      6898/iobroker.js-co
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12810      483/sshd: /usr/sbin
      tcp6       0      0 :::22                   :::*                    LISTEN      0          12821      483/sshd: /usr/sbin
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       41198      9258/io.admin.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12111      654/dhcpcd
      udp        0      0 0.0.0.0:58815           0.0.0.0:*                           108        9723       361/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9721       361/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          9776       654/dhcpcd
      udp6       0      0 :::55504                :::*                                108        9724       361/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                108        9722       361/avahi-daemon: r
      2023-03-16 20:59:37.383  - info: host.paul iobroker host.paul object system.adapter.hue.0.memHeapTotal created
      2023-03-16 20:59:37.404  - info: host.paul iobroker host.paul object system.adapter.hue.0.memRss created
      2023-03-16 20:59:37.423  - info: host.paul iobroker host.paul object system.adapter.hue.0.uptime created
      2023-03-16 20:59:37.444  - info: host.paul iobroker host.paul object system.adapter.hue.0.inputCount created
      2023-03-16 20:59:37.474  - info: host.paul iobroker host.paul object system.adapter.hue.0.outputCount created
      2023-03-16 20:59:37.492  - info: host.paul iobroker host.paul object system.adapter.hue.0.eventLoopLag created
      2023-03-16 20:59:37.523  - info: host.paul iobroker host.paul object system.adapter.hue.0.sigKill created
      2023-03-16 20:59:37.538  - info: host.paul iobroker host.paul object system.adapter.hue.0.logLevel created
      2023-03-16 20:59:37.551  - info: host.paul iobroker host.paul object hue.0.info created
      2023-03-16 20:59:37.565  - info: host.paul iobroker host.paul object hue.0.info.connection created
      2023-03-16 20:59:37.586  - info: host.paul iobroker host.paul Set default value of hue.0.info.connection: false
      2023-03-16 20:59:37.620  - info: host.paul iobroker host.paul object system.adapter.hue.0 created
      2023-03-16 20:59:37.949  - info: backitup.0 (9434) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
      2023-03-16 20:59:38.183  - info: backitup.0 (9434) [iobroker] backup was activated at 02:40 every 1 day(s)
      2023-03-16 20:59:38.778  - info: host.paul iobroker exit 0
      2023-03-16 20:59:40.678  - info: host.paul instance system.adapter.hue.0 started with pid 9457
      2023-03-16 20:59:40.852  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-03-16 20:59:44.837  - info: hue.0 (9457) starting. Version 3.7.1 in /opt/iobroker/node_modules/iobroker.hue, node: v16.19.1, js-controller: 4.0.24
      2023-03-16 20:59:44.897  - warn: hue.0 (9457) No bridge configured yet - please configure the adapter first
      2023-03-16 21:01:20.805  - error: hue.0 (9457) Error on browsing via NUPNP: Problems resolving hue bridges, Request failed with status code 429
      2023-03-16 21:01:26.662  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31
      2023-03-16 21:02:05.344  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
      2023-03-16 21:02:05.919  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
      2023-03-16 21:12:39.742  - info: admin.0 (9258) <== Disconnect system.user.admin from ::ffff:192.168.178.31 admin
      2023-03-16 21:12:40.568  - info: admin.0 (9258) ==> Connected system.user.admin from ::ffff:192.168.178.31
        iob diag
        bitte...
        pmther
        #94
        @djmarc75
        Habe gerade schon nach einem vierer geschaut. Meinst du, die 2gb Variante reicht oder ist das wieder nichts halbes und nichts ganzes?
        wendy2702W DJMarc75D 2 Antworten Letzte Antwort
        • P pmther
          @djmarc75
          wendy2702W Offline
          wendy2702W Offline
          #95
          @pmther Nichts halbes und nichts ganzes.
          Meine Meinung.
          P 1 Antwort Letzte Antwort
          • wendy2702W wendy2702
            Meine Meinung.
            pmther
            #96
            @wendy2702 okay, also gleich den 8er?
            • P pmther
              @djmarc75
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              #97
              @pmther sagte in Erstinstallation Ip Adresse nicht gefunden:
              Ich hab mal nen 2GB als Prodsystem genutzt - nach paar Wochen dann aber nen 8GB geholt mit dem ich mehr als zufrieden bin.
              Bedenke:
              Die Ansprüche wachsen mit der Zeit und dann sind 2GB eigentlich NIX ;)
                Bedenke:
                pmther
                #98
                @djmarc75 ja gut das stimmt natürlich. dann werde ich mir wohl einen 8 gb holen. Ist bei meinem jetzt das Problem der Arbeitsspeicher?
                • P pmther
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  #99
                  Kurz und knapp: ja, wie am Anfang schon geschrieben ;)
                    pmther
                    #100
                    @djmarc75 okay, das heißt, dass ich mit dem rein gar nichts anfangen kann im Moment?
                    • P pmther
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      #101
                      naja, vll bissle üben was Linux angeht 😀
                        pmther
                        #102
                        @djmarc75 nagut okay, dann danke trotzdem für die ganze Hilfe. Ich werde dann mal schauen ob ich ihn verkauft kriege...
                        • P pmther
                          ja das mache ich beim nächsten mal.. danke.
                          jetzt zeigt der Biobroker mir langsame Verbindung an. Laut fritzbox wird er aber mit 390 mbit/s gespeist.. muss ich da noch etwas umstellen?
                          #103
                          Das bezieht sich auf den Speicher. Der Kleine ist schwer am kämpfen.
                            pmther
                            #104
                            @thomas-braun Ja, habe grad auch eine Meldung bekommen, dass nur 86 mb Arbeitsspeicher verfügbar sind.
                            • P pmther
                              #105
                              @pmther
                              Ja, mit 512 MB kannste halt ein paar Trockenübungen machen. Mit viel Geduld...
                                @pmther
                                pmther
                                #106
                                Die Visualisierung kann ich doch aber schonmal anfangen oder läuft das nur mit den entsprechenden Adaptern?
                                Worüber macht man die Visualisierung dann?
                                • P pmther
                                  #107
                                  Mit dem schmalen RAM ist da nix gescheites mit Vis. Der ist schon etwas hungriger.
                                    pmther
                                    #108
                                    Moin, ich habe nun den neuen Raspberry mit 8 GB RAM. Gestern habe ich mich dann mal an der Visualisierung versucht. Immer wenn ich die „fertige“ visualisierung aufrufe kommt ein Lizenzfehler.. Im Forum hab ich gelesen, dass es hilft eine ältere Version runterzuladen. Bei mir leider nicht.
                                    Könnt ihr mir da vielleicht helfen?
                                    lg
                                    Paul
                                    • P pmther
                                      lg
                                      Paul
                                      #109
                                      Off Topic.
                                      Neuen Thread und dann dort die genaue Fehlermeldung aus dem Logfile in Textform rein.
                                        @pmther
                                        Konfiguration
                                        VIS benötigt den WEB Adapter, dieser wird bei der Installation von VIS automatisch mit installiert. Bis auf die Eingabe der Lizenz, die unter https://iobroker.net/ zu beziehen ist, ist keine weitere Konfiguration notwendig. Bei privater Nutzung ist diese Lizenz kostenlos.
                                        Es kann nur eine VIS Instanz geben.
                                        #110
                                        @wendy2702
                                        Bitte hier antworten:
                                        https://forum.iobroker.net/topic/64097/visualisierung-lizenzfehler
                                          @wendy2702
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          #111
                                          @thomas-braun Oh, nicht gesehen das es einen neuen Fred gibt.
                                          ich verschiebe
