  3. Off Topic
  4. Microcontroller
  5. Tasmota ESPHome Presence Sensor LD2410
Geplant Angeheftet Gesperrt Verschoben Microcontroller
187 Beiträge 17 Kommentatoren 58.8k Aufrufe 18 Beobachtet
  • liv-in-skyL Offline
    liv-in-skyL Offline
    hier noch ein yaml für einen wemos D1 mini mit esphome - zeile 53 ff und 172 sind die pins definiert
    • die pins zum anschliessen sind im yaml zu lesen
    • die zusatzdatei https://forum.iobroker.net/post/957138 muss auch im system sein
    esphome:
     includes:
       - uart_read_line_sensor_ld2410v3.h
     on_boot:
        priority: -100
        then:
         - script.execute: get_config
    esp8266:
         board: esp01_1m
    # Enable logging
    logger:
     baud_rate: 0
     logs:
       sensor: INFO # DEBUG level with uart_target_output = overload!
       binary_sensor: INFO
       text_sensor: INFO
    # Enable Home Assistant API
    api:
    ota:
    wifi:
     ssid: "yyyyyyyyy1"
     password: "xxxxxxxxxxxxxx2"
     use_address: 192.168.178.67
    substitutions:
     device_name: dev-sensor
    mqtt:
     broker: 192.168.178.59
     port: 1506
     topic_prefix: ld2410motion/motion3
    web_server:
     port: 80
     version: 2
     include_internal: true
     ota: false
    captive_portal:
    uart:
     tx_pin:
       number: GPIO1
     rx_pin:
       number: GPIO3
     baud_rate: 256000
     parity: NONE
     stop_bits: 1
    switch:
     - platform: safe_mode
     - platform: template
       optimistic: true
       # assumed_state: false
       turn_on_action:
         # - switch.turn_off: engineering_mode
         - lambda: 'static_cast<LD2410 *>(ld2410)->setConfigMode(true);'
         - delay: 100ms
         - script.execute: clear_targets
       turn_off_action:
         - lambda: 'static_cast<LD2410 *>(ld2410)->setConfigMode(false);'
       optimistic: true
       internal: true
       turn_off_action:
    text_sensor:
       icon: mdi:clock-start
       update_interval: 60s
    sensor:
     - platform: uptime
       internal: true
       on_raw_value:
         then:
           - text_sensor.template.publish:
               state: !lambda |-
                         int seconds = round(id(uptime_sensor).raw_state);
                         int days = seconds / (24 * 3600);
                         seconds = seconds % (24 * 3600);
                         int hours = seconds / 3600;
                         seconds = seconds % 3600;
                         int minutes = seconds /  60;
                         seconds = seconds % 60;
                         return (
                           (days ? to_string(days)+":" : "00:") +
                           (hours ? to_string(hours)+":" : "00:") +
                           (minutes ? to_string(minutes)+":" : "00:") +
                           (to_string(seconds))
                         ).c_str();
     - platform: custom # currently crashes ESP32
       lambda: |-
         auto uart_component = static_cast<LD2410 *>(ld2410);
         //return {uart_component->movingTargetDistance,uart_component->movingTargetEnergy,uart_component->stillTargetDistance,uart_component->stillTargetEnergy,uart_component->detectDistance};
         return {};
       sensors:
       unit_of_measurement: "cm"
       accuracy_decimals: 0
       internal: true
       unit_of_measurement: "%"
       internal: true
       internal: true
       internal: true
       internal: true
    custom_component:
     - lambda: |-
         return {new LD2410(id(uart_bus))};
       components:
         - id: ld2410
    binary_sensor:
     - platform: gpio
       pin: GPIO5
       device_class: motion
       on_state:
         then:
           - if:
               condition:
                 - binary_sensor.is_off: mmwave_presence_ld2410
               then:
                 - delay: 150ms
    number:
       unit_of_measurement: "M"
       min_value: 0.75
       max_value: 6
       step: 0.75
       update_interval: never
       optimistic: true
       set_action:
         - switch.turn_on: configmode
         - delay: 50ms
         - lambda: |-
             uart_component->setMaxDistancesAndNoneDuration(x/0.75,x/0.75,id(noneDuration).state);
         - delay: 50ms
         - lambda: 'static_cast<LD2410 *>(ld2410)->queryParameters();'
         - delay: 50ms
         - switch.turn_off: configmode
       min_value: 10
       max_value: 100
       step: 5
       mode: box
       optimistic: true
       set_action:
         - delay: 50ms
         - lambda: |-
             uart_component->setAllSensitivity(x);
         - delay: 50ms
         - delay: 50ms
       min_value: 0
       # max_value: 32767
       max_value: 900
       step: 1
       mode: box
       optimistic: true
       set_action:
         - delay: 50ms
         - lambda: |-
             uart_component->setMaxDistancesAndNoneDuration(id(maxconfigDistance).state, id(maxconfigDistance).state, x);
         - delay: 50ms
         - delay: 50ms
    button:
     - platform: restart
       entity_category: diagnostic
       on_press:
         - delay: 50ms
         - lambda: 'static_cast<LD2410 *>(ld2410)->factoryReset();'
         - delay: 150ms
         - lambda: 'static_cast<LD2410 *>(ld2410)->reboot();'
         - delay: 150ms
    script:
     - id: get_config
       then:
         - delay: 500ms
         - delay: 500ms
     - id: clear_targets
       then:
         - lambda: |-
             //id(hasTarget).publish_state(0);
             //id(hasMovingTarget).publish_state(0);
             //id(hasStillTarget).publish_state(0);
             id(movingTargetDistance).publish_state(0);
             id(movingTargetEnergy).publish_state(0);
             id(stillTargetDistance).publish_state(0);
             id(stillTargetEnergy).publish_state(0);
             id(detectDistance).publish_state(0);
    ich bin kein profi mit esphome - vielleicht habe ich das ganze etwas umständlich gemacht. hier eine kurze beschreibung:
    • vorbereitendes yamls: name ändern, unter mqtt die richtigen daten eingeben
    • die stromversorgung für den sensor nicht durch den esp nehmen, sondern den esp 5V und den sensor vcc parallel an der stromversorgung anschliessen - also nicht über den mini usb port anschliessen (nur zum flashen) -
    • genutzt wird der esphome adapter
    • die zusatzdatei uart_read_line_sensor_ld2410v3.h ins system kopieren: /opt/iobroker/iobroker-data/esphome.0
    • dann ein standard esphome yaml für den esp erstellt unter: https://web.esphome.io/ und die wifi angaben machen - der esp wird dazu am usb port des pc's angeschlossen (die serielle-verbindung zwischen sensor und esp erst anschliessen, wenn das erste flashen vorbei ist - wenn noch am pc angeschlossen)
    • die ip adresse habe ich dann im yaml eingetragen - unter wifi - use address
    • der esp mit esphome wird anschliessend im adapter dashboard sichtbar - dann adapt drücken
    • im esphome-dashboard auf edit drücken und das yaml hineinkopieren - sichern - installieren - der esp wird über wifi neu geflasht
    war das erfolgreich müßte unter der ip adresse des esp eine webseite aufgehen, in der man das ganze konfigurieren kann
    dann testen, ob der esp richtige daten im mqtt ordner bringt
      liv-in-skyL Offline
      also ich muss sagen, der sensor gefällt mir
      habe einen raum sensorisch in 3 teile aufgeteilt - funktioniert gut
      • man kann sozusagen licht steuern, wenn die anwesenheit einer person in einer ecke ist
      • ist jmd in der dusche
      • das licht in einem langen flur oder einer treppe steuern
      • geht man zum fenster, wird außenlicht eingeschaltet
      wer noch ideen hat - bitte her damit
      ZarelloZ RoboCopR 2 Antworten Letzte Antwort
      • liv-in-skyL liv-in-sky
        ZarelloZ Offline
        ZarelloZ Offline
        Zarello
        schrieb am zuletzt editiert von Zarello
        Kleiner Wasserstandsbericht von mir:
        Wenn man sonst so gut wie nichts auf dem ESP8266 laufen lässt und auch die Stats nicht abholt, funktioniert der Sensor bei mir.
        Sobald ein PWM für 'ne LED nebenbei laufen soll, kommt der ESP nicht mehr hinterher. Auch Updates funktionieren dann bei mir nur noch, wenn ich den LD2410 abklemme und den Sensor über USB aktualisiere. Über WLAN kann ich das dann komplett vergessen.
        Es liegt möglicherweise auch daran, dass ich das Ganze etwas umgebaut habe, damit die maximalen Entfernungen für bewegte und bewegungslose Personen getrennt angegeben werden können und alle Sensitivitäten für die Bereiche getrennt angegeben werden können.
        Bisher sind bei einem Neustart immer die eingestellten Werte wieder zurückgesetzt. Egal wie ich es probiert habe (ob vom LD2410 beim Start auslesen oder die Werte des ESPHome wieder zum Sensor schreiben) hat es bisher nicht funktionert, dass er seine Konfiguration behalten hat.
        Da ich des öfteren Meldungen hatte, dass nicht mehr genug Speicher für eine Allokation vorhanden ist, habe ich sämtlichen dynamischen Speicherallokationen soweit wie möglich entfernt bzw. reduziert.
        @liv-in-sky : Das Setzen der Werte von aussen über MQTT funktioniert übrigens über einen anderen Topic als das auslesen. Die Topics zum Setzen der Werte haben per Default am Ende command statt state. Leider muss man die erst erzeugen lassen indem man z.B. über die Kommandozeile ein entsprechenden Topic einfach postet.
        (z.B.:mosquitto_pub -t ledtest/config/motion_hold_cmd -m 2 -- angepasst an die geänderten Topics, wie ich sie in meiner YAML verwendet habe).
        Dann muss man noch in den Objekteigenschaften im MQTT-Bereich publish auf true setzen.
        Hier erstmal meine Sourcen, wie sie zur Zeit bei mir rumliegen:
        #include "esphome.h"
        #include <iterator>
        #include <deque>
        template<class T, unsigned size_>
        class CyclicBuffer
          size_t _start {0};
          size_t _end {0};
          bool _values_dropped {false};
          std::array<T,size_> _buffer;
        public:
          class iterator : public std::iterator<std::bidirectional_iterator_tag, T>
            CyclicBuffer& _b;
            size_t _pos;
          public:
            iterator (CyclicBuffer& b, size_t pos)
            : _b (b), _pos (pos) {};
            // prefix++
            iterator& operator++ () { _pos = _pos+1; return *this; }
            iterator operator++ (int) { iterator i = *this; _pos = _pos+1; return i; }
            T& operator* () { return _b[_pos]; }
            T* operator-> () { return &(_b[_pos]); }
            bool operator== (const iterator& other) const { return _pos == other._pos; }
            bool operator!= (const iterator& other) const { return _pos != other._pos; }
          size_t size () const { return (_end + size_ - _start) % size_; }
          iterator begin () { return iterator(*this, 0);}
          iterator end () { return iterator(*this, (_end + size_ - _start) % size_);}
          T& operator[] (size_t pos) { return _buffer[(_start+pos)%size_]; }
          const T& operator[] (size_t pos) const { return _buffer[(_start+pos)%size_]; }
          void clear () { _end = _start; }
          void push_back (const T &v)
            if (((_end + 1) % size_) == _start)
              _values_dropped = true;
              return;
            _buffer[_end] = v;
            _end = (_end+1) % size_;
          void pop_front ()
            if (_start != _end)
              _start = (_start + 1) % size_;
        TARGET EXAMPLE DATA
        {F4:F3:F2:F1}:{0D:00}:{02}:{AA}: 02  : 4B:00:  4F  : 00:00 : 64   :  29:00 :{55}: {00} :{F8:F7:F6:F5}
        {  header   }  {len}  {typ}{hd}{state}{mdist}{mval}{stadis}{staval}{decdis} {tl} {chck} {    MFR    }
        typedef struct
            uint32_t MFR;
            uint16_t len;
            uint8_t type;                 // target or engineering
            uint8_t head;                // fixed head
            uint8_t state;              // state
            uint8_t movdist;          // movement distance
            uint8_t movdist2;          // movement distance
            uint8_t movval;           // movement energy value
            uint8_t stadist;        // stationary distance
            uint8_t stadist2;        // stationary distance
            uint8_t staval;         // stationary energy value
            uint8_t decdist;      // detection distance
            uint8_t decdist2;      // detection distance
            uint8_t tail;         // tail
            uint8_t chk;         // unused
            uint32_t MFR_end ;  // end
        } TARGET;
        CONF EXAMPLE DATA
        FD:FC:FB:FA MFR[0-3]
        1C:00 len[4-5]
        61:01 CMD[6-7]
        00:00 ACKstat[8-9]
        AA Head [10]
        08 maxDist [11]
        06 maxMovDist[12]
        06 maxStaDist[13]
        1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E:1E (9mov & 9sta sensitivities)
        5A:00 none[32-33]
        04:03:02:01[34-37]
        typedef struct
            uint32_t MFR;
            uint16_t len;
            uint8_t cmd;
            uint8_t cmd_val;
            uint8_t ack_stat;
            uint8_t ack_stathigh;
            uint8_t head;
            uint8_t max_dist;
            uint8_t max_mov_dist;
            uint8_t max_sta_dist;
            uint8_t mov0sen;
            uint8_t mov1sen;
            uint8_t mov2sen;
            uint8_t mov3sen;
            uint8_t mov4sen;
            uint8_t mov5sen;
            uint8_t mov6sen;
            uint8_t mov7sen;
            uint8_t mov8sen;
            uint8_t sta0sen;
            uint8_t sta1sen;
            uint8_t sta2sen;
            uint8_t sta3sen;
            uint8_t sta4sen;
            uint8_t sta5sen;
            uint8_t sta6sen;
            uint8_t sta7sen;
            uint8_t sta8sen;
            uint16_t none;
            uint32_t MFR_end;
        } CONF;
        class LD2410 : public Component, public UARTDevice
        public:
          //using BufferType = std::deque<uint8_t>;
          using BufferType = CyclicBuffer<uint8_t, 120>;
          BufferType bytes;
          const std::array<uint8_t, 6> config_header = {0xFD, 0xFC, 0xFB, 0xFA, 0x1C, 0x00};
          const std::array<uint8_t, 6> target_header = {0xF4, 0xF3, 0xF2, 0xF1, 0x0D, 0x00};
          const std::array<uint8_t, 6> ld2410_end_conf = {0x04, 0x03, 0x02, 0x01};
          LD2410(UARTComponent *parent);
          void setup() override;
          void loop() override;
          void setConfigMode(bool confenable);
          void setSensitivity(int gate, int senval_mov, int senval_sta);
          void setMaxDistancesAndNoneDuration(int maxMovingDistanceRange, int maxStillDistanceRange, int noneDuration);
          void queryParameters();
          void restart();
        private:
          void setMaxDistancesAndNoneDurationImpl(int maxMovingDistanceRange, int maxStillDistanceRange, int noneDuration);
          void queryParametersImpl();
          void factoryReset();
          void reboot();
          void ESP_LOGD_HEX(std::vector<uint8_t> bytes, uint8_t separator);
          void sendCommand(char *commandStr, char *commandValue, int commandValueLen);
          int twoByteToInt(char firstByte, char secondByte);
          void handleTargetData(BufferType buffer);
          void handleConfData(BufferType buffer);
          void setEngineeringMode(bool engenable);
          void setSensitivityImpl(int gate, int senval_mov, int senval_sta);
          void setBaudrate(int index);
          bool doesHeaderMatch(BufferType bytes, std::array<uint8_t,6> header);
          typedef union
            TARGET target;
            uint8_t bytes[sizeof(TARGET)];
          } TARGETUnion;
          typedef union
            CONF conf;
            uint8_t bytes[sizeof(CONF)];
          } CONFUnion;
        LD2410::LD2410(UARTComponent *parent) : UARTDevice(parent)
        void LD2410::setup()
          setConfigMode (true);
        #if 0
          setMaxDistancesAndNoneDurationImpl(id(maxconfigDistanceMoving).state / 0.75,
                                             id(maxconfigDistanceStill).state / 0.75,
          setSensitivityImpl(0, id(sensitivity0Moving).state, id(sensitivity0Still).state);
          setSensitivityImpl(1, id(sensitivity1Moving).state, id(sensitivity1Still).state);
          setSensitivityImpl(2, id(sensitivity2Moving).state, id(sensitivity2Still).state);
          setSensitivityImpl(3, id(sensitivity3Moving).state, id(sensitivity3Still).state);
          setSensitivityImpl(4, id(sensitivity4Moving).state, id(sensitivity4Still).state);
          setSensitivityImpl(5, id(sensitivity5Moving).state, id(sensitivity5Still).state);
          setSensitivityImpl(6, id(sensitivity6Moving).state, id(sensitivity6Still).state);
          setSensitivityImpl(7, id(sensitivity7Moving).state, id(sensitivity7Still).state);
          setSensitivityImpl(8, id(sensitivity8Moving).state, id(sensitivity8Still).state);
        #endif
          setConfigMode (false);
        void LD2410::loop()
          while (available())
            bytes.push_back(read());
            while (bytes.size() >= 6)
              if (doesHeaderMatch(bytes, config_header))
                if (bytes.size() < sizeof(CONF))
                  break;
                handleConfData(bytes);
                bytes.clear();
              else if (doesHeaderMatch(bytes, target_header)) {
                if (bytes.size() < sizeof(TARGET))
                  break;
                handleTargetData(bytes);
                bytes.clear();
              else
                //ESP_LOGD("custom", "erase one byte");
                bytes.pop_front();
        void LD2410::ESP_LOGD_HEX(std::vector<uint8_t> bytes, uint8_t separator)
          std::string res;
          size_t len = bytes.size();
          char buf[5];
          for (size_t i = 0; i < len; i++) {
            if (i > 0) {
              res += separator;
            sprintf(buf, "%02X", bytes[i]);
            res += buf;
          ESP_LOGD("custom", "%s", res.c_str());
        void LD2410::sendCommand(char *commandStr, char *commandValue, int commandValueLen)
          uint16_t len = 2;
          if (commandValue != nullptr) {
            len += commandValueLen;
          static std::vector<uint8_t> ld2410_conf = {0xFD, 0xFC, 0xFB, 0xFA};
          size_t needed_size = 8 + (commandValue != nullptr ? commandValueLen : 0) + ld2410_end_conf.size ();
          if (ld2410_conf.capacity () < needed_size)
            ld2410_conf.reserve (needed_size);
          ld2410_conf.resize (8);
          ld2410_conf[4] = lowByte(len);
          ld2410_conf[5] = highByte(len);
          ld2410_conf[6] = commandStr[0];
          ld2410_conf[7] = commandStr[1];
            for (int i = 0; i < commandValueLen; i++)
              ld2410_conf.push_back(commandValue[i]);
          for (int i = 0; i < ld2410_end_conf.size(); i++)
            ld2410_conf.push_back(ld2410_end_conf[i]);
          // ESP_LOGD_HEX(ld2410_conf,':');
          write_array(ld2410_conf);
        int LD2410::twoByteToInt(char firstByte, char secondByte)
          return (int16_t)(secondByte << 8) + firstByte;
        void LD2410::handleTargetData(BufferType buffer)
          static TARGETUnion targetUnion;
          std::copy(buffer.begin(), buffer.end(), targetUnion.bytes);
          if (id(show_stats).state == 1 && targetUnion.target.type == 0x02 && targetUnion.target.state != 0x00)
            int movdist = twoByteToInt(targetUnion.target.movdist, targetUnion.target.movdist2);
            if (id(movingTargetDistance).state != movdist)
              id(movingTargetDistance).publish_state(movdist);
            if (id(movingTargetEnergy).state != targetUnion.target.movval)
              id(movingTargetEnergy).publish_state(targetUnion.target.movval);
            int stadist = twoByteToInt(targetUnion.target.stadist, targetUnion.target.stadist2);
            if (id(stillTargetDistance).state != stadist)
              id(stillTargetDistance).publish_state(stadist);
            if (id(stillTargetEnergy).state != targetUnion.target.staval)
              id(stillTargetEnergy).publish_state(targetUnion.target.staval);
            int decdist = twoByteToInt(targetUnion.target.decdist, targetUnion.target.decdist2);
            if (id(detectDistance).state != decdist)
              id(detectDistance).publish_state(decdist);
          else
            return;
          // Engineering data - datasheet is horrible
          // if (targetUnion.target.type == 0x01)
        void LD2410::handleConfData(BufferType buffer)
          static CONFUnion confUnion;
          std::copy(buffer.begin(), buffer.end(), confUnion.bytes);
          if (confUnion.conf.cmd == 0x61 && confUnion.conf.cmd_val == 0x01
              && confUnion.conf.ack_stat == 0x00 && confUnion.conf.head == 0xAA)
            id(maxconfigDistanceMoving).publish_state(float(confUnion.conf.max_mov_dist * 0.75));
            id(maxconfigDistanceStill).publish_state(float(confUnion.conf.max_sta_dist * 0.75));
            id(sensitivity0Moving).publish_state(confUnion.conf.mov0sen);
            id(sensitivity0Still).publish_state(confUnion.conf.sta0sen);
            id(sensitivity1Moving).publish_state(confUnion.conf.mov1sen);
            id(sensitivity1Still).publish_state(confUnion.conf.sta1sen);
            id(sensitivity2Moving).publish_state(confUnion.conf.mov2sen);
            id(sensitivity2Still).publish_state(confUnion.conf.sta2sen);
            id(sensitivity3Moving).publish_state(confUnion.conf.mov3sen);
            id(sensitivity3Still).publish_state(confUnion.conf.sta3sen);
            id(sensitivity4Moving).publish_state(confUnion.conf.mov4sen);
            id(sensitivity4Still).publish_state(confUnion.conf.sta4sen);
            id(sensitivity5Moving).publish_state(confUnion.conf.mov5sen);
            id(sensitivity5Still).publish_state(confUnion.conf.sta5sen);
            id(sensitivity6Moving).publish_state(confUnion.conf.mov6sen);
            id(sensitivity6Still).publish_state(confUnion.conf.sta6sen);
            id(sensitivity7Moving).publish_state(confUnion.conf.mov7sen);
            id(sensitivity7Still).publish_state(confUnion.conf.sta7sen);
            id(sensitivity8Moving).publish_state(confUnion.conf.mov8sen);
            id(sensitivity8Still).publish_state(confUnion.conf.sta8sen);
            id(noneDuration).publish_state(confUnion.conf.none);
        void LD2410::setConfigMode(bool confenable)
          char cmd[2] = {char (confenable ? 0xFF : 0xFE),0x00};
          char value[2] = {0x01, 0x00};
          sendCommand(cmd, confenable ? value : nullptr, 2);
        void LD2410::queryParameters()
        void LD2410::queryParametersImpl()
          char cmd_query[2] = {0x61, 0x00};
          sendCommand(cmd_query, nullptr, 0);
        void LD2410::setEngineeringMode(bool engenable)
          char cmd[2] = {char (engenable ? 0x62 : 0x63),0x00};
          sendCommand(cmd, nullptr, 0);
        void LD2410::setMaxDistancesAndNoneDuration(int maxMovingDistanceRange, int maxStillDistanceRange, int noneDuration)
          setMaxDistancesAndNoneDurationImpl(maxMovingDistanceRange, maxStillDistanceRange, noneDuration);
        void LD2410::setMaxDistancesAndNoneDurationImpl(int maxMovingDistanceRange, int maxStillDistanceRange, int noneDuration)
          char cmd[2] = {0x60, 0x00};
          char value[18] = {0x00, 0x00, lowByte(maxMovingDistanceRange), highByte(maxMovingDistanceRange), 0x00, 0x00,
                            0x01, 0x00, lowByte(maxStillDistanceRange), highByte(maxStillDistanceRange), 0x00, 0x00,
                            0x02, 0x00, lowByte(noneDuration), highByte(noneDuration), 0x00, 0x00};
          sendCommand(cmd, value, sizeof(value));
        void LD2410::setSensitivityImpl(int gate, int senval_mov, int senval_sta)
          ESP_LOGD("custom", "set sensitivity for gate %d to (%d / %d)", gate, senval_mov, senval_sta);
          //  64 00  00 00  FF FF 00 00 01 00  28 00 00 00 02 00 28 00 00 00 04 03 02 01
          // {cmd  }{dword}{   dgate  }{mword} {   mval   }{sword}{   sval   }{    MFR  }
          char cmd[2] = {0x64, 0x00};
          char value[18] = {0x00, 0x00, lowByte(gate), highByte(gate), 0x00, 0x00,
                            0x01, 0x00, lowByte(senval_mov), highByte(senval_mov), 0x00, 0x00,
                            0x02, 0x00, lowByte(senval_sta), highByte(senval_sta), 0x00, 0x00};
        void LD2410::setSensitivity(int gate, int senval_mov, int senval_sta)
          setSensitivityImpl(gate, senval_mov, senval_sta);
        void LD2410::restart()
          factoryReset ();
          reboot ();
        void LD2410::factoryReset()
          char cmd[2] = {0xA2, 0x00};
        void LD2410::reboot()
          char cmd[2] = {0xA3, 0x00};
          // not need to exit config mode because the ld2410 will reboot automatically
        void LD2410::setBaudrate(int index)
          char cmd[2] = {0xA1, 0x00};
          char value[2] = {char (index), 0x00};
        bool LD2410::doesHeaderMatch(BufferType bytes, std::array<uint8_t,6> header)
          return std::equal(header.begin(), header.end(), bytes.begin());
        esphome:
          friendly_name: led-test
          includes:
        #  on_boot:
        #    priority: -100
        #    then:
        #      - script.execute: get_config
        esp8266:
          board: d1_mini
        wifi:
          ssid: !secret wifi_ssid
          password: !secret wifi_password
          # Enable fallback hotspot (captive portal) in case wifi connection fails
          ap:
            ssid: !secret ap_ssid
            password: !secret ap_password
        ota:
          password: !secret ota_password
        # Enable logging
        logger:
          baud_rate: 0
        web_server:
          port: 80
        mqtt:
          broker: 192.168.1.33
          username: ledtest
        #  password: !secret mqtt_password
          topic_prefix: ledtest
        uart:
          tx_pin: TX
          rx_pin: RX
          baud_rate: 256000
          parity: NONE
          stop_bits: 1
        #light:
        #  - platform: monochromatic
        #    name: "RGB-LED Red"
        #    output: output_r
        #    name: "RGB-LED Green"
        #    output: output_g
        #    name: "RGB-LED Blue"
        #    output: output_b
        output:
        #  - platform: esp8266_pwm
        #    id: output_r
        #    pin: D1
        #    inverted: true
        #    frequency: 50 Hz
        #    #max_power: 50%
        #    id: output_g
        #    pin: D2
        #    inverted: true
        #    frequency: 50 Hz
        #    #max_power: 50%
        #    id: output_b
        #    pin: D3
        #    inverted: true
        #    frequency: 50 Hz
        #    #max_power: 50%
          - platform: gpio
            pin: D1
            inverted: true
          - platform: gpio
            pin: D2
            inverted: true
          - platform: gpio
            pin: D3
            inverted: true
        captive_portal:
        switch:
        # - platform: safe_mode
        #   name: use_safe_mode
           optimistic: true
           internal: true
           turn_on_action:
             - delay: 100ms
           turn_off_action:
           optimistic: true
           internal: false
           turn_off_action:
        sensor:
        #  - platform: wifi_signal
        #    name: "Wifi Power"
        #    update_interval: 10s
           internal: false
           state_topic: ledtest/moveDistance
           internal: false
           state_topic: ledtest/moveEnergy
           internal: false
           state_topic: ledtest/stillDistance
           internal: false
           state_topic: ledtest/stillEnergy
           internal: false
           state_topic: ledtest/distance
        custom_component:
         - lambda: |-
             return {new LD2410(id(uart1))};
           components:
             - id: ld2410
        binary_sensor:
         - platform: gpio
           pin: D7
           state_topic: ledtest/occupancy
           on_state:
             then:
               - if:
                   condition:
                   then:
                     - delay: 150ms
                     - output.turn_off:
                   else:
                     - output.turn_on:
        number:
           min_value: 0.75
           max_value: 6
           step: 0.75
           optimistic: true
           state_topic: ledtest/config/dist_max_move
           command_topic: ledtest/config/dist_max_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setMaxDistancesAndNoneDuration(x/0.75,id(maxconfigDistanceStill).state/0.75,id(noneDuration).state);
           min_value: 0.75
           max_value: 6
           step: 0.75
           optimistic: true
           state_topic: ledtest/config/dist_max_still
           command_topic: ledtest/config/dist_max_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setMaxDistancesAndNoneDuration(id(maxconfigDistanceMoving).state/0.75,x/0.75,id(noneDuration).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_0_move
           command_topic: ledtest/config/sens_threshold_0_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(0,x,id(sensitivity0Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_0_still
           command_topic: ledtest/config/sens_threshold_0_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(0,id(sensitivity0Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_1_move
           command_topic: ledtest/config/sens_threshold_1_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(1,x,id(sensitivity1Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_1_still
           command_topic: ledtest/config/sens_threshold_1_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(1,id(sensitivity1Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_2_move
           command_topic: ledtest/config/sens_threshold_2_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(2,x,id(sensitivity2Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_2_still
           command_topic: ledtest/config/sens_threshold_2_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(2,id(sensitivity2Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_3_move
           command_topic: ledtest/config/sens_threshold_3_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(3,x,id(sensitivity3Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_3_still
           command_topic: ledtest/config/sens_threshold_3_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(3,id(sensitivity3Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_4_move
           command_topic: ledtest/config/sens_threshold_4_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(4,x,id(sensitivity4Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_4_still
           command_topic: ledtest/config/sens_threshold_4_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(4,id(sensitivity4Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_5_move
           command_topic: ledtest/config/sens_threshold_5_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(5,x,id(sensitivity5Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_5_still
           command_topic: ledtest/config/sens_threshold_5_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(5,id(sensitivity5Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_6_move
           command_topic: ledtest/config/sens_threshold_6_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(6,x,id(sensitivity6Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_6_still
           command_topic: ledtest/config/sens_threshold_6_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(6,id(sensitivity6Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_7_move
           command_topic: ledtest/config/sens_threshold_7_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(7,x,id(sensitivity7Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_7_still
           command_topic: ledtest/config/sens_threshold_7_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(7,id(sensitivity7Moving).state,x);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_8_move
           command_topic: ledtest/config/sens_threshold_8_move_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(8,x,id(sensitivity8Still).state);
           min_value: 10
           max_value: 100
           step: 5
           mode: box
           optimistic: true
           state_topic: ledtest/config/sens_threshold_8_still
           command_topic: ledtest/config/sens_threshold_8_still_cmd
           on_value:
             - lambda: |-
                 uart_component->setSensitivity(8,id(sensitivity8Moving).state,x);
           min_value: 0
           max_value: 900
           step: 1
           mode: box
           optimistic: true
           state_topic: ledtest/config/motion_hold
           command_topic: ledtest/config/motion_hold_cmd
           on_value:
             - lambda: |-
                 uart_component->setMaxDistancesAndNoneDuration(id(maxconfigDistanceMoving).state, id(maxconfigDistanceStill).state, x);
        button:
         - platform: restart
           on_press:
             - lambda: 'static_cast<LD2410 *>(ld2410)->restart();'
           #entity_category: diagnostic
           on_press:
        script:
         - id: clear_targets
           then:
             - lambda: |-
        Falls jemand übrigens weiß, wie man im YAML Variablen benutzt oder womöglich sogar Schleifen programmiert, da hätte ich gesteigertes Interesse ;-)
        Schleife meint hier nicht eine Schleife in einem Lambda sondern mehrere number - plattform: template Einträge, die sich nur duch wenige Einträge voneinander unterscheiden. Siehe im obigen YAML die Einträge mit den IDs sensitivity[0-8](Still|Moving).
        • ZarelloZ Zarello
          #include <iterator>
          #include <deque>
          class CyclicBuffer
            size_t _start {0};
            size_t _end {0};
          public:
              CyclicBuffer& _b;
              size_t _pos;
            public:
              // prefix++
                return;
              _buffer[_end] = v;
            void pop_front ()
              if (_start != _end)
          TARGET EXAMPLE DATA
          typedef struct
              uint32_t MFR;
              uint16_t len;
          } TARGET;
          CONF EXAMPLE DATA
          1C:00 len[4-5]
          61:01 CMD[6-7]
          00:00 ACKstat[8-9]
          AA Head [10]
          08 maxDist [11]
          06 maxMovDist[12]
          06 maxStaDist[13]
          5A:00 none[32-33]
          04:03:02:01[34-37]
          typedef struct
              uint32_t MFR;
              uint16_t len;
              uint8_t cmd;
              uint8_t cmd_val;
              uint8_t ack_stat;
              uint8_t head;
              uint8_t max_dist;
              uint8_t mov0sen;
              uint8_t mov1sen;
              uint8_t mov2sen;
              uint8_t mov3sen;
              uint8_t mov4sen;
              uint8_t mov5sen;
              uint8_t mov6sen;
              uint8_t mov7sen;
              uint8_t mov8sen;
              uint8_t sta0sen;
              uint8_t sta1sen;
              uint8_t sta2sen;
              uint8_t sta3sen;
              uint8_t sta4sen;
              uint8_t sta5sen;
              uint8_t sta6sen;
              uint8_t sta7sen;
              uint8_t sta8sen;
              uint16_t none;
              uint32_t MFR_end;
          } CONF;
          public:
            BufferType bytes;
            void restart();
          private:
            void reboot();
            typedef union
              TARGET target;
            } TARGETUnion;
            typedef union
              CONF conf;
            } CONFUnion;
          #if 0
          #endif
          void LD2410::loop()
            while (available())
                    break;
                  bytes.clear();
                    break;
                  bytes.clear();
                else
                  bytes.pop_front();
            std::string res;
            char buf[5];
              if (i > 0) {
                res += separator;
              res += buf;
            uint16_t len = 2;
            else
              return;
            factoryReset ();
            reboot ();
          esphome:
            includes:
          #  on_boot:
          #    priority: -100
          #    then:
          esp8266:
            board: d1_mini
          wifi:
            ap:
          ota:
          # Enable logging
          logger:
            baud_rate: 0
          web_server:
            port: 80
          mqtt:
            username: ledtest
          uart:
            tx_pin: TX
            rx_pin: RX
            baud_rate: 256000
            parity: NONE
            stop_bits: 1
          #light:
          #    output: output_r
          #    output: output_g
          #    output: output_b
          output:
          #    id: output_r
          #    pin: D1
          #    inverted: true
          #    frequency: 50 Hz
          #    #max_power: 50%
          #    id: output_g
          #    pin: D2
          #    inverted: true
          #    frequency: 50 Hz
          #    #max_power: 50%
          #    id: output_b
          #    pin: D3
          #    inverted: true
          #    frequency: 50 Hz
          #    #max_power: 50%
            - platform: gpio
              pin: D1
              inverted: true
            - platform: gpio
              pin: D2
              inverted: true
            - platform: gpio
              pin: D3
              inverted: true
          captive_portal:
          switch:
             optimistic: true
             internal: true
             turn_on_action:
               - delay: 100ms
             turn_off_action:
             optimistic: true
             internal: false
             turn_off_action:
          sensor:
             internal: false
             internal: false
             internal: false
             internal: false
             internal: false
          custom_component:
           - lambda: |-
             components:
               - id: ld2410
          binary_sensor:
           - platform: gpio
             pin: D7
             on_state:
               then:
                 - if:
                     condition:
                     then:
                       - delay: 150ms
                       - output.turn_off:
                     else:
                       - output.turn_on:
          number:
             min_value: 0.75
             max_value: 6
             step: 0.75
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 0.75
             max_value: 6
             step: 0.75
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 10
             max_value: 100
             step: 5
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
             min_value: 0
             max_value: 900
             step: 1
             mode: box
             optimistic: true
             on_value:
               - lambda: |-
          button:
           - platform: restart
             on_press:
             on_press:
          script:
           - id: clear_targets
             then:
               - lambda: |-
          liv-in-skyL Offline
          liv-in-skyL Offline
          erstmal danke, dass du weiter testest
          bei dem yaml, welches ich gepostet habe, bleibt das setting - wie das im yaml gemacht wird, weiß ich nicht
          mit esp32 hatte ich als erstes geschafft, ein stabiles yaml zu bekommen - war verwundert, aber auch das yaml für den wemos d1 mini läuft stabil
          ZarelloZ 1 Antwort Letzte Antwort
          • BananaJoeB Offline
            BananaJoeB Offline
            BananaJoe
            @zarello sagte in Tasmota ESPHome Presence Sensor LD2410:
            Du kannst auch mit sendTo arbeiten, dann wird das Topic auch angelegt und ist nutzbar (hab ich diverse mal für Tasmota gebraucht da außer dem POWER unter cmnd in der Regel nicht angelegt wird, Tasmota aber ja auf alle bekannten Befehle dort lauscht):
            // Beispiel für SendTo von https://github.com/ioBroker/ioBroker.mqtt
            // Test ob ich das zum Anlegen von neuen MQTT-Topics etc. nutzen kann
             * @param {string}  MQTT instance     Specify MQTT instance to send message through (may be either server or client)
             * @param {string}  action            Action to use (always 'sendMessage2Client' for sending plain messages)
             * @param {object}  payload
             * @param {string}  payload.topic     Topic to publish message on
             * @param {string}  payload.message   Message to be published on specified topic
            sendTo('mqtt.0', 'sendMessage2Client', {topic: 'znil/Tests/Testnachricht', message: '42'});
            im MQTT-Adapter den ich als Client für einen Mosquitto einsetze sind ansonsten alle Haken raus:
            So kann man bei Bedarf die "MQTT-Datenpunkte" damit anlegen. Oder gleich im Skript immer mit sendTo arbeiten
            Bei Bedarf hätte ich auch ein Blockly-Beispiel
            Das ganz habe ich in der Hilfe zum MQTT-Adapter gefunden (auch wenn da nicht steht das man es zum anlegen nutzen soll)
            • BananaJoeB BananaJoe
              ZarelloZ Offline
              ZarelloZ Offline
              Zarello
              @bananajoe sagte in Tasmota ESPHome Presence Sensor LD2410:
              Schade, mit dem mqtt-client Adapter scheint das nicht zu funktionieren - getestet mit 'mqtt-client.0' als Ziel.
              Jetzt muss ich mir wohl überlegen, ob ich den normalen mqtt Adapter verwenden möchte und alle Datenpunkte umziehen möchte.
                ZarelloZ Offline
                ZarelloZ Offline
                Zarello
                @liv-in-sky sagte in Tasmota ESPHome Presence Sensor LD2410:
                Ich habe da ein bisschen in der setup Methode in der Header-Datei rumgespielt.
                Inzwischen habe ich festgestellt, so wie es jetzt ist bleiben bei Strom aus und wieder an die Settings erhalten.
                Nur wenn ich eine neue Software aufspiele hat er wieder seine Default-Werte. Das wundert mich, denn eigentlich hole ich die Werte am Anfang vom Sensor. Eine neue Software sollte für den Sensor ja nichts anderes sein als aus- und wieder einschalten. Evtl. wird aber irgendwo noch der Reset aufgerufen. Den werde ich mal abklemmen.
                Außerdem wird bei mir der Wert für stillTargetDistance niemals geändert. Der bleibt einfach auf 0.
                Bekommst Du da sinnvolle Werte?
                • ZarelloZ Zarello
                  liv-in-skyL Offline
                  liv-in-skyL Offline
                  stillTargetDistance
                  bei mir auch nicht - steht in der webgui , bleibt aber immer 0 - auch kein mqtt datenpunkt
                  ich konzentriere mich aber auf den presence dp - mehr brauche ich eigentlich nicht (oder ich weiß noch nicht, dass ich ihn brauche
                    stillTargetDistance
                    ZarelloZ Offline
                    ZarelloZ Offline
                    Zarello
                    Idee wäre, über zwei Geräte aus den Abständen die Position zu ermitteln. Aber ich vermute, dass wird sowieso nicht funktionieren, da zwei Geräte in einem Raum sich höchstwahrscheinlich gegenseitig stören.
                    Die müsste man dann synchronisieren und immer eines der beiden ausschalten, allerdings bieten die Geräte diese Option nicht und wenn man ihnen einfach den Strom klaut, funktionieren sie vermutlich nicht mehr so gut, denn nach meinen Beobachtungen funktioniert die Detektion von unbewegten Personen nur, wenn sie vorher als bewegt erkannt wurden.
                    Wenn man sich im Sensorbereich komplett still verhält (Atem anhalten), kann man danach normal atmen ohne, dass der Sensor anschlägt. Erst wenn man sich wieder etwas mehr bewegt und der Sensor das erkennt, bleibt er danach auch aktiv, wenn man nur atmet.
                      esphome:
                       includes:
                       on_boot:
                          priority: -100
                          then:
                      esp8266:
                           board: esp01_1m
                      # Enable logging
                      logger:
                       baud_rate: 0
                       logs:
                         binary_sensor: INFO
                         text_sensor: INFO
                      api:
                      ota:
                      wifi:
                       ssid: "yyyyyyyyy1"
                      substitutions:
                      mqtt:
                       port: 1506
                      web_server:
                       port: 80
                       version: 2
                       ota: false
                      captive_portal:
                      uart:
                       tx_pin:
                         number: GPIO1
                       rx_pin:
                         number: GPIO3
                       baud_rate: 256000
                       parity: NONE
                       stop_bits: 1
                      switch:
                         optimistic: true
                         turn_on_action:
                           - delay: 100ms
                         turn_off_action:
                         optimistic: true
                         internal: true
                         turn_off_action:
                      text_sensor:
                      sensor:
                       - platform: uptime
                         internal: true
                         on_raw_value:
                           then:
                                 state: !lambda |-
                                           return (
                                           ).c_str();
                         lambda: |-
                           return {};
                         sensors:
                         internal: true
                         internal: true
                         internal: true
                         internal: true
                         internal: true
                      custom_component:
                       - lambda: |-
                         components:
                           - id: ld2410
                      binary_sensor:
                       - platform: gpio
                         pin: GPIO5
                         on_state:
                           then:
                             - if:
                                 condition:
                                 then:
                                   - delay: 150ms
                      number:
                         min_value: 0.75
                         max_value: 6
                         step: 0.75
                         optimistic: true
                         set_action:
                           - delay: 50ms
                           - lambda: |-
                           - delay: 50ms
                           - delay: 50ms
                         min_value: 10
                         max_value: 100
                         step: 5
                         mode: box
                         optimistic: true
                         set_action:
                           - delay: 50ms
                           - lambda: |-
                           - delay: 50ms
                           - delay: 50ms
                         min_value: 0
                         # max_value: 32767
                         max_value: 900
                         step: 1
                         mode: box
                         optimistic: true
                         set_action:
                           - delay: 50ms
                           - lambda: |-
                           - delay: 50ms
                           - delay: 50ms
                      button:
                       - platform: restart
                         on_press:
                           - delay: 50ms
                           - delay: 150ms
                           - delay: 150ms
                      script:
                       - id: get_config
                         then:
                           - delay: 500ms
                           - delay: 500ms
                       - id: clear_targets
                         then:
                           - lambda: |-
                      Stadtschloss
                      schrieb am zuletzt editiert von Stadtschloss
                      @liv-in-sky Danke für das Script! Leider bleibt bei mir der Wert "mmwave_presence_ld2410" immer auf ON. Auch nach den abgelaufenen 5 Sekunden wo keine Bewegung passiert.
                      Edit: Ah okay musst noch die Out vom Sensor an den D1 anlöten :)
                      • ZarelloZ Zarello
                        liv-in-skyL Offline
                        liv-in-skyL Offline
                        @zarello
                        sorry - habe deinen letzten post völlig übersehen :-(
                        scheint, als ob du tief in den sensor einsteigst :-)
                        habe ja 3 sensoren in einem zimmer getestet - die presence funtioniert ohne gegenseitige störungen - ob das auch für die anderen werte gilt, kann ich nicht sagen, da ich die entfernungen nicht protokoliere bzw trianguliere
                        wenn ich über die api, die entfernung beobachte - 2 sensoren direkt vor mir am schreibtisch, werden die werte für ... bei beiden korrekt angezeigt
                        kommt eher selten vor, dass ich in einen bereich (bewegungslos) hineingehe - auch versuche ich meist zu atmen - ist so eine angewohnheit von mir :-) :-) :-)
                        bisher nutze ich den sensor (weitere langzeit-tests):
                        • sitze ich auf dem sofa in meinem büro, werden die monitore des hauptdesktops abgeschalten - die brauchen viele watt - gehe ich wieder zum schreibtisch, werden die monitore wieder aktiviert - funktioniert alles sehr stabil
                        mittlerweile ist die hardware auch in gehäuse eingebaut - habe aber die sensoren außerhalb des gehäuses angebracht - innerhalb wollte das ganze nicht mehr so richtig (obwohl es plastik ist)
                        ich fand die idee mit den leds ganz gut - muss mal schauen, wenn ich zeit habe, ob ich die aus deinem yaml in meine esp32 yaml bekomme und ob das ganze dann noch funtioniert - sollte bald noch eine lieferung bekommen
                        • S Stadtschloss
                          liv-in-skyL Offline
                          liv-in-skyL Offline
                          @stadtschloss ja - den pin braucht man irgendwie :-)
                            @zarello
                            ZarelloZ Offline
                            ZarelloZ Offline
                            Zarello
                            Ich hatte schon überlegt, ob ich bei Gelegenheit einen Vorschlag für einen überarbeiteten LD2410 in ESPHome mache. Aber da benötige ich etwas mehr meiner knappen Zeit für, da ich dann zuerst rausfinden muss, wie ich eine eigene ESPHome-Variante mit dem ESPHome-Adapter verwende.
                            Und vermutlich werde ich dann die ganzen unterschiedlichen Sensitivitäten eher über 1-2 Objekte über JSON steuern und in dem Fall evtl. auch als Alternative, dass man einfach nur einen Wert eintragen kann statt einer Liste und dieser dann für alle Bereiche verwendet wird. Wie gesagt: Zeit haben...
                            Das wäre ja super. Da bin ich mal gespannt. Im Moment warte ich noch auf Anschlusskabel mit passenden Steckern, da ich beschlossen habe, dass ich nicht alle Sensoren anlöten möchte. Die Pins liegen einfach zu dicht beieinander.
                            Ich hatte es schon ein paar mal geschafft so ruhig auf dem Sofa zu sitzen, dass der Sensor mich nicht mehr erkannt hat. Passiert eher bei größerer Entfernung (> 3m).
                            Vielleicht sollte ich mir auch einfach das Atmen wieder angewöhnen ;-)
                            Aber wenn die sich nicht gegenseitig stören kann ich ja auch einfach einen zweiten hinstellen, der dann dichter am Sofa ist.
                            Im Datenblatt des Sensors stehen dazu ganz interessante Infos: Je nach Art des Plastiks gibt es eine empfohlene Dicke (berechnet anhand der halben Wellenlänge des Mediums, meist zwischen 2-5 mm) und einen empfohlenen Abstand (einfache oder eineinhalbfache Wellenlänge in der Luft: 12,4 bzw. 18,6mm).
                            Das Plastik sollte allerdings möglichst homogen sein. Ein 3D-gedrucktes Teil entspricht dem mit Sicherheit nicht, da gibt es viel zu viele Lufteinschlüsse.
                            Ich hatte bei mir einfach mal Papier als Abdeckung getestet. Das hatte gut funktioniert. Ich werde vermutlich die Gehäuse so bauen, dass ich die Seite vor dem Sensor einfach mit Papier abklebe, das sieht etwas netter aus als der blanke Sensor.
                            • Stefan WilkeS Offline
                              Stefan Wilke
                              schrieb am zuletzt editiert von Stefan Wilke
                              Ein richtig guter Bewegungs- und Präsenz Sensor der LD2410 und mein langer Weg zur wirklich guten Erkennung.
                              Den Adapter ESPHome 0.2.4 installiert aber ich habe es nicht geschafft, egal was ich auch probiert habe die YAML Datei über ESPHome im IoBroker zu kompilieren oder gar auf den ESP32 zu übertragen. Stundenlang im Netz gesucht aber keine Lösung dazu gefunden bis ich dann auf diesen Link
                              https://smarthomeyourself.de/wiki/esphome/esphome-mit-python-ueber-die-kommandozeile-flashen/
                              gestoßen bin.
                              Hier wird wirklich super erklärt wie man ESPHome mit Python über die Kommandozeile flashen kann.
                              Bei meiner langen Suche im Netz habe ich auch eine gute id2410.yaml Datei mit dazugehöriger ld2410.h Datei gefunden.
                              Python auf meinem Windows PC installiert, ein neues Verzeichnis esphome angelegt und dann noch Kommandozeile aus dem Arbeitsplatz heraus gestartet. In der Kommandozeile dann noch die 4 Befehle ausgeführt.
                              Jetzt noch mit dem letzten Befehl die YAML Datei kompiliert und ab damit auf den ESP32
                              Anschließend kann man noch in der Web Oberfläche des ESP32 die einzelnen Parameter einstellen und diese werden auch übernommen.
                              Was die Werte motionGate0Sensitivity bis motionGate8Sensitivity sowie staticGate2Sensitivity bis staticGate8Sensitivity bewirken ist mir leider nicht bekannt. Vielleicht kann mich jemand aufklären. Diese Werte waren ursprünglich anders aber ich habe in der Web Oberfläche auf den Reset Button geklickt und dann waren es die Einstellungen wie auf meinem Bild und der Sensor arbeitet so wie ich mir das vorgestellt habe.
                              Jetzt muß ich nur noch jemand finden, der mir ein 3D Gehäuse druckt.
                              So ein Gehäuse wäre schon schön.
                              Meine YAML Datei und dazu auch die h Datei
                              ld2410.yaml
                              ld2410.h
                              In der ld2410.yaml Datei unter WIFI die IP des ESP32, die SSID und das Netzwerkpasswort, unter mqtt die IP eures mqtt Broker ggf. auch den Port eintragen.
                              Dann noch ein kleines Blockly. Geht bestimmt einfacher und besser aber funktioniert bei mir.
                              Ich habe noch nicht ganz die Türklinke in der Hand und das Licht geht an und bleibt auch solange an bis ich den Raum verlasse. Habe noch ein Verzögerung von 4 Sekunden eingebaut mit der Variable setze timer auf 4.
                              • Stefan WilkeS Stefan Wilke
                                gestoßen bin.
                                ld2410.yaml
                                ld2410.h
                                liv-in-skyL Offline
                                liv-in-skyL Offline
                                @stefan-wilke
                                erstmal vielen dank für deinen post - bin gerade am testen - weißt du, wie man diesen datenpunkt aktiviert - ist immer off bei mir - geht das überhaupt ?
                                bisher verstehe ich die anzeigen nicht richtig - es werden massig daten gesendet - also gut für entfernungsmessung und schnell !
                                bei meinem yaml gibt es off und on, wenn man im bereich ist - also bedeutend weniger datentransfer
                                hast du eine link, wo du dieses yaml her hast ?
                                die motionGate und sensitivityGat sachen, sollen wohl die bereiche darstellen ?
                                  Stefan Wilke
                                  @liv-in-sky
                                  keine Ahnung wie man diesen Datenpunkt aktiviert. Habe den Link gefunden wo ich meine YAML und h Datei her habe. https://github.com/amandel/esphome-ld2410
                                  Ja, es werden viele Daten gesendet aber bisher war das für mein IOBroker auf dem Pi kein Problem.
                                  Das mit motionGate und sensiivityGate habe ich noch nicht verstanden aber ich könnte mir vorstellen, das man z.B. einen Bereich von 30-150 cm angeben kann und wenn dort jemand erkannt wird geht Lampe 1 an und wenn im Bereich von 4-5 Meter jemand erkannt wird geht Lampe 2 an.
                                  Habe gerade noch 2 Bilder für ein Gehäuse gefunden aber leider ohne 3D Druckdatei.
                                    @liv-in-sky
                                    liv-in-skyL Offline
                                    liv-in-skyL Offline
                                    @stefan-wilke
                                    bei mir ist das setting "show stats" nach einem neustart (strom aus/ein) nicht mehr gesetzt - damit keine werte - ist das bei dir auch so ?
                                    edit: kann aber über ein blockly wieder gestzt werden, wenn esp online geht
                                    Stefan WilkeS 1 Antwort Letzte Antwort
                                      @stefan-wilke
                                      Stefan Wilke
                                      @liv-in-sky
                                      Ja, das ist bei mir auch so.
                                      in der YAML Datei ist etwas zu deiner Frage zu dem Datenpunkt zu finden.
                                      binary_sensor:
                                      • platform: gpio
                                        pin: GPIO14
                                      Habe keine Ahnung was das bedeutet aber ich könnte mir vorstellen, dass das mit dem Out Pin auf dem ld2410 zu tun hat.
                                        @liv-in-sky
                                        binary_sensor:
                                        • platform: gpio
                                          pin: GPIO14
                                        liv-in-skyL Offline
                                        liv-in-skyL Offline
                                        @stefan-wilke ja habe ich auch gefunden
                                        ja definiert den pin - aber es reagiert nicht im mqtt - evtl muss man den ersteller in github anschreiben
                                        in dem ls2410.h file kann mal wohl die stats immer einschalten zeile 189 - habe es aber nicht getestet
                                          Stefan Wilke
                                          @liv-in-sky
                                          Habe eine Github Anfrage gestartet und auch schon eine Antwort auf meine Frage erhalten. Es funktioniert, habe es gerade getestet.
                                          Um das Setting "Show Stats" auch nach einen Neustart auf On zu setzten muß in meiner YAML Datei folgende Zeilen eingefügt werden.
                                          Anstatt:
                                          esphome:
                                            includes:
                                              - ld2410.h
                                          muss das da stehen:
                                          esphome:
                                            includes:
                                              - ld2410.h
                                            on_boot:
                                              priority: -10
                                              then:
                                                - switch.turn_on: show_stats
                                          und etwas weiter unten
                                          Anstatt:
                                          switch:
                                            - platform: custom
                                              lambda: |-
                                                auto c = static_cast<LD2410 *>(ld2410);
                                                return {c->show_stats, c->show_engineering_stats};
                                              switches:
                                                - name: "Show Stats"
                                                - name: "Show Engineering Stats"
                                          muss das dort stehen:
                                          switch:
                                            - platform: custom
                                              lambda: |-
                                              switches:
