  4. Port 8081 nicht mehr erreichbar, "error: conn. to databases
    5.5k
16 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
    @meute
    iob diag
    spuckt was aus?
    meuteM Offline
    meuteM Offline
    meute
    @thomas-braun sagte in Port 8081 nicht mehr erreichbar, "error: conn. to databases:
    @meute
    iob diag
    spuckt was aus?
    Ergebnis von
    iob diag
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     11:40:11 up 16:21,  1 user,  load average: 0.39, 0.49, 0.43
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Mar  5 10:40:11 UTC 2023
    Sun Mar  5 11:40:11 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    meinuser
    /home/meinuser
    meinuser adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin docker gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            909M        364M         79M        4.0M        466M        404M
    Swap:             0B          0B          0B
    Total:          909M        364M         79M
              909 M total memory
              364 M used memory
              124 M active memory
              349 M inactive memory
               78 M free memory
               19 M buffer memory
              447 M swap cache
                0 M total swap
                0 M used swap
                0 M free swap
    *** FILESYSTEM ***
    Filesystem                              Type      Size  Used Avail Use% Mounted on
    /dev/root                               ext4       15G  7.9G  5.8G  58% /
    devtmpfs                                devtmpfs  325M     0  325M   0% /dev
    tmpfs                                   tmpfs     455M     0  455M   0% /dev/shm
    tmpfs                                   tmpfs     182M  908K  182M   1% /run
    tmpfs                                   tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/sda1                               vfat      253M   31M  222M  13% /boot
    tmpfs                                   tmpfs      91M   20K   91M   1% /run/user/109
    192.168.23.82:/media/nfs_usb_ssd_backup nfs4      110G   38G   67G  36% /media/raspi02_usb_ssd_backup
    tmpfs                                   tmpfs      91M   20K   91M   1% /run/user/1000
    Messages in dmesg:
    [Sat Mar  4 19:18:24 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=fc635420-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [Sat Mar  4 19:18:30 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sat Mar  4 19:18:30 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sat Mar  4 19:18:33 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET                          SOURCE                                  FSTYPE OPTIONS
    /                               /dev/sda2                               ext4   rw,noatime
    |-/media/raspi02_usb_ssd_backup 192.168.23.82:/media/nfs_usb_ssd_backup nfs4   rw,relatime,vers=4.2,rsize=131072,wsize=131072,namlen=255,hard,proto=tcp,timeo=600,retrans=2,sec=sys,clientaddr=192.168.23.81,local_lock=none,addr=192.168.23.82
    `-/boot                         /dev/sda1                               vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    4.0G    /var/
    2.6G    /var/lib
    2.3G    /var/lib/docker
    2.2G    /var/lib/docker/overlay2
    1.2G    /var/log/journal/dbb184e505344dae88426d3e21a16a3f
    /opt/iobroker/backups:
    2.3M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    44M     /opt/iobroker/iobroker-data/
    19M     /opt/iobroker/iobroker-data/backup-objects
    15M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    9.9M    /opt/iobroker/iobroker-data/objects.jsonl
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
    1.1M    /opt/iobroker/iobroker-data/backup-objects/2023-03-03_00-14_objects.jsonl.gz
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
     Could not connect to states database at 127.0.0.1:9000 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
    Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    ioBroker-Repositories
     Objects database error: connect ECONNREFUSED 127.0.0.1:9001
    No connection to databases possible ...
    Installed ioBroker-Instances
    Objects and States
    Objects:        3
    States:         3
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:5 https://download.docker.com/linux/debian bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:7 https://apt.syncthing.net syncthing InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      0          113267     15437/docker-proxy
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          99167      12224/cupsd
    tcp        0      0 0.0.0.0:2388            0.0.0.0:*               LISTEN      0          14828      526/sshd: /usr/sbin
    tcp        0      0 192.168.23.81:8384      0.0.0.0:*               LISTEN      1000       12170      665/syncthing
    tcp        0      0 0.0.0.0:9443            0.0.0.0:*               LISTEN      0          113261     15403/docker-proxy
    tcp6       0      0 :::22000                :::*                    LISTEN      1000       14963      665/syncthing
    tcp6       0      0 :::9000                 :::*                    LISTEN      0          113270     15444/docker-proxy
    tcp6       0      0 :::2388                 :::*                    LISTEN      0          14830      526/sshd: /usr/sbin
    tcp6       0      0 :::9443                 :::*                    LISTEN      0          113264     15418/docker-proxy
    tcp6       0      0 :::80                   :::*                    LISTEN      0          114974     15578/apache2
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          99166      12224/cupsd
    udp        0      0 0.0.0.0:21027           0.0.0.0:*                           1000       12851      665/syncthing
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12691      412/dhcpcd
    udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          13858      -
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          99826      12227/cups-browsed
    udp        0      0 0.0.0.0:56995           0.0.0.0:*                           1000       12850      665/syncthing
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12532      375/avahi-daemon: r
    udp        0      0 0.0.0.0:40249           0.0.0.0:*                           108        12534      375/avahi-daemon: r
    udp6       0      0 :::22000                :::*                                1000       14972      665/syncthing
    udp6       0      0 :::21027                :::*                                1000       12853      665/syncthing
    udp6       0      0 :::51820                :::*                                0          13859      -
    udp6       0      0 :::5353                 :::*                                108        12533      375/avahi-daemon: r
    udp6       0      0 :::36225                :::*                                108        12535      375/avahi-daemon: r
    udp6       0      0 :::43413                :::*                                1000       12852      665/syncthing
    2023-03-05 11:41:32.216  - info: host.raspi01 iobroker _restart
    2023-03-05 11:41:38.966  - info: host.raspi01 iobroker.js-controller version 4.0.24 js-controller starting
    2023-03-05 11:41:38.977  - info: host.raspi01 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-03-05 11:41:38.979  - info: host.raspi01 hostname: raspi01, node: v16.19.1
    2023-03-05 11:41:38.982  - info: host.raspi01 ip addresses: 192.168.23.81 fe80::8346:74b8:a078:2c7e 100.64.0.81 172.17.0.1 fe80::42:aaff:febb:2b6c 169.254.8.200 fe80::9c1b:8fff:febc:7a93
    2023-03-05 11:41:42.322  - error: host.raspi01-Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    2023-03-05 11:41:48.078  - info: host.raspi01 iobroker.js-controller version 4.0.24 js-controller starting
    2023-03-05 11:41:48.089  - info: host.raspi01 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-03-05 11:41:48.091  - info: host.raspi01 hostname: raspi01, node: v16.19.1
    2023-03-05 11:41:48.094  - info: host.raspi01 ip addresses: 192.168.23.81 fe80::8346:74b8:a078:2c7e 100.64.0.81 172.17.0.1 fe80::42:aaff:febb:2b6c 169.254.8.200 fe80::9c1b:8fff:febc:7a93
    2023-03-05 11:41:51.419  - error: host.raspi01-Server Cannot start inMem-states on port 9000: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
    2023-03-05 11:41:57.453  - info: host.raspi01 iobroker.js-controller version 4.0.24 js-controller starting
    2023-03-05 11:41:57.469  - info: host.raspi01 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-03-05 11:41:57.472  - info: host.raspi01 hostname: raspi01, node: v16.19.1
    2023-03-05 11:41:57.476  - info: host.raspi01 ip addresses: 192.168.23.81 fe80::8346:74b8:a078:2c7e 100.64.0.81 172.17.0.1 fe80::42:aaff:febb:2b6c 169.254.8.200 fe80::9c1b:8fff:febc:7a93
    2023-03-05 11:41:59.241  - info: host.raspi01-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
    2023-03-05 11:42:27.521  - error: host.raspi01 No connection to databases possible, restart
    2023-03-05 11:42:27.536  - info: host.raspi01 iobroker _restart
    2023-03-05 11:42:34.481  - info: host.raspi01 iobroker.js-controller version 4.0.24 js-controller starting
    2023-03-05 11:42:34.493  - info: host.raspi01 Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2023-03-05 11:42:34.496  - info: host.raspi01 hostname: raspi01, node: v16.19.1
    2023-03-05 11:42:34.499  - info: host.raspi01 ip addresses: 192.168.23.81 fe80::8346:74b8:a078:2c7e 100.64.0.81 172.17.0.1 fe80::42:aaff:febb:2b6c 169.254.8.200 fe80::9c1b:8fff:febc:7a93
    2023-03-05 11:42:35.813  - info: host.raspi01-Server  Error inMem-objects listening on port 9000: Error: listen EADDRINUSE: address already in use 127.0.0.1:9000
    2023-03-05 11:43:04.532  - error: host.raspi01 No connection to databases possible, restart
    2023-03-05 11:43:04.545  - info: host.raspi01 iobroker _restart
    fraenk for friends Code: MATF103
    • meuteM meute
      @meute
      iob diag
      spuckt was aus?
      Ergebnis von
      iob diag
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      meinuser
      /home/meinuser
      X-Server:       true
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:             0B          0B          0B
                909 M total memory
                364 M used memory
                124 M active memory
                 78 M free memory
                 19 M buffer memory
                447 M swap cache
                  0 M total swap
                  0 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      Messages in dmesg:
      /var:
      4.0G    /var/
      2.6G    /var/lib
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      admin:          6.3.5
      Adapter State
      Objects and States
      Objects:        3
      States:         3
      Pending Updates: 0
      @meute sagte in Port 8081 nicht mehr erreichbar, "error: conn. to databases:
      docker-proxy
      was ist das?
      und ein Desktop drauf?
      meuteM 1 Antwort Letzte Antwort
      • meuteM meute
        @meute
        iob diag
        spuckt was aus?
        Ergebnis von
        iob diag
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Docker:         false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        meinuser
        /home/meinuser
        X-Server:       true
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:             0B          0B          0B
                  909 M total memory
                  364 M used memory
                  124 M active memory
                   78 M free memory
                   19 M buffer memory
                  447 M swap cache
                    0 M total swap
                    0 M used swap
                    0 M free swap
        *** FILESYSTEM ***
        Messages in dmesg:
        /var:
        4.0G    /var/
        2.6G    /var/lib
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
        nodejs:
          Version table:
        ioBroker Status
        admin:          6.3.5
        Adapter State
        Objects and States
        Objects:        3
        States:         3
        Pending Updates: 0
        @meute
        Desktop ausschalten.
        Und was ist
        für eine Quelle?
        Mit einem GB RAM hast du nichts an irgendwas anderes zu verschenken. Kein Desktop, kein Docker, kein Syncthing.
          docker-proxy
          was ist das?
          meuteM Offline
          meuteM Offline
          meute
          Jetzt läuft ioBroker wieder auf Port 8081.
          Port 8081 ist wieder erreichbar.
          Danke für die Unterstrüzung.
          @homoran sagte in Port 8081 nicht mehr erreichbar, "error: conn. to databases:
          docker-proxy
          was ist das?
          Docker war da mal dauf, wurde aber schon länger deinstalliert.
          docker-proxy dürfte bei der Deinstallation übrig geblieben sein.
          Ich habe jetzt alle Docker-Pakete gesucht und gepurged.
          Habe auch noch Reste von mariadb gesucht und gepurged.
          Desktop ist vermutlich drauf, benutze ich aber nicht.
          @meute
          Und was ist
          für eine Quelle?
          Mit Syncthing synce ich im LAN Daten zwischen Handy und PC.
          Das will ich dort schon lassen.
          Wie man den Desktop deaktiviert,weiß ich noch nicht.
          Muss ich mal suchen.
          • meuteM meute
            docker-proxy
            was ist das?
            @meute
            Und was ist
            für eine Quelle?
            Fang in
            sudo raspi-config
            an. Da kann man das Booten einstellen.
              Fang in
              sudo raspi-config
              meuteM Offline
              meuteM Offline
              meute
              schrieb am zuletzt editiert von meute
              Ich habe jetzt die GUI deaktiviert.
              https://www.cyberciti.biz/faq/switch-boot-target-to-text-gui-in-systemd-linux/
              Start mit Kommandozeile aktivieren:
              sudo systemctl set-default multi-user.target
              sudo reboot
              Grafische Benutzeroberfläche / Kommandozeile prüfen:
              systemctl get-default
              multi-user.target
              Speichernutzung mit GUI:
              free --mega -h
                       gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
              Speicher:  909M          417M     123M        4,0M          368M      429M
              Swap:        0B            0B       0B
              Speichernutzung ohne GUI:
              free --mega -h
              Speicher:  909M          329M     311M        1,0M          268M      522M
              Swap:        0B            0B       0B
              • meuteM meute
                sudo reboot
                multi-user.target
                free --mega -h
                Swap:        0B            0B       0B
                free --mega -h
                Swap:        0B            0B       0B
                @meute
                Siehste, mehr RAM verfügbar. Wobei ich den SWAP wieder aktivieren würde. Der wird bei Bedarf genutzt.
                  @meute
                  meuteM Offline
                  meuteM Offline
                  meute
                  @meute
                  Hm?
                  Ich habe mal gelesen, dass beim RPi Swap nicht benötigt wird.
                  Deshalb wurde Swap deaktiviert.
                  • meuteM meute
                    @meute
                    Hm?
                    wieso sollte das so sein? und wieso Geräte abhängig?
                    • meuteM meute
                      @meute
                      Hm?
                      Das ist Quatsch. Das Betriebssystem verwendet Swap als 'Überlauf'. Der sollte nicht permanent gefüllt sein, aber als Puffer wird der bei Bedarf von diversen Prozessen verwendet.
                        meuteM Offline
                        meuteM Offline
                        meute
                        Das ist Quatsch. Das Betriebssystem verwendet Swap als 'Überlauf'. Der sollte nicht permanent gefüllt sein, aber als Puffer wird derbei Bedarf von diversen Prozessen verwendet.
                        Habe Swap nun wieder aktiviert.
