  3. Off Topic
  4. Temperaturwert per GSM an Webseite senden?
    6.1k
25 Beiträge 6 Kommentatoren 3.3k Aufrufe 4 Beobachtet
    @feuersturm ich hatte @Beowolf so verstanden, dass er in die ioBroker SQL-Datenbank schreiben will
    Beowolf
    @homoran sagte in Temperaturwert per GSM an Webseite senden?:
    Nein, das ist wohl falsch rüber gekommen.
    Also: Der Temperatursensor sendet seine Daten zu dieser Webseite in eine mysql Datenbank
    https://www.glanemanns.de/public_html/esp-chart.php
    mit diesem Arduino Programm.
      Rui Santos
      Complete project details at https://RandomNerdTutorials.com/esp32-sim800l-publish-data-to-cloud/
      Permission is hereby granted, free of charge, to any person obtaining a copy
      of this software and associated documentation files.
      The above copyright notice and this permission notice shall be included in all
      copies or substantial portions of the Software.
    // Your GPRS credentials (leave empty, if not needed)
    const char apn[]      = ""; // APN (example: internet.vodafone.pt) use https://wiki.apnchanger.org
    const char gprsUser[] = ""; // GPRS User
    const char gprsPass[] = ""; // GPRS Password
    // SIM card PIN (leave empty, if not defined)
    const char simPIN[]   = "";
    // Server details
    // The server variable can be just a domain name or it can have a subdomain. It depends on the service you are using
    const char server[] = "example.com"; // domain name: example.com, maker.ifttt.com, etc
    const char resource[] = "/post-data.php";         // resource path, for example: /post-data.php
    const int  port = 80;                             // server port number
    // Keep this API Key value to be compatible with the PHP code provided in the project page.
    // If you change the apiKeyValue value, the PHP file /post-data.php also needs to have the same key
    String apiKeyValue = "tPmAT5Ab3j7F9";
    // TTGO T-Call pins
    #define MODEM_RST            5
    #define MODEM_PWKEY          4
    #define MODEM_POWER_ON       23
    #define MODEM_TX             27
    #define MODEM_RX             26
    #define I2C_SDA              21
    #define I2C_SCL              22
    // BME280 pins
    #define I2C_SDA_2            18
    #define I2C_SCL_2            19
    // Set serial for debug console (to Serial Monitor, default speed 115200)
    #define SerialMon Serial
    // Set serial for AT commands (to SIM800 module)
    #define SerialAT Serial1
    // Configure TinyGSM library
    #define TINY_GSM_MODEM_SIM800      // Modem is SIM800
    #define TINY_GSM_RX_BUFFER   1024  // Set RX buffer to 1Kb
    // Define the serial console for debug prints, if needed
    //#define DUMP_AT_COMMANDS
    #include <Wire.h>
    #include <TinyGsmClient.h>
    #ifdef DUMP_AT_COMMANDS
      #include <StreamDebugger.h>
      StreamDebugger debugger(SerialAT, SerialMon);
      TinyGsm modem(debugger);
    #else
      TinyGsm modem(SerialAT);
    #endif
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BME280.h>
    // I2C for SIM800 (to keep it running when powered from battery)
    TwoWire I2CPower = TwoWire(0);
    // I2C for BME280 sensor
    TwoWire I2CBME = TwoWire(1);
    Adafruit_BME280 bme;
    // TinyGSM Client for Internet connection
    TinyGsmClient client(modem);
    #define uS_TO_S_FACTOR 1000000UL   /* Conversion factor for micro seconds to seconds */
    #define TIME_TO_SLEEP  3600        /* Time ESP32 will go to sleep (in seconds) 3600 seconds = 1 hour */
    #define IP5306_ADDR          0x75
    #define IP5306_REG_SYS_CTL0  0x00
    bool setPowerBoostKeepOn(int en){
      I2CPower.beginTransmission(IP5306_ADDR);
      I2CPower.write(IP5306_REG_SYS_CTL0);
      if (en) {
        I2CPower.write(0x37); // Set bit1: 1 enable 0 disable boost keep on
      } else {
        I2CPower.write(0x35); // 0x37 is default reg value
      return I2CPower.endTransmission() == 0;
    void setup() {
      // Set serial monitor debugging window baud rate to 115200
      SerialMon.begin(115200);
      // Start I2C communication
      I2CPower.begin(I2C_SDA, I2C_SCL, 400000);
      I2CBME.begin(I2C_SDA_2, I2C_SCL_2, 400000);
      // Keep power when running from battery
      bool isOk = setPowerBoostKeepOn(1);
      SerialMon.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
      // Set modem reset, enable, power pins
      pinMode(MODEM_PWKEY, OUTPUT);
      pinMode(MODEM_RST, OUTPUT);
      pinMode(MODEM_POWER_ON, OUTPUT);
      digitalWrite(MODEM_PWKEY, LOW);
      digitalWrite(MODEM_RST, HIGH);
      digitalWrite(MODEM_POWER_ON, HIGH);
      // Set GSM module baud rate and UART pins
      SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
      delay(3000);
      // Restart SIM800 module, it takes quite some time
      // To skip it, call init() instead of restart()
      SerialMon.println("Initializing modem...");
      modem.restart();
      // use modem.init() if you don't need the complete restart
      // Unlock your SIM card with a PIN if needed
      if (strlen(simPIN) && modem.getSimStatus() != 3 ) {
        modem.simUnlock(simPIN);
      // You might need to change the BME280 I2C address, in our case it's 0x76
      if (!bme.begin(0x76, &I2CBME)) {
        Serial.println("Could not find a valid BME280 sensor, check wiring!");
        while (1);
      // Configure the wake up source as timer wake up
      esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
    void loop() {
      SerialMon.print("Connecting to APN: ");
      SerialMon.print(apn);
      if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
        SerialMon.println(" fail");
      else {
        SerialMon.println(" OK");
        SerialMon.print("Connecting to ");
        SerialMon.print(server);
        if (!client.connect(server, port)) {
        else {
          // Making an HTTP POST request
          SerialMon.println("Performing HTTP POST request...");
          // Prepare your HTTP POST request data (Temperature in Celsius degrees)
          String httpRequestData = "api_key=" + apiKeyValue + "&value1=" + String(bme.readTemperature())
                                 + "&value2=" + String(bme.readHumidity()) + "&value3=" + String(bme.readPressure()/100.0F) + "";
          // Prepare your HTTP POST request data (Temperature in Fahrenheit degrees)
          //String httpRequestData = "api_key=" + apiKeyValue + "&value1=" + String(1.8 * bme.readTemperature() + 32)
          //                       + "&value2=" + String(bme.readHumidity()) + "&value3=" + String(bme.readPressure()/100.0F) + "";
          // You can comment the httpRequestData variable above
          // then, use the httpRequestData variable below (for testing purposes without the BME280 sensor)
          //String httpRequestData = "api_key=tPmAT5Ab3j7F9&value1=24.75&value2=49.54&value3=1005.14";
          client.print(String("POST ") + resource + " HTTP/1.1\r\n");
          client.print(String("Host: ") + server + "\r\n");
          client.println("Connection: close");
          client.println("Content-Type: application/x-www-form-urlencoded");
          client.print("Content-Length: ");
          client.println(httpRequestData.length());
          client.println();
          client.println(httpRequestData);
          unsigned long timeout = millis();
          while (client.connected() && millis() - timeout < 10000L) {
            // Print available data (HTTP response from server)
            while (client.available()) {
              char c = client.read();
              SerialMon.print(c);
              timeout = millis();
          SerialMon.println();
          // Close client and disconnect
          client.stop();
          SerialMon.println(F("Server disconnected"));
          modem.gprsDisconnect();
          SerialMon.println(F("GPRS disconnected"));
      // Put ESP32 into deep sleep mode (with timer wake up)
      esp_deep_sleep_start();
    das ich von dieser Webseite
    https://randomnerdtutorials.com/esp32-sim800l-publish-data-to-cloud/
    habe. Dort wird eigentlich alles erklärt (ist nicht ganz so wichtig).
    Jetzt möchte ich die Daten eben von der Webseite auch in ioBroker haben bzw. ioBroker soll die Daten von dort abholen und dann als Datenpunkt für die weitere Verarbeitung darstellen.
    Ist das so verständlich erklärt? 😊
    Manfred
    • FeuersturmF Feuersturm
      @beowolf du könntest mal auf die Suche gehen, wie du über ein Javascript Skript auf die MySQL Datenbank zugreifen kannst, um dort die Werte auszulesen und um sie danach in iobroker weiter zu verarbeiten. Eine erste Suche findet z.b. das https://forum.iobroker.net/topic/4014/zugriff-auf-eigene-mysql-datenbank
      Beowolf
      @feuersturm
      Bin gerade dabei mir das Skript anzuschauen.
      Danbke für die Hilfe
      • B Beowolf
        @feuersturm
        bommel_030
        @beowolf
        Wenn ich dich richtig verstehe willst du die Daten aus der Webseite im iobroker?
        Klingt nach Parser und dann Webseite auslesen.
        Oder du kannst dein Ardunio Programm so umbauen, dass es zusätzlich über die simple API direkt in den iobroker schreibt.
        • B bommel_030
          @beowolf
          Beowolf
          schrieb am zuletzt editiert von Beowolf
          @bommel_030 sagte in Temperaturwert per GSM an Webseite senden?:
          @beowolf
          Direkt nach ioBroker wäre natürlich der beste Weg.
          Aber
          Man kann das bestimmt - Ich leider nicht. Ich will ja auch nicht die ioBroker Datenbank zerschießen.
          Ach ja. Auf der Empfänger Webseite ist dieses Skript.
          <?php
            Rui Santos
          $servername = "localhost";
          // REPLACE with your Database name
          $dbname = "REPLACE_WITH_YOUR_DATABASE_NAME";
          // REPLACE with Database user
          $username = "REPLACE_WITH_YOUR_USERNAME";
          // REPLACE with Database user password
          $password = "REPLACE_WITH_YOUR_PASSWORD";
          // Keep this API Key value to be compatible with the ESP32 code provided in the project page. If you change this value, the ESP32 sketch needs to match
          $api_key_value = "tPmAT5Ab3j7F9";
          $api_key = $value1 = $value2 = $value3 = "";
          if ($_SERVER["REQUEST_METHOD"] == "POST") {
              $api_key = test_input($_POST["api_key"]);
              if($api_key == $api_key_value) {
                  $value1 = test_input($_POST["value1"]);
                  $value2 = test_input($_POST["value2"]);
                  $value3 = test_input($_POST["value3"]);
                  // Create connection
                  $conn = new mysqli($servername, $username, $password, $dbname);
                  // Check connection
                  if ($conn->connect_error) {
                      die("Connection failed: " . $conn->connect_error);
                  $sql = "INSERT INTO Sensor (value1, value2, value3)
                  VALUES ('" . $value1 . "', '" . $value2 . "', '" . $value3 . "')";
                  if ($conn->query($sql) === TRUE) {
                      echo "New record created successfully";
                  else {
                      echo "Error: " . $sql . "<br>" . $conn->error;
                  $conn->close();
              else {
                  echo "Wrong API Key provided.";
          else {
              echo "No data posted with HTTP POST.";
          function test_input($data) {
              $data = trim($data);
              $data = stripslashes($data);
              $data = htmlspecialchars($data);
              return $data;
          • B Beowolf
            @beowolf
            Aber
            <?php
              Rui Santos
                    // Check connection
                    else {
                    $conn->close();
                else {
            else {
                return $data;
            bommel_030
            @beowolf
            Bin wahrlich kein IT-Fachmann, aber die simple API ist tatsächlich so simpel wie sie klingt...
            Einzige "Hürde" ob bzw. wie dein iobroker von außen erreichbar ist. Hab es bei mir mit nem Reverse Proxy gelöst, klappt problemlos.
            • B bommel_030
              @beowolf
              Beowolf
              @bommel_030
              Das mit dem "von außen erreichbar" möchte ich eigentlich nicht. Sicherer wäre es, wenn ioBroker es sich holt.
              Reverse Proxy? Muß ich mir anschauen.
              • B Beowolf
                @bommel_030
                bommel_030
                @beowolf
                Wenn du deinen iobroker "nur" lokal nutzt dann schau dir den Parser Adapter an, damit Holst sich der iobroker die Daten ohne das irgendwas von außen geöffnet ist. Auf jeden Fall kein Portforwading, das ist böse ;-)
                • B bommel_030
                  @beowolf
                  Beowolf
                  @bommel_030
                  Den Parser Adapter hatte ich mir schon angeschaut. Das ist im Moment noch ein Ding mit sieben Siegeln.
                  W 1 Antwort Letzte Antwort
                  • B Beowolf
                    @bommel_030
                    W Offline
                    W Offline
                    watcherkb
                    @beowolf hi, hast du hier schon eine Lösung gefunden? Stehe vor der selben Frage, wie ich remote an mein iobroker Daten senden kann.
                    CC2538+CC2592 PA-Zigbee-Funkmodul
                    B BananaJoeB 2 Antworten Letzte Antwort
                    • W watcherkb
                      Beowolf
                      @watcherkb
                      ich habe das Projekt nicht weiter verfolgt, da sich die Notwendigkeit erledigt hatte. Ich kann dir da leider nicht weiter helfen.
                      • W watcherkb
                        BananaJoeB Offline
                        BananaJoeB Offline
                        BananaJoe
                        @watcherkb man kann per Python leicht einen eigenen "Webserver" aufsetzen der die aufgerufene URL dann weiter verarbeitet.
                        Ich hab das mal genutzt um Werte per Befehlsaufruf an Zabbix zu senden:
                        https://znil.net/index.php?title=Zabbix_sender_per_Web_URL-Aufruf_nutzen
                        wie man sieht ist das mehr als einfach, man definiert die URL und die einzelnen Abschnitte zwischen den / stehen als Parameter zur Verfügung.
                        Darüber könntest du das dann intern per Simple API etc. an ioBroker weiterleiten (oder per mosquitto_pub an einen MQTT-Broker senden)
                        Wie man daraus einen Dienst macht habe ich auch beschrieben
                        Das kann man auch noch mit einer Anmeldung absichern wenn man will. Nach außen bräuchtest du halt den Port weiter geleitet (den du im Skript auch aussuchen kannst). Absicherung über einen Reverse-Proxy ginge auch.
                        • BananaJoeB BananaJoe
                          W Offline
                          W Offline
                          watcherkb
                          @bananajoe sagte in Temperaturwert per GSM an Webseite senden?:
                          Hi, danke dir. Ich hadere noch damit, einen Port nach außen aufzumachen. Ich möchte mir nicht unnötig eine Sicherheitslücke ins System holen. Mit reverse-proxy habe ich mich bisher nicht beschäftigt. Wie aufwändig ist es denn, das aufzusetzen?
                          • BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            @watcherkb wenn du das noch nicht gemacht hast ist es aufwendig, jupp.
                            Ich persönlich hätte keine Bauchschmerzen einen - ggf. separaten MQTT-Broker über einen nicht Standardport von außen erreichbar machen - natürlich mit Benutzername + Passwort, eventuell auch noch SSL.
                            Es gibt aber auch "freie" MQTT-Broker im Internet. Dur könntest auch dorthin publishen und dir gezielt die Werte per Client wiederholen. Musst halt damit leben das jeder andere auch die Werte lesen könnte, je nach Anbieter
                              W Offline
                              W Offline
                              watcherkb
                              @bananajoe hey, bin dir noch eine Rückmeldung schuldig ;-)
                              Ich habe das jetzt folgendermaßen gelöst und es läuft bisher ganz gut.
                              ESP32 GSM Modul mit kostenloser SIM-Datenkarte von Netzclub. Dieser sendet einen http request an meinen reverse-proxy. Reverse-proxy ist mit Zugangsdaten abgesichert und leitet den request an iobroker und dort an die rest-api Adapter weiter.
