  4. Eufy-Security Adapter installiert sich nicht.
    5.5k
52 Beiträge 3 Kommentatoren 2.5k Aufrufe 3 Beobachtet
  • wendy2702W wendy2702
    @longbow
    ls -la /opt/iobroker/
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    LongbowL Offline
    LongbowL Offline
    Longbow
    schrieb am zuletzt editiert von Longbow
    @wendy2702 sagte in Eufy-Security Adapter installiert sich nicht.:
    ls -la /opt/iobroker/ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    das kommt da:
    cototal 1416
    drwxrwxr-x+    6 iobroker iobroker    4096 Feb 23 08:05 .
    drwxr-xr-x     3 root     root        4096 Feb  2 19:11 ..
    -rw-rwxr--+    1 iobroker iobroker     155 Feb 23 08:05 .npmrc
    -rwxrwxrwx+    1 iobroker iobroker     549 Feb 23 08:05 INSTALLER_INFO.txt
    drwxrwxr-x+    2 iobroker iobroker    4096 Feb 23 02:40 backups
    lrwxrwxrwx     1 iobroker iobroker      22 Feb 23 08:05 iob -> /opt/iobroker/iobroker
    -rwxr-xr-x+    1 iobroker iobroker     512 Feb 23 08:05 iobroker
    drwxrwxr-x+   12 iobroker iobroker    4096 Feb 23 16:28 iobroker-data
    drwxrwxr-x+    2 iobroker iobroker    4096 Feb 23 16:45 log
    drwxrwxr-x+ 1119 iobroker iobroker   36864 Feb 23 12:09 node_modules
    -rw-rwxr--+    1 iobroker iobroker 1369981 Feb 23 12:09 package-lock.json
    -rw-rwxr--+    1 iobroker iobroker    2987 Feb 23 11:10 package.jsonde_text
    x86_64
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    /usr/bin/npx
    v16.19.1
    v16.19.1
    8.19.3
    8.19.3
    4.0.24
    cliffkirchhof
    cliffkirchhof sudo iobroker
    /home/cliffkirchhof
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://security.debian.org bullseye-security InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Reading package lists... Done
    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org bullseye-security/main amd64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main amd64 Packages
      @longbow
      Am Rechner kannst du dann auch
      iob diag
      ausführen, da ist neben dem obigen auch noch weiterers drin enthalten.
      LongbowL Offline
      LongbowL Offline
      Longbow
      @thomas-braun sagte in Eufy-Security Adapter installiert sich nicht.:
      iob diag
      Copy text starting here:
                           v.2023-01-02
      Operatingsystem:        Debian GNU/Linux 11 (bullseye)
      Installation:           lxc
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               false
      Pending OS-Updates:     2
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      + system.adapter.admin.0                  : admin                 : iobroker-Final                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Pending iob updates:    0
      Active repo(s): stable
      Objects:                33299
      States:                 25869
      Size of iob-Database:
      46M     /opt/iobroker/iobroker-data/objects.jsonl
      33M     /opt/iobroker/iobroker-data/states.jsonl
      • LongbowL Longbow
        das kommt da:
        cototal 1416
        x86_64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v16.19.1
        v16.19.1
        8.19.3
        8.19.3
        4.0.24
        cliffkirchhof
        /home/cliffkirchhof
        nodejs:
          Version table:
        @longbow
        Bitte die Langfassung.
        LongbowL 1 Antwort Letzte Antwort
        • LongbowL Longbow
          iob diag
                               v.2023-01-02
          Installation:           lxc
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Status admin:
          Objects:                33299
          States:                 25869
          wendy2702W Online
          wendy2702W Online
          @longbow Nachdem du das log für Thomas gepostet hast.
          Bitte mal Instanz und Adapter komplett löschen.
          Dann nochmal:
          ls -la /opt/iobroker/node_modules/ |grep eu
          LongbowL 2 Antworten Letzte Antwort
            Dann nochmal:
            LongbowL Offline
            LongbowL Offline
            Longbow
            @wendy2702
            wie lösche ich den kompeltt... über admin im iobroker bleibt es leider immer..
              @longbow
              LongbowL Offline
              LongbowL Offline
              Longbow
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Architecture:   x86_64
              Docker:         false
              Virtualization: lxc
              Distributor ID: Debian
              Description:    Debian GNU/Linux 11 (bullseye)
              Release:        11
              Codename:       bullseye
              PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
              NAME="Debian GNU/Linux"
              VERSION_ID="11"
              VERSION="11 (bullseye)"
              VERSION_CODENAME=bullseye
              ID=debian
              HOME_URL="https://www.debian.org/"
              SUPPORT_URL="https://www.debian.org/support"
              BUG_REPORT_URL="https://bugs.debian.org/"
              Systemuptime and Load:
               17:11:59 up  2:51,  1 user,  load average: 0.15, 0.37, 0.51
              CPU threads: 4
              *** Time and Time Zones ***
              Thu Feb 23 16:11:59 UTC 2023
              Thu Feb 23 17:11:59 CET 2023
              CET +0100
              Europe/Berlin
              *** User and Groups ***
              cliffkirchhof
              /home/cliffkirchhof
              *** X-Server-Setup ***
              X-Server:       false
              Desktop:
              Terminal:
              *** MEMORY ***
              Mem:            8.1G        3.2G        4.1G        0.0K        847M        4.9G
              Swap:           8.1G          0B        8.1G
              Total:           16G        3.2G         12G
                       8096 M total memory
                       3181 M used memory
                        393 M active memory
                       3394 M inactive memory
                       4066 M free memory
                          0 M buffer memory
                        847 M swap cache
                       8096 M total swap
                          0 M used swap
                       8096 M free swap
              *** FILESYSTEM ***
              Filesystem                       Type      Size  Used Avail Use% Mounted on
              /dev/mapper/pve-vm--210--disk--0 ext4       20G  4.8G   14G  26% /
              none                             tmpfs     492K  4.0K  488K   1% /dev
              udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
              tmpfs                            tmpfs     7.8G     0  7.8G   0% /dev/shm
              tmpfs                            tmpfs     3.2G   96K  3.2G   1% /run
              tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
              Messages in dmesg:
              dmesg: read kernel buffer failed: Operation not permitted
              TARGET SOURCE                           FSTYPE OPTIONS
              /      /dev/mapper/pve-vm--210--disk--0 ext4   rw,relatime,stripe=16
              /var:
              499M    /var/
              222M    /var/cache
              218M    /var/cache/apt
              151M    /var/cache/apt/archives
              142M    /var/log
              /opt/iobroker/backups:
              170M    /opt/iobroker/backups/
              /opt/iobroker/iobroker-data:
              601M    /opt/iobroker/iobroker-data/
              432M    /opt/iobroker/iobroker-data/files
              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
              64M     /opt/iobroker/iobroker-data/backup-objects
              51M     /opt/iobroker/iobroker-data/files/javascript.admin
              60M     /opt/iobroker/iobroker-data/states.jsonl
              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
              15M     /opt/iobroker/iobroker-data/files/vis.0/Iobroker/vis-views.json
              15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
              *** NodeJS-Installation ***
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              *** ioBroker-Installation ***
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              Core adapters versions
              js-controller:  4.0.24
              admin:          6.3.5
              javascript:     6.1.4
              Adapters from github:   4
              Adapter State
              + system.adapter.backitup.0               : backitup              : iobroker-Final                           -  enabled
              + system.adapter.chromecast.0             : chromecast            : iobroker-Final                           -  enabled
              + system.adapter.cloud.0                  : cloud                 : iobroker-Final                           -  enabled
                system.adapter.daswetter.0              : daswetter             : iobroker-Final                           -  enabled
              + system.adapter.discovery.0              : discovery             : iobroker-Final                           -  enabled
                system.adapter.dwd.0                    : dwd                   : iobroker-Final                           -  enabled
              + system.adapter.echarts.0                : echarts               : iobroker-Final                           -  enabled
              + system.adapter.email.0                  : email                 : iobroker-Final                           -  enabled
              + system.adapter.energiefluss.0           : energiefluss          : iobroker-Final                           -  enabled
              + system.adapter.energiefluss.1           : energiefluss          : iobroker-Final                           -  enabled
                system.adapter.eusec.0                  : eusec                 : iobroker-Final                           -  enabled
              + system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker-Final                           -  enabled
                system.adapter.feiertage.0              : feiertage             : iobroker-Final                           -  enabled
                system.adapter.flot.0                   : flot                  : iobroker-Final                           -  enabled
              + system.adapter.followthesun.0           : followthesun          : iobroker-Final                           -  enabled
              + system.adapter.geofency.0               : geofency              : iobroker-Final                           -  enabled, port: 7999, bind: 0.0.0.0
              + system.adapter.history.0                : history               : iobroker-Final                           -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : iobroker-Final                           -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker-Final                           -  enabled, port: 0
              + system.adapter.homeconnect.0            : homeconnect           : iobroker-Final                           -  enabled
                system.adapter.hue-extended.0           : hue-extended          : iobroker-Final                           - disabled
              + system.adapter.hue.0                    : hue                   : iobroker-Final                           -  enabled, port: 443
                system.adapter.ical.0                   : ical                  : iobroker-Final                           -  enabled
                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker-Final                           -  enabled
                system.adapter.icons-icons8.0           : icons-icons8          : iobroker-Final                           -  enabled
                system.adapter.icons-material-png.0     : icons-material-png    : iobroker-Final                           -  enabled
                system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker-Final                           -  enabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker-Final                           -  enabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker-Final                           -  enabled
                system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker-Final                           -  enabled
                system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker-Final                           -  enabled
              + system.adapter.influxdb.0               : influxdb              : iobroker-Final                           -  enabled, port: 8086
              + system.adapter.info.0                   : info                  : iobroker-Final                           -  enabled
              + system.adapter.iot.0                    : iot                   : iobroker-Final                           -  enabled
              + system.adapter.javascript.0             : javascript            : iobroker-Final                           -  enabled
                system.adapter.klf200.0                 : klf200                : iobroker-Final                           - disabled
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker-Final                           -  enabled, port: 54321
              + system.adapter.modbus.0                 : modbus                : iobroker-Final                           -  enabled
              + system.adapter.myenergi.0               : myenergi              : iobroker-Final                           -  enabled
              + system.adapter.netatmo.0                : netatmo               : iobroker-Final                           -  enabled
              + system.adapter.nina.0                   : nina                  : iobroker-Final                           -  enabled
              + system.adapter.nuki.0                   : nuki                  : iobroker-Final                           -  enabled
                system.adapter.openweathermap.0         : openweathermap        : iobroker-Final                           -  enabled
                system.adapter.parser.0                 : parser                : iobroker-Final                           - disabled
                system.adapter.places.0                 : places                : iobroker-Final                           - disabled
              + system.adapter.pollenflug.0             : pollenflug            : iobroker-Final                           -  enabled
              + system.adapter.proxmox.0                : proxmox               : iobroker-Final                           -  enabled, port: 8006
              + system.adapter.pvforecast.0             : pvforecast            : iobroker-Final                           -  enabled
              + system.adapter.scenes.0                 : scenes                : iobroker-Final                           -  enabled
              + system.adapter.shelly.0                 : shelly                : iobroker-Final                           -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.smartgarden.0            : smartgarden           : iobroker-Final                           -  enabled
              + system.adapter.smartthings.0            : smartthings           : iobroker-Final                           -  enabled
              + system.adapter.sonos.0                  : sonos                 : iobroker-Final                           -  enabled
              + system.adapter.synology.0               : synology              : iobroker-Final                           -  enabled, port: 5000
              + system.adapter.synology.1               : synology              : iobroker-Final                           -  enabled, port: 5000
              + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker-Final                           -  enabled
                system.adapter.telegram.0               : telegram              : iobroker-Final                           - disabled, port: 8443, bind: 0.0.0.0
              + system.adapter.tr-064.0                 : tr-064                : iobroker-Final                           -  enabled
              + system.adapter.tr-064.1                 : tr-064                : iobroker-Final                           -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : iobroker-Final                           -  enabled
              + system.adapter.tuya.0                   : tuya                  : iobroker-Final                           -  enabled
                system.adapter.unifi.0                  : unifi                 : iobroker-Final                           - disabled
              + system.adapter.upnp.0                   : upnp                  : iobroker-Final                           -  enabled
                system.adapter.vis-bars.0               : vis-bars              : iobroker-Final                           -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker-Final                           -  enabled
                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobroker-Final                           -  enabled
                system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker-Final                           -  enabled
                system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker-Final                           -  enabled
                system.adapter.vis-history.0            : vis-history           : iobroker-Final                           -  enabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-Final                           -  enabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker-Final                           -  enabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker-Final                           -  enabled
                system.adapter.vis-map.0                : vis-map               : iobroker-Final                           -  enabled
                system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker-Final                           -  enabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : iobroker-Final                           -  enabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-Final                           -  enabled
                system.adapter.vis.0                    : vis                   : iobroker-Final                           -  enabled
              + system.adapter.vw-connect.0             : vw-connect            : iobroker-Final                           -  enabled
              + system.adapter.vw-connect.1             : vw-connect            : iobroker-Final                           -  enabled
                system.adapter.weatherunderground.0     : weatherunderground    : iobroker-Final                           -  enabled
              + system.adapter.web.0                    : web                   : iobroker-Final                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              + system.adapter.wolf-smartset.0          : wolf-smartset         : iobroker-Final                           -  enabled
              + system.adapter.wolf.0                   : wolf                  : iobroker-Final                           -  enabled, port: 12004, bind: 192.168.178.210
                system.adapter.youtube.0                : youtube               : iobroker-Final                           -  enabled
                system.adapter.yr.0                     : yr                    : iobroker-Final                           -  enabled
              + instance is alive
              ioBroker-Repositories
              Installed ioBroker-Instances
              Used repository: stable
              Adapter    "backitup"     : 2.5.12   , installed 2.5.12
              Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
              Adapter    "cloud"        : 4.3.0    , installed 4.3.0
              Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
              Adapter    "echarts"      : 1.0.12   , installed 1.0.12
              Adapter    "email"        : 1.1.4    , installed 1.1.4
              Adapter    "eusec"        : 0.9.9    , installed 0.9.9
              Adapter    "fb-checkpresence": 1.1.25, installed 1.1.25
              Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
              Adapter    "flot"         : 1.11.0   , installed 1.11.0
              Adapter    "followthesun" : 0.4.1    , installed 0.4.1
              Adapter    "geofency"     : 1.2.4    , installed 1.2.4
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
              Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
              Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
              Adapter    "hue"          : 3.7.1    , installed 3.7.1
              Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
              Adapter    "info"         : 1.9.19   , installed 1.9.26
              Adapter    "iot"          : 1.14.2   , installed 1.14.2
              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
              Adapter    "klf200"       : 1.0.1    , installed 1.0.1
              Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
              Adapter    "modbus"       : 5.0.11   , installed 5.0.11
              Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
              Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
              Adapter    "nina"         : 0.0.25   , installed 0.0.25
              Adapter    "nuki"         : 1.6.0    , installed 1.6.0
              Adapter    "openweathermap": 0.3.3   , installed 0.3.3
              Adapter    "parser"       : 1.1.8    , installed 1.1.8
              Adapter    "places"       : 1.1.2    , installed 1.1.2
              Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
              Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
              Adapter    "pvforecast"   : 2.3.0    , installed 2.3.0
              Adapter    "shelly"       : 6.3.1    , installed 6.3.1
              Adapter    "smartgarden"  : 2.0.0    , installed 2.0.0
              Adapter    "smartthings"  : 0.0.4    , installed 0.0.4
              Adapter    "sonos"        : 2.2.3    , installed 2.2.3
              Adapter    "synology"     : 2.1.13   , installed 2.1.13
              Adapter    "telegram"     : 1.15.2   , installed 1.15.2
              Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
              Adapter    "trashschedule": 2.2.0    , installed 2.2.0
              Adapter    "tuya"         : 3.13.1   , installed 3.13.1
              Adapter    "unifi"        : 0.5.10   , installed 0.5.10
              Adapter    "upnp"         : 1.0.21   , installed 1.0.21
              Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
              Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
              Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
              Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
              Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "vw-connect"   : 0.0.56   , installed 0.0.56
              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
              Adapter    "wolf"         : 1.5.0    , installed 1.5.0
              Adapter    "wolf-smartset": 1.0.0    , installed 1.0.0
              Adapter    "youtube"      : 4.1.0    , installed 4.1.0
              Adapter    "yr"           : 5.3.0    , installed 5.3.0
              Objects and States
              Objects:        33299
              States:         25869
              Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:4 https://deb.nodesource.com/node_16.x bullseye InRelease
              Pending Updates: 2
              *** Listening Ports ***
              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       420272263  127/iobroker.js-con
              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       420273259  127/iobroker.js-con
              tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          420272116  300/master
              tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      104        420272191  115/systemd-resolve
              tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      104        420272185  115/systemd-resolve
              tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          420268930  1/init
              tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       420277692  839/io.shelly.0
              tcp        0      0 192.168.178.210:2010    0.0.0.0:*               LISTEN      1001       420277988  958/io.hm-rpc.0
              tcp        0      0 192.168.178.210:12004   0.0.0.0:*               LISTEN      1001       420277347  720/io.wolf.0
              tcp6       0      0 ::1:25                  :::*                    LISTEN      0          420272117  300/master
              tcp6       0      0 :::5355                 :::*                    LISTEN      104        420272188  115/systemd-resolve
              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       420292314  3805/io.web.0
              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       420274620  399/io.admin.0
              tcp6       0      0 :::8000                 :::*                    LISTEN      1001       420302987  1363/io.upnp.0
              tcp6       0      0 :::7999                 :::*                    LISTEN      1001       420277299  679/io.geofency.0
              tcp6       0      0 :::111                  :::*                    LISTEN      0          420268932  1/init
              tcp6       0      0 :::22                   :::*                    LISTEN      0          420269678  1/init
              tcp6       0      0 :::3500                 :::*                    LISTEN      1001       420275608  601/io.sonos.0
              udp        0      0 0.0.0.0:55450           0.0.0.0:*                           1001       420282248  1363/io.upnp.0
              udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       420278409  746/io.tuya.0
              udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       420278410  746/io.tuya.0
              udp        0      0 127.0.0.53:53           0.0.0.0:*                           104        420272190  115/systemd-resolve
              udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          420268931  1/init
              udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       420284703  1363/io.upnp.0
              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       420333590  3917/io.mihome-vacu
              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       420282487  1122/io.chromecast.
              udp        0      0 192.168.178.210:5353    0.0.0.0:*                           1001       420276705  809/io.tr-064.1
              udp        0      0 192.168.178.210:5353    0.0.0.0:*                           1001       420275940  783/io.tr-064.0
              udp        0      0 0.0.0.0:5355            0.0.0.0:*                           104        420272184  115/systemd-resolve
              udp6       0      0 :::111                  :::*                                0          420268933  1/init
              udp6       0      0 :::5355                 :::*                                104        420272187  115/systemd-resolve
              2023-02-23 17:10:04.449  - info: synology.0 (571) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:10:05.114  - info: weatherunderground.0 (6244) starting. Version 3.4.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v16.19.1, js-controller: 4.0.24
              2023-02-23 17:10:16.609  - info: synology.1 (653) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:10:23.203  - info: nuki.0 (2784) Bridge Info requested: http://192.168.178.67:8080/info?ts=2023-02-23T16:10:23Z&rnr=15448&hash=9dfb013ef501395b066ef1265989c8f817ac9fc47d1c3b41d9ddb237d61fc32d
              2023-02-23 17:10:26.211  - info: nuki.0 (2784) Lock list requested: http://192.168.178.67:8080/list?ts=2023-02-23T16:10:26Z&rnr=62489&hash=68b5126ab027c3ddb86c65f65a32c8d24cf6959339e51378387275052131c859
              2023-02-23 17:10:36.325  - info: weatherunderground.0 (6244) Terminated (NO_ERROR): Without reason
              2023-02-23 17:10:36.837  - info: host.iobroker-Final instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
              2023-02-23 17:10:37.760  - info: synology.0 (571) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:10:38.477  - info: shelly.0 (839) [MQTT] Device with client id "shelly1-349454708DEB" connected!
              2023-02-23 17:10:39.458  - info: web.0 (3805) <== Disconnect system.user.admin from ::ffff:192.168.178.102 energiefluss.0
              2023-02-23 17:10:41.363  - info: admin.0 (399) ==> Connected system.user.admin from ::ffff:192.168.178.102
              2023-02-23 17:10:41.922  - info: web.0 (3805) ==> Connected system.user.admin from ::ffff:192.168.178.102
              2023-02-23 17:10:42.241  - info: admin.0 (399) <== Disconnect system.user.admin from ::ffff:192.168.178.102 vis.0
              2023-02-23 17:10:49.712  - info: web.0 (3805) <== Disconnect system.user.admin from ::ffff:192.168.178.102 energiefluss.0
              2023-02-23 17:10:49.744  - info: web.0 (3805) ==> Connected system.user.admin from ::ffff:192.168.178.102
              2023-02-23 17:10:50.017  - info: synology.1 (653) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:11:11.168  - info: synology.0 (571) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:11:23.204  - info: nuki.0 (2784) Bridge Info requested: http://192.168.178.67:8080/info?ts=2023-02-23T16:11:23Z&rnr=59217&hash=6d1c3f8a1bd060ac94170a8b1bd91be3086255f9536ccfec90f1b06d5ffc5813
              2023-02-23 17:11:23.364  - info: synology.1 (653) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:11:26.206  - info: nuki.0 (2784) Lock list requested: http://192.168.178.67:8080/list?ts=2023-02-23T16:11:26Z&rnr=34439&hash=3547d7e31ff6c58a5aeec9e0173b69b9cc03731893351de05710e844ba6207be
              2023-02-23 17:11:44.544  - info: synology.0 (571) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:11:56.672  - info: synology.1 (653) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:12:17.856  - info: synology.0 (571) Connecting to Synology 192.168.178.101:5000
              2023-02-23 17:12:23.206  - info: nuki.0 (2784) Bridge Info requested: http://192.168.178.67:8080/info?ts=2023-02-23T16:12:23Z&rnr=2886&hash=730ec8cad7f1d652383bb9791e1b03356e0c05b655bb7d30406e37e9744388bf
              2023-02-23 17:12:26.204  - info: nuki.0 (2784) Lock list requested: http://192.168.178.67:8080/list?ts=2023-02-23T16:12:26Z&rnr=21939&hash=3db9a6c9162b0df985c2533cf82a100e752ec077a93abe75c95e4d0af700ca22
              iob diag has finished.
                                   v.2023-01-02
              Installation:           lxc
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
                                      admin                   6.3.5
              Objects type: jsonl
              States  type: jsonl
              Status admin:
              Objects:                33299
              States:                 25869
              61M     /opt/iobroker/iobroker-data/states.jsonl
                Dann nochmal:
                LongbowL Offline
                LongbowL Offline
                Longbow
                drwxrwxr-x+    2 iobroker iobroker   4096 Feb  2 19:12 encodeurl
                drwxrwxr-x+    2 iobroker iobroker   4096 Feb 21 20:41 eufy-security-client
                drwxrwxr-x+    3 iobroker iobroker   4096 Feb 23 17:14 eufy-security-ws
                drwxrwxr-x+    6 iobroker iobroker   4096 Feb  2 19:12 express-fileupload
                drwxrwxr-x+    3 iobroker iobroker   4096 Feb  3 08:09 p-queue
                drwxrwxr-x+    2 iobroker iobroker   4096 Feb  2 19:15 parseuri
                drwxrwxr-x+    2 iobroker iobroker   4096 Feb  2 19:12 parseurl
                drwxrwxr-x+    2 iobroker iobroker   4096 Feb  5 12:10 queue-microtask
                drwxrwxr-x+    3 iobroker iobroker   4096 Feb  5 12:10 reusify
                drwxrwxr-x+    2 iobroker iobroker   4096 Feb  5 12:10 yocto-queue
                • LongbowL Longbow
                  @wendy2702
                  wendy2702W Online
                  wendy2702W Online
                  @longbow sagte in Eufy-Security Adapter installiert sich nicht.:
                  @wendy2702
                  Zuerst die "Mülltonne" hinter der Instanz, dann die "Mülltonne" hinter dem Adapter.
                  Dann öffnet sich jeweils ein Fenster mit dem Log. Zeige die mal
                    @wendy2702
                    LongbowL Offline
                    LongbowL Offline
                    Longbow
                    @wendy2702
                    Also ich kann Ihn nicht löschen, also ganz. Oder wie erreicht man das?
                    @Thomas-Braun
                    Und was erkennen können, aus dem log?
                    Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                    • LongbowL Longbow
                      @wendy2702
                      @Thomas-Braun
                      Nein, soweit unauffällig.
                      Vielleicht das Boot Target noch auf Multiuser setzen und die beiden Updates einspielen.
                      • LongbowL Longbow
                        @wendy2702
                        @Thomas-Braun
                        wendy2702W Online
                        wendy2702W Online
                        @wendy2702
                        Ne, passt so.
                        Schau mal bitte mit dem „ls -la ….“ Befehl von vorhin ob es in Node-modules noch was von Eufy gibt
                          @wendy2702
                          Ne, passt so.
                          LongbowL Offline
                          LongbowL Offline
                          Longbow
                          @wendy2702
                          das ist jetzt mit dem Befehl gekommen:
                            LongbowL Offline
                            LongbowL Offline
                            Longbow
                            ok was bitte, da bin raus... bin ja nicht so fit und neuling.
                            • LongbowL Longbow
                              wendy2702W Online
                              wendy2702W Online
                              @longbow
                              rm -R opt/iobroker/node_modules/eufy-security-client
                              rm -R opt/iobroker/node_modules/eufy-security-ws
                              cd /opt/iobroker/
                              sudo -u iobroker npm cache clean --force
                              Dann nochmal bitte den eusec Adapter per Admin, nicht Github oder Link, installieren und das log hier posten.
                                @longbow
                                cd /opt/iobroker/
                                LongbowL Offline
                                LongbowL Offline
                                Longbow
                                @wendy2702
                                verrückt, jetzt kommt das bei deinem Befehl
                                cd /opt/iobroker/
                                rm: cannot remove 'opt/iobroker/node_modules/eufy-security-client': No such file or directory
                                rm: cannot remove 'opt/iobroker/node_modules/eufy-security-ws': No such file or directory
                                Und wenn ich den ls Befehl mache, kommt das
                                drwxrwxr-x+    2 iobroker iobroker   4096 Feb  2 19:12 encodeurl/node_modules/ |grep eu
                                • LongbowL Longbow
                                  @wendy2702
                                  cd /opt/iobroker/
                                  wendy2702W Online
                                  wendy2702W Online
                                  @longbow Sorry. Probier mal so:
                                  rm -R /opt/iobroker/node_modules/eufy-security-client
                                  rm -R /opt/iobroker/node_modules/eufy-security-ws
                                    LongbowL Offline
                                    LongbowL Offline
                                    Longbow
                                    @wendy2702
                                    Danke, damit ging es zulöschen, mit de Befehl ls war es dann weg aus der Liste.
                                    Dann über den Admin installiert und kam keine Fehlermeldung... aber dann in Portokoll von iobroker weiterhin diese Fehlermeldung:
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	instance system.adapter.eusec.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: }
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: requestPath: 'eufy-security-client'
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/eufy-security-client/package.json',
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1069:32) {
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1245:10)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1191:14)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.eusec/build/main.js:35:32)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:108:18)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1093:19)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:866:27)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:1007:27)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:638:18)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:425:19)
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/eufy-security-client/build/index.js'. Please verify that the package.json has a valid "main" entry
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: ^
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: throw err;
                                    host.iobroker-Final
                                    2023-02-24 11:31:18.464	error	Caught by controller[0]: node:internal/modules/cjs/loader:433
                                    • wendy2702W Online
                                      wendy2702W Online
                                      Kannst du jetzt nochmal zeigen bitte:
                                      ls -la /opt/iobroker/node_modules/eufy-security-client/
                                        LongbowL Offline
                                        LongbowL Offline
                                        Longbow
                                        @wendy2702
                                        kein Ding, bitte :-)
                                        ~$ ls -la /opt/iobroker/node_modules/eufy-security-client/
                                        total 92
                                        drwxrwxr-x+    2 iobroker iobroker  4096 Feb 24 11:34 .
                                        drwxrwxr-x+ 1119 iobroker iobroker 36864 Feb 24 11:34 ..
                                        -rw-rw-r--+    1 iobroker iobroker  1096 Feb 24 11:34 LICENSE
                                        -rw-rw-r--+    1 iobroker iobroker 38631 Feb 24 11:34 README.md
                                        -rw-rw-r--+    1 iobroker iobroker  2061 Feb 24 11:34 package.json
                                        • LongbowL Longbow
                                          @wendy2702
                                          total 92
                                          wendy2702W Online
                                          wendy2702W Online
                                          @longbow
                                          Echt komsich warum er das bei dir nicht sauber installiert.
                                          cd /opt/iobroker/node_modules/
                                          npm i eufy-security-client --verbose
                                          Es sollten 69 Pakete installiert werden und das log so aussehen:
                                          npm verb cli /usr/bin/node /usr/bin/npm
                                          npm info using npm@8.19.3
                                          npm info using node@v16.19.0
                                          npm timing npm:load:whichnode Completed in 0ms
                                          npm timing config:load:defaults Completed in 2ms
                                          npm timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 29ms
                                          npm timing config:load:builtin Completed in 29ms
                                          npm timing config:load:cli Completed in 3ms
                                          npm timing config:load:env Completed in 1ms
                                          npm timing config:load:file:/opt/iobroker/.npmrc Completed in 1ms
                                          npm timing config:load:project Completed in 3ms
                                          npm timing config:load:file:/home/iobroker/.npmrc Completed in 0ms
                                          npm timing config:load:user Completed in 0ms
                                          npm timing config:load:file:/usr/etc/npmrc Completed in 0ms
                                          npm timing config:load:global Completed in 0ms
                                          npm timing config:load:validate Completed in 1ms
                                          npm timing config:load:credentials Completed in 1ms
                                          npm timing config:load:setEnvs Completed in 0ms
                                          npm timing config:load Completed in 40ms
                                          npm timing npm:load:configload Completed in 40ms
                                          npm timing npm:load:mkdirpcache Completed in 1ms
                                          npm timing npm:load:mkdirplogs Completed in 0ms
                                          npm verb title npm i eufy-security-client
                                          npm verb argv "i" "eufy-security-client" "--loglevel" "verbose"
                                          npm timing npm:load:setTitle Completed in 2ms
                                          npm timing config:load:flatten Completed in 3ms
                                          npm timing npm:load:display Completed in 17ms
                                          npm verb logfile logs-max:10 dir:/home/iobroker/.npm/_logs
                                          npm verb logfile /home/iobroker/.npm/_logs/2023-02-24T15_17_02_740Z-debug-0.log
                                          npm timing npm:load:logFile Completed in 8ms
                                          npm timing npm:load:timers Completed in 0ms
                                          npm timing npm:load:configScope Completed in 0ms
                                          npm timing npm:load Completed in 73ms
                                          npm timing arborist:ctor Completed in 0ms
                                          npm timing idealTree:init Completed in 530ms
                                          npm timing idealTree:userRequests Completed in 2ms
                                          npm http fetch GET 200 https://registry.npmjs.org/eufy-security-client 466ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/got 44ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/protobuf-typescript 47ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/node-rsa 48ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/crypto-js 48ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/ts-log 49ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/tiny-typed-emitter 50ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/i18n-iso-countries 50ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@cospired%2fi18n-iso-languages 51ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/sweet-collections 51ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/mqtt 52ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/p-throttle 53ms (cache hit)
                                          npm timing idealTree:#root Completed in 534ms
                                          npm http fetch GET 200 https://registry.npmjs.org/diacritics 89ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/commist 89ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/concat-stream 90ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/debug 91ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/duplexify 91ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/help-me 92ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/minimist 92ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/mqtt-packet 97ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/rfdc 97ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/split2 97ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/ws 99ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2faspromise 104ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2fbase64 104ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2fcodegen 106ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2feventemitter 107ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2ffetch 110ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2ffloat 111ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2finquire 112ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2fpath 112ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2fpool 113ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@protobufjs%2futf8 114ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@types%2flong 115ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/@types%2fnode 121ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/long 222ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/number-allocator 232ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/readable-stream 233ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/reinterval 234ms (cache hit)
                                          npm timing idealTree:node_modules/eufy-security-client Completed in 273ms
                                          npm timing idealTree:node_modules/@cospired/i18n-iso-languages Completed in 0ms
                                          npm timing idealTree:node_modules/crypto-js Completed in 0ms
                                          npm timing idealTree:node_modules/i18n-iso-countries Completed in 2ms
                                          npm timing idealTree:node_modules/diacritics Completed in 0ms
                                          npm http fetch GET 200 https://registry.npmjs.org/bufferutil 9ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/utf-8-validate 3ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/leven 31ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/typedarray 32ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/ms 32ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/stream-shift 32ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/glob 33ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/js-sdsl 33ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/string_decoder 34ms (cache hit)
                                          npm timing idealTree:node_modules/mqtt Completed in 85ms
                                          npm timing idealTree:node_modules/commist Completed in 1ms
                                          npm timing idealTree:node_modules/concat-stream Completed in 3ms
                                          npm timing idealTree:node_modules/duplexify Completed in 3ms
                                          npm http fetch GET 200 https://registry.npmjs.org/fs.realpath 11ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/inflight 11ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/minimatch 11ms (cache hit)
                                          npm http fetch GET 200 https://registry.npmjs.org/path-is-absolute 11ms (cache hit)
                                          npm timing idealTree:node_modules/help-me Completed in 24ms
                                          npm http fetch GET 200 https://registry.npmjs.org/brace-expansion 9ms (cache hit)
                                          npm timing idealTree:node_modules/glob Completed in 38ms
                                          npm timing idealTree:node_modules/fs.realpath Completed in 0ms
                                          npm timing idealTree:node_modules/inflight Completed in 0ms
                                          npm timing idealTree:node_modules/leven Completed in 0ms
                                          npm timing idealTree:node_modules/minimist Completed in 0ms
                                          npm timing idealTree:node_modules/mqtt-packet Completed in 1ms
                                          npm timing idealTree:node_modules/node-rsa Completed in 0ms
                                          npm timing idealTree:node_modules/number-allocator Completed in 3ms
                                          npm timing idealTree:node_modules/js-sdsl Completed in 0ms
                                          npm timing idealTree:node_modules/p-throttle Completed in 0ms
                                          npm timing idealTree:node_modules/path-is-absolute Completed in 0ms
                                          npm timing idealTree:node_modules/protobuf-typescript Completed in 29ms
                                          npm timing idealTree:node_modules/@protobufjs/aspromise Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/base64 Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/codegen Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/eventemitter Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/fetch Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/float Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/inquire Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/path Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/pool Completed in 0ms
                                          npm timing idealTree:node_modules/@protobufjs/utf8 Completed in 0ms
                                          npm timing idealTree:node_modules/@types/long Completed in 0ms
                                          npm timing idealTree:node_modules/long Completed in 0ms
                                          npm timing idealTree:node_modules/reinterval Completed in 0ms
                                          npm timing idealTree:node_modules/rfdc Completed in 1ms
                                          npm timing idealTree:node_modules/split2 Completed in 1ms
                                          npm timing idealTree:node_modules/stream-shift Completed in 0ms
                                          npm timing idealTree:node_modules/sweet-collections Completed in 0ms
                                          npm timing idealTree:node_modules/tiny-typed-emitter Completed in 0ms
                                          npm timing idealTree:node_modules/ts-log Completed in 0ms
                                          npm timing idealTree:node_modules/typedarray Completed in 0ms
                                          npm http fetch GET 200 https://registry.npmjs.org/safe-buffer 7ms (cache hit)
                                          npm timing idealTree:node_modules/concat-stream/node_modules/readable-stream Completed in 10ms
                                          npm timing idealTree:node_modules/concat-stream/node_modules/string_decoder Completed in 1ms
                                          npm timing idealTree:node_modules/concat-stream/node_modules/safe-buffer Completed in 0ms
                                          npm timing idealTree:node_modules/duplexify/node_modules/readable-stream Completed in 6ms
                                          npm timing idealTree:node_modules/duplexify/node_modules/string_decoder Completed in 1ms
                                          npm timing idealTree:node_modules/duplexify/node_modules/safe-buffer Completed in 0ms
                                          npm timing idealTree:node_modules/eufy-security-client/node_modules/got Completed in 0ms
                                          npm http fetch GET 200 https://registry.npmjs.org/concat-map 3ms (cache hit)
                                          npm timing idealTree:node_modules/glob/node_modules/minimatch Completed in 7ms
                                          npm timing idealTree:node_modules/glob/node_modules/brace-expansion Completed in 1ms
                                          npm timing idealTree:node_modules/concat-map Completed in 0ms
                                          npm timing idealTree:node_modules/help-me/node_modules/readable-stream Completed in 2ms
                                          npm timing idealTree:node_modules/help-me/node_modules/string_decoder Completed in 1ms
                                          npm timing idealTree:node_modules/help-me/node_modules/safe-buffer Completed in 0ms
                                          npm timing idealTree:node_modules/mqtt-packet/node_modules/debug Completed in 3ms
                                          npm timing idealTree:node_modules/mqtt-packet/node_modules/ms Completed in 0ms
                                          npm timing idealTree:node_modules/mqtt/node_modules/debug Completed in 1ms
                                          npm timing idealTree:node_modules/mqtt/node_modules/ms Completed in 0ms
                                          npm timing idealTree:node_modules/mqtt/node_modules/readable-stream Completed in 1ms
                                          npm timing idealTree:node_modules/mqtt/node_modules/string_decoder Completed in 0ms
                                          npm timing idealTree:node_modules/mqtt/node_modules/safe-buffer Completed in 0ms
                                          npm timing idealTree:node_modules/mqtt/node_modules/ws Completed in 0ms
                                          npm timing idealTree:node_modules/number-allocator/node_modules/debug Completed in 2ms
                                          npm timing idealTree:node_modules/number-allocator/node_modules/ms Completed in 0ms
                                          npm timing idealTree:node_modules/protobuf-typescript/node_modules/@types/node Completed in 0ms
                                          npm timing idealTree:node_modules/split2/node_modules/readable-stream Completed in 2ms
                                          npm timing idealTree:node_modules/split2/node_modules/string_decoder Completed in 1ms
                                          npm timing idealTree:node_modules/split2/node_modules/safe-buffer Completed in 0ms
                                          npm timing idealTree:buildDeps Completed in 1067ms
                                          npm timing idealTree:fixDepFlags Completed in 22ms
                                          npm timing idealTree Completed in 1631ms
                                          npm timing reify:loadTrees Completed in 1632ms
                                          npm timing reify:diffTrees Completed in 17ms
                                          npm timing reify:retireShallow Completed in 1ms
                                          npm timing reify:createSparse Completed in 17ms
                                          npm timing reify:loadBundles Completed in 0ms
                                          npm verb reify failed optional dependency /opt/iobroker/node_modules/fsevents
                                          npm timing reifyNode:node_modules/fsevents Completed in 20ms
                                          npm timing reifyNode:node_modules/@types/long Completed in 561ms
                                          npm timing reifyNode:node_modules/path-is-absolute Completed in 562ms
                                          npm timing reifyNode:node_modules/inflight Completed in 562ms
                                          npm timing reifyNode:node_modules/leven Completed in 562ms
                                          npm timing reifyNode:node_modules/concat-stream Completed in 565ms
                                          npm timing reifyNode:node_modules/glob/node_modules/brace-expansion Completed in 568ms
                                          npm timing reifyNode:node_modules/mqtt-packet/node_modules/ms Completed in 569ms
                                          npm timing reifyNode:node_modules/mqtt/node_modules/ms Completed in 575ms
                                          npm timing reifyNode:node_modules/p-throttle Completed in 582ms
                                          npm timing reifyNode:node_modules/number-allocator/node_modules/ms Completed in 584ms
                                          npm timing reifyNode:node_modules/fs.realpath Completed in 589ms
                                          npm timing reifyNode:node_modules/stream-shift Completed in 589ms
                                          npm timing reifyNode:node_modules/diacritics Completed in 590ms
                                          npm timing reifyNode:node_modules/tiny-typed-emitter Completed in 590ms
                                          npm timing reifyNode:node_modules/help-me/node_modules/string_decoder Completed in 593ms
                                          npm timing reifyNode:node_modules/duplexify/node_modules/string_decoder Completed in 594ms
                                          npm timing reifyNode:node_modules/concat-stream/node_modules/string_decoder Completed in 594ms
                                          npm timing reifyNode:node_modules/mqtt/node_modules/string_decoder Completed in 595ms
                                          npm timing reifyNode:node_modules/@protobufjs/path Completed in 600ms
                                          npm timing reifyNode:node_modules/@protobufjs/fetch Completed in 602ms
                                          npm timing reifyNode:node_modules/@protobufjs/eventemitter Completed in 601ms
                                          npm timing reifyNode:node_modules/@protobufjs/codegen Completed in 602ms
                                          npm timing reifyNode:node_modules/@protobufjs/base64 Completed in 602ms
                                          npm timing reifyNode:node_modules/@protobufjs/aspromise Completed in 603ms
                                          npm timing reifyNode:node_modules/glob/node_modules/minimatch Completed in 605ms
                                          npm timing reifyNode:node_modules/split2/node_modules/string_decoder Completed in 606ms
                                          npm timing reifyNode:node_modules/@protobufjs/pool Completed in 612ms
                                          npm timing reifyNode:node_modules/split2 Completed in 613ms
                                          npm timing reifyNode:node_modules/reinterval Completed in 613ms
                                          npm timing reifyNode:node_modules/commist Completed in 614ms
                                          npm timing reifyNode:node_modules/split2/node_modules/safe-buffer Completed in 618ms
                                          npm timing reifyNode:node_modules/help-me/node_modules/safe-buffer Completed in 618ms
                                          npm timing reifyNode:node_modules/duplexify/node_modules/safe-buffer Completed in 619ms
                                          npm timing reifyNode:node_modules/concat-stream/node_modules/safe-buffer Completed in 619ms
                                          npm timing reifyNode:node_modules/mqtt/node_modules/safe-buffer Completed in 620ms
                                          npm timing reifyNode:node_modules/concat-map Completed in 627ms
                                          npm timing reifyNode:node_modules/duplexify Completed in 629ms
                                          npm timing reifyNode:node_modules/number-allocator/node_modules/debug Completed in 632ms
                                          npm timing reifyNode:node_modules/mqtt-packet/node_modules/debug Completed in 633ms
                                          npm timing reifyNode:node_modules/mqtt/node_modules/debug Completed in 635ms
                                          npm timing reifyNode:node_modules/@protobufjs/utf8 Completed in 644ms
                                          npm timing reifyNode:node_modules/glob Completed in 644ms
                                          npm timing reifyNode:node_modules/@protobufjs/float Completed in 655ms
                                          npm timing reifyNode:node_modules/@protobufjs/inquire Completed in 659ms
                                          npm timing reifyNode:node_modules/typedarray Completed in 658ms
                                          npm timing reifyNode:node_modules/rfdc Completed in 663ms
                                          npm timing reifyNode:node_modules/long Completed in 694ms
                                          npm timing reifyNode:node_modules/number-allocator Completed in 702ms
                                          npm timing reifyNode:node_modules/mqtt/node_modules/ws Completed in 740ms
                                          npm timing reifyNode:node_modules/minimist Completed in 750ms
                                          npm timing reifyNode:node_modules/mqtt-packet Completed in 754ms
                                          npm timing reifyNode:node_modules/help-me Completed in 756ms
                                          npm timing reifyNode:node_modules/help-me/node_modules/readable-stream Completed in 759ms
                                          npm timing reifyNode:node_modules/duplexify/node_modules/readable-stream Completed in 760ms
                                          npm timing reifyNode:node_modules/concat-stream/node_modules/readable-stream Completed in 759ms
                                          npm timing reifyNode:node_modules/mqtt/node_modules/readable-stream Completed in 760ms
                                          npm timing reifyNode:node_modules/split2/node_modules/readable-stream Completed in 764ms
                                          npm timing reifyNode:node_modules/ts-log Completed in 771ms
                                          npm timing reifyNode:node_modules/node-rsa Completed in 776ms
                                          npm timing reifyNode:node_modules/sweet-collections Completed in 796ms
                                          npm timing reifyNode:node_modules/@cospired/i18n-iso-languages Completed in 818ms
                                          npm timing reifyNode:node_modules/eufy-security-client/node_modules/got Completed in 859ms
                                          npm timing reifyNode:node_modules/crypto-js Completed in 862ms
                                          npm timing reifyNode:node_modules/protobuf-typescript/node_modules/@types/node Completed in 874ms
                                          npm timing reifyNode:node_modules/mqtt Completed in 875ms
                                          npm timing reifyNode:node_modules/i18n-iso-countries Completed in 918ms
                                          npm timing reifyNode:node_modules/js-sdsl Completed in 1008ms
                                          npm timing reifyNode:node_modules/eufy-security-client Completed in 1011ms
                                          npm WARN deprecated protobuf-typescript@6.8.8: Package no longer supported. Contact Support at https://www.npmjs.com/support for more info.
                                          npm timing reifyNode:node_modules/protobuf-typescript Completed in 1690ms
                                          npm timing reify:unpack Completed in 1695ms
                                          npm timing reify:unretire Completed in 0ms
                                          npm timing build:queue Completed in 3ms
                                          npm timing build:link:node_modules/mqtt Completed in 4ms
                                          npm timing build:link:node_modules/protobuf-typescript Completed in 2ms
                                          npm timing build:link Completed in 5ms
                                          npm info run protobuf-typescript@6.8.8 postinstall node_modules/protobuf-typescript node scripts/postinstall
                                          npm info run protobuf-typescript@6.8.8 postinstall { code: 0, signal: null }
                                          npm timing build:run:postinstall:node_modules/protobuf-typescript Completed in 68ms
                                          npm timing build:run:postinstall Completed in 69ms
                                          npm timing build:deps Completed in 79ms
                                          npm timing build Completed in 79ms
                                          npm timing reify:build Completed in 79ms
                                          npm timing reify:trash Completed in 1ms
                                          npm timing reify:save Completed in 161ms
                                          npm timing reify Completed in 3760ms
                                          added 69 packages in 4s
                                          50 packages are looking for funding
                                            run `npm fund` for details
                                          npm timing command:i Completed in 3769ms
                                          npm verb exit 0
                                          npm timing npm Completed in 3981ms
                                          npm info ok
