  4. Zigbee Adapter schaltet immer wieder auf rot
    5.5k
50 Beiträge 6 Kommentatoren 7.3k Aufrufe 5 Beobachtet
  • A Airmaxchen
    Das ändert leider nicht viel.
    Folgendes log ist mit Loglevel GEBUG ab manuellem Neustart des Adapters bis zum Wechsel auf rot und dann wieder grün.
    Wieder als .txt weil es zu groß für das Forum ist: Zigbee Log 2.txt
    wendy2702W Online
    wendy2702W Online
    @airmaxchen Mach mal ein Log und achte auf die zeit wann rot wird und wieder grün damit man nach den Zeitstempeln im log suchen kann.
    Aktuell sehe ich nur sowas:
    zigbee.0
    2023-02-23 11:44:11.292	debug	DeviceAvailability:Non-pingable device 0x00158d000465510e lumi.remote.b286acn01 was last seen '968.94' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.292	debug	DeviceAvailability:Non-pingable device 0x000d6f000f24030d Lightify Switch Mini was last seen '1438.885' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.292	debug	DeviceAvailability:Non-pingable device 0x0017880106ebdda3 RWL021 was last seen '138847.955' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.291	debug	DeviceAvailability:Non-pingable device 0x00158d00029a7687 lumi.sensor_cube.aqgl01 was last seen '2124.233' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.291	debug	DeviceAvailability:Non-pingable device 0x00158d00022c9fe9 lumi.sensor_switch was last seen '1977.674' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.291	debug	DeviceAvailability:Non-pingable device 0x00158d00054cf4fe lumi.sensor_magnet.aq2 was last seen '1121.9' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.291	debug	DeviceAvailability:Non-pingable device 0x00158d0002720ee2 lumi.weather was last seen '1547.867' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.291	debug	DeviceAvailability:Non-pingable device 0x00158d00024a95d9 lumi.sensor_wleak.aq1 was last seen '1978.768' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.290	debug	DeviceAvailability:Non-pingable device 0x00158d00041ebece lumi.sensor_switch was last seen '2288.074' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.290	debug	DeviceAvailability:Non-pingable device 0x00158d0002c9e6a2 lumi.sensor_magnet.aq2 was last seen '290.389' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.290	debug	DeviceAvailability:Non-pingable device 0x00158d000418aa49 lumi.weather was last seen '1099.279' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.289	debug	DeviceAvailability:Non-pingable device 0x00158d000270d0c3 lumi.sensor_wleak.aq1 was last seen '1843.393' seconds ago.
    zigbee.0
    2023-02-23 11:44:11.289	debug	DeviceAvailability:Non-pingable device 0x00158d00023fa627 lumi.sensor_wleak.aq1 was last seen '2506.939' seconds ago.
    Keine Ahnung ob diese nicht Erreichbarkeit eine Ursache sein kann.
    • A Airmaxchen
      arteckA Offline
      arteckA Offline
      arteck
      @airmaxchen nochmal.... INFO nicht DEBUG... egal was ein anderer sagt...
      dann ab adapter Start
      wendy2702W A 2 Antworten Letzte Antwort
      • arteckA arteck
        wendy2702W Online
        wendy2702W Online
        @arteck sagte in Zigbee Adapter schaltet immer wieder auf rot:
        Nur mal so,
        was steht in Info drin was nicht in Debug enthalten ist? Kann ich für die Zukunft was lernen.
        • wendy2702W wendy2702
          Nur mal so,
          arteckA Offline
          arteckA Offline
          arteck
          @wendy2702 sagte in Zigbee Adapter schaltet immer wieder auf rot:
          nix das ist es ja.. im zigbee adapter geben wir (für diesen fall) zu viele informationen im Debug aus..
          hier gehts es nur warum der adapter sich von der hardware trennt..
          ich such mir dann einen wolf ab..
          sonst bin ich bei dir..
          • arteckA arteck
            deswegen ja als zusätzliche Info zum normalen log und dabei die Frage nach dem Timestamp wann die Instanz auf rot geht.
            • arteckA arteck
              Airmaxchen
              @arteck Ich habe mit INFO oben gepostet. Da tut sich nach dem Start des Adapters gar nichts mehr. Egal ober der rot/grün-Wechsel kommt oder ich etwas schalte. Der Adapter meldet unter INFO gar nichts mehr.
              Das ist das Log direkt nach einem manuellen Neustart meinerseits:
              zigbee.0
              2023-02-23 11:29:16.149	info	Zigbee started
              zigbee.0
              2023-02-23 11:29:16.148	info	0x04cd15fffe02c1fb (addr 55511): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.147	info	0x04cd15fffe0673f1 (addr 985): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.146	info	0x04cd15fffe066dad (addr 56600): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.145	info	0xcc86ecfffe35ba8e (addr 27036): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.143	info	0x60a423fffe62111b (addr 33876): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.142	info	0xcc86ecfffef3c061 (addr 38390): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.141	info	0xcc86ecfffef3c8a4 (addr 18992): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.139	info	0x00158d000465510e (addr 12286): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.138	info	0x000d6f000f24030d (addr 26342): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.136	info	0x0017880106ebdda3 (addr 34902): 324131092621 - Philips Hue dimmer switch (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.135	info	0x00158d00029a7687 (addr 21159): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.135	info	0x00158d00022c9fe9 (addr 52540): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.134	info	0x00158d00054cf4fe (addr 32636): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.133	info	0x00158d0002720ee2 (addr 28024): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.133	info	0x00158d00024a95d9 (addr 8745): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.132	info	0x0017880102b14f9a (addr 41378): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
              zigbee.0
              2023-02-23 11:29:16.131	info	0x0017880102b35756 (addr 15193): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
              zigbee.0
              2023-02-23 11:29:16.130	info	0x84ba20fffe6e7cf6 (addr 25227): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
              zigbee.0
              2023-02-23 11:29:16.129	info	0x0017880102b32b5d (addr 2841): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
              zigbee.0
              2023-02-23 11:29:16.128	info	0x00158d00041ebece (addr 15657): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.127	info	0x00158d0002c9e6a2 (addr 15143): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.126	info	0x0017880102b2703f (addr 52224): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
              zigbee.0
              2023-02-23 11:29:16.125	info	0x842e14fffe6cc85d (addr 37614): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
              zigbee.0
              2023-02-23 11:29:16.124	info	0x842e14fffe631b1e (addr 41611): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
              zigbee.0
              2023-02-23 11:29:16.122	info	0x84ba20fffe655268 (addr 1765): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
              zigbee.0
              2023-02-23 11:29:16.121	info	0x086bd7fffe5db6f4 (addr 20632): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
              zigbee.0
              2023-02-23 11:29:16.120	info	0x00158d000418aa49 (addr 44810): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.119	info	0x04cd15fffe02dc9d (addr 48475): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
              zigbee.0
              2023-02-23 11:29:16.118	info	0x00158d000270d0c3 (addr 41428): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.117	info	0x00158d00023fa627 (addr 55296): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
              zigbee.0
              2023-02-23 11:29:16.112	info	0x003c84fffe8c866e (addr 65006): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
              zigbee.0
              2023-02-23 11:29:16.061	info	Currently 31 devices are joined:
              zigbee.0
              2023-02-23 11:29:16.020	info	--> transmitPower : high+
              zigbee.0
              2023-02-23 11:29:16.010	info	Unable to disable LED, unsupported function.
              zigbee.0
              2023-02-23 11:29:16.004	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
              zigbee.0
              2023-02-23 11:29:15.889	warn	Extended PAN ID is reversed (expected=beb49f21004b1200, actual=00124b00219fb4be)
              zigbee.0
              2023-02-23 11:29:15.299	info	Installed Version: iobroker.zigbee@1.8.10
              zigbee.0
              2023-02-23 11:29:13.863	info	Starting Zigbee npm ...
              zigbee.0
              2023-02-23 11:29:13.861	info	delete old Backup files. keep only last 10
              zigbee.0
              2023-02-23 11:29:13.137	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
              zigbee.0
              2023-02-23 11:29:04.151	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
              zigbee.0
              2023-02-23 11:29:04.150	info	terminating
              zigbee.0
              2023-02-23 11:29:03.613	info	Zigbee: disabling joining new devices.
              zigbee.0
              2023-02-23 11:29:03.532	info	cleaned everything up...
              zigbee.0
              2023-02-23 11:29:03.532	info	Got terminate signal TERMINATE_YOURSELF
              zigbee.0
              2023-02-23 11:17:24.550	info	Loglevel changed from "silly" to "info"
              • A Airmaxchen
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                zigbee.0
                @airmaxchen sagte in Zigbee Adapter schaltet immer wieder auf rot:
                und bei welchem Timestamp wird die Instanz rot?
                BTW sind das alles nur INFO, kein debug
                  Airmaxchen
                  @homoran sagte in Zigbee Adapter schaltet immer wieder auf rot:
                  Ja, so wie von @arteck angefragt.
                  • A Airmaxchen
                    @airmaxchen bleibt immer noch die Antwort aus für
                      Airmaxchen
                      @homoran Es gibt leider keinen genauen Timestamp für den Übergang zu rot. In dem oben geposteten "Zigbee Log2.txt" passiert es irgendwann innerhalb der vielen Zeilen. Die Logeiträge ändern sich nicht zu einem bestimmten Zeitpunkt. In dem Moment des Wechsels von grün auf rot passiert im Log nichts anderes als sonst unter DEBUG zu sehen ist.
                      • A Airmaxchen
                        aber du hast doch die Uhrzeit, wenn du davor sitzst und siehst, wann es umschlägt.
                        Mit eingeblendeter Systemuhr sogar sekundengenau
                          Airmaxchen
                          @homoran Ich habe es jetzt noch einmal gemacht.
                          Hier das Logfile im DEBUG: Zigbee Log 3.txt
                          Bei Timestamp 20:15:10 hat es von grün auf rot gewechselt und bei 20:16:08 wieder zurück auf grün.
                          • A Airmaxchen
                            AsgothianA Offline
                            AsgothianA Offline
                            Asgothian
                            Deinem Log nach jagst Du einen Geist. Der Adapter ist normal durch gelaufen. es gibt kein Anzeichen darauf das er um 20:15:10 angehalten wurde.
                            Erkennbar ist das der Adapter um 20:14:14 gestartet wurde. Was ist davor passiert ?
                            Mach bitte den folgenden Test:
                            • Adapter anhalten
                            • Log löschen
                            • Adapter starten (im INFO modus, nicht DEBUG)
                            • Laufen lassen, bis er mindestens 3 mal von rot auf grün gewechselt hat (alternativ - 10 Minuten)
                            • Log herunter laden.
                            • Alle Einträge die nicht vom Zigbee-Adapter stammen löschen, rest hier posten
                            Dann können wir sehen ob der Adapter neu startet, oder ob du nur ein Problem mit deiner Web-Oberfläche hast. Der Effekt das die Anzeige des Status im Admin nicht sekundengenau stimmt und das da mal was von rot auf grün wechselt hatte ich auch schon einmal. Meine Lösung war "Seite ohne Cache neu laden", dann war der Effekt weg.
                            A.
                            • AsgothianA Asgothian
                              • Adapter anhalten
                              • Log löschen
                              A.
                              Airmaxchen
                              @asgothian Ich habe jetzt den Test gemacht:
                              Wie schon geschrieben kommt leider im Log nichts vor.
                              Neustart des Adapters 16:20:54
                              1. rot: 16:23:50 bis 16:24:55
                              2. rot: 16:25:20 bis 16:25:27
                              3. rot: 16:26:22 bis 16:27:39
                              4. rot: 16:27:59 bis 16:28:17
                              zigbee.0
                              2023-02-24 16:21:29.866	info	Zigbee started
                              zigbee.0
                              2023-02-24 16:21:29.865	info	0x04cd15fffe02c1fb (addr 55511): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.864	info	0x04cd15fffe0673f1 (addr 985): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.863	info	0x04cd15fffe066dad (addr 56600): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.862	info	0xcc86ecfffe35ba8e (addr 27036): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.860	info	0x60a423fffe62111b (addr 33876): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.860	info	0xcc86ecfffef3c061 (addr 38390): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.859	info	0xcc86ecfffef3c8a4 (addr 18992): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.858	info	0x00158d000465510e (addr 12286): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.857	info	0x000d6f000f24030d (addr 26342): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.854	info	0x0017880106ebdda3 (addr 34902): 324131092621 - Philips Hue dimmer switch (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.853	info	0x00158d00029a7687 (addr 21159): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.853	info	0x00158d00022c9fe9 (addr 52540): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.852	info	0x00158d00054cf4fe (addr 32636): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.851	info	0x00158d0002720ee2 (addr 28024): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.851	info	0x00158d00024a95d9 (addr 8745): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.850	info	0x0017880102b14f9a (addr 41378): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                              zigbee.0
                              2023-02-24 16:21:29.850	info	0x0017880102b35756 (addr 15193): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                              zigbee.0
                              2023-02-24 16:21:29.849	info	0x84ba20fffe6e7cf6 (addr 25227): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                              zigbee.0
                              2023-02-24 16:21:29.847	info	0x0017880102b32b5d (addr 2841): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                              zigbee.0
                              2023-02-24 16:21:29.846	info	0x00158d00041ebece (addr 15657): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.846	info	0x00158d0002c9e6a2 (addr 15143): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.845	info	0x0017880102b2703f (addr 52224): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                              zigbee.0
                              2023-02-24 16:21:29.844	info	0x842e14fffe6cc85d (addr 37614): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                              zigbee.0
                              2023-02-24 16:21:29.843	info	0x842e14fffe631b1e (addr 41611): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                              zigbee.0
                              2023-02-24 16:21:29.843	info	0x84ba20fffe655268 (addr 1765): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                              zigbee.0
                              2023-02-24 16:21:29.841	info	0x086bd7fffe5db6f4 (addr 20632): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                              zigbee.0
                              2023-02-24 16:21:29.841	info	0x00158d000418aa49 (addr 44810): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.840	info	0x04cd15fffe02dc9d (addr 48475): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                              zigbee.0
                              2023-02-24 16:21:29.839	info	0x00158d000270d0c3 (addr 41428): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.838	info	0x00158d00023fa627 (addr 55296): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                              zigbee.0
                              2023-02-24 16:21:29.833	info	0x003c84fffe8c866e (addr 65006): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                              zigbee.0
                              2023-02-24 16:21:29.784	info	Currently 31 devices are joined:
                              zigbee.0
                              2023-02-24 16:21:29.776	info	--> transmitPower : high+
                              zigbee.0
                              2023-02-24 16:21:29.765	info	Unable to disable LED, unsupported function.
                              zigbee.0
                              2023-02-24 16:21:29.759	info	Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                              zigbee.0
                              2023-02-24 16:21:29.637	warn	Extended PAN ID is reversed (expected=beb49f21004b1200, actual=00124b00219fb4be)
                              zigbee.0
                              2023-02-24 16:21:29.516	info	Installed Version: iobroker.zigbee@1.8.10
                              zigbee.0
                              2023-02-24 16:21:29.248	info	Starting Zigbee npm ...
                              zigbee.0
                              2023-02-24 16:21:28.740	info	delete old Backup files. keep only last 10
                              zigbee.0
                              2023-02-24 16:21:28.674	info	starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
                              zigbee.0
                              2023-02-24 16:20:55.594	warn	Got terminate signal. Checking desired PID: 11931 vs own PID 11789
                              zigbee.0
                              2023-02-24 16:20:55.582	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              zigbee.0
                              2023-02-24 16:20:55.582	info	terminating
                              zigbee.0
                              2023-02-24 16:20:55.581	warn	Failed to stop zigbee during startup
                              zigbee.0
                              2023-02-24 16:20:54.428	info	Zigbee: disabling joining new devices.
                              zigbee.0
                              2023-02-24 16:20:54.239	info	cleaned everything up...
                              zigbee.0
                              2023-02-24 16:20:54.237	warn	Got terminate signal. Checking desired PID: 0 vs own PID 11789
                              wendy2702W AsgothianA 2 Antworten Letzte Antwort
                              • A Airmaxchen
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                zigbee.0
                                wendy2702W Online
                                wendy2702W Online
                                @airmaxchen
                                Das denn mal gemacht:
                                @asgothian sagte in Zigbee Adapter schaltet immer wieder auf rot:
                                • A Airmaxchen
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  AsgothianA Offline
                                  AsgothianA Offline
                                  Asgothian
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  zigbee.0
                                  Du schreibst Zeiten auf, lieferst aber nur ein Log welches die Zeiten die du aufschreibst nicht beinhaltest.
                                  Dazu kommt - das Log welches du lieferst kommt scheinbar aus dem Admin, nicht - wie ich erbeten habe - über "Log herunter laden" und "log einträge kürzen."
                                  Bitte das nachliefern.
                                  A.
                                    Airmaxchen
                                    @asgothian Danke für deine Mühe bis jetzt.
                                    Ich habe das Ganze jetzt nochmal gemacht. Aber wie schon oben erwähnt, erscheint in den Rotphasen nichts im Log. Es wird erst wieder etwas ins Log geschrieben, wenn ich manuell den Adapter neu starte.
                                    Was ich vielleicht einmal versuchen könnte wäre, dass ich den cc26x2r1 mittel LAN-Adapter betreibe. Dazu habe ich alles da. Das habe ich aber schon einmal versucht und da waren lange Verzögerungen (damals habe ich aber nicht auf den Status des Adapters geachtet). Es waren einfach Verzögerungen und deshalb habe ich wieder zurückgebaut auf den direkten USB-Anschluss an die Synology. Könnte das Sinn machen? Liegt das Problem eher an der Verbindung zum cc... oder am Adapter selbst?
                                    Start Adapter: 19:43:34
                                    1. rot: 19:45:36 bis 19:47:23
                                    2. rot: 19:47:48 bis 19:48:27
                                    3. rot: 19:48:53 bis 19:50:37
                                    2023-02-24 19:43:34.633 - info: host.iobroker "system.adapter.zigbee.0" enabled
                                    2023-02-24 19:43:34.869 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 21173
                                    2023-02-24 19:43:36.856 - info: zigbee.0 (21173) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
                                    2023-02-24 19:43:36.919 - info: zigbee.0 (21173) delete old Backup files. keep only last 10
                                    2023-02-24 19:43:37.114 - info: zigbee.0 (21173) Starting Zigbee npm ...
                                    2023-02-24 19:43:37.396 - error: zigbee.0 (21173) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    2023-02-24 19:43:37.397 - error: zigbee.0 (21173) Failed to start Zigbee
                                    2023-02-24 19:43:37.397 - error: zigbee.0 (21173) Error herdsman start
                                    2023-02-24 19:43:37.410 - info: zigbee.0 (21173) Installed Version: iobroker.zigbee@1.8.10
                                    2023-02-24 19:43:47.400 - info: zigbee.0 (21173) Try to reconnect. 1 attempts left
                                    2023-02-24 19:43:47.401 - info: zigbee.0 (21173) Starting Zigbee npm ...
                                    2023-02-24 19:43:47.416 - info: zigbee.0 (21173) Installed Version: iobroker.zigbee@1.8.10
                                    2023-02-24 19:43:47.438 - error: zigbee.0 (21173) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
                                    2023-02-24 19:43:47.439 - error: zigbee.0 (21173) Failed to start Zigbee
                                    2023-02-24 19:43:47.439 - error: zigbee.0 (21173) Error herdsman start
                                    2023-02-24 19:43:50.097 - info: zigbee.0 (21121) cleaned everything up...
                                    2023-02-24 19:43:50.203 - info: zigbee.0 (21121) Zigbee: disabling joining new devices.
                                    2023-02-24 19:43:51.189 - info: zigbee.0 (21121) Got terminate signal TERMINATE_YOURSELF
                                    2023-02-24 19:43:51.189 - warn: zigbee.0 (21121) Got terminate signal. Checking desired PID: 0 vs own PID 21121
                                    2023-02-24 19:43:51.189 - warn: zigbee.0 (21121) Got terminate signal. Checking desired PID: 21173 vs own PID 21121
                                    2023-02-24 19:43:51.506 - info: zigbee.0 (21121) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2023-02-24 19:43:52.829 - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                    2023-02-24 19:43:52.829 - info: host.iobroker Restart adapter system.adapter.zigbee.0 because enabled
                                    2023-02-24 19:43:53.878 - warn: zigbee.0 (21173) Got terminate signal. Checking desired PID: 0 vs own PID 21173
                                    2023-02-24 19:43:53.906 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 21202
                                    2023-02-24 19:43:55.954 - info: zigbee.0 (21202) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
                                    2023-02-24 19:43:53.879 - info: zigbee.0 (21173) cleaned everything up...
                                    2023-02-24 19:43:53.991 - info: zigbee.0 (21173) Zigbee: disabling joining new devices.
                                    2023-02-24 19:43:56.384 - warn: zigbee.0 (21173) Failed to stop zigbee during startup
                                    2023-02-24 19:43:56.385 - info: zigbee.0 (21173) terminating
                                    2023-02-24 19:43:56.386 - info: zigbee.0 (21173) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2023-02-24 19:43:56.393 - warn: zigbee.0 (21173) Got terminate signal. Checking desired PID: 21202 vs own PID 21173
                                    2023-02-24 19:43:56.026 - info: zigbee.0 (21202) delete old Backup files. keep only last 10
                                    2023-02-24 19:43:56.340 - info: zigbee.0 (21202) Starting Zigbee npm ...
                                    2023-02-24 19:43:56.639 - info: zigbee.0 (21202) Installed Version: iobroker.zigbee@1.8.10
                                    2023-02-24 19:43:56.741 - warn: zigbee.0 (21202) Extended PAN ID is reversed (expected=beb49f21004b1200, actual=00124b00219fb4be)
                                    2023-02-24 19:43:56.855 - info: zigbee.0 (21202) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                                    2023-02-24 19:43:56.861 - info: zigbee.0 (21202) Unable to disable LED, unsupported function.
                                    2023-02-24 19:43:56.871 - info: zigbee.0 (21202) --> transmitPower : high+
                                    2023-02-24 19:43:56.910 - info: zigbee.0 (21202) Currently 31 devices are joined:
                                    2023-02-24 19:43:56.963 - error: host.iobroker instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                    2023-02-24 19:43:56.964 - info: host.iobroker Do not restart adapter system.adapter.zigbee.0 because desired by instance
                                    2023-02-24 19:43:56.971 - info: zigbee.0 (21202) 0x003c84fffe8c866e (addr 65006): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                    2023-02-24 19:43:56.975 - info: zigbee.0 (21202) 0x00158d00023fa627 (addr 55296): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                    2023-02-24 19:43:56.976 - info: zigbee.0 (21202) 0x00158d000270d0c3 (addr 41428): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                    2023-02-24 19:43:56.977 - info: zigbee.0 (21202) 0x04cd15fffe02dc9d (addr 48475): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.978 - info: zigbee.0 (21202) 0x00158d000418aa49 (addr 44810): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2023-02-24 19:43:56.978 - info: zigbee.0 (21202) 0x086bd7fffe5db6f4 (addr 20632): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                    2023-02-24 19:43:56.979 - info: zigbee.0 (21202) 0x84ba20fffe655268 (addr 1765): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                    2023-02-24 19:43:56.980 - info: zigbee.0 (21202) 0x842e14fffe631b1e (addr 41611): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                    2023-02-24 19:43:56.980 - info: zigbee.0 (21202) 0x842e14fffe6cc85d (addr 37614): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                    2023-02-24 19:43:56.981 - info: zigbee.0 (21202) 0x0017880102b2703f (addr 52224): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                    2023-02-24 19:43:56.982 - info: zigbee.0 (21202) 0x00158d0002c9e6a2 (addr 15143): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2023-02-24 19:43:56.983 - info: zigbee.0 (21202) 0x00158d00041ebece (addr 15657): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                    2023-02-24 19:43:56.984 - info: zigbee.0 (21202) 0x0017880102b32b5d (addr 2841): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                    2023-02-24 19:43:56.985 - info: zigbee.0 (21202) 0x84ba20fffe6e7cf6 (addr 25227): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                    2023-02-24 19:43:56.985 - info: zigbee.0 (21202) 0x0017880102b35756 (addr 15193): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                    2023-02-24 19:43:56.986 - info: zigbee.0 (21202) 0x0017880102b14f9a (addr 41378): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                    2023-02-24 19:43:56.986 - info: zigbee.0 (21202) 0x00158d00024a95d9 (addr 8745): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                    2023-02-24 19:43:56.987 - info: zigbee.0 (21202) 0x00158d0002720ee2 (addr 28024): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                    2023-02-24 19:43:56.988 - info: zigbee.0 (21202) 0x00158d00054cf4fe (addr 32636): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                    2023-02-24 19:43:56.988 - info: zigbee.0 (21202) 0x00158d00022c9fe9 (addr 52540): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                    2023-02-24 19:43:56.989 - info: zigbee.0 (21202) 0x00158d00029a7687 (addr 21159): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                    2023-02-24 19:43:56.990 - info: zigbee.0 (21202) 0x0017880106ebdda3 (addr 34902): 324131092621 - Philips Hue dimmer switch (EndDevice)
                                    2023-02-24 19:43:56.992 - info: zigbee.0 (21202) 0x000d6f000f24030d (addr 26342): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                                    2023-02-24 19:43:56.992 - info: zigbee.0 (21202) 0x00158d000465510e (addr 12286): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
                                    2023-02-24 19:43:56.993 - info: zigbee.0 (21202) 0xcc86ecfffef3c8a4 (addr 18992): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.994 - info: zigbee.0 (21202) 0xcc86ecfffef3c061 (addr 38390): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.995 - info: zigbee.0 (21202) 0x60a423fffe62111b (addr 33876): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.996 - info: zigbee.0 (21202) 0xcc86ecfffe35ba8e (addr 27036): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.997 - info: zigbee.0 (21202) 0x04cd15fffe066dad (addr 56600): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.998 - info: zigbee.0 (21202) 0x04cd15fffe0673f1 (addr 985): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.999 - info: zigbee.0 (21202) 0x04cd15fffe02c1fb (addr 55511): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                    2023-02-24 19:43:56.999 - info: zigbee.0 (21202) Zigbee started
                                    • A Airmaxchen
                                      AsgothianA Offline
                                      AsgothianA Offline
                                      Asgothian
                                      @airmaxchen Anscheinend läuft die Zigbee Instanz bei Dir 2 mal.
                                      Bitte folgendes Tun:
                                      • Log löschen
                                      • Zigbee Adapter anhalten
                                      • auf der Konsole schauen das nichts vom Zigbee mehr läuft (ps -ax | grep -e zigbee) - darf nur einen Prozess zeigen - den vom ps
                                      • zigbee Adapter starten
                                      • 6 Minuten warten
                                      • Log herunterladen
                                      • Ohne edits posten.
                                      Irgendetwas stimmt mit den Zeiten nicht - entweder ist Deine Uhr asynchron, oder Du postest nicht den vollständigen Log-Text:
                                      Lt deiner Aussage sollte im Log ein Zeitraum von 5 Minuten zu sehen sein
                                      Zu sehen ist weniger als 1 Minute.
                                      A.
                                        • Log löschen
                                        • 6 Minuten warten
                                        • Log herunterladen
                                        A.
                                        Airmaxchen
                                        Das liefert mir folgendes:
                                        21202 pts/0 Dl+ 10:37 io.zigbee.0
                                        26297 pts/1 S+ 0:00 grep -e zigbee
                                        Ja, ich weiß. Wie schon oben erwähnt, wird einfach nichts in den Log geschrieben nachdem der Adapter gestartet ist.
                                        2023-02-25 09:07:31.179 - info: host.iobroker "system.adapter.zigbee.0" enabled
                                        2023-02-25 09:07:31.357 - info: host.iobroker instance system.adapter.zigbee.0 started with pid 26445
                                        2023-02-25 09:07:31.321 - warn: zigbee.0 (21202) Got terminate signal. Checking desired PID: 0 vs own PID 21202
                                        2023-02-25 09:07:31.324 - info: zigbee.0 (21202) cleaned everything up...
                                        2023-02-25 09:07:31.519 - info: zigbee.0 (21202) Zigbee: disabling joining new devices.
                                        2023-02-25 09:07:32.533 - info: zigbee.0 (21202) terminating
                                        2023-02-25 09:07:32.533 - info: zigbee.0 (21202) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2023-02-25 09:07:32.538 - warn: zigbee.0 (21202) Got terminate signal. Checking desired PID: 26445 vs own PID 21202
                                        2023-02-25 09:07:33.467 - error: host.iobroker instance system.adapter.zigbee.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                        2023-02-25 09:07:33.467 - info: host.iobroker Do not restart adapter system.adapter.zigbee.0 because desired by instance
                                        2023-02-25 09:07:39.913 - info: zigbee.0 (26445) starting. Version 1.8.10 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.19.0, js-controller: 4.0.24
                                        2023-02-25 09:07:40.741 - info: zigbee.0 (26445) delete old Backup files. keep only last 10
                                        2023-02-25 09:07:40.742 - info: zigbee.0 (26445) Starting Zigbee npm ...
                                        2023-02-25 09:07:42.034 - info: zigbee.0 (26445) Installed Version: iobroker.zigbee@1.8.10
                                        2023-02-25 09:07:42.594 - warn: zigbee.0 (26445) Extended PAN ID is reversed (expected=beb49f21004b1200, actual=00124b00219fb4be)
                                        2023-02-25 09:07:42.712 - info: zigbee.0 (26445) Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20220219}}
                                        2023-02-25 09:07:42.718 - info: zigbee.0 (26445) Unable to disable LED, unsupported function.
                                        2023-02-25 09:07:42.727 - info: zigbee.0 (26445) --> transmitPower : high+
                                        2023-02-25 09:07:42.764 - info: zigbee.0 (26445) Currently 31 devices are joined:
                                        2023-02-25 09:07:42.811 - info: zigbee.0 (26445) 0x003c84fffe8c866e (addr 65006): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                        2023-02-25 09:07:42.816 - info: zigbee.0 (26445) 0x00158d00023fa627 (addr 55296): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        2023-02-25 09:07:42.817 - info: zigbee.0 (26445) 0x00158d000270d0c3 (addr 41428): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        2023-02-25 09:07:42.818 - info: zigbee.0 (26445) 0x04cd15fffe02dc9d (addr 48475): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.819 - info: zigbee.0 (26445) 0x00158d000418aa49 (addr 44810): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        2023-02-25 09:07:42.820 - info: zigbee.0 (26445) 0x086bd7fffe5db6f4 (addr 20632): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                        2023-02-25 09:07:42.821 - info: zigbee.0 (26445) 0x84ba20fffe655268 (addr 1765): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                        2023-02-25 09:07:42.821 - info: zigbee.0 (26445) 0x842e14fffe631b1e (addr 41611): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                        2023-02-25 09:07:42.822 - info: zigbee.0 (26445) 0x842e14fffe6cc85d (addr 37614): E1603/E1702/E1708 - IKEA TRADFRI control outlet (Router)
                                        2023-02-25 09:07:42.823 - info: zigbee.0 (26445) 0x0017880102b2703f (addr 52224): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                        2023-02-25 09:07:42.823 - info: zigbee.0 (26445) 0x00158d0002c9e6a2 (addr 15143): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2023-02-25 09:07:42.824 - info: zigbee.0 (26445) 0x00158d00041ebece (addr 15657): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                        2023-02-25 09:07:42.825 - info: zigbee.0 (26445) 0x0017880102b32b5d (addr 2841): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                        2023-02-25 09:07:42.826 - info: zigbee.0 (26445) 0x84ba20fffe6e7cf6 (addr 25227): TS011F_plug_3 - TuYa Smart plug (with power monitoring by polling) (Router)
                                        2023-02-25 09:07:42.827 - info: zigbee.0 (26445) 0x0017880102b35756 (addr 15193): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                        2023-02-25 09:07:42.827 - info: zigbee.0 (26445) 0x0017880102b14f9a (addr 41378): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
                                        2023-02-25 09:07:42.828 - info: zigbee.0 (26445) 0x00158d00024a95d9 (addr 8745): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                                        2023-02-25 09:07:42.829 - info: zigbee.0 (26445) 0x00158d0002720ee2 (addr 28024): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                        2023-02-25 09:07:42.829 - info: zigbee.0 (26445) 0x00158d00054cf4fe (addr 32636): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                        2023-02-25 09:07:42.830 - info: zigbee.0 (26445) 0x00158d00022c9fe9 (addr 52540): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                                        2023-02-25 09:07:42.830 - info: zigbee.0 (26445) 0x00158d00029a7687 (addr 21159): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                                        2023-02-25 09:07:42.831 - info: zigbee.0 (26445) 0x0017880106ebdda3 (addr 34902): 324131092621 - Philips Hue dimmer switch (EndDevice)
                                        2023-02-25 09:07:42.833 - info: zigbee.0 (26445) 0x000d6f000f24030d (addr 26342): AC0251100NJ/AC0251600NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                                        2023-02-25 09:07:42.834 - info: zigbee.0 (26445) 0x00158d000465510e (addr 12286): WXKG02LM_rev2 - Xiaomi Aqara double key wireless wall switch (2018 model) (EndDevice)
                                        2023-02-25 09:07:42.835 - info: zigbee.0 (26445) 0xcc86ecfffef3c8a4 (addr 18992): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.836 - info: zigbee.0 (26445) 0xcc86ecfffef3c061 (addr 38390): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.836 - info: zigbee.0 (26445) 0x60a423fffe62111b (addr 33876): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.838 - info: zigbee.0 (26445) 0xcc86ecfffe35ba8e (addr 27036): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.839 - info: zigbee.0 (26445) 0x04cd15fffe066dad (addr 56600): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.840 - info: zigbee.0 (26445) 0x04cd15fffe0673f1 (addr 985): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.841 - info: zigbee.0 (26445) 0x04cd15fffe02c1fb (addr 55511): TS0121_plug - TuYa 10A UK or 16A EU smart plug (Router)
                                        2023-02-25 09:07:42.841 - info: zigbee.0 (26445) Zigbee started
                                        2023-02-25 09:07:43.026 - info: device-watcher.0 (1165) Folgendes Gerät ist wieder erreichbar:
                                        Hue Schalter (09:07 Uhr)
                                        • A Airmaxchen
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          Lesen kannst du aber schon ?
                                          Ich hatte darum gebeten das du den Adapter erst neu startest wenn das grep nur eine Zeile liefert. Bei dir kommen 2 Zeilen - damit läuft der Adapter im Hintergrund noch.
                                          Dann wartest du weniger als 7 sekunden zwischen anhalten und neu starten. War der Adapter da komplett aus ? Diese Meldung deutet darauf hin das das nicht der Fall war: Got terminate signal. Checking desired PID: 26445 vs own PID 21202
                                          Dann hatte ich darum gebeten 6 Minuten deines wertvollen Logs zu sehen - du postest nicht einmal 1 Minute.
                                          So kann Dir keiner helfen.
                                          A.
