  4. Reiter Alias beim Datenpunkt erstellen
    5.5k
30 Beiträge 5 Kommentatoren 2.6k Aufrufe 4 Beobachtet
    Tobi68
    @mickym
    Ich muss bei dem Thema gerade hier hier nachfragen..
    Habe mich gestern auch mal mit dem Alias beschäftigt..
    Hat nicht so recht geklappt..
    Wo kann ich die Fehler abstellen, sehe wohl mal wieder den Wald vor lauter Bäumen nicht..
    Alias subscription error. Please check your alias definitions: sourceId=smartmeter.0.1-0:16_7_0__255.value, sourceObj={"type":"state","common":{"name":"1-0:16_7_0__255.value","type":"number","read":true,"unit":"W","role":"value","write":false,"custom":{"history.0":{"enabled":true,"aliasId":"","changesOnly":true,"debounce":"1000","changesRelogInterval":"0","changesMinDelta":"0","maxLength":"960","retention":"31536000","debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"customRetentionDuration":365,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","start_day":808.806521578603,"start_week":788.4922968752733,"start_month":571.8277208402744,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":808.806521578603,"alias":"Akt Stromverbrauch","basicRate":true},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","changesOnly":true,"debounce":1000,"changesRelogInterval":120,"changesMinDelta":0,"retention":31536000,"debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false}}},"native":{"id":"1-0:16_7_0__255.value"},"_id":"smartmeter.0.1-0:16_7_0__255.value","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1670886000256}
    admin.0
    2023-02-20 09:38:54.263	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.Server-Schrank.ENERGY_Today, sourceObj={"_id":"sonoff.0.Server-Schrank.ENERGY_Today","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Server-Schrank ENERGY Today"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1676720310388,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
    admin.0
    2023-02-20 09:38:54.262	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.Server-Schrank.ENERGY_Yesterday, sourceObj={"_id":"sonoff.0.Server-Schrank.ENERGY_Yesterday","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Server
    • T Tobi68
      @mickym
      admin.0
      admin.0
      mickymM Offline
      mickymM Offline
      mickym
      @tobi68 na ein Alias ist dazu da einen originalen Datenpunkt anzuzeigen. Du hast den Alias angelegt, aber nicht den originalen Datenpunkt auf den der Alias vereisen soll.
      • mickymM mickym
        Tobi68
        schrieb am zuletzt editiert von Tobi68
        @mickym sagte in Reiter Alias beim Datenpunkt erstellen:
        verstehe ich nicht, dachte schon:
        • T Tobi68
          mickymM Offline
          mickymM Offline
          mickym
          @tobi68 Hast Du das so reingeschrieben oder den Datenpunkt über die 3 Punkte ausgewählt?
          • mickymM mickym
            Tobi68
            @mickym
            ja, genau!
            Ich dachte es wäre irgendwie was mit falschem Datentyp oder so
            • T Tobi68
              @mickym
              ja, genau!
              mickymM Offline
              mickymM Offline
              mickym
              @tobi68 Na ehrlich gesagt bin ich dann auch überfragt - da muss dan wohl einer der Gurus helfen. @paul53 zum Beispiel. ;)
              T paul53P 2 Antworten Letzte Antwort
              • mickymM mickym
                Tobi68
                @mickym
                Hat der grüne Strich bei dir eine Bedeutung?
                • T Tobi68
                  @mickym
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @tobi68
                  Weil wenn du das Objekt ja direkt auswählst dann sollte es ja da keine Fehler geben.
                  Du kannst ja spasseshalber den Pfad zum Datenpunkt auch manuell kopieren, ob das Teil dann auch zicken macht.
                  Na der Strich soll nur darauf hindeuten, dass Du auf den Kreis klicken solltest. ;)
                  Und ich würde auch alle Alias Adapter deaktivieren. Nicht dass die hier dazwischen funken.
                  • mickymM mickym
                    @mickym sagte: bin ich dann auch überfragt
                    Ich kenne das Problem auch nicht, habe aber mehrmals hier im Forum darüber gelesen. Ich würde mal ioBroker neu starten.
                    • mickymM mickym
                      @tobi68
                      Tobi68
                      @mickym
                      Alias Adapter?
                      habe erst mit angefangen und gedacht ich müsste den installieren.. scheint gar nicht mehr der Fall zu sein..
                      also den wieder deinstallieren?
                      • mickymM mickym
                        @tobi68
                        @mickym sagte: alle Alias Adapter deaktivieren. Nicht dass die hier dazwischen funken.
                        Das sind keine "echten" Adapter, sondern nur Eingabehilfen zur Alias-Erstellung.
                        • T Tobi68
                          @mickym
                          Alias Adapter?
                          mickymM Offline
                          mickymM Offline
                          mickym
                          @tobi68 Na ja der erstellt auch aliases und standardisierte Eigenschaften für bestimmte Gerätetypen - ich hab mit dem Teil nur Probleme gehabt und das ist bei mir wieder rausgeflogen. Aber vielleicht hilft es Dir ja - bei mir hat der Adapter nicht wie gewünscht funktioniert.
                          T 2 Antworten Letzte Antwort
                          • mickymM mickym
                            Tobi68
                            @mickym
                            Ok, ich schau mal..
                            Hab eh schon alles 2 mal eingegeben..
                            sobald ich was mache regnets..
                            • mickymM mickym
                              Tobi68
                              @mickym
                              aha..
                              hier steht auch mal ne Zahl:
                              • T Tobi68
                                @mickym
                                aha..
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @tobi68 Na und was war das Problem - dieser ".... " Devices - Adapter?
                                • mickymM mickym
                                  Tobi68
                                  @mickym
                                  Den habe ich mal deinstalliert.. ich bastel mal weiter...
                                  Ich war eigentlich dabei den Energiefluss Adapter zu füttern.. Wollte in dem Zug auch mit den Aliasen anfangen.
                                  Habe jetzt immer noch Fehlermeldungen, weis aber nicht wann die entstehen.. jetzt nicht mehr vom Admin, sondern vom WEB:
                                  • T Tobi68
                                    @mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @tobi68 Sind ja nicht mehr soviele - vielleicht die nochmal löschen und neu anlegen.
                                    • mickymM mickym
                                      Tobi68
                                      @mickym
                                      Hab mal neu gestartet..
                                      Alles seltsam, es regnet wenn ich die Energiefluss Seite aufrufe..
                                      Hab die ganzen angemeckerten Objekte da noch gar nicht drinn..
                                      Heute mal Feierabend..
                                      • T Tobi68
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @tobi68 Na das ist aber das Problem - es gibt immer Meldungen wenn Du einen Alias ohne Source angibst. Also nicht alle Aliase zuerst angelegen.
                                        • mickymM mickym
                                          Tobi68
                                          @mickym
                                          Nein, die Source existiert , liefert nur derzeit keine Werte.
                                          Der sonoff für die Poolpumpe ist zwar online, aber die Pumpe nicht eingeschaltet.
                                          Du denkt daran liegts?
                                          Morgen wird die Waschmaschine auch wieder laufen..
                                          Die Bezeichnungen sind etas durcheinander.. sind teilweise zwischen Stecker die jetzt ne andere Verwendung haben..
                                          Dann werde ich die mal in Betrieb nehmen..
                                          Sind teilweise nur konfiguriert und in den IOB genommen..
