  4. Reiter Alias beim Datenpunkt erstellen
    5.5k
30 Beiträge 5 Kommentatoren 2.6k Aufrufe 4 Beobachtet
  • J Offline
    Jacke
    @mickym @Ahnungsbefreit @paul53
    perfekt vielen Dank für die schnelle Antwort das werde ich heute Abend direkt ausprobieren.
      Tobi68
      @mickym
      Ich muss bei dem Thema gerade hier hier nachfragen..
      Habe mich gestern auch mal mit dem Alias beschäftigt..
      Hat nicht so recht geklappt..
      Wo kann ich die Fehler abstellen, sehe wohl mal wieder den Wald vor lauter Bäumen nicht..
      Alias subscription error. Please check your alias definitions: sourceId=smartmeter.0.1-0:16_7_0__255.value, sourceObj={"type":"state","common":{"name":"1-0:16_7_0__255.value","type":"number","read":true,"unit":"W","role":"value","write":false,"custom":{"history.0":{"enabled":true,"aliasId":"","changesOnly":true,"debounce":"1000","changesRelogInterval":"0","changesMinDelta":"0","maxLength":"960","retention":"31536000","debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"customRetentionDuration":365,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","start_day":808.806521578603,"start_week":788.4922968752733,"start_month":571.8277208402744,"start_quarter":0,"start_year":0,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":true,"valueAtDeviceInit":null,"valueAtDeviceReset":null,"cumulativeValue":808.806521578603,"alias":"Akt Stromverbrauch","basicRate":true},"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","changesOnly":true,"debounce":1000,"changesRelogInterval":120,"changesMinDelta":0,"retention":31536000,"debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false}}},"native":{"id":"1-0:16_7_0__255.value"},"_id":"smartmeter.0.1-0:16_7_0__255.value","acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"},"from":"system.adapter.sourceanalytix.0","user":"system.user.admin","ts":1670886000256}
      admin.0
      2023-02-20 09:38:54.263	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.Server-Schrank.ENERGY_Today, sourceObj={"_id":"sonoff.0.Server-Schrank.ENERGY_Today","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Server-Schrank ENERGY Today"},"native":{},"type":"state","from":"system.adapter.sonoff.0","user":"system.user.admin","ts":1676720310388,"acl":{"object":1636,"state":1636,"owner":"system.user.admin","ownerGroup":"system.group.administrator"}}
      admin.0
      2023-02-20 09:38:54.262	error	Alias subscription error. Please check your alias definitions: sourceId=sonoff.0.Server-Schrank.ENERGY_Yesterday, sourceObj={"_id":"sonoff.0.Server-Schrank.ENERGY_Yesterday","common":{"type":"number","role":"value.power.consumption","read":true,"write":false,"unit":"kWh","name":"Server
      • T Tobi68
        @mickym
        admin.0
        admin.0
        mickymM Offline
        mickymM Offline
        mickym
        @tobi68 na ein Alias ist dazu da einen originalen Datenpunkt anzuzeigen. Du hast den Alias angelegt, aber nicht den originalen Datenpunkt auf den der Alias vereisen soll.
        • mickymM mickym
          Tobi68
          schrieb am zuletzt editiert von Tobi68
          @mickym sagte in Reiter Alias beim Datenpunkt erstellen:
          verstehe ich nicht, dachte schon:
          • T Tobi68
            mickymM Offline
            mickymM Offline
            mickym
            @tobi68 Hast Du das so reingeschrieben oder den Datenpunkt über die 3 Punkte ausgewählt?
            • mickymM mickym
              Tobi68
              @mickym
              ja, genau!
              Ich dachte es wäre irgendwie was mit falschem Datentyp oder so
              • T Tobi68
                @mickym
                ja, genau!
                mickymM Offline
                mickymM Offline
                mickym
                @tobi68 Na ehrlich gesagt bin ich dann auch überfragt - da muss dan wohl einer der Gurus helfen. @paul53 zum Beispiel. ;)
                T paul53P 2 Antworten Letzte Antwort
                • mickymM mickym
                  Tobi68
                  @mickym
                  Hat der grüne Strich bei dir eine Bedeutung?
                  • T Tobi68
                    @mickym
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @tobi68
                    Weil wenn du das Objekt ja direkt auswählst dann sollte es ja da keine Fehler geben.
                    Du kannst ja spasseshalber den Pfad zum Datenpunkt auch manuell kopieren, ob das Teil dann auch zicken macht.
                    Na der Strich soll nur darauf hindeuten, dass Du auf den Kreis klicken solltest. ;)
                    Und ich würde auch alle Alias Adapter deaktivieren. Nicht dass die hier dazwischen funken.
                    • mickymM mickym
                      @mickym sagte: bin ich dann auch überfragt
                      Ich kenne das Problem auch nicht, habe aber mehrmals hier im Forum darüber gelesen. Ich würde mal ioBroker neu starten.
                      • mickymM mickym
                        @tobi68
                        Tobi68
                        @mickym
                        Alias Adapter?
                        habe erst mit angefangen und gedacht ich müsste den installieren.. scheint gar nicht mehr der Fall zu sein..
                        also den wieder deinstallieren?
                        • mickymM mickym
                          @tobi68
                          @mickym sagte: alle Alias Adapter deaktivieren. Nicht dass die hier dazwischen funken.
                          Das sind keine "echten" Adapter, sondern nur Eingabehilfen zur Alias-Erstellung.
                          • T Tobi68
                            @mickym
                            Alias Adapter?
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @tobi68 Na ja der erstellt auch aliases und standardisierte Eigenschaften für bestimmte Gerätetypen - ich hab mit dem Teil nur Probleme gehabt und das ist bei mir wieder rausgeflogen. Aber vielleicht hilft es Dir ja - bei mir hat der Adapter nicht wie gewünscht funktioniert.
                            T 2 Antworten Letzte Antwort
                            • mickymM mickym
                              Tobi68
                              @mickym
                              Ok, ich schau mal..
                              Hab eh schon alles 2 mal eingegeben..
                              sobald ich was mache regnets..
                              • mickymM mickym
                                Tobi68
                                @mickym
                                aha..
                                hier steht auch mal ne Zahl:
                                • T Tobi68
                                  @mickym
                                  aha..
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @tobi68 Na und was war das Problem - dieser ".... " Devices - Adapter?
                                  • mickymM mickym
                                    Tobi68
                                    @mickym
                                    Den habe ich mal deinstalliert.. ich bastel mal weiter...
                                    Ich war eigentlich dabei den Energiefluss Adapter zu füttern.. Wollte in dem Zug auch mit den Aliasen anfangen.
                                    Habe jetzt immer noch Fehlermeldungen, weis aber nicht wann die entstehen.. jetzt nicht mehr vom Admin, sondern vom WEB:
                                    • T Tobi68
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @tobi68 Sind ja nicht mehr soviele - vielleicht die nochmal löschen und neu anlegen.
                                      • mickymM mickym
                                        Tobi68
                                        @mickym
                                        Hab mal neu gestartet..
                                        Alles seltsam, es regnet wenn ich die Energiefluss Seite aufrufe..
                                        Hab die ganzen angemeckerten Objekte da noch gar nicht drinn..
                                        Heute mal Feierabend..
                                        • T Tobi68
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @tobi68 Na das ist aber das Problem - es gibt immer Meldungen wenn Du einen Alias ohne Source angibst. Also nicht alle Aliase zuerst angelegen.
