  4. Cubietruck 3 nicht erreichbar nach node 14.x Löschung
    5.4k
158 Beiträge 6 Kommentatoren 22.4k Aufrufe 4 Beobachtet
  • B blackangel15741
    Mount | sort
    blackangel1508@cubietruck:~$ mount | sort
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mo
    de=700)
    cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev
    ,noexec,relatime,nsdelegate)
    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noe
    xec,relatime,blkio)
    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nod
    ev,noexec,relatime,cpu,cpuacct)
    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,no
    exec,relatime,cpuset)
    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,n
    oexec,relatime,devices)
    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,n
    oexec,relatime,freezer)
    cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,no
    exec,relatime,memory)
    cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosui
    d,nodev,noexec,relatime,net_cls,net_prio)
    cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,node
    v,noexec,relatime,perf_event)
    cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noex
    ec,relatime,pids)
    cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noex
    ec,relatime,rdma)
    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,n
    oexec,relatime,xattr,name=systemd)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    /dev/mmcblk0p1 on / type ext4 (rw,noatime,errors=remount-ro,com
    mit=600)
    /dev/mmcblk0p1 on /var/log.hdd type ext4 (rw,noatime,errors=rem
    ount-ro,commit=600)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5
    ,mode=620,ptmxmode=000)
    /dev/zram1 on /var/log type ext4 (rw,relatime,discard)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,re
    latime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,n
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,
    fd=42,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,
    size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=204800
    k,mode=755)
    tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=
    204796k,mode=700)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,si
    ze=204796k,mode=700,uid=1000,gid=1000)
    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode
    =755)
    tmpfs on /tmp type tmpfs (rw,nosuid,relatime)
    tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
    udev on /dev type devtmpfs (rw,nosuid,relatime,size=969528k,nr_
    inodes=160685,mode=755)
    blackangel1508@cubietruck:~$��������������������������������������������������������
    #87
    @blackangel15741
    danke!
    siehe edit
    • B blackangel15741
      @thomas-braun ist das jetzt 1:1 so zu übernehmen?
      sudo usermod -a -G iobroker DEINUSER
      #88
      @blackangel15741
      DEINUSER ist natürlich durch den username zu ersetzen. Vermutlich bei dir durch blackangel1508
        @blackangel15741
        blackangel15741
        #89
        @thomas-braun Dankeschön
        Welchen usernamen ich vorher hatte weiß ich nicht genau ....den namen blackangel1508 hatte ich mir hier bei der Neuinstallation angelegt.
          @blackangel15741
          danke!
          siehe edit
          blackangel15741
          #90
          @homoran das mit dem mounten klappt nicht....der sagt....Befehl nicht gefunden
          • B blackangel15741
            #91
            @blackangel15741
            Habt ihr eigentlich keine Vornamen? Die eignen sich nämlich hervorragend als user names. Vergisst man auch in der Regel nicht.
            • B blackangel15741
              #92
              @blackangel15741
              sudo mount /dev/sda1 /mnt
              • B blackangel15741
                #93
                @blackangel15741 sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
                wie genau sieht das aus?
                Ein- und Ausgabe bitte in code-tags posten
                  blackangel15741
                  #94
                  @homoran hatte den Befehl "mount" vergessen
                  Also habe jetzt Zugriff auf die Platte und habe mir aus sda1 das Backup auf den Laptob gezogen "backupiobroker.tar.gz"
                  5,9 MB
                  Ist da jetzt alles an Einstellungen gesichert auch vis. Projekte und eigene scripte?
                  Soll ich jetzt die Platte installieren mit boot sd und system nach sata also sda1 ?
                  Bleibt mir dann sda2 sda3 erhalten?
                  Wenn jetzt alle iobroker daten auf der sda1 vorliegen kann man das jetzt reaktivieren oder ist das nicht möglich weil alles überschrieben wird, weil ja beim installieren "system nach sda1" die Platte gelöscht wird?
                  Hoffe ich konnte mich verständlich erklären.
                  • B blackangel15741
                    5,9 MB
                    #95
                    Nicht so ganz...
                    Was liegt denn auf /dev/sda2 und /dev/sda3 drauf?
                    Wenn du jetzt ein Backup hast ist doch alles gut. System frisch von Grundauf neuinstallieren, ohne Rücksicht auf (durch Backup nicht vorhandene) Verluste und das Backup in den frischen ioBroker einspielen.
                      Nicht so ganz...
                      blackangel15741
                      #96
                      @thomas-braun mir war so als ob da die Projekte für vis abgelegt waren oder backups aber wenn ich mit der Backup datei von iobroker soweit alles gesichert habe....dann wäre es nicht schlimm, wenn diese Partitionen gelöscht werden.
                      • B blackangel15741
                        #97
                        Das kannst nur du wissen. Oder nachschauen.
                          blackangel15741
                          schrieb am zuletzt editiert von blackangel15741
                          #98
                          @thomas-braun na im Backup müsste ja alles drin sein.
                          Soll ich jetzt configurieren boot von sd und system nach sata?
                          Wie vorher....und dann nach einer Anleitung iobroker installieren?
                          Ist es heute auch noch erforderlich bei der Neuinstallation einen extra Ordner für das Backup zu erstellen um dann das Backup dort zu hinterlegen?
                          Nach welcher Anleitung kann ich vorgehen?
                          • B blackangel15741
                            #99
                            Mein System läuft erstmal vollständig von der SSD, eine SD-Karte steckt noch als FallBack-Lösung drin. Falls irgendwas mit der SSD sein sollte wird die SD-Karte herangezogen.
                            Edit: Hatte vergessen, du bist da ja nicht mit einem Raspberry unterwegs. Keine Ahnung ob und wie das auf dem Cubietruck geht.
                            Wäre mir neu, dass das überhaupt mal erforderlich war. Backups liegen im Verzeichnis /opt/iobroker/backups
                              #100
                              @thomas-braun sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
                              doch!
                              der Ordner backups wird (wurde?) erst mit dem ersten backup angelegt.
                              um auf einer neuen Installation ein altes Backup lokal wiederherstellen zu können musste erst das Verzeichnis erstellt und dann das Backup hineingeschoben werden, bevor es mit iobroker restore wiederhergestellt werden konnte.
                              bietet sudo armbian-config bein Cubietruck nicht mehr an, auch den Boot auf der Platte zu haben?
                              B wendy2702W 2 Antworten Letzte Antwort
                                doch!
                                blackangel15741
                                #101
                                @homoran ich weiß nicht glaube das hatte ich noch nie im Angebot in der config oder ich finde das nicht.
                                Wenn ich z.B. nand-sata-install vorgebe habe ich nur zur Auswahl boot von sd und system on sata, USB
                                Kann ich system zu sata machen also sda1 und dann boot von sda1 einrichten? Habe ich danach trotzdem Zugriff auf sda2 und sda3?
                                Nach welcher Anleitung kann ich vorgehen für iobroker Installation und für die Erstellung des Ordners iobrocker backup?
                                  doch!
                                  wendy2702W Online
                                  wendy2702W Online
                                  #102
                                  @homoran sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
                                  Oder man gibt den vollständigen Pfad an. (Hat zumindest früher funktioniert)
                                  • B blackangel15741
                                    #103
                                    ok!
                                    ich meine zwar früher die SD Karte rausgenommen zu haben, aber wenn es nicht mehr geht, ist es so.
                                    ich habe dich gerade so verstanden dass das nicht geht.
                                    Zugriff auf die anderen Partitionen müsstest du mit mounts hinbekommen.
                                      ok!
                                      blackangel15741
                                      #104
                                      @homoran also vorhin hatte ich Zugriff und habe die Backup kopiert, seit dem nichts verändert und jetzt ist unter mnt nichts mehr zu sehen. Wie geht das, dachte dad mit mount ist dauerhaft.
                                      Muss ich jetzt wie folgt vorgehen?....
                                      System zu Sata mit nand-sata-install
                                      dann
                                      Iobroker installieren
                                      dann
                                      Backup Ordner anlegen und backup dort hinzufügen und dann einspielen?
                                      Kann mir jemand helfen oder Link nach welcher aktuellen Anleitung iobroker am besten zu installieren ist? Die Anleitung vor einiger Zeit noch genutzt gibt es nicht mehr, also Link funktioniert nicht.
                                      Node wird dann denke ich automatisch mit installiert?
                                      Sorry für die Anfängerfragen aber will jetzt nix falsch machen.
                                      Geht es auch boot von der ssd einzustellen bzw. ?
                                      • B blackangel15741
                                        dann
                                        dann
                                        #105
                                        das hatte ich dich vorhin gefragt.
                                        Nach deiner Aussage bietet armbian-config das nicht (mehr) an.
                                        welche?
                                        https://www.iobroker.net/#de/intro
                                        einfach den code unten links kopieren und ausführen.
                                        nocht dass ich wüsst. Ist aber nicht meine Wissensstufe. @Thomas-Braun kann dir das genau sagen.
                                        dann
                                        dann
                                        was immer der erste Punkt bedeuten soll. der Rest passt
                                        • B blackangel15741
                                          dann
                                          dann
                                          #106
                                          Nein, für dauerhaft macht man das per fstab. Und in andere Verzeichnisse. Aber du wolltest doch nur Daten da runterkopieren.
