  4. Fehler bei Installation i2c Adapter
    5.6k
    1.5k
58 Beiträge 4 Kommentatoren 4.5k Aufrufe 3 Watching
  • C Offline
    Chris_B
    Ich würde gerne Geräte über den i2c Bus steuern.
    Bei der Installation des iobroker.i2c Adapters erhalte ich die unterstehende Fehlermeldung.
    i2c Bus ist enabled (via raspi-config).
    Hat jemand eine Idee die mir weiterhilft?
    iobroker npm ERR! command failednpm ERR! command sh -c node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:936npm ERR! throw err;npm ERR! ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.jsnpm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:778:27)npm ERR! at Module.require (node:internal/modules/cjs/loader:1005:19)npm ERR! at require (node:internal/modules/cjs/helpers:102:18)npm ERR! at Object.<anonymous> (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR! at Module._compile (node:internal/modules/cjs/loader:1105:14)npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)npm ERR! at Module.load (node:internal/modules/cjs/loader:981:32)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:822:12)npm ERR! at Module.require (node:internal/modules/cjs/loader:1005:19) {npm ERR! code: 'MODULE_NOT_FOUND',npm ERR! requireStack: [npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR! ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-10T14_43_26_796Z-debug-0.log
    • C Chris_B
      @chris_b
      Bitte lesbaren Text posten. Das ist ja Buchstabensuppe.
      Und die Installation von nodejs prüfen.
      • C Offline
        Chris_B
        schrieb am zuletzt editiert von Chris_B
        1. Es tut mir leid wegen der 'Buchstabensuppe'. Das ist direkt aus dem log (Protokoll) kopiert; und dort erscheint es genau so. Wie kann ich das besser darstellen?
        2. Node-js: Ist auf Version 16.16.0, mit dem Hinweis, dass ich auf Version 16.19.0 updaten kann. Was meinst Du mit 'prüfen'? Mein iobroker läuft ansonsten ohne Probleme.
        Besten Dank
        HomoranH wendy2702W Thomas BraunT 3 Antworten Letzte Antwort
        • C Chris_B
          Besten Dank
          @chris_b sagte in Fehler bei Installation i2c Adapter:
          really?
          wo sind dann Timestamp, Adaptername, loglevel...?
          Das Forum freut sich über eine Spende. Benutzt dazu den Spendenbutton im Header. Danke!
          • C Chris_B
            Besten Dank
            wendy2702W Online
            wendy2702W Online
            Aus dem Browserfenster?
            Noch nie so gesehen.
            Wie steht es denn im log auf dem Speichermedium:
            /opt/iobroker/log/<logfile mit Datum von heute>
            • C Offline
              Chris_B
              Das Folgende ist jetzt direkt aus dem log-File kopiert.
              Mit dem Riesenwust ab 15:43:34.369:
              2023-02-10 15:43:21.816 - info: host.raspberrypi4-iob iobroker add i2c auto --host raspberrypi4-iob --debug
              2023-02-10 15:43:25.646 - info: host.raspberrypi4-iob iobroker NPM version: 8.11.0
              2023-02-10 15:43:25.647 - info: host.raspberrypi4-iob iobroker Installing iobroker.i2c@1.2.1... (System call)
              2023-02-10 15:43:34.351 - info: host.raspberrypi4-iob iobroker npm ERR! code 1npm ERR! path /opt/iobroker/node_modules/i2c-bus
              2023-02-10 15:43:34.369 - info: host.raspberrypi4-iob iobroker npm ERR! command failednpm ERR! command sh -c node-gyp rebuildnpm ERR! node:internal/modules/cjs/loader:936npm ERR! throw err;npm ERR! ^npm ERR! npm ERR! Error: Cannot find module 'object-assign'npm ERR! Require stack:npm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.jsnpm ERR! - /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.jsnpm ERR! at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:778:27)npm ERR! at Module.require (node:internal/modules/cjs/loader:1005:19)npm ERR! at require (node:internal/modules/cjs/helpers:102:18)npm ERR! at Object. (/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js:4:20)npm ERR! at Module._compile (node:internal/modules/cjs/loader:1105:14)npm ERR! at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)npm ERR! at Module.load (node:internal/modules/cjs/loader:981:32)npm ERR! at Function.Module._load (node:internal/modules/cjs/loader:822:12)npm ERR! at Module.require (node:internal/modules/cjs/loader:1005:19) {npm ERR! code: 'MODULE_NOT_FOUND',npm ERR! requireStack: [npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/render-template.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/plumbing.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/gauge/index.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/node_modules/npmlog/log.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/lib/node-gyp.js',npm ERR! '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js'npm ERR! ]npm ERR! }npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2023-02-10T14_43_26_796Z-debug-0.log
              2023-02-10 15:43:34.402 - error: host.raspberrypi4-iob iobroker host.raspberrypi4-iob Cannot install iobroker.i2c@1.2.1: 1
              2023-02-10 15:43:35.455 - info: host.raspberrypi4-iob iobroker exit 25
              2023-02-10 16:04:16.085 - info: admin.0 (602) <== Disconnect system.user.admin from ::ffff:192.168.1.137 admin
              2023-02-10 16:05:23.668 - info: admin.0 (602) ==> Connected system.user.admin from ::ffff:192.168.1.137
              2023-02-10 16:27:06.648 - info: admin.0 (602) <== Disconnect system.user.admin from ::ffff:192.168.1.137 admin
              MOD EDIT: LOG IN CODE TAGS </> GESETZT
              • C Chris_B
                Besten Dank
                Schau in meiner Signatur.
                • wendy2702W Online
                  wendy2702W Online
                  https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8
                  • C Offline
                    Chris_B
                    OK, werde ich versuchen. Melde mich wieder. Aber nicht mehr heute.
                    • wendy2702W wendy2702
                      @wendy2702
                      Hier dürfte aber was anderes im Argen liegen.
                      Vielleicht sieht man was beim Check auf 'senkrechte' Installation von nodejs.
                        @wendy2702
                        wendy2702W Online
                        wendy2702W Online
                        @thomas-braun sagte in Fehler bei Installation i2c Adapter:
                        @wendy2702
                        Vermutlich. Habe nachdem ich die Code Tags drum gebaut habe nicht mehr gesehen das man noch ewig nach rechts scrollen kann :grimacing:
                        Habe nur runter gescrollt und die „25“ gesehen.
                        Vielleicht dürfen wir ja auch einen Blick hier rein werfen
                        • C Offline
                          Chris_B
                          Die ewig lange Zeile entspricht der oben genannten 'Buchstabensuppe'.
                          Hier ist das log File:
                          Vielen Dank für die Hilfe...
                          • C Chris_B
                            @chris_b
                            nodejs geprüft?
                            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                            uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            sagt?
                            • C Offline
                              Chris_B
                              @Thomas-Braun Das kommt dabei heraus (ich hoffe, ich habe das richtig gemacht, bin da nicht so fit wie ihr):
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              /usr/bin/npx
                              v16.16.0
                              v16.16.0
                              8.11.0
                              8.11.0
                              4.0.24
                              pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker pijuice
                              tty
                              /home/pi
                              OK:1 http://archive.raspberrypi.org/debian buster InRelease
                              OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                              OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                              OK:4 https://phoscon.de/apt/deconz buster InRelease
                              Aktualisierung für 136 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
                              nodejs:
                                Installiert:           16.16.0-deb-1nodesource1
                                Installationskandidat: 16.19.0-deb-1nodesource1
                                Versionstabelle:
                                   16.19.0-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                               *** 16.16.0-deb-1nodesource1 100
                                   10.24.0~dfsg-1~deb10u2 500
                              • C Chris_B
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                /usr/bin/npx
                                v16.16.0
                                v16.16.0
                                8.11.0
                                8.11.0
                                4.0.24
                                pi
                                tty
                                /home/pi
                                nodejs:
                                  Versionstabelle:
                                Updaten. Jetzt und alles.
                                Und danach den buster beerdigen und bullseye installieren.
                                https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                • C Offline
                                  Chris_B
                                  Sorry Thomas. Bitte ein bisschen ausführlicher - bin da nicht so drin.
                                  Ich muss nodejs von 16.16.0 auf 16.19.0 updaten und das wars?
                                  Und danke für den weiteren Link.
                                  Wieso lohnt sich das? ein Link würde mir da auch helfen.
                                  • C Chris_B
                                    und das wars?
                                    Nein, dein komplettes Betriebssystem ist versumpft.
                                    Das muss sich nicht 'lohnen', weil dein Release abgekündigt ist und nicht mehr gepflegt wird. Daher stellt sich die Frage erst gar nicht.
                                    Siehe auch hier:
                                    https://wiki.debian.org/DebianReleases
                                    • C Offline
                                      Chris_B
                                      Ich habe nun node.js und NPM auf die neuste Version gezogen:
                                      node.js auf V16.19.0, NPM auf V8.19.3.
                                      iobroker fix auch ausgeführt, alles ohne Probleme.
                                      Trotzdem lässt sich der i2c Adapter nicht installieren, die gleichen Fehlermeldungen erscheinen.
                                      Ich überlege die nächsten Schritte. Evtl. bei Gelegenheit System neu aufsetzen (bullseye)...
                                      • C Chris_B
                                        wendy2702W Online
                                        wendy2702W Online
                                        @chris_b
                                        iob stop
                                        iob fix
                                        iob start
                                        iob diag
                                        Ausgaben bitte vollständig hier posten.
                                        C 1 Antwort Letzte Antwort
                                          @chris_b
                                          iob stop
                                          iob fix
                                          iob start
                                          iob diag
                                          Chris_B
                                          @wendy2702
                                          here it is:
                                          Skript v.2023-01-02
                                          *** BASE SYSTEM ***
                                          Model           : Raspberry Pi 4 Model B Rev 1.5
                                          Architecture:   armv7l
                                          Docker:         false
                                          Virtualization: none
                                          Distributor ID: Raspbian
                                          Description:    Raspbian GNU/Linux 10 (buster)
                                          Release:        10
                                          Codename:       buster
                                          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                                          NAME="Raspbian GNU/Linux"
                                          VERSION_ID="10"
                                          VERSION="10 (buster)"
                                          VERSION_CODENAME=buster
                                          ID=raspbian
                                          ID_LIKE=debian
                                          HOME_URL="http://www.raspbian.org/"
                                          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                          Systemuptime and Load:
                                           18:03:09 up 40 min,  1 user,  load average: 1.54, 1.01, 0.64
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                          Sat Feb 11 17:03:09 UTC 2023
                                          Sat Feb 11 18:03:09 CET 2023
                                          CET +0100
                                          Europe/Zurich
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:           3.8G        980M        2.3G         24M        560M        2.9G
                                          Swap:           99M          0B         99M
                                          Total:         3.9G        980M        2.4G
                                                   3838 M total memory
                                                    980 M used memory
                                                    335 M active memory
                                                   1046 M inactive memory
                                                   2297 M free memory
                                                    127 M buffer memory
                                                    433 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       15G  4.6G  9.2G  34% /
                                          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                          tmpfs          tmpfs     1.9G   25M  1.9G   2% /run
                                          tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
                                          /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
                                          tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                                          Messages in dmesg:
                                          [Sat Feb 11 17:22:11 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:A8:12:03 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=cd3e8f54-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                                          [Sat Feb 11 17:22:13 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
                                          [Sat Feb 11 17:22:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Sat Feb 11 17:22:16 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                                          TARGET        SOURCE         FSTYPE OPTIONS
                                          /             /dev/mmcblk0p2 ext4   rw,noatime
                                          |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
                                          `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                          /var:
                                          502M    /var/
                                          294M    /var/cache
                                          288M    /var/cache/apt
                                          229M    /var/cache/apt/archives
                                          92M     /var/lib
                                          /opt/iobroker/backups:
                                          21M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          222M    /opt/iobroker/iobroker-data/
                                          105M    /opt/iobroker/iobroker-data/files
                                          94M     /opt/iobroker/iobroker-data/backup-objects
                                          51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                          32M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                                          7.6M    /opt/iobroker/iobroker-data/objects.jsonl
                                          6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
                                          6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                                          6.2M    /opt/iobroker/iobroker-data/objects.json.migrated
                                          6.2M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v16.19.0
                                          /usr/bin/node           v16.19.0
                                          /usr/bin/npm            8.19.3
                                          /usr/bin/npx            8.19.3
                                          nodejs:
                                            Installed: 16.19.0-deb-1nodesource1
                                            Candidate: 16.19.0-deb-1nodesource1
                                            Version table:
                                           *** 16.19.0-deb-1nodesource1 500
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  4.0.24
                                          admin:          6.3.5
                                          javascript:     6.1.4
                                          Adapters from github:   0
                                          Adapter State
                                          + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
                                          + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
                                          + system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         -  enabled
                                          + system.adapter.denon.0                  : denon                 : raspberrypi4-iob                         -  enabled
                                          + system.adapter.denon.1                  : denon                 : raspberrypi4-iob                         -  enabled
                                          + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
                                            system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
                                          + system.adapter.heos.0                   : heos                  : raspberrypi4-iob                         -  enabled
                                          + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
                                          + system.adapter.hue.0                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
                                          + system.adapter.hue.1                    : hue                   : raspberrypi4-iob                         -  enabled, port: 80
                                          + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
                                          + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
                                          + system.adapter.netatmo.0                : netatmo               : raspberrypi4-iob                         -  enabled
                                          + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
                                          + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
                                          + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          + system.adapter.socketio.0               : socketio              : raspberrypi4-iob                         -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                                            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4-iob                         - disabled
                                            system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
                                          + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                          + system.adapter.yahka.0                  : yahka                 : raspberrypi4-iob                         -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): stable
                                          Installed ioBroker-Instances
                                          Used repository: stable
                                          Adapter    "backitup"     : 2.5.12   , installed 2.5.12
                                          Adapter    "cloud"        : 4.3.0    , installed 4.3.0
                                          Adapter    "denon"        : 1.13.4   , installed 1.13.4
                                          Adapter    "email"        : 1.1.4    , installed 1.1.4
                                          Adapter    "flot"         : 1.11.0   , installed 1.11.0
                                          Adapter    "heos"         : 1.10.0   , installed 1.10.0
                                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                                          Adapter    "homekit-controller": 0.5.1, installed 0.5.1
                                          Adapter    "hue"          : 3.7.1    , installed 3.7.1
                                          Adapter    "info"         : 1.9.19   , installed 1.9.19
                                          Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                                          Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
                                          Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                                          Objects and States
                                          Objects:        3093
                                          States:         2599
                                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                          Hit:2 https://phoscon.de/apt/deconz buster InRelease
                                          Hit:3 https://deb.nodesource.com/node_16.x buster InRelease
                                          Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                                          Reading package lists...
                                          Pending Updates: 0
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17590      585/sshd
                                          tcp        0      0 127.0.0.1:43801         0.0.0.0:*               LISTEN      1001       191843     21588/io.yahka.0
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       187068     20468/iobroker.js-c
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       187061     20468/iobroker.js-c
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       189559     20489/io.admin.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       191294     21389/io.web.0
                                          tcp6       0      0 :::8084                 :::*                    LISTEN      1001       191171     21098/io.socketio.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          17592      585/sshd
                                          tcp6       0      0 :::8087                 :::*                    LISTEN      1001       190525     20863/io.simple-api
                                          tcp6       0      0 :::34381                :::*                    LISTEN      1001       193677     21588/io.yahka.0
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16640      573/dhcpcd
                                          udp        0      0 0.0.0.0:42135           0.0.0.0:*                           1001       188978     20815/io.heos.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       193678     21588/io.yahka.0
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12814      377/avahi-daemon: r
                                          udp        0      0 0.0.0.0:41800           0.0.0.0:*                           108        12816      377/avahi-daemon: r
                                          udp6       0      0 :::38941                :::*                                108        12817      377/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          16653      573/dhcpcd
                                          udp6       0      0 :::5353                 :::*                                108        12815      377/avahi-daemon: r
                                          2023-02-11 18:02:07.466  - info: cloud.0 (20724) Trying to connect as system.user.admin to cloud
                                          2023-02-11 18:02:07.601  - info: cloud.0 (20724) Connection changed: connect
                                          2023-02-11 18:02:08.580  - info: vis.0 (21336) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
                                          2023-02-11 18:02:08.791  - info: vis.0 (21336) vis license is OK.
                                          2023-02-11 18:02:09.456  - info: vis.0 (21336) Terminated (NO_ERROR): Without reason
                                          2023-02-11 18:02:10.134  - info: host.raspberrypi4-iob instance system.adapter.vis.0 terminated while should be started once
                                          2023-02-11 18:02:10.923  - info: host.raspberrypi4-iob instance system.adapter.web.0 started with pid 21389
                                          2023-02-11 18:02:14.861  - info: host.raspberrypi4-iob instance system.adapter.yahka.0 started with pid 21588
                                          2023-02-11 18:02:17.276  - info: yahka.0 (21588) starting. Version 0.13.1 in /opt/iobroker/node_modules/iobroker.yahka, node: v16.19.0, js-controller: 4.0.24
                                          2023-02-11 18:02:17.314  - info: yahka.0 (21588) adapter ready, checking config
                                          2023-02-11 18:02:17.329  - info: yahka.0 (21588) adding Wasser Höfli 1A with UUID: 10c354a6-9830-470f-9a77-a332861ef8a9
                                          2023-02-11 18:02:17.342  - info: yahka.0 (21588) adding Wasser Höfli 2A with UUID: e801a2ae-6c62-44d0-870f-a7a316e4a4b6
                                          2023-02-11 18:02:17.346  - info: yahka.0 (21588) adding Wasser Garten 3A with UUID: e7a975c7-14b7-4db6-93c9-a5c06b0f0906
                                          2023-02-11 18:02:17.350  - info: yahka.0 (21588) adding Wasser Garten 4A with UUID: b19d1566-51f7-4dbf-a436-f10b00d4d3bf
                                          2023-02-11 18:02:17.354  - info: yahka.0 (21588) adding Wasser Garten 5A with UUID: cfba9462-495d-445e-bdaf-92d89e5d323c
                                          2023-02-11 18:02:17.358  - info: yahka.0 (21588) adding Wasser Feedback 1 with UUID: 80efd4c4-8f76-48b0-b794-663ac97d7d2a
                                          2023-02-11 18:02:17.362  - info: yahka.0 (21588) adding Wasser Feedback 2 with UUID: c7c1a3fe-b438-43eb-a479-bbda51d1d6c8
                                          2023-02-11 18:02:17.366  - info: yahka.0 (21588) adding Wasser Feedback 3 with UUID: 3270564c-f984-4208-88ed-bcafad48b3e3
                                          2023-02-11 18:02:17.370  - info: yahka.0 (21588) adding Wasser Feedback 4 with UUID: 94316748-7b8a-456d-9813-e1529df2ff42
                                          2023-02-11 18:02:17.375  - info: yahka.0 (21588) adding Wasser Feedback 5 with UUID: 192619c5-90be-4580-8af2-9cdd5282fc7a
                                          2023-02-11 18:02:17.379  - info: yahka.0 (21588) adding Wasser Feedback 6 with UUID: 442ced11-b93a-4a60-9eaf-d6b789ce2e54
                                          2023-02-11 18:02:17.382  - info: yahka.0 (21588) adding Wasser Garten 6A with UUID: 5356872a-1195-47ad-a30c-62d253157baf
                                          2023-02-11 18:02:17.386  - info: yahka.0 (21588) adding Motion Cat1 with UUID: 01ba38ce-6b34-4467-8989-7af6f0774eeb
                                          2023-02-11 18:02:17.389  - info: yahka.0 (21588) adding Motion Cat2 with UUID: 9122c6a7-6598-4298-84f5-ecc8c2598e8d
                                          2023-02-11 18:02:17.392  - info: yahka.0 (21588) publishing bridge Yahka-0 on 0.0.0.0 using ciao
                                          und Teil2:
                                                               v.2023-01-02
                                          Operatingsystem:        Raspbian GNU/Linux 10 (buster)
                                          Installation:           Native
                                          Timezone:               Europe/Zurich
                                          User-ID:                1000
                                          X-Server:               false
                                          Pending OS-Updates:     0
                                          Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
        /usr/bin/npm            8.19.3
        /usr/bin/npx            8.19.3
                                          ioBroker Core:          js-controller           4.0.24
        admin                   6.3.5
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Status admin:
                                          Pending iob updates:    0
                                          Objects:                3093
                                          States:                 2599
                                          Size of iob-Database:
                                          1.8M    /opt/iobroker/iobroker-data/states.jsonl
                                          684K    /opt/iobroker/iobroker-data/states.json.migrated
                                          684K    /opt/iobroker/iobroker-data/states.json.bak.migrated
                                          32.7k
                                          82.6k
