  4. NPM WARN
    1.6k
NPM WARN
9 Beiträge 2 Kommentatoren 802 Aufrufe 2 Beobachtet
    djsirius
    Moin.
    kann mir vielleicht bitte jemand erklären, wie ich die folgenden npm Warnungen beheben kann?
    Die nerven, zudem dauert durch die Warnungen die Updates gefühlt eine halbe Stunde. :-(
    NPM version: 8.19.3
    Installing iobroker.hm-rega@3.0.43... (System call)
    npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
    npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
    npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
    npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
    npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
    npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    removed 871 packages, and changed 1164 packages in 3m
    106 packages are looking for funding run `npm fund` for details
    Vielen Dank!
    djsirius
    • D djsirius
      Moin.
      NPM version: 8.19.3
      Vielen Dank!
      @djsirius sagte in NPM WARN:
      Gar nicht. Lass einfach die Finger davon.
      Die Abfrage der Registry geht eigentlich recht flott. Das kann nicht der Grund für dein 'Gefühl' sein.
        djsirius
        schrieb am zuletzt editiert von djsirius
        Okay, vielen Dank!
        Dass die Updates so lange dauern ist erst seit dem Update auf NPM 8 der Fall. Vorher liefen die Updates schnell durch.
        djsirius
        • D djsirius
          Okay, vielen Dank!
          Das ist eigentlich eher bei npm6 ein Thema gewesen.
          Ist da bei dir alles senkrecht in der Ecke?
          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
          sagt?
            sagt?
            djsirius
            iobroker@debian:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx        -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt u        pdate &> /dev/null && sudo apt update && apt policy nodejs
            iobroker@debian:~$ uname -m && type -P nodejs node npm npx && nodejs -v && node        -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE &        & pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v16.19.0
            v16.19.0
            8.19.3
            8.19.3
            4.0.24
            iobroker
            iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth        lpadmin scanner
            tty
            /home/iobroker
            OK:1 http://deb.debian.org/debian buster InRelease
            OK:2 http://security.debian.org/debian-security buster/updates InRelease
            OK:3 http://deb.debian.org/debian-security buster/updates InRelease
            OK:4 http://deb.debian.org/debian buster-updates InRelease
            OK:5 http://ftp.de.debian.org/debian buster InRelease
            OK:6 https://deb.nodesource.com/node_16.x buster InRelease
            OK:7 http://deb.debian.org/debian buster-backports InRelease
            OK:8 http://ftp.de.debian.org/debian buster-updates InRelease
            OK:9 https://packages.sury.org/php buster InRelease
            OK:10 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
            Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
            nodejs:
              Installiert:           16.19.0-deb-1nodesource1
              Installationskandidat: 16.19.0-deb-1nodesource1
              Versionstabelle:
             *** 16.19.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
                 10.24.0~dfsg-1~deb10u2 500
                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                    500 http://deb.debian.org/debian-security buster/updates/main amd64 Packages
                 10.24.0~dfsg-1~deb10u1 500
                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
                    500 http://deb.debian.org/debian buster/main amd64 Packages
            djsirius
            • D djsirius
              x86_64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              v16.19.0
              v16.19.0
              8.19.3
              8.19.3
              4.0.24
              iobroker
              tty
              /home/iobroker
              nodejs:
                Versionstabelle:
              Beerdige den Buster, der ist seit September 2022 verstorben.
              Bullseye / Debian 11 ist gerade stabil.
                djsirius
                Ok!
                Kann man das Update drüber bügeln, oder muss man alles neu installieren?
                djsirius
                • D djsirius
                  Ok!
                  Ich hab das hier
                  https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                  mal per Distributions-Upgrade gemacht.
                  Der offizielle Weg sieht allerdings eine Neuinstallation vor.
                    Ich hab das hier
                    djsirius
                    Vielen Dank! 👍
                    djsirius
                    82.9k
