<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[NPM WARN]]></title><description><![CDATA[<p dir="auto">Moin.</p>
<p dir="auto">kann mir vielleicht bitte jemand erklären, wie ich die folgenden npm Warnungen beheben kann?</p>
<p dir="auto">Die nerven, zudem dauert durch die Warnungen die Updates gefühlt eine halbe Stunde. :-(</p>
<pre><code>NPM version: 8.19.3
Installing iobroker.hm-rega@3.0.43... (System call)
npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
npm WARN deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
npm WARN deprecated debug@4.1.1: Debug versions &gt;=3.2.0 &lt;3.2.7 || &gt;=4 &lt;4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
removed 871 packages, and changed 1164 packages in 3m
106 packages are looking for funding run `npm fund` for details
</code></pre>
<p dir="auto">Vielen Dank!</p>
]]></description><link>https://forum.iobroker.net/topic/62859/npm-warn</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 04:50:52 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/62859.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 10 Feb 2023 11:11:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 12:15:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a><br />
Vielen Dank! <img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f44d.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--+1" style="height:23px;width:auto;vertical-align:middle" title=":+1:" alt="👍" /></p>
]]></description><link>https://forum.iobroker.net/post/944453</link><guid isPermaLink="true">https://forum.iobroker.net/post/944453</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 10 Feb 2023 12:15:10 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 12:12:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a> sagte in <a href="/post/944449">NPM WARN</a>:</p>
<blockquote>
<p dir="auto">Kann man das Update drüber bügeln, oder muss man alles neu installieren?</p>
</blockquote>
<p dir="auto">Ich hab das hier<br />
<a href="https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye">https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye</a><br />
mal per Distributions-Upgrade gemacht.<br />
Der offizielle Weg sieht allerdings eine Neuinstallation vor.</p>
]]></description><link>https://forum.iobroker.net/post/944450</link><guid isPermaLink="true">https://forum.iobroker.net/post/944450</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 10 Feb 2023 12:12:33 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 12:10:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Ok!</p>
]]></description><link>https://forum.iobroker.net/post/944449</link><guid isPermaLink="true">https://forum.iobroker.net/post/944449</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 10 Feb 2023 12:10:56 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 12:09:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a> sagte in <a href="/post/944446">NPM WARN</a>:</p>
<p dir="auto">Beerdige den Buster, der ist seit September 2022 verstorben.<br />
Bullseye / Debian 11 ist gerade stabil.</p>
]]></description><link>https://forum.iobroker.net/post/944448</link><guid isPermaLink="true">https://forum.iobroker.net/post/944448</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 10 Feb 2023 12:09:40 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 12:08:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>iobroker@debian:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &amp;&gt; /dev/null
uname -m &amp;&amp; type -P nodejs node npm npx &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; npx        -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; echo $XDG_SESSION_TYPE &amp;&amp; pwd &amp;&amp; sudo apt u        pdate &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
iobroker@debian:~$ uname -m &amp;&amp; type -P nodejs node npm npx &amp;&amp; nodejs -v &amp;&amp; node        -v &amp;&amp; npm -v &amp;&amp; npx -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; echo $XDG_SESSION_TYPE &amp;        &amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
x86_64
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
/usr/bin/npx
v16.19.0
v16.19.0
8.19.3
8.19.3
4.0.24
iobroker
iobroker tty dialout cdrom floppy sudo audio dip video plugdev netdev bluetooth        lpadmin scanner
tty
/home/iobroker
OK:1 http://deb.debian.org/debian buster InRelease
OK:2 http://security.debian.org/debian-security buster/updates InRelease
OK:3 http://deb.debian.org/debian-security buster/updates InRelease
OK:4 http://deb.debian.org/debian buster-updates InRelease
OK:5 http://ftp.de.debian.org/debian buster InRelease
OK:6 https://deb.nodesource.com/node_16.x buster InRelease
OK:7 http://deb.debian.org/debian buster-backports InRelease
OK:8 http://ftp.de.debian.org/debian buster-updates InRelease
OK:9 https://packages.sury.org/php buster InRelease
OK:10 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
nodejs:
  Installiert:           16.19.0-deb-1nodesource1
  Installationskandidat: 16.19.0-deb-1nodesource1
  Versionstabelle:
 *** 16.19.0-deb-1nodesource1 500
        500 https://deb.nodesource.com/node_16.x buster/main amd64 Packages
        100 /var/lib/dpkg/status
     10.24.0~dfsg-1~deb10u2 500
        500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
        500 http://deb.debian.org/debian-security buster/updates/main amd64 Packages
     10.24.0~dfsg-1~deb10u1 500
        500 http://ftp.de.debian.org/debian buster/main amd64 Packages
        500 http://deb.debian.org/debian buster/main amd64 Packages
</code></pre>
]]></description><link>https://forum.iobroker.net/post/944446</link><guid isPermaLink="true">https://forum.iobroker.net/post/944446</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 10 Feb 2023 12:08:12 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 11:59:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a> sagte in <a href="/post/944438">NPM WARN</a>:</p>
<blockquote>
<p dir="auto">Dass die Updates so lange dauern ist erst seit dem Update auf NPM 8 der Fall.</p>
</blockquote>
<p dir="auto">Das ist eigentlich eher bei npm6 ein Thema gewesen.<br />
Ist da bei dir alles senkrecht in der Ecke?</p>
<pre><code>sudo ln -s /usr/bin/node /usr/bin/nodejs &amp;&gt; /dev/null
uname -m &amp;&amp; type -P nodejs node npm npx &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v &amp;&amp; npx -v &amp;&amp; iob -v &amp;&amp; whoami &amp;&amp; groups &amp;&amp; echo $XDG_SESSION_TYPE &amp;&amp; pwd &amp;&amp; sudo apt update &amp;&gt; /dev/null &amp;&amp; sudo apt update &amp;&amp; apt policy nodejs
</code></pre>
<p dir="auto">sagt?</p>
]]></description><link>https://forum.iobroker.net/post/944439</link><guid isPermaLink="true">https://forum.iobroker.net/post/944439</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 10 Feb 2023 11:59:42 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 11:58:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Okay, vielen Dank!</p>
<p dir="auto">Dass die Updates so lange dauern ist erst seit dem Update auf NPM 8 der Fall. Vorher liefen die Updates schnell durch.</p>
]]></description><link>https://forum.iobroker.net/post/944438</link><guid isPermaLink="true">https://forum.iobroker.net/post/944438</guid><dc:creator><![CDATA[djsirius]]></dc:creator><pubDate>Fri, 10 Feb 2023 11:58:31 GMT</pubDate></item><item><title><![CDATA[Reply to NPM WARN on Fri, 10 Feb 2023 11:15:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/djsirius" aria-label="Profile: djsirius">@<bdi>djsirius</bdi></a> sagte in <a href="/post/944424">NPM WARN</a>:</p>
<blockquote>
<p dir="auto">wie ich die folgenden npm Warnungen beheben kann?</p>
</blockquote>
<p dir="auto">Gar nicht. Lass einfach die Finger davon.</p>
<blockquote>
<p dir="auto">dauert durch die Warnungen die Updates gefühlt eine halbe Stunde</p>
</blockquote>
<p dir="auto">Die Abfrage der Registry geht eigentlich recht flott. Das kann nicht der Grund für dein 'Gefühl' sein.</p>
]]></description><link>https://forum.iobroker.net/post/944425</link><guid isPermaLink="true">https://forum.iobroker.net/post/944425</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 10 Feb 2023 11:15:41 GMT</pubDate></item></channel></rss>
