  4. Cubietruck 3 nicht erreichbar nach node 14.x Löschung
    5.4k
158 Beiträge 6 Kommentatoren 22.4k Aufrufe 4 Beobachtet
  • B blackangel15741
    Also ich habe das vor längerem gemacht aber weiß das booten von sd und system auf Festplatte sda1
    Für persönlich Daten also z.B. vis Projekte habe ich dann auf eine andere Partition hinterlegt.
    root@cubietruck:~# sudo mount | sort
    bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
    cgroup2 on /sys/fs/cgroup/unified type cgroup2 (rw,nosuid,nodev,noexec,relati
    me,nsdelegate)
    cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,b
    lkio)
    cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,rela
    time,cpu,cpuacct)
    cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,
    cpuset)
    cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime
    ,devices)
    cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime
    ,freezer)
    cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,
    memory)
    cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec
    ,relatime,net_cls,net_prio)
    cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relat
    ime,perf_event)
    cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pi
    ds)
    cgroup on /sys/fs/cgroup/rdma type cgroup (rw,nosuid,nodev,noexec,relatime,rd
    ma)
    cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime
    ,xattr,name=systemd)
    configfs on /sys/kernel/config type configfs (rw,relatime)
    debugfs on /sys/kernel/debug type debugfs (rw,relatime)
    /dev/mmcblk0p1 on / type ext4 (rw,noatime,errors=remount-ro,commit=600)
    /dev/mmcblk0p1 on /var/log.hdd type ext4 (rw,noatime,errors=remount-ro,commit
    =600)
    devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmx
    mode=000)
    /dev/zram1 on /var/log type ext4 (rw,relatime,discard)
    fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
    mqueue on /dev/mqueue type mqueue (rw,relatime)
    proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
    pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
    securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,re
    latime)
    sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
    sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
    systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=39,pgrp=1,t
    imeout=0,minproto=5,maxproto=5,direct)
    tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
    tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
    tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=205920k,mode=755)
    tmpfs on /run/user/0 type tmpfs (rw,nosuid,nodev,relatime,size=205916k,mode=7
    00)
    tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=205916k,mod
    e=700,uid=1000,gid=1000)
    tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
    tmpfs on /tmp type tmpfs (rw,nosuid,relatime)
    tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
    udev on /dev type devtmpfs (rw,nosuid,relatime,size=975140k,nr_inodes=160658,
    mode=755)
    root@cubietruck:~#
    @blackangel15741
    Nicht als root herumhampeln!
    Standarduser anlegen, dem sudo-Rechte geben und dann weiter mit dem herumhüpfen.
      @blackangel15741 sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
      dass das iobroker system ja noch komplett auf der sda1 vorliegt backup und vis projekte ggf auf der sda2
      Hast du das denn so eingestellt gehabt? Oder ist das jetzt Vermutung und Wunschdenken?
      Hast du jetzt wieder ein laufendes System und die drei genannten Partitionen sind da gar nicht gemountet oder wie?
      mount | sort
      sagt?
      blackangel15741
      schrieb am zuletzt editiert von blackangel15741
      @thomas-braun ja also cubietruck ist wieder erreichbar aber zeigt die Festplatte nicht an.....wenn man danach sucht findet er die sda1 sda2 und sda3 auch aber jetzt komme ich nicht weiter System hatte ich ein neues Image eingespielt...iobroker habe ich jetzt noch nicht am laufen...
      Müsste ja jetzt ggf über nand-sata-install dann die Festplatte einrichten und habe jetzt Angst,weil da steht, dass dann alles gelöscht wird, wenn ich mich richtig erinnere.
      Weiß nur nicht ob das Löschen nur die Partition sda1 betrifft oder die ganze Platte und ob man dann trotzdem Zugriff auf die anderen Partitionen hat, falls nur die sda 1 gelöscht wird.
      • B blackangel15741
        Was bedeutet das für mich? Wie suchst du denn danach?
          @blackangel15741
          blackangel15741
          @thomas-braun sagte in Cubietruck 3 nicht erreichbar nach node 14.x Löschung:
          @blackangel15741
          Wie mache ich das? Ich wurde gleich bei der Installation nach einem Passwort gefragt Benutzername und Loginname. Hatte vorher auch keine sudo zur Ausführung gebraucht.
            blackangel15741
            Habe es so gemacht
            fdisk -l
            • B blackangel15741
              @blackangel15741
              Wie mache ich das?
              Schau in die Anleitung zu Armbian. Dürfte in einem der ersten Kapitel zu finden sein, weil absolute Grundlage.
              • B blackangel15741
                @blackangel15741
                dann nutze diesen User mit seinem Passwort
                  blackangel15741
                  @homoran denke so ist das gemeint ?
                  Last login: Thu Feb  9 20:14:22 2023 from 192.168.xxx.xxx
                  blackangel1508@cubietruck:~$
                  Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
                  • B blackangel15741
                    #66
                    @blackangel15741
                    groups
                    als dieser User sagt?
                    • B blackangel15741
                      wendy2702W Online
                      wendy2702W Online
                      #67
                      Interne IP‘s muss man nicht XXXXXXXX….. die gibt es zu tausenden. Kann keiner was mit anfangen.
                        blackangel15741
                        #68
                        blackangel1508@cubietruck:~$ groups
                        blackangel1508 tty disk dialout sudo audio video plugdev games
                        users systemd-journal input netdev ssh
                        • wendy2702W wendy2702
                          blackangel15741
                          #69
                          @wendy2702 danke
                          • B blackangel15741
                            #70
                            @blackangel15741
                            Den User noch in die Gruppe 'iobroker' packen und den root vergessen, der wird nicht mehr verwendet.
                              @blackangel15741
                              blackangel15741
                              #71
                              @thomas-braun also iobroker läuft ja noch nicht komme mit der Festplatte nicht weiter siehe auch weiter oben
                              In die Gruppe iobroker packen? Da scheitere ich wieder
                              • B blackangel15741
                                #72
                                @blackangel15741
                                sudo usermod -a -G iobroker DEINUSER
                                B 2 Antworten Letzte Antwort
                                  @blackangel15741
                                  blackangel15741
                                  #73
                                  @thomas-braun bringt das jetzt was, wenn iobroker noch nicht läuft?
                                  • B blackangel15741
                                    wendy2702W Online
                                    wendy2702W Online
                                    #74
                                    @blackangel15741 Hat mit laufendem iobroker nichts zu tun. Der muss nur installiert sein und es die Gruppe geben.
                                    • B blackangel15741
                                      #75
                                      was ist dabei rausgekommen?
                                      mount | sort
                                      sagt?
                                      ich hab die Antworten dazu irgendwie übersehen.
                                        mount | sort
                                        sagt?
                                        blackangel15741
                                        #76
                                        blackangel1508@cubietruck:~$ mount | sort
                                        binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,re
                                        latime)
                                        de=700)
                                        ,noexec,relatime,nsdelegate)
                                        xec,relatime,blkio)
                                        ev,noexec,relatime,cpu,cpuacct)
                                        exec,relatime,cpuset)
                                        oexec,relatime,devices)
                                        oexec,relatime,freezer)
                                        exec,relatime,memory)
                                        d,nodev,noexec,relatime,net_cls,net_prio)
                                        v,noexec,relatime,perf_event)
                                        ec,relatime,pids)
                                        ec,relatime,rdma)
                                        oexec,relatime,xattr,name=systemd)
                                        mit=600)
                                        ount-ro,commit=600)
                                        ,mode=620,ptmxmode=000)
                                        latime)
                                        fd=37,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)
                                        size=5120k)
                                        tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=204800
                                        k,mode=755)
                                        204796k,mode=700)
                                        ze=204796k,mode=700,uid=1000,gid=1000)
                                        =755)
                                        udev on /dev type devtmpfs (rw,nosuid,relatime,size=969528k,nr_
                                        inodes=160685,mode=755)
                                          @blackangel15741
                                          blackangel15741
                                          #77
                                          @blackangel15741
                                          Also jetzt die Zeile 1 zu 1 so übernehmen?
