  3. Einsteigerfragen
  4. Installation
  5. Installation auf RapsPi, Node.js nicht installiert
    5.5k
12 Beiträge 3 Kommentatoren 1.3k Aufrufe 3 Beobachtet
    Sammy R.
    schrieb am zuletzt editiert von Sammy R.
    Moin,
    ich bin der angepinnten Anleitung Installation auf Raspi gefolgt. Genutzt habe ich die 64-Bit-light-Version vom OS.
    Leider wird der ioBroker nicht installiert, da die vorherige Installation von node.js nicht funktioniert hat.
    Hier mal der Beginn des Logs:
        Node.js not found. Installing...
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Hit:1 http://deb.debian.org/debian bullseye InRelease
    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
    Err:1 http://deb.debian.org/debian bullseye InRelease
      Couldn't create temporary file /tmp/apt.conf.EEOXG6 for passing config to apt-key
    Err:2 http://deb.debian.org/debian bullseye-updates InRelease
      Couldn't create temporary file /tmp/apt.conf.Pb6WJ9 for passing config to apt-key
    Err:3 http://security.debian.org/debian-security bullseye-security InRelease
      Couldn't create temporary file /tmp/apt.conf.criiSe for passing config to apt-key
    Err:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Couldn't create temporary file /tmp/apt.conf.LxSyxk for passing config to apt-key
    Reading package lists... Done
    W: chown to _apt:root of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
    W: chmod 0700 of directory /var/lib/apt/lists/partial failed - SetupAPTPartialDirectory (30: Read-only file system)
    W: chown to _apt:root of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system)
    W: chmod 0755 of directory /var/lib/apt/lists/auxfiles failed - SetupAPTPartialDirectory (30: Read-only file system)
    W: Not using locking for read only lock file /var/lib/apt/lists/lock
    Mit viel Einsatz könnte ich jetzt versuchen, dass manuell zu korrigieren, dann würde ich aber unsicheres Terrain betreten, weshalb ich lieber Leute frage die sich wirklich damit auskennen ;-)
    Für mich liest sich das so, als würden die Berechtigungen für /tmp nicht passen.
    Vor allem aber scheint der Fehler ja in der Anleitung nicht vorgesehen zu sein und wenn ich nicht 'Schuld' bin, dann sollte die ja evtl. angepasst werden.
    Also vorsichtige Frage: Hab ich etwas falsch gemacht? Hat sich im Raps-Image evtl. etwas geändert?
    Edit: Ich habe die Anpassung für die SD-Karte ebenfalls vorgenommen.
    wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
    • S Sammy R.
      Moin,
      + apt-get update
      wendy2702W Offline
      wendy2702W Offline
      @sammy-r dann bist du der Anleitung nicht gefolgt.
      Denn da steht nichts von vorherige Node Installation.
      Fang von vorne an und mache nur was in der Anleitung steht.
      • wendy2702W wendy2702
        Sammy R.
        @wendy2702
        Ich habe nichts vorher installiert. Das hab ich auch nicht geschrieben. Ich habe das curl nach Anleitung angeworfen und das will als erstes Node.ja installieren, bevor dann das iobroker kommt. Dessen Fehlermeldung dürfen aber dann ja Folgefehler sein, weshalb ich nur den Beginn kopiert habe.
        Zur Sicherheit:
        Das kommt bei curl -sLf https://iobroker.net/install.sh | bash -
        • S Sammy R.
          @wendy2702
          Zur Sicherheit:
          @sammy-r
          Da ist dein Dateisystem vermutlich im Eimer. Warum auch immer. Anderes Installationsmedium probieren.
          • S Sammy R.
            Moin,
            + apt-get update
            @sammy-r sagte in Installation auf RapsPi, Node.js nicht installiert:
            Nein, es hat sich bei der Installation nichts geändert.
            Welche Anpassung?
              Welche Anpassung?
              Sammy R.
              Ich meinte die Frequenz, in der auf die SD-Karte geschrieben wird.
              • S Sammy R.
                @sammy-r
                Da was falsch gemacht?
                Das Dateisystem ist nur lesbar eingehängt.
                  @sammy-r
                  Sammy R.
                  You're right.
                  Ich hatte jetzt etwas mehr Zeit und habe mal nachgelesen, was die sed-Parameter eigentlich bedeuten...
                  Ich glaube, dass ich da ein Space vor dem 'commit=600' hatte und das dann nur korrigiert hatte. Durch den zweite Aufruf ist die Zeile dann vermutlich ungültig geworden (2 Kommata hintereinander).
                  Das passiert, wenn man meint, dass man die kurze Anleitung nebenbei abarbeiten kann - sry!
                  Nun komme ich weiter, bekomme aber immer noch einen Fehler:
                  library: loaded
                  Library version=2022-12-09
                      Welcome to the ioBroker installer!
                      Installer version: 2022-12-22
                      You might need to enter your password a couple of times.
                      Installing prerequisites (1/4)
                  + apt-get update
                  ## Confirming "bullseye" is supported...
                  + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
                  ## Adding the NodeSource signing key to your keyring...
                  + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
                  ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
                  + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
                  + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
                  ## Running `apt-get update` for you...
                  + apt-get update
                  Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                  Get:5 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
                  Get:6 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages [771 B]
                  Get:7 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages [784 B]
                  Fetched 6,141 B in 6s (1,068 B/s)
                  ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
                  ## You may also need development tools to build native addons:
                       sudo apt-get install gcc g++ make
                  ## To install the Yarn package manager, run:
                       curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
                       echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                       sudo apt-get update && sudo apt-get install yarn
                  Installed nodejs
                  Cannot install Node.js! Please install it manually.
                  Ich nehme mal an, dass das 'installed nodejs' einfach eine finale Ausgabe des Skripts ist und nicht nur bei Erfolg ausgegeben wird.
                  Eine manuelle Installation soll aber ja eigentlich nicht notwendig sein. Könntet Ihr Profis da bitte einen Blick drauf werfen?
                  ## Run `sudo apt-get install -y nodejs`...
                  Hätte ich (warum auch immer) cUrl vielleicht mit sudo hätte aufrufen müssen?
                  Edit: Nein, das hilft auch nicht ;-).
                  • S Sammy R.
                    You're right.
                    library: loaded
                    + apt-get update
                    + apt-get update
                    Installed nodejs
                    wendy2702W Offline
                    wendy2702W Offline
                    @sammy-r Habe es gerade mal getestet, geht immer noch:
                    Installed nodejs
                    Node.js Installed successfully!
                    Changing npm registry to https://registry.npmjs.org
                    Installed acl
                    Installed build-essential
                    Installed gcc-c++
                    Installed libavahi-compat-libdnssd-dev
                    Installed libudev-dev
                    Installed libpam0g-dev
                    Installed git
                    Installed unzip
                    Installed libcairo2-dev
                    Zwischen dem Beginn der Installation und der Fertigmeldung vergehen allerdings paar Sekunden ohne sichtbare Ausgabe.
                    • S Sammy R.
                      You're right.
                      library: loaded
                      + apt-get update
                      + apt-get update
                      Installed nodejs
                      @sammy-r
                      Ist eigentlich ziemlich eindeutig. Und in einem gesunden System ist die Installation natürlich per Installer möglich. Irgendwas läuft da bei dir falsch.
                      Installier es einfach nochmal und lass den Zusatz für die SD-Karte weg.
                        @sammy-r
                        Sammy R.
                        Das wäre der nächste Versuch gewesen.
                        Ich habe jetzt einfach mal die 32-Bit-Version versucht und damit geht es problemfrei, Installation ist durch und ioiBroker im Browser aufrufbar.
                        Zugegeben, es war der 2. Versuch, beim ersten kamen bereits beim Update des OS Fehlermeldungen (evtl. beim Image die SD-Karte nicht korrekt entfernt?!).
                        Gegenüber den diversen mit dem 64-Bit-System ist das aber ein guter Schnitt und wohl eher kein Zufall.
                        Ich nutze einen Raspberry Pi 3B, vielleicht kann damit ja jemand mal die 64-Bit-Version ausprobieren. Vielleicht passt da ja doch etwas nicht.
                        • S Sammy R.
                          Sammy R.
                          …und bevor ich das vergesse:
                          Danke für die Hilfe durch genannten Post und die Antworten hier und allgemein Euren Einsatz hier!
