4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • mickymM mickym
    @mickym Habe ich
    Wo hast Du es denn hin kopiert?
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #3459
    @mickym links rein
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      @mickym links rein
      mickymM Offline
      mickymM Offline
      mickym
      #3460
      @damrak2022 Ja dann mach halt einen Screenshot von der Webseite dann sehe ich das. Du könntest mir das ja auch hier in CodeTags reinkopieren, dann kann ich es auch auf die try Seite kopieren.
      • mickymM mickym
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #3461
        @mickym
        [{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T20:42:42.51Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T20:50:45.646Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T21:00:38.102Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T21:30:37.019Z","_value":16.7,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T21:45:37.613Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:00:36.16Z","_value":16.28,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:05:33.349Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:15:37.665Z","_value":16.28,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:20:34.613Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:30:36.384Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:45:36.481Z","_value":16.7,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T22:55:30.062Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T23:00:26.799Z","_value":16.14,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T23:05:33.648Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T23:10:29.994Z","_value":16.7,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T23:15:25.881Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-02T23:20:33.739Z","_value":16.28,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:05:26.567Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:10:24.056Z","_value":16.7,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:20:26.456Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:30:17.96Z","_value":16.7,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:45:17.705Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:50:15.562Z","_value":16.42,"_field":"value","_measurement":"Temperatur_Kueche"},{"result":"_result","table":0,"_start":"2023-01-04T00:58:17.992155465Z","_stop":"2023-02-03T00:58:17.992155465Z","_time":"2023-02-03T00:55:22.939Z","_value":16.56,"_field":"value","_measurement":"Temperatur_Kueche"}]
        Mit besten Grüßen
        Andy
          @mickym
          mickymM Offline
          mickymM Offline
          mickym
          #3462
          @damrak2022 Gut dann sollte Deine Webseite ja nun so aussehen:
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #3463
            @mickym Korrekt
            Mit besten Grüßen
            Andy
              @mickym Korrekt
              mickymM Offline
              mickymM Offline
              mickym
              #3464
              @damrak2022 Gut was musst Du in die Change Node eingeben, wenn Du mit JSONATA - das Eingangsobjekt unverändert wieder ausgeben möchtest?
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #3465
                @mickym Auf der Exercise Seite ist es das $ Zeichen. Change Node weiß ich gerade. nicht, hattest Du mir aber gestern gesagt, das weiß ich noch
                Mit besten Grüßen
                Andy
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #3466
                  @mickym payload
                  Mit besten Grüßen
                  Andy
                    @mickym payload
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #3467
                    @mickym payload
                    Korrekt - das hab ich Dir gesagt und Du hast es ja mit dem Array aus der payload und der series aus dem Nachrichtenobjekt vor 5 Minuten gemacht. :)
                    Also wenn Du nichts änderst und willst mit JSONATA das unverändert weitergeben. Dann gibt man die payload unverändert weiter.
                    • mickymM mickym
                      @mickym payload
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #3468
                      @mickym Okay, ich hatte weiter oben gefragt wofür es da "result" und "table" gibt. Das ist mir nicht klar.
                      Mit besten Grüßen
                      Andy
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #3469
                        Das kommt halt aus der Abfrage aus Deiner Influx DB raus. Aber diese Informationen brauchen wir nicht - Du solltest Dich in erster Linie darauf konzentrieren, wie das Objekt aussehen muss, was in die Chart Node muss. Also was muss da für ein Objekt rein.
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #3470
                          @mickym time und value, evtl. auch start stop
                          payload[0]._value
                          payload[0]._time
                          payload[0]._measurement
                          Mit besten Grüßen
                          Andy
                            payload[0]._value
                            payload[0]._time
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #3471
                            @damrak2022 Oh bitte - nicht wieder nach dem Eingangsobjekt richten. Sondern was muss rauskommen? Welche Datentypen - wie ist der Aufbau. - Was haben wir die letzten 2 Tage gemacht?
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #3472
                              @mickym Mit diesen Fragen tue ich mich schwer.
                              Wir brauchen den Wert, also die Temperatur und die Zeit, also beides Zahlenwerte.
                              Mit besten Grüßen
                              Andy
                                payload[0]._value
                                payload[0]._time
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #3473
                                payload[0]._value
                                payload[0]._time
                                Und wenn du dies Daten rausholen würdest, dann würdest Du die Werte des ersten Datensatzes rausholen. Du brauchst aber alle. Also vergiss das erst mal - sondern richte Dein GESAMTES AUGENMERK nur darauf wie das Zielobjekt aussehen musst.
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #3474
                                  NEIN - das Zielobjekt sieht aus - wie auf Steves Screenshot.
                                  • mickymM mickym
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #3475
                                    @mickym Hast Du den Screenshot greifbar?
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #3476
                                      Ja
                                      steht etwas weiter unten im Thread. Das haben wir die letzten 2 Tage gemacht.
                                      labels brauchen wir aber nicht für den Linienchart.
                                      mickymM Damrak2022D 2 Antworten Letzte Antwort
                                      • mickymM mickym
                                        Ja
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #3477
                                        @mickym Also was ist das Ganze für ein Objekt. Was ist das 1. Zeichen des Objektes.
                                        • mickymM mickym
                                          Ja
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #3478
                                          @mickym Wir brauchen die Eigenschaften x und y
                                          Mit besten Grüßen
                                          Andy
