4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • mickymM mickym
    @damrak2022 Nein sorry ist mir wieder ein Fehler passiert. Ich ändere es gleich. So ich habs korrigiert nochmal importieren pls:
           "id": "e79f1c62ef97b36a",
           "type": "inject",
           "z": "1983aa28392732ca",
           "name": "Influx DB Abfrage zur Initialisierung",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "[{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T05:50:55.302Z\",\"_value\":84,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T06:07:26.39Z\",\"_value\":78,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T10:07:26.438Z\",\"_value\":87,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":0,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:22:26.52Z\",\"_value\":71,\"_field\":\"value\",\"_measurement\":\"Diastole\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T05:51:28.093Z\",\"_value\":114,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T06:07:26.392Z\",\"_value\":106,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:07:26.442Z\",\"_value\":106,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":1,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:22:26.521Z\",\"_value\":85,\"_field\":\"value\",\"_measurement\":\"Puls\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T05:50:25.342Z\",\"_value\":127,\"_field\":\"value\",\"_measurement\":\"Systole\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-23T06:07:26.39Z\",\"_value\":114,\"_field\":\"value\",\"_measurement\":\"Systole\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:07:26.439Z\",\"_value\":114,\"_field\":\"value\",\"_measurement\":\"Systole\"},{\"result\":\"_result\",\"table\":2,\"_start\":\"2023-01-19T00:35:58.94679632Z\",\"_stop\":\"2023-01-26T00:35:58.94679632Z\",\"_time\":\"2023-01-24T07:22:26.521Z\",\"_value\":107,\"_field\":\"value\",\"_measurement\":\"Systole\"}]",
           "payloadType": "json",
           "x": 500,
           "y": 340,
           "wires": [
                   "efd1ab4c73f3d571",
                   "a9c39616decfa97c"
           "id": "efd1ab4c73f3d571",
           "type": "change",
           "name": "Create Object Arrays",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "[]",
                   "tot": "jsonata"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 780,
           "y": 340,
           "wires": [
                   "cb3a1a566bc5679f"
           "id": "a9c39616decfa97c",
           "type": "debug",
           "name": "Array aus InfluxDB Abfrage",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 800,
           "y": 400,
           "wires": []
           "id": "cb3a1a566bc5679f",
           "type": "debug",
           "name": "Array zur Initialisierung der Chart Node",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1110,
           "y": 340,
           "wires": []
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #3230
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      mickymM Offline
      mickymM Offline
      mickym
      #3231
      @damrak2022 Nein schaut nicht so aus, wie bei mir.
      Du sollst anfangen wir ich gesagt habe. Die Change Node gibt ein leeres Array aus. Wie definierst Du ein leeres Array?
      • mickymM mickym
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #3232
        @mickym Naja, nur eckige Klammern, ohne Inhalt dazwischen
        Mit besten Grüßen
        Andy
          mickymM Offline
          mickymM Offline
          mickym
          #3233
          Na genau, dann mach das halt - sollte dann immer so aussehen, wie ich poste:
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #3234
            Mit besten Grüßen
            Andy
              mickymM Offline
              mickymM Offline
              mickym
              #3235
              @damrak2022 Genau. Dann was für ein Datentyp ist das erste Element in dem Array?
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #3236
                @mickym Ein Objekt:
                Mit besten Grüßen
                Andy
                  @mickym Ein Objekt:
                  mickymM Offline
                  mickymM Offline
                  mickym
                  #3237
                  @damrak2022 Ja aber nicht wegen dem Input - vergiss den mal - ganz einfach wir bauen die Change Node nicht nach dem Ursprung auf, sondern wie die Nachricht am Ende aussehen soll. Also bleib bitte bei dem Screenshot.
                  Ich habe es violett markiert:
                  Siehst Du das Objekt - wie gesagt - vergiss Deine Quelle es geht NUR um diesen Screenshot.
                  Wenn Du das Objekt mit den beiden geschweiften Klammern erkannt hast, dann änderst Du nun die Change Node so, dass Du in unser leeres Array nun ein leeres Objekt definierst.
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #3238
                    @mickym Ich denke mal so, weil es ja momentan noch leer bleiben soll
                    Mit besten Grüßen
                    Andy
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #3239
                      @damrak2022 Richtig, wie bauen es ja auf.
                      Du siehst also anhand des Screenshots, dass das Array nur EIN Objekt enthält.
                      Siehst Du das?
                      Wenn ja heißt denn die 1. Eigenschaft des einzigen Objektes und was für einen Datentyp einhält es?
                      • mickymM mickym
                        Siehst Du das?
                        Damrak2022D Offline
                        Damrak2022D Offline
                        Damrak2022
                        #3240
                        @mickym Ja klar sehe ich das, die Eigenschaft ist "empty" und es ist ein "string". Bei allem was ich hier schreibe, hoffe ich immer das es stimmt.
                        Mit besten Grüßen
                        Andy
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #3241
                          @damrak2022 Nein Du sollst Dich NUR an dem Screenshot - das ist unser Ziel orientieren.
                          Ich hab Dir doch den Anfang und das Ende des Objektes violett unterstrichen. Wie heißt nun die erste Eigenschaft dieses einen und einzigen Objektes unseres Arrays
                          • mickymM mickym
                            Damrak2022D Offline
                            Damrak2022D Offline
                            Damrak2022
                            #3242
                            @mickym Na, dann müsste die Eigenschaft in dem Fall "Number" sein, aber ich bekomme die Verbindung nicht hin. Ich habe ein leeres Objekt erstellt und das hatte als Eigenschaft "empty", deswegen verwirrt mich das gerade.
                            Mit besten Grüßen
                            Andy
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #3243
                              @damrak2022 Wie ist ein Objekt definiert?
                              • mickymM mickym
                                Damrak2022D Offline
                                Damrak2022D Offline
                                Damrak2022
                                #3244
                                @mickym geschweifte Klammern
                                Mit besten Grüßen
                                Andy
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #3245
                                  @damrak2022 Ja und was enthält ein Objekt bitte die vollständige Definition.
                                  • mickymM mickym
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #3246
                                    @mickym Ein Objekt beinhaltet diverse Eigenschaften in geschweiften Klammern, welche durch ein Komma getrennt werden.
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #3247
                                      @damrak2022 Genau, wie heisst also die erste Eigenschaft in dem Objekt?
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #3248
                                        @mickym das ist das "x"
                                        Mit besten Grüßen
                                        Andy
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #3249
                                          NEIN - kannst Du mir bitte sagen, wieso du auf ein x kommst?
                                          Warum liest Du nicht der Reihe nach Wörter und Buchstaben? was folgt denn direkt auf die geschweifte Klammer?
