  4. Kein Zugriff mehr auf Iobroker :-(
    5.5k
22 Beiträge 4 Kommentatoren 2.6k Aufrufe 3 Beobachtet
  • FC1002F FC1002
    @thomas-braun jetzt kommt wieder eine Fehlermeldung:
                         v.2023-01-02
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Installation:           Native
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/node           v16.19.0
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    ioBroker Status:         Cannot load "custom": Connection is closed.
     Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
    No connection to databases possible ...
    Status admin:
    /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
            throw e;
    Error: Connection is closed.
        at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
        at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
        at Object.onceWrapper (node:events:628:26)
        at Socket.emit (node:events:513:28)
        at TCP.<anonymous> (node:net:301:12)
    Emitted 'error' event on ScanStream instance at:
        at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
        at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
        at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
        at processTicksAndRejections (node:internal/process/task_queues:96:5)
    Pending iob updates:    2
    Active repo(s): stable
    Objects:                23657
    States:                 18287
    Size of iob-Database:
    24M     /opt/iobroker/iobroker-data/objects.jsonl
    36M     /opt/iobroker/iobroker-data/states.jsonl
    @fc1002
    Gib uns mal die Langfassung.
    FC1002F 1 Antwort Letzte Antwort
      @fc1002
      FC1002F Offline
      FC1002F Offline
      FC1002
      @thomas-braun Bitteschön
      Skript v.2023-01-02
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Architecture:   armv7l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       15:44:51 up  4:02,  2 users,  load average: 2.95, 3.29, 3.36
      CPU threads: 4
      *** Time and Time Zones ***
      Sun Jan 15 14:44:51 UTC 2023
      Sun Jan 15 15:44:51 CET 2023
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker wmbusmeters
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.5G        237M        0.0K        1.1G        1.9G
      Swap:            99M         56M         43M
      Total:          3.9G        2.5G        280M
               3837 M total memory
               2479 M used memory
                738 M active memory
               2612 M inactive memory
                237 M free memory
                126 M buffer memory
                995 M swap cache
                 99 M total swap
                 56 M used swap
                 43 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4      110G   12G   95G  11% /
      devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
      tmpfs          tmpfs     768M  980K  767M   1% /run
      /dev/sda1      vfat      253M   50M  203M  20% /boot
      tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
      Messages in dmesg:
      [Sun Jan 15 11:42:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:19:02:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=3957acc8-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
      [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): write access will be enabled during recovery
      [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
      [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): 5 orphan inodes deleted
      [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): recovery complete
      [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [Sun Jan 15 11:42:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
      [Sun Jan 15 11:42:10 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
      TARGET  SOURCE    FSTYPE OPTIONS
      /       /dev/sda2 ext4   rw,noatime
      `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      5.4G    /var/
      3.3G    /var/log
      3.0G    /var/log/journal/b580c5da96934f68b876283b60e13518
      1.1G    /var/lib
      /opt/iobroker/backups:
      62M     /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      628M    /opt/iobroker/iobroker-data/
      503M    /opt/iobroker/iobroker-data/files
      72M     /opt/iobroker/iobroker-data/files/telegram.admin
      69M     /opt/iobroker/iobroker-data/backup-objects
      67M     /opt/iobroker/iobroker-data/files/minuvis
      34M     /opt/iobroker/iobroker-data/states.jsonl
      33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
      15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm            8.19.3
      /usr/bin/npx            8.19.3
      nodejs:
        Installed: 16.19.0-deb-1nodesource1
        Candidate: 16.19.0-deb-1nodesource1
        Version table:
       *** 16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
           12.22.12~dfsg-1~deb11u1 500
      *** ioBroker-Installation ***
      ioBroker Status
              throw e;
      Core adapters versions
      js-controller:  4.0.24
      admin:          6.3.5
      javascript:     6.1.4
      Adapters from github:   1
      Adapter State
      + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
      + system.adapter.b-control-em.0           : b-control-em          : iobroker                                 -  enabled
      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
      + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
      + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
      + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
        system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
        system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
      + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
        system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
      + system.adapter.history.0                : history               : iobroker                                 -  enabled
      + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
      + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
      + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
      + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.material.0               : material              : iobroker                                 - disabled
      + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
        system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
        system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
      + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
      + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
      + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.parser.0                 : parser                : iobroker                                 - disabled
      + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
      + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
        system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
      + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
      + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
        system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
        system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
        system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
      + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
      + system.adapter.tibber.0                 : tibber                : iobroker                                 -  enabled
      + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
      + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
        system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 - disabled
      + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyACM0
        system.adapter.zoe2.0                   : zoe2                  : iobroker                                 -  enabled
      + instance is alive
      ioBroker-Repositories
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
      Adapter    "b-control-em" : 0.2.1    , installed 0.2.1
      Adapter    "backitup"     : 2.5.10   , installed 2.5.9  [Updatable]
      Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "dwd"          : 2.8.3    , installed 2.8.3
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "go-e"         : 1.0.23   , installed 1.0.23
      Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
      Adapter    "hid-community": 0.3.0    , installed 0.3.0
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "hue"          : 3.7.1    , installed 3.7.1
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
      Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
      Adapter    "material"     : 1.1.2    , installed 1.1.2
      Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
      Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
      Adapter    "minuvis"      : 2.2.0    , installed 2.2.0
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "moma"         : 1.2.9    , installed 1.2.9
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "parser"       : 1.1.8    , installed 1.1.8
      Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
      Adapter    "radar2"       : 2.0.3    , installed 2.0.3
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
      Adapter    "shelly"       : 6.0.0    , installed 6.0.0
      Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
      Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
      Adapter    "statistics"   : 2.2.0    , installed 2.2.0
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
      Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "tuya"         : 3.12.1   , installed 3.12.1
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "weatherunderground": 3.4.2, installed 3.4.2
      Adapter    "wireless-mbus": 0.8.6    , installed 0.8.6
      Adapter    "wled"         : 0.6.7    , installed 0.6.7
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
      Objects and States
      Objects:        0
      States:         18288
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:3 https://download.docker.com/linux/raspbian bullseye InRelease [26.7 kB]
      Hit:4 https://repos.influxdata.com/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Fetched 26.7 kB in 4s (6694 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13713      779/influxd
      tcp        0      0 0.0.0.0:9010            0.0.0.0:*               LISTEN      0          16011      1433/docker-proxy
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       347225     28301/node-red
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       347669     27766/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       346074     28287/io.sonoff.0
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       341470     27572/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       342229     27572/iobroker.js-c
      tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      109        14644      1132/mysqld
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       350547     28562/io.jarvis.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9067       496/sshd: /usr/sbin
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        14177      1338/grafana-server
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       340952     27594/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       349153     28762/io.web.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        17797      779/influxd
      tcp6       0      0 :::9010                 :::*                    LISTEN      0          17482      1457/docker-proxy
      tcp6       0      0 :::22                   :::*                    LISTEN      0          9069       496/sshd: /usr/sbin
      udp        0      0 0.0.0.0:59236           0.0.0.0:*                           1001       349589     28727/io.tradfri.0
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       349676     28412/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       349677     28412/io.tuya.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       352382     28280/io.shelly.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11000      774/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       346078     28912/io.wled.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11905      389/avahi-daemon: r
      udp        0      0 0.0.0.0:35096           0.0.0.0:*                           108        11907      389/avahi-daemon: r
      udp6       0      0 :::41428                :::*                                108        11908      389/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          13576      774/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        11906      389/avahi-daemon: r
      2023-01-15 15:46:30.932  - info: plenticore.0 (28660) Got all internal forecast data and made it available to main process.
      2023-01-15 15:46:33.560  - info: dwd.0 (11253) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2023-01-15 15:46:36.070  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2023-01-15 15:46:39.624  - info: plenticore.0 (28660) calcMinSoC for day 1.
      2023-01-15 15:46:39.790  - info: plenticore.0 (28660) calcMinSoC for day 2.
      2023-01-15 15:46:39.791  - info: plenticore.0 (28660) Using forecast of day 2 for MinSoC calculation.
      2023-01-15 15:46:48.048  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
      2023-01-15 15:47:10.839  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
      2023-01-15 15:47:29.993  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
      2023-01-15 15:47:51.465  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
      2023-01-15 15:48:11.099  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
      2023-01-15 15:48:31.761  - warn: javascript.0 (27643) getState "mielecloudservice.0.Dishwashers.000105640993.estimatedEndTime" not found (3)
      2023-01-15 15:48:31.790  - warn: javascript.0 (27643)     at script.js.Eigene_Scripte.Geschirrspüler_Status:24:60
      2023-01-15 15:48:31.792  - warn: javascript.0 (27643)     at Object.<anonymous> (script.js.Eigene_Scripte.Geschirrspüler_Status:24:184)
      2023-01-15 15:48:31.793  - warn: javascript.0 (27643)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
      2023-01-15 15:48:31.796  - warn: javascript.0 (27643)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
      2023-01-15 15:48:31.798  - warn: javascript.0 (27643)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
      2023-01-15 15:48:31.799  - warn: javascript.0 (27643)     at processImmediate (node:internal/timers:466:21)
      2023-01-15 15:48:31.801  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: -8.88
      2023-01-15 15:48:31.802  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: -532800
      2023-01-15 15:48:31.804  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: -888
      2023-01-15 15:48:31.805  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: 60
      2023-01-15 15:48:31.806  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: 948
      2023-01-15 15:48:33.570  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
      2023-01-15 15:48:40.580  - warn: wled.0 (28912) State attribute definition missing for : liveseg with value : -1
      Thomas BraunT SegwayS 2 Antworten Letzte Antwort
      • FC1002F FC1002
        ich habe eine Herausforderung.
        Mein Iobroker auf meinen Raspi4 / SSD ist in letzter Zeit sehr träge geworden, Zugriff auf die Oberfläche größer 60 sekunden :-(
        Heute habe ich nun mal eine Sudo apt-get update & upgrade gemacht und die Pi neu gestartet, Allerdings hat sich die Responsezeit nicht verbessert.
        Wenn ich über die Oberfläche iobroker Status eingebe, kommt das:
        Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
        at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/l ib/states/statesInRedisClient.js:579:23)
        nach mehreren Minuten warten, läuft er dann, aber wieder sehr träge.
        Was könnte das sein?
        Vg Frank
        wendy2702W Offline
        wendy2702W Offline
        @fc1002 sagte in Kein Zugriff mehr auf Iobroker :-(:
        Ist das ein Master Slave System ?
        • FC1002F FC1002
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Docker:         false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          CET +0100
          Europe/Berlin
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         56M         43M
                   3837 M total memory
                   2479 M used memory
                    738 M active memory
                    237 M free memory
                    126 M buffer memory
                    995 M swap cache
                     99 M total swap
                     56 M used swap
                     43 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          5.4G    /var/
          3.3G    /var/log
          1.1G    /var/lib
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
                  throw e;
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        0
          States:         18288
          Pending Updates: 0
          Irgendwas haut da auf die CPU-Auslastung.
          Meist sind das 'krumme' Skripte.
          Und dein journal ist riesig. Was steht denn da drin?
          journalctl --since "2023-01-14 17:15:00"
            wendy2702W Offline
            wendy2702W Offline
            @thomas-braun Kleiner Computer… Viel drauf mit Influx, Grafana, Docker….
            • FC1002F FC1002
              Skript v.2023-01-02
              *** BASE SYSTEM ***
              Docker:         false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              CET +0100
              Europe/Berlin
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M         56M         43M
                       3837 M total memory
                       2479 M used memory
                        738 M active memory
                        237 M free memory
                        126 M buffer memory
                        995 M swap cache
                         99 M total swap
                         56 M used swap
                         43 M free swap
              *** FILESYSTEM ***
              Messages in dmesg:
              /var:
              5.4G    /var/
              3.3G    /var/log
              1.1G    /var/lib
              /usr/bin/npm            8.19.3
              /usr/bin/npx            8.19.3
              nodejs:
                Version table:
              ioBroker Status
                      throw e;
              admin:          6.3.5
              javascript:     6.1.4
              Adapter State
              + instance is alive
              Objects and States
              Objects:        0
              States:         18288
              Pending Updates: 0
              SegwayS Offline
              SegwayS Offline
              Segway
              @fc1002
              Mach mal dein journal kleiner und prüfe VORHER was da reinfallest. Das ist viel zu gross.
              Anleitung kleiner machen ist HIER
              Datei editieren - aber vorher herausfinden warum das so gross ist:
              /etc/systemd/journald.conf
              mit
              SystemMaxUse=100M
              SystemMaxFileSize=100M
              und dann
              service systemd-journald restart
              Gruß Dirk
              • wendy2702W wendy2702
                FC1002F Offline
                FC1002F Offline
                FC1002
                @wendy2702 nein, nur ein Raspi4
                • SegwayS Segway
                  @fc1002
                  mit
                  SystemMaxUse=100M
                  und dann
                  FC1002F Offline
                  FC1002F Offline
                  FC1002
                  Ich hab mir mal das journal aufgerufen. Seite dem 08.12. wird 20x die Sekunde folgendes eingetragen:
                  "Using TZID without Luxon available is unsupported. Returned times are in UTC, not the requested time zone"
                  liegt vermutlich am ical in Verbindung mit Google-Kalender.
                  • FC1002F FC1002
                    Die VOLLSTÄNDIGE Zeile schaut wie aus?
                    iobroker version ical
                    sagt?
                      sagt?
                      FC1002F Offline
                      FC1002F Offline
                      FC1002
                      @thomas-braun Die ical Version ist die 1.13.2
                      Ich habe aber noch was gefunden, die neuesten Einträge lauten:
                      Jan 15 20:45:51 iobroker influxd-systemd-start.sh[779]: [httpd] 192.168.178.60 - iobroker [15/Jan/2023:20:45:51 +0100 "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=iobroker HTTP/1.1 " 204 0 "-" "-" 09c532fc-950e-11ed-ba6f-dca63219025f 4146
                      Sind das die normalen Schreibvorgänge in die Influx-DB?
                      • FC1002F FC1002
                        @fc1002
                        Ja, dürften Schreibvorgänge in die influxdb sein.
