  4. Kein Zugriff mehr auf Iobroker :-(
    5.5k
22 Beiträge 4 Kommentatoren 2.6k Aufrufe 3 Beobachtet
    @fc1002
    Bitte sauber in CodeTags einbetten.
    iobroker start admin
    FC1002F Offline
    FC1002F Offline
    FC1002
    schrieb am zuletzt editiert von FC1002
    @thomas-braun said in Kein Zugriff mehr auf Iobroker :-(:
                         v.2023-01-02
    Operatingsystem:        Raspbian GNU/Linux 11 (bullseye)
    Installation:           Native
    Timezone:               Europe/Berlin
    User-ID:                1000
    X-Server:               false
    Boot Target:            multi-user.target
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/node           v16.19.0
                            /usr/bin/npm            8.19.3
                            /usr/bin/npx            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    ioBroker Status:        iobroker is not running on this host.
    Objects type: jsonl
    States  type: jsonl
    Status admin:
      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    Pending iob updates:    2
    Active repo(s): stable
    Objects:                23596
    States:                 18224
    Size of iob-Database:
    16M     /opt/iobroker/iobroker-data/objects.jsonl
    4.2M    /opt/iobroker/iobroker-data/states.jsonl
    2023-01-15 12:56:16.383  - warn: host.iobroker Cannot get view: Connection is closed.
    2023-01-15 12:56:16.385  - warn: host.iobroker Cannot get view: Connection is closed.
    2023-01-15 12:56:16.386  - warn: host.iobroker Cannot get view: Connection is closed.
    2023-01-15 12:56:16.388  - error: host.iobroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    2023-01-15 12:56:16.389  - error: host.iobroker Caught by controller[0]: Error: DB closed
    2023-01-15 12:56:16.389  - error: host.iobroker Caught by controller[0]:     at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25)
    2023-01-15 12:56:16.390  - error: host.iobroker Caught by controller[0]:     at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20)
    2023-01-15 12:56:16.390  - error: host.iobroker Caught by controller[0]:     at Object.onceWrapper (node:events:628:26)
    2023-01-15 12:56:16.391  - error: host.iobroker Caught by controller[0]:     at Socket.emit (node:events:513:28)
    2023-01-15 12:56:16.391  - error: host.iobroker Caught by controller[0]:     at Socket.emit (node:domain:489:12)
    2023-01-15 12:56:16.392  - error: host.iobroker Caught by controller[0]:     at TCP.<anonymous> (node:net:301:12)
    2023-01-15 12:56:16.392  - warn: host.iobroker instance system.adapter.shelly.0 terminated due to SIGTERM
    2023-01-15 12:56:16.393  - info: host.iobroker instance system.adapter.shelly.0 terminated with code null ()
    2023-01-15 12:56:16.413  - info: host.iobroker All instances are stopped.
    2023-01-15 12:56:16.414  - warn: host.iobroker instance system.adapter.history.0 terminated due to SIGTERM
    2023-01-15 12:56:16.415  - info: host.iobroker instance system.adapter.history.0 terminated with code null ()
    2023-01-15 12:56:16.415  - info: host.iobroker All instances are stopped.
    2023-01-15 12:56:16.416  - warn: host.iobroker instance system.adapter.influxdb.0 terminated due to SIGTERM
    2023-01-15 12:56:16.416  - info: host.iobroker instance system.adapter.influxdb.0 terminated with code null ()
    2023-01-15 12:56:16.417  - info: host.iobroker All instances are stopped.
    2023-01-15 12:56:16.418  - warn: host.iobroker instance system.adapter.tuya.0 terminated due to SIGTERM
    2023-01-15 12:56:16.418  - info: host.iobroker instance system.adapter.tuya.0 terminated with code null ()
    2023-01-15 12:56:16.419  - info: host.iobroker All instances are stopped.
    2023-01-15 12:56:16.466  - info: host.iobroker force terminating
    • FC1002F FC1002
                           v.2023-01-02
      User-ID:                1000
      X-Server:               false
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      Objects:                23596
      States:                 18224
      @fc1002
      Der Admin läuft nicht.
      FC1002F 1 Antwort Letzte Antwort
        @fc1002
        FC1002F Offline
        FC1002F Offline
        FC1002
        @thomas-braun naja, nach iob stop kommt ja auch kein iob start in deinem Posting oder?
        Ich hab jetzt die Diagnose jetzt nochmal nach dem Start durchlaufen lassen.
                             v.2023-01-02
        User-ID:                1000
        X-Server:               false
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                23959
        States:                 18568
        22M     /opt/iobroker/iobroker-data/objects.jsonl
        21M     /opt/iobroker/iobroker-data/states.jsonl
        • FC1002F FC1002
                               v.2023-01-02
          User-ID:                1000
          X-Server:               false
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  admin                   6.3.5
          Objects type: jsonl
          States  type: jsonl
          Status admin:
          Objects:                23959
          States:                 18568
          @fc1002
          Alles gesund.
            @fc1002
            Alles gesund.
            FC1002F Offline
            FC1002F Offline
            FC1002
            @thomas-braun jetzt kommt wieder eine Fehlermeldung:
                                 v.2023-01-02
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
                                    admin                   6.3.5
            ioBroker Status:         Cannot load "custom": Connection is closed.
             Cannot initialize database scripts: Cannot load "custom" into objects database: Connection is closed.
            No connection to databases possible ...
            Status admin:
            /opt/iobroker/node_modules/standard-as-callback/built/index.js:6
                    throw e;
            Error: Connection is closed.
            Emitted 'error' event on ScanStream instance at:
                at /opt/iobroker/node_modules/ioredis/built/ScanStream.js:38:22
                at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:12:23)
                at /opt/iobroker/node_modules/standard-as-callback/built/index.js:33:51
                at processTicksAndRejections (node:internal/process/task_queues:96:5)
            Objects:                23657
            States:                 18287
            24M     /opt/iobroker/iobroker-data/objects.jsonl
            36M     /opt/iobroker/iobroker-data/states.jsonl
            • FC1002F FC1002
                                   v.2023-01-02
              User-ID:                1000
              X-Server:               false
                                      /usr/bin/npm            8.19.3
                                      /usr/bin/npx            8.19.3
                                      admin                   6.3.5
              Status admin:
                      throw e;
              Objects:                23657
              States:                 18287
              @fc1002
              Gib uns mal die Langfassung.
                @fc1002
                FC1002F Offline
                FC1002F Offline
                FC1002
                @thomas-braun Bitteschön
                Skript v.2023-01-02
                *** BASE SYSTEM ***
                Model           : Raspberry Pi 4 Model B Rev 1.1
                Architecture:   armv7l
                Docker:         false
                Virtualization: none
                Distributor ID: Raspbian
                Description:    Raspbian GNU/Linux 11 (bullseye)
                Release:        11
                Codename:       bullseye
                PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                NAME="Raspbian GNU/Linux"
                VERSION_ID="11"
                VERSION="11 (bullseye)"
                VERSION_CODENAME=bullseye
                ID=raspbian
                ID_LIKE=debian
                HOME_URL="http://www.raspbian.org/"
                SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                Systemuptime and Load:
                 15:44:51 up  4:02,  2 users,  load average: 2.95, 3.29, 3.36
                CPU threads: 4
                *** Time and Time Zones ***
                Sun Jan 15 14:44:51 UTC 2023
                Sun Jan 15 15:44:51 CET 2023
                CET +0100
                Europe/Berlin
                *** User and Groups ***
                pi
                /home/pi
                pi adm dialout cdrom sudo audio video plugdev games users input render netdev docker gpio i2c spi iobroker wmbusmeters
                *** X-Server-Setup ***
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            3.8G        2.5G        237M        0.0K        1.1G        1.9G
                Swap:            99M         56M         43M
                Total:          3.9G        2.5G        280M
                         3837 M total memory
                         2479 M used memory
                          738 M active memory
                         2612 M inactive memory
                          237 M free memory
                          126 M buffer memory
                          995 M swap cache
                           99 M total swap
                           56 M used swap
                           43 M free swap
                *** FILESYSTEM ***
                /dev/root      ext4      110G   12G   95G  11% /
                devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                tmpfs          tmpfs     768M  980K  767M   1% /run
                /dev/sda1      vfat      253M   50M  203M  20% /boot
                tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                Messages in dmesg:
                [Sun Jan 15 11:42:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:19:02:5F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=3957acc8-02 rootfstype=ext4 fsck.repair=yes rootwait
                [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): INFO: recovery required on readonly filesystem
                [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): write access will be enabled during recovery
                [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): orphan cleanup on readonly fs
                [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): 5 orphan inodes deleted
                [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): recovery complete
                [Sun Jan 15 11:42:08 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                [Sun Jan 15 11:42:08 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                [Sun Jan 15 11:42:10 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
                TARGET  SOURCE    FSTYPE OPTIONS
                /       /dev/sda2 ext4   rw,noatime
                `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                /var:
                5.4G    /var/
                3.3G    /var/log
                3.0G    /var/log/journal/b580c5da96934f68b876283b60e13518
                1.1G    /var/lib
                /opt/iobroker/backups:
                62M     /opt/iobroker/backups/
                /opt/iobroker/iobroker-data:
                628M    /opt/iobroker/iobroker-data/
                503M    /opt/iobroker/iobroker-data/files
                72M     /opt/iobroker/iobroker-data/files/telegram.admin
                69M     /opt/iobroker/iobroker-data/backup-objects
                67M     /opt/iobroker/iobroker-data/files/minuvis
                34M     /opt/iobroker/iobroker-data/states.jsonl
                33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
                15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
                *** NodeJS-Installation ***
                /usr/bin/npm            8.19.3
                /usr/bin/npx            8.19.3
                nodejs:
                  Installed: 16.19.0-deb-1nodesource1
                  Candidate: 16.19.0-deb-1nodesource1
                  Version table:
                 *** 16.19.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                     12.22.12~dfsg-1~deb11u1 500
                *** ioBroker-Installation ***
                ioBroker Status
                        throw e;
                Core adapters versions
                js-controller:  4.0.24
                admin:          6.3.5
                javascript:     6.1.4
                Adapters from github:   1
                Adapter State
                + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
                + system.adapter.b-control-em.0           : b-control-em          : iobroker                                 -  enabled
                + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                  system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                + system.adapter.device-reminder.1        : device-reminder       : iobroker                                 -  enabled
                  system.adapter.devices.0                : devices               : iobroker                                 - disabled
                + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                  system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                + system.adapter.echarts.0                : echarts               : iobroker                                 -  enabled
                  system.adapter.fb-checkpresence.0       : fb-checkpresence      : iobroker                                 - disabled
                  system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
                  system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                  system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                + system.adapter.go-e.0                   : go-e                  : iobroker                                 -  enabled
                  system.adapter.habpanel.0               : habpanel              : iobroker                                 - disabled
                + system.adapter.history.0                : history               : iobroker                                 -  enabled
                + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 80
                  system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                  system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                  system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                  system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
                + system.adapter.influxdb.0               : influxdb              : iobroker                                 -  enabled, port: 8086
                + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
                + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                  system.adapter.material.0               : material              : iobroker                                 - disabled
                + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
                  system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                  system.adapter.minuvis.0                : minuvis               : iobroker                                 - disabled
                  system.adapter.mobile.0                 : mobile                : iobroker                                 - disabled
                + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                + system.adapter.moma.0                   : moma                  : iobroker                                 -  enabled
                + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.mqtt.1                   : mqtt                  : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                + system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
                + system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
                  system.adapter.parser.0                 : parser                : iobroker                                 - disabled
                + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                + system.adapter.plenticore.0             : plenticore            : iobroker                                 -  enabled, port: 80
                  system.adapter.rickshaw.0               : rickshaw              : iobroker                                 - disabled
                + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                + system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
                  system.adapter.schoolfree.0             : schoolfree            : iobroker                                 -  enabled
                + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
                  system.adapter.solarwetter.0            : solarwetter           : iobroker                                 -  enabled
                + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                  system.adapter.statistics.0             : statistics            : iobroker                                 - disabled
                + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
                + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
                + system.adapter.tibber.0                 : tibber                : iobroker                                 -  enabled
                + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                + system.adapter.tr-064.1                 : tr-064                : iobroker                                 -  enabled
                + system.adapter.tradfri.0                : tradfri               : iobroker                                 -  enabled
                + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
                + system.adapter.virtualpowermeter.0      : virtualpowermeter     : iobroker                                 -  enabled
                  system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                  system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : iobroker                                 - disabled
                  system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 -  enabled
                + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                  system.adapter.vis-justgage.0           : vis-justgage          : iobroker                                 -  enabled
                  system.adapter.vis-lcars.0              : vis-lcars             : iobroker                                 - disabled
                  system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 -  enabled
                  system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 -  enabled
                  system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                  system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                  system.adapter.wireless-mbus.0          : wireless-mbus         : iobroker                                 - disabled
                + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
                  system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
                  system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyACM0
                  system.adapter.zoe2.0                   : zoe2                  : iobroker                                 -  enabled
                + instance is alive
                ioBroker-Repositories
                Installed ioBroker-Instances
                Used repository: stable
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "b-control-em" : 0.2.1    , installed 0.2.1
                Adapter    "backitup"     : 2.5.10   , installed 2.5.9  [Updatable]
                Adapter    "birthdays"    : 2.1.0    , installed 2.1.0
                Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                Adapter    "devices"      : 1.1.2    , installed 1.1.2
                Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
                Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                Adapter    "flot"         : 1.11.0   , installed 1.11.0
                Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                Adapter    "go-e"         : 1.0.23   , installed 1.0.23
                Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                Adapter    "hid-community": 0.3.0    , installed 0.3.0
                Adapter    "history"      : 2.2.4    , installed 2.2.4
                Adapter    "hue"          : 3.7.1    , installed 3.7.1
                Adapter    "info"         : 1.9.19   , installed 1.9.19
                Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
                Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
                Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                Adapter    "lovelace"     : 3.0.1    , installed 3.0.1
                Adapter    "material"     : 1.1.2    , installed 1.1.2
                Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
                Adapter    "mihome-vacuum": 3.8.8    , installed 3.8.8
                Adapter    "minuvis"      : 2.2.0    , installed 2.2.0
                Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                Adapter    "moma"         : 1.2.9    , installed 1.2.9
                Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                Adapter    "netatmo-crawler": 0.8.1  , installed 0.8.1
                Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                Adapter    "parser"       : 1.1.8    , installed 1.1.8
                Adapter    "plenticore"   : 2.2.0    , installed 2.2.0
                Adapter    "radar2"       : 2.0.3    , installed 2.0.3
                Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
                Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
                Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "sprinklecontrol": 0.2.13 , installed 0.2.13
                Adapter    "statistics"   : 2.2.0    , installed 2.2.0
                Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                Adapter    "text2command" : 2.3.0    , installed 2.3.0
                Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
                Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
                Adapter    "trashschedule": 2.0.3    , installed 2.0.3
                Adapter    "tuya"         : 3.12.1   , installed 3.12.1
                Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                Adapter    "weatherunderground": 3.4.2, installed 3.4.2
                Adapter    "wireless-mbus": 0.8.6    , installed 0.8.6
                Adapter    "wled"         : 0.6.7    , installed 0.6.7
                Adapter    "yr"           : 5.3.0    , installed 5.3.0
                Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                Objects and States
                Objects:        0
                States:         18288
                Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                Get:3 https://download.docker.com/linux/raspbian bullseye InRelease [26.7 kB]
                Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Fetched 26.7 kB in 4s (6694 B/s)
                Reading package lists...
                Pending Updates: 0
                *** Listening Ports ***
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        13713      779/influxd
                tcp        0      0 0.0.0.0:9010            0.0.0.0:*               LISTEN      0          16011      1433/docker-proxy
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       347225     28301/node-red
                tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       347669     27766/io.mqtt.0
                tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       346074     28287/io.sonoff.0
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       341470     27572/iobroker.js-c
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       342229     27572/iobroker.js-c
                tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      109        14644      1132/mysqld
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       350547     28562/io.jarvis.0
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          9067       496/sshd: /usr/sbin
                tcp6       0      0 :::3000                 :::*                    LISTEN      110        14177      1338/grafana-server
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       340952     27594/io.admin.0
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       349153     28762/io.web.0
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        17797      779/influxd
                tcp6       0      0 :::9010                 :::*                    LISTEN      0          17482      1457/docker-proxy
                tcp6       0      0 :::22                   :::*                    LISTEN      0          9069       496/sshd: /usr/sbin
                udp        0      0 0.0.0.0:59236           0.0.0.0:*                           1001       349589     28727/io.tradfri.0
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       349676     28412/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       349677     28412/io.tuya.0
                udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       352382     28280/io.shelly.0
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          11000      774/dhcpcd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       346078     28912/io.wled.0
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11905      389/avahi-daemon: r
                udp        0      0 0.0.0.0:35096           0.0.0.0:*                           108        11907      389/avahi-daemon: r
                udp6       0      0 :::41428                :::*                                108        11908      389/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          13576      774/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        11906      389/avahi-daemon: r
                2023-01-15 15:46:30.932  - info: plenticore.0 (28660) Got all internal forecast data and made it available to main process.
                2023-01-15 15:46:33.560  - info: dwd.0 (11253) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                2023-01-15 15:46:36.070  - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                2023-01-15 15:46:39.624  - info: plenticore.0 (28660) calcMinSoC for day 1.
                2023-01-15 15:46:39.790  - info: plenticore.0 (28660) calcMinSoC for day 2.
                2023-01-15 15:46:39.791  - info: plenticore.0 (28660) Using forecast of day 2 for MinSoC calculation.
                2023-01-15 15:46:48.048  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
                2023-01-15 15:47:10.839  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
                2023-01-15 15:47:29.993  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
                2023-01-15 15:47:51.465  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
                2023-01-15 15:48:11.099  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
                2023-01-15 15:48:31.761  - warn: javascript.0 (27643) getState "mielecloudservice.0.Dishwashers.000105640993.estimatedEndTime" not found (3)
                2023-01-15 15:48:31.790  - warn: javascript.0 (27643)     at script.js.Eigene_Scripte.Geschirrspüler_Status:24:60
                2023-01-15 15:48:31.792  - warn: javascript.0 (27643)     at Object.<anonymous> (script.js.Eigene_Scripte.Geschirrspüler_Status:24:184)
                2023-01-15 15:48:31.793  - warn: javascript.0 (27643)     at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1244:38)
                2023-01-15 15:48:31.796  - warn: javascript.0 (27643)     at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:593:29)
                2023-01-15 15:48:31.798  - warn: javascript.0 (27643)     at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:5916:56)
                2023-01-15 15:48:31.799  - warn: javascript.0 (27643)     at processImmediate (node:internal/timers:466:21)
                2023-01-15 15:48:31.801  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: -8.88
                2023-01-15 15:48:31.802  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: -532800
                2023-01-15 15:48:31.804  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: -888
                2023-01-15 15:48:31.805  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: 60
                2023-01-15 15:48:31.806  - info: javascript.0 (27643) script.js.Eigene_Scripte.Geschirrspüler_Status: 948
                2023-01-15 15:48:33.570  - info: plenticore.0 (28660) State value to set for "plenticore.0.scb.export.LastExportOk" has to be type "boolean" but received type "number"
                2023-01-15 15:48:40.580  - warn: wled.0 (28912) State attribute definition missing for : liveseg with value : -1
                Thomas BraunT SegwayS 2 Antworten Letzte Antwort
                • FC1002F FC1002
                  ich habe eine Herausforderung.
                  Mein Iobroker auf meinen Raspi4 / SSD ist in letzter Zeit sehr träge geworden, Zugriff auf die Oberfläche größer 60 sekunden :-(
                  Heute habe ich nun mal eine Sudo apt-get update & upgrade gemacht und die Pi neu gestartet, Allerdings hat sich die Responsezeit nicht verbessert.
                  Wenn ich über die Oberfläche iobroker Status eingebe, kommt das:
                  Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                  at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/l ib/states/statesInRedisClient.js:579:23)
                  nach mehreren Minuten warten, läuft er dann, aber wieder sehr träge.
                  Was könnte das sein?
                  Vg Frank
                  wendy2702W Offline
                  wendy2702W Offline
                  @fc1002 sagte in Kein Zugriff mehr auf Iobroker :-(:
                  Ist das ein Master Slave System ?
                  • FC1002F FC1002
                    Skript v.2023-01-02
                    *** BASE SYSTEM ***
                    Docker:         false
                    Release:        11
                    Codename:       bullseye
                    VERSION_ID="11"
                    ID=raspbian
                    ID_LIKE=debian
                    CPU threads: 4
                    CET +0100
                    Europe/Berlin
                    pi
                    /home/pi
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Swap:            99M         56M         43M
                             3837 M total memory
                             2479 M used memory
                              738 M active memory
                              237 M free memory
                              126 M buffer memory
                              995 M swap cache
                               99 M total swap
                               56 M used swap
                               43 M free swap
                    *** FILESYSTEM ***
                    Messages in dmesg:
                    /var:
                    5.4G    /var/
                    3.3G    /var/log
                    1.1G    /var/lib
                    /usr/bin/npm            8.19.3
                    /usr/bin/npx            8.19.3
                    nodejs:
                      Version table:
                    ioBroker Status
                            throw e;
                    admin:          6.3.5
                    javascript:     6.1.4
                    Adapter State
                    + instance is alive
                    Objects and States
                    Objects:        0
                    States:         18288
                    Pending Updates: 0
                    Irgendwas haut da auf die CPU-Auslastung.
                    Meist sind das 'krumme' Skripte.
                    Und dein journal ist riesig. Was steht denn da drin?
                    journalctl --since "2023-01-14 17:15:00"
                      wendy2702W Offline
                      wendy2702W Offline
                      @thomas-braun Kleiner Computer… Viel drauf mit Influx, Grafana, Docker….
                      • FC1002F FC1002
                        Skript v.2023-01-02
                        *** BASE SYSTEM ***
                        Docker:         false
                        Release:        11
                        Codename:       bullseye
                        VERSION_ID="11"
                        ID=raspbian
                        ID_LIKE=debian
                        CPU threads: 4
                        CET +0100
                        Europe/Berlin
                        pi
                        /home/pi
                        X-Server:       false
                        Desktop:
                        Terminal:       tty
                        *** MEMORY ***
                        Swap:            99M         56M         43M
                                 3837 M total memory
                                 2479 M used memory
                                  738 M active memory
                                  237 M free memory
                                  126 M buffer memory
                                  995 M swap cache
                                   99 M total swap
                                   56 M used swap
                                   43 M free swap
                        *** FILESYSTEM ***
                        Messages in dmesg:
                        /var:
                        5.4G    /var/
                        3.3G    /var/log
                        1.1G    /var/lib
                        /usr/bin/npm            8.19.3
                        /usr/bin/npx            8.19.3
                        nodejs:
                          Version table:
                        ioBroker Status
                                throw e;
                        admin:          6.3.5
                        javascript:     6.1.4
                        Adapter State
                        + instance is alive
                        Objects and States
                        Objects:        0
                        States:         18288
                        Pending Updates: 0
                        SegwayS Offline
                        SegwayS Offline
                        Segway
                        @fc1002
                        Mach mal dein journal kleiner und prüfe VORHER was da reinfallest. Das ist viel zu gross.
                        Anleitung kleiner machen ist HIER
                        Datei editieren - aber vorher herausfinden warum das so gross ist:
                        /etc/systemd/journald.conf
                        mit
                        SystemMaxUse=100M
                        SystemMaxFileSize=100M
                        und dann
                        service systemd-journald restart
                        Gruß Dirk
                        • wendy2702W wendy2702
                          FC1002F Offline
                          FC1002F Offline
                          FC1002
                          @wendy2702 nein, nur ein Raspi4
                          • SegwayS Segway
                            @fc1002
                            mit
                            SystemMaxUse=100M
                            und dann
                            FC1002F Offline
                            FC1002F Offline
                            FC1002
                            Ich hab mir mal das journal aufgerufen. Seite dem 08.12. wird 20x die Sekunde folgendes eingetragen:
                            "Using TZID without Luxon available is unsupported. Returned times are in UTC, not the requested time zone"
                            liegt vermutlich am ical in Verbindung mit Google-Kalender.
                            • FC1002F FC1002
                              Die VOLLSTÄNDIGE Zeile schaut wie aus?
                              iobroker version ical
                              sagt?
                                sagt?
                                FC1002F Offline
                                FC1002F Offline
                                FC1002
                                @thomas-braun Die ical Version ist die 1.13.2
                                Ich habe aber noch was gefunden, die neuesten Einträge lauten:
                                Jan 15 20:45:51 iobroker influxd-systemd-start.sh[779]: [httpd] 192.168.178.60 - iobroker [15/Jan/2023:20:45:51 +0100 "POST /write?database=iobroker&db=iobroker&p=%5BREDACTED%5D&precision=ms&u=iobroker HTTP/1.1 " 204 0 "-" "-" 09c532fc-950e-11ed-ba6f-dca63219025f 4146
                                Sind das die normalen Schreibvorgänge in die Influx-DB?
                                • FC1002F FC1002
                                  @fc1002
                                  Ja, dürften Schreibvorgänge in die influxdb sein.
