  4. Test Adapter Hoover hON
184 Beiträge 34 Kommentatoren 49.2k Aufrufe 31 Beobachtet
  • S sonny608
    Hallo. Ich habe genau das gleiche Problem. Der Adapter stürzt nach 1 Tag Betrieb ab. Um wieder Statusmeldungen von Geräten zu erhalten, muss ich es neu starten.
    2022-12-28 09:17:17.267 - info: hoover.0 (401) reconnect
    2022-12-28 09:19:25.648 - info: hoover.0 (401) reconnect
    2022-12-28 09:21:23.340 - info: admin.0 (164) ==> Connected system.user.admin from ::ffff:192.168.0.50
    2022-12-28 09:21:33.974 - info: hoover.0 (401) reconnect
    2022-12-28 09:22:09.294 - info: admin.0 (164) <== Disconnect system.user.admin from ::ffff:192.168.0.50 admin
    2022-12-28 09:22:14.412 - info: admin.0 (164) ==> Connected system.user.admin from ::ffff:192.168.0.50
    2022-12-28 09:22:16.581 - info: host.fd61d37ab4e3 stopInstance system.adapter.hoover.0 (force=false, process=true)
    2022-12-28 09:22:16.635 - info: hoover.0 (401) Got terminate signal TERMINATE_YOURSELF
    2022-12-28 09:22:16.638 - info: hoover.0 (401) terminating
    2022-12-28 09:22:16.640 - info: hoover.0 (401) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2022-12-28 09:22:16.675 - info: host.fd61d37ab4e3 stopInstance system.adapter.hoover.0 send kill signal
    2022-12-28 09:22:17.536 - info: host.fd61d37ab4e3 instance system.adapter.hoover.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2022-12-28 09:22:19.767 - info: host.fd61d37ab4e3 instance system.adapter.hoover.0 started with pid 4192
    2022-12-28 09:22:26.768 - info: hoover.0 (4192) starting. Version 0.0.4 in /opt/iobroker/node_modules/iobroker.hoover, node: v16.18.1, js-controller: 4.0.23
    2022-12-28 09:22:26.850 - info: hoover.0 (4192) starting login
    2022-12-28 09:22:30.601 - info: hoover.0 (4192) Found 1 devices
    2022-12-28 09:22:30.626 - info: hoover.0 (4192) Connecting to MQTT
    2022-12-28 09:22:31.437 - info: hoover.0 (4192) mqtt connected
    2022-12-28 09:22:31.439 - info: hoover.0 (4192) subscribe to xyz……
    tombox
    @sonny608 im log tauchen nur die reconnects auf?
    • T tombox
      sonny608
      @tombox Ja. Nach dem Neustart des Adapters ist für etwa einen Tag alles wieder normal.
      • S sonny608
        tombox
        @sonny608 könntest du den adapter in debug log setzen und warten bis keine Daten mehr reinkommen und mir den log per mail zusenden
        tombox2020@gmail.com
        • T tombox
          sonny608
          @tombox Natürlich. Ich werde die Daten über mehrere Tage sammeln und Ihnen die Daten zusenden
          • S sonny608
            tombox
            @sonny608 Probier mal die GitHub zu installieren und schauen ob sich das verhalten verbessert
              alf4711
              zunächst vielen Dank für das programmieren des Adapters !
              Leider erhalte ich auch - analog anderen - keine zeinahe Informationen über den aktuellen Zustand. Der Wert im Ordner Stream wird nur "sporadisch" aktualisiert.
              Hat jemand eine Lösung?
              Danke.
              Gruß, Jörg
              • A alf4711
                Danke.
                Gruß, Jörg
                tombox
                @alf4711 Ist das auch bei der GitHub version der fall?
                • T tombox
                  alf4711
                  @tombox
                  Hallo !
                  Ich habe mal den alten (ioBroker) HON Adapter gelöscht und wollte den über github installieren. Dabei erhalte ich folgende Fehlermeldung:
                  $ iobroker url TA2k/ioBroker.hoover --host raspberrypi --debug
                  install TA2k/ioBroker.hoover
                  Installing TA2k/ioBroker.hoover... (System call)
                  npm WARN http-cookie-agent@4.0.2 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                  • iobroker.hoover@0.0.4removed 1 package and updated 1 package in 325.99s
                    95 packages are looking for funding run npm fund for details
                    upload [3] hoover.admin /opt/iobroker/node_modules/iobroker.hoover/admin/admin.d.ts admin.d.ts video/mp2t
                    upload [1] hoover.admin /opt/iobroker/node_modules/iobroker.hoover/admin/index_m.html index_m.html text/html
                    upload [0] hoover.admin /opt/iobroker/node_modules/iobroker.hoover/admin/jsonConfig.json jsonConfig.json application/json
                    Process exited with code 0
                  Weiß jemand was das heißen könnte?
                  Danke…
                  Gruß, Jörg
                  • A alf4711
                    @tombox
                    Hallo !
                    Danke…
                    Gruß, Jörg
                    astrakid
                    @alf4711 das sind nur warnungen und können ignoriert werden. die installation ist erfolgreich durchgelaufne (exit code 0).
                    • Horst BöttcherH Offline
                      Horst Böttcher
                      @tombox gibt es eigentlich auch eine adapter für die Hoover Wizard app da meine Waschmaschine nicht in die Hon app geht
                      ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
                      • A astrakid
                        alf4711
                        @astrakid: Guten Morgen ! Leider nein... es wird kein Adapter installiert. Gruß, Jörg
                        A T 2 Antworten Letzte Antwort
                        • A alf4711
                          astrakid
                          @alf4711 kannst mal probieren tough-cookie händisch über die Konsole zu installieren (kenne die npm Befehle nicht, vllt
                          npm Install tough-cookie
                          • A alf4711
                            tombox
                            @alf4711 Sicher das der Adapter nicht da ist? Vielleicht fehlt ja nur die Instanz. Du kannst auch v0.0.5 probieren einfach via npm installieren
                            • P Offline
                              Paddel0815
                              schrieb am zuletzt editiert von Paddel0815
                              Ich habe einen Candy Backofen, der per sympli fi über Wlan kommuniziert, gibt es dafür einen Adapter oder kann dies hier mit integriert werden?
                              • Stefan SchnakeS Offline
                                Stefan Schnake
                                ich bekomme leider diesen Fehler.
                                hoover.0
                                2023-02-02 20:02:29.914	error	{"message":"[AuraClientInputException from server] Unexpected request input. Expected input format: \"Data in a request must be a valid JSON Object.\"."}
                                hoover.0
                                2023-02-02 20:02:29.913	error	AxiosError: Request failed with status code 400
                                hoover.0
                                2023-02-02 20:02:29.913	error	Login step #3 failed
                                hoover.0
                                2023-02-02 20:02:28.776	error	TypeError: Cannot read properties of undefined (reading 'split')
                                hoover.0
                                2023-02-02 20:02:28.764	error	Login step #2 failed
                                Was mache ich falsch ?
                                • Stefan SchnakeS Stefan Schnake
                                  hoover.0
                                  hoover.0
                                  hoover.0
                                  hoover.0
                                  hoover.0
                                  @stefan-schnake
                                  Moin,
                                  ich bekomme auch diese Meldung bei mir hängt dahinter der Login zu einer Heier Waschmaschine, auch bei der Hon APP hatte ich anfängliche Probleme, da gab es wohl ein Update, sodas der Login nicht mehr funktioniert.
                                  In der Handy APP geht es wieder, nur beim Hoover - Adapter nicht.
                                  Mal ein PN auf Github aufmachen.
                                  https://github.com/TA2k/ioBroker.hoover/issues/6
                                  Bernd
                                  P.S.: Aktuell habe ich die Version 0.0.5 Installiert.
                                    @stefan-schnake
                                    Moin,
                                    Bernd
                                    tombox
                                    @dp20eic Mit 0.0.6 gefixt
                                    Stefan SchnakeS 1 Antwort Letzte Antwort
                                    • T tombox
                                      Stefan Schnake
                                      schrieb am zuletzt editiert von Stefan Schnake
                                      @tombox
                                      login ist nun ok. Aber es werden keine Geräte angezeigt
                                      hoover.0
                                      2023-02-03 04:57:14.894	info	subscribe to undefined
                                      hoover.0
                                      2023-02-03 04:57:14.894	info	mqtt connected
                                      hoover.0
                                      2023-02-03 04:57:14.835	error	{"error":{"message":"Invalid macAddress","code":"IMA","statusCode":400}}
                                      hoover.0
                                      2023-02-03 04:57:14.834	error	AxiosError: Request failed with status code 400
                                      hoover.0
                                      2023-02-03 04:57:14.834	error	https://api-iot.he.services/commands/v1/context?macAddress=undefined&applianceType=WC&category=CYCLE
                                      hoover.0
                                      2023-02-03 04:57:14.442	info	Connecting to MQTT
                                      hoover.0
                                      2023-02-03 04:57:14.442	error	Error: The id is empty! Please provide a valid id.
                                      hoover.0
                                      2023-02-03 04:57:14.440	info	Found 2 devices
                                      hoover.0
                                      2023-02-03 04:57:11.607	info	starting login
                                      Ich habe eine Waschmschine und das Default Weinlager in der APP
                                        @tombox
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        hoover.0
                                        tombox
                                        @stefan-schnake Dann bräuchte ich ein account mit geraten oder ein debug log per pn
                                        • T tombox
                                          @tombox
                                          Schicke ich Dir gleich, sobald ich mit dem Finanzamt durch bin :(
                                          Bernd
                                          Edit
                                          Du hast Post
