  4. Update funktioniert nicht mehr
36 Beiträge 5 Kommentatoren 4.0k Aufrufe 5 Beobachtet
    @norp2k22
    Installier mit --debug Option.
    Hast du jetzt nodejs16/Gallium installiert?
    N Offline
    N Offline
    norp2k22
    iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2022-12-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    [sudo] Passwort für iob-user:
    sudo: apt-get: Befehl nicht gefunden
    Installed acl
    Installed sudo
    Installed libcap2-bin
    Installed build-essential
    Installed gcc-c++
    Installed make
    Installed libavahi-compat-libdnssd-dev
    Installed libudev-dev
    Installed libpam0g-dev
    Installed pkg-config
    Installed git
    Installed curl
    Installed unzip
    Installed libcairo2-dev
    Installed libpango1.0-dev
    Installed libjpeg-dev
    Installed libgif-dev
    Installed librsvg2-dev
    Installed libpixman-1-dev
    Installed net-tools
    Installed cmake
        Checking ioBroker user and directory permissions (2/4)
        Database maintenance (3/4)
    Checking for uncompressed JSONL databases... This might take a while!
    Compressing /opt/iobroker/iobroker-data/states.jsonl
    Compressing /opt/iobroker/iobroker-data/objects.jsonl
    Compressed 2 JSONL files. Done
        Checking autostart (4/4)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    und
    $ iob diag
    bash: /home/iobroker/.diag.sh: Keine Berechtigung
    • N norp2k22
      iob fix
      library: loaded
      Installed acl
      Installed sudo
      Installed gcc-c++
      Installed make
      Installed git
      Installed curl
      Installed unzip
      Installed net-tools
      Installed cmake
      Autostart enabled!
      und
      $ iob diag
      @norp2k22
      ls -la /home/iobroker/.diag.sh
      N 1 Antwort Letzte Antwort
        @norp2k22
        N Offline
        N Offline
        norp2k22
        Ok, interessant..
        iob stop
        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
        iob fix
        iob start
        danach noch
        iob upgrade
        Jetzt sind alle Adapter aktuell und alles funktioniert wieder.
        Das NodeJS 16 gallium Paket aus dem AUR habe ich jetzt (noch) nicht installiert,
        wollte auf diesem Rechner die verwendung vom AUR Repo eigentlich vermeiden.
        Brauche ich dieses spezielle Paket UNBEDINGT für den IOB ?
        Weil wie es aussieht, funktioniert jetzt alles wieder.
        • N norp2k22
          Ok, interessant..
          iob stop
          iob fix
          iob start
          danach noch
          iob upgrade
          @norp2k22 sagte in Update funktioniert nicht mehr:
          Ok, interessant..
          was stand denn da?
          v19 ist wie alle ungeraden Versionen eine Entwicklerversion und eher Beta. Selbst unter v18 gibt es bei ioBroker noch leichte Probleme
          • N norp2k22
            Ok, interessant..
            iob stop
            iob fix
            iob start
            danach noch
            iob upgrade
            @norp2k22
            Ja, du brauchst eine stabile Basis. Über pacman rollt dir das immer weg. Rolling Release halt...
            Da man das bei runtimes nicht will gibt es die fixierten Pakete ja.
              @norp2k22
              N Offline
              N Offline
              norp2k22
              schrieb am zuletzt editiert von norp2k22
              Achso, deswegen.
              Ok, dann wird das Paket jetzt nachinstalliert.
              Nachtrag :
              So, alles läuft wieder wie es soll.
              Danke euch !
              • N norp2k22
                Achso, deswegen.
                Nachtrag :
                Danke euch !
                @norp2k22
                Magst mir jetzt noch die Ausgabe von
                iob diag
                geben?
                  @norp2k22
                  iob diag
                  geben?
                  N Offline
                  N Offline
                  norp2k22
                  Den Befehl kann ich nur mit Rootrechten ausführen, wird sonst der zugriff verweigert.
                  sudo soll man ja nicht verwenden in verbindung mit dem IOB.
                  Ist das Script mit Rootrechten ungefährlich ? Habe absolut keine Lust, mir jetzt
                  doch noch alles zu zerschiessen.
                  • N norp2k22
                    Das liest nur, schreibt/ändert nichts. Von daher safe.
                    Mich würde halt interessieren wie sich das Ding unter Arch verhält, da ich das auf einem Debian zusammengeskriptet habe.
                      N Offline
                      N Offline
                      norp2k22
                      So :
                                           v.2022-12-31
                      Operatingsystem:        Manjaro Linux
                      Installation:           oracle
                      Timezone:               Europe/Berlin
                      User-ID:                0
                      X-Server:               true
                      Pending OS-Updates:
                      Nodejs-Installation:    /usr/bin/nodejs         v19.3.0
                                              /usr/bin/node           v19.3.0
                                              /usr/bin/npm            8.19.2
                      ioBroker Core:          js-controller           4.0.23
                                              admin                   6.3.5
                      Objects type: jsonl
                      States  type: jsonl
                      Status admin:
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: ****, bind: 0.0.0.0 (SSL), run as: admin
                      Cannot download repository hash file from "http://download.iobroker.net/sources-dist-hash.json": timeout of 10000ms exceeded
                      Cannot download repository file from "http://download.iobroker.net/sources-dist.json": timeout of 10000ms exceeded
                      Pending iob updates:    0
                      Active repo(s): stable
                      Objects:                8860
                      States:                 6891
                      Size of iob-Database:
                      11M     /opt/iobroker/iobroker-data/objects.jsonl
                      6.3M    /opt/iobroker/iobroker-data/states.jsonl
                      Nicht wundern, habe das NodeJS Paket noch nicht installiert und weil bei Installation oracle steht,
                      meine IOB Installation ist in einer VBox seit einiger zeit.
                      Thomas BraunT N 2 Antworten Letzte Antwort
                      • N norp2k22
                        So :
                                             v.2022-12-31
                        User-ID:                0
                        X-Server:               true
                        Pending OS-Updates:
                                                /usr/bin/npm            8.19.2
                                                admin                   6.3.5
                        Objects type: jsonl
                        States  type: jsonl
                        Status admin:
                        Objects:                8860
                        States:                 6891
                        @norp2k22
                        Gib mal den vollständigen Output davor.
                        • N norp2k22
                          So :
                                               v.2022-12-31
                          User-ID:                0
                          X-Server:               true
                          Pending OS-Updates:
                                                  /usr/bin/npm            8.19.2
                                                  admin                   6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Status admin:
                          Objects:                8860
                          States:                 6891
                          N Offline
                          N Offline
                          norp2k22
                          Bist du hier für die Kompatibilität vom IOB mit Arch/Manjaro zuständig ?
                          • N norp2k22
                            Nein.
                            Aber das diag skript ist von mir.
                            Und ich würde gerne mal sehen wie es sich auf 'nicht-debian' verhält.
                              Nein.
                              N Offline
                              N Offline
                              norp2k22
                              @thomas-braun said in Update funktioniert nicht mehr:
                              Na dann installier dir doch ganz einfach VirtualBox, bau dir eine kleine VM mit Manjaro als Gast OS
                              und installiere dort den IOB.
                              Damit kannst du ausgiebig und unkompliziert testen. :-)
                              • N norp2k22
                                @norp2k22
                                Ich will das aber auf einem anderen System sehen.
                                Ich hab selber ein Manjaro auf einem Raspberry laufen, das ist für mich kein Problem.
                                  @norp2k22
                                  N Offline
                                  N Offline
                                  norp2k22
                                  Same here.
                                  Sei mir bitte nicht böse, aber das Script liest schon ziemlich viel, sehr tief im System aus,
                                  das gebe ich nicht raus. Weder hier, noch per PN.
                                  Thomas BraunT Meister MopperM 2 Antworten Letzte Antwort
                                  • N norp2k22
                                    Same here.
                                    Eigentlich nichts, was nicht für den Betrieb von iobroker wesentlich wäre.
                                    • N norp2k22
                                      Same here.
                                      Meister MopperM Online
                                      Meister Mopper
                                      Hast Du ein kritisches Beispiel, was eine Veröffentlichung des Skript-Ergebnisses rechtertigte?
                                      Proxmox und HA ...
                                        @meister-mopper sagte in Update funktioniert nicht mehr:
                                        das verstehe ich jetzt inhaltlich nicht
                                          Meister Mopper
                                          schrieb am zuletzt editiert von Meister Mopper
                                          Natürlich, sorry:
                                          Hast Du ein kritisches Beispiel, was eine Nichtveröffentlichung des Skript-Ergebnisses rechtertigte?
                                          Proxmox und HA ...
