  4. [Solved] Code 25 - Standard Abhilfe funktioniert nicht!
28 Beiträge 5 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • B badsnoopy667
    @glasfaser Die Debug Ausgabe ist relativ unspektakulär leider:
    $ iobroker upgrade hm-rpc@1.15.16
    Update hm-rpc from @1.15.15 to @1.15.16
    NPM version: 8.11.0
    Installing iobroker.hm-rpc@1.15.16... (System call)
    host.iobroker Cannot install iobroker.hm-rpc@1.15.16: 228
    ERROR: Process exited with code 25
    Und beim Versuch den js-controller zu updaten kommt gar nix.
    GlasfaserG Offline
    GlasfaserG Offline
    @badsnoopy667 sagte in Code 25 - Standard Abhilfe funktioniert nicht!:
    in der Console
    iobroker upgrade hm-rpc@1.15.16 --debug
    • B badsnoopy667
      NPM version: 8.11.0
      @badsnoopy667
      Und weil es immer interessant ist:
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
      • GlasfaserG Glasfaser
        in der Console
        B Online
        B Online
        badsnoopy667
        @glasfaser Na das sieht schon interessanter aus:
        iobroker@iobroker:~$ iobroker upgrade hm-rpc@1.15.16 --debug
        This upgrade of "hm-rpc" will introduce the following changes:
        -> 1.15.16:
        we have linked images of new devices
        we ensure, that the `LEVEL` datapoint of blinds is of role `level.blind` (closes        #681)
        Would you like to upgrade hm-rpc from @1.15.15 to @1.15.16 now? [(y)es, (n)o]: y
        NPM version: 8.11.0
        npm WARN skipping integrity check for git dependency ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git
        npm WARN skipping integrity check for git dependency ssh://git@github.com/bropat/ioBroker.eufy-security.git
        npm WARN skipping integrity check for git dependency ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.gi                                            t
        npm WARN skipping integrity check for git dependency ssh://git@github.com/KornSW/ioBroker.fusionsolar.git
        npm WARN skipping integrity check for git dependency ssh://git@github.com/PfisterDaniel/ioBroker.apple-find-me.gi                                            t
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we                                             will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've                                             depended on crypto, you should switch to the one that's built-in.
        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so yo                                            u do not need this installed.
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now depreca                                            ted request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated json3@3.3.2: Please use the native JSON object instead of JSON 3
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed sep                                            arately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression                                             when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionm                                            edia/debug/issues/797)
        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearc                                            hParams API instead.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in                                             certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/31                                            42
        npm WARN deprecated cron@1.8.3: Breaking dependency change (moved from moment to luxon). Please move to 2.0.0.
        npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see htt                                            ps://github.com/axios/axios/pull/3410
        npm WARN deprecated protobuf-typescript@6.8.8: Package no longer supported. Contact Support at https://www.npmjs.                                            com/support for more info.
        npm ERR! code 228
        npm ERR! git dep preparation failed
        npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
        npm ERR! npm WARN using --force Recommended protections disabled.
        npm ERR! npm WARN old lockfile
        npm ERR! npm WARN old lockfile The package-lock.json file was created with an old version of npm,
        npm ERR! npm WARN old lockfile so supplemental metadata must be fetched from the registry.
        npm ERR! npm WARN old lockfile This is a one-time fix-up, please be patient...
        npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
        npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
        npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
        npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
        npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
        npm ERR! npm WARN tar TAR_ENTRY_ERROR ENOSPC: no space left on device, write
        npm ERR! npm ERR! code ENOSPC
        npm ERR! npm ERR! syscall write
        npm ERR! npm ERR! errno -28
        npm ERR! npm ERR! nospc ENOSPC: no space left on device, write
        npm ERR! npm ERR! nospc There appears to be insufficient space on your system to finish.
        npm ERR! npm ERR! nospc Clear up some disk space and try again.
        npm ERR!
        npm ERR! npm ERR! A complete log of this run can be found in:
        npm ERR! npm ERR!     /home/iobroker/.npm/_logs/2023-01-06T11_11_26_465Z-debug-0.log
        npm ERR!     /home/iobroker/.npm/_logs/2023-01-06T11_08_18_185Z-debug-0.log
        Thomas BraunT SegwayS 2 Antworten Letzte Antwort
        • B badsnoopy667
          -> 1.15.16:
          NPM version: 8.11.0
          npm ERR! code 228
          npm ERR!
          Nix Platz mehr, nix Update.
            @badsnoopy667
            B Online
            B Online
            badsnoopy667
            Here we go:
            iobroker@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            iobroker@iobroker:~$ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
            x86_64
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            /usr/bin/npx
            v16.16.0
            v16.16.0
            8.11.0
            8.11.0
            4.0.23
            iobroker
            iobroker cdrom floppy audio dip video plugdev netdev
            /home/iobroker
            Ign:1 http://debian.netcologne.de/debian stretch InRelease
            OK:2 http://debian.netcologne.de/debian stretch-updates InRelease
            OK:3 http://security.debian.org/debian-security stretch/updates InRelease
            OK:4 http://debian.netcologne.de/debian stretch Release
            OK:5 https://deb.nodesource.com/node_16.x stretch InRelease
            nodejs:
              Installiert:           16.16.0-1nodesource1
              Installationskandidat: 16.19.0-1nodesource1
              Versionstabelle:
                 16.19.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x stretch/main amd64 Packages
             *** 16.16.0-1nodesource1 100
                 4.8.2~dfsg-1 500
                    500 http://debian.netcologne.de/debian stretch/main amd64 Packages
            • B badsnoopy667
              -> 1.15.16:
              NPM version: 8.11.0
              npm ERR! code 228
              npm ERR!
              SegwayS Offline
              SegwayS Offline
              Segway
              :male-police-officer:
              Gruß Dirk
              • B badsnoopy667
                Here we go:
                x86_64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v16.16.0
                v16.16.0
                8.11.0
                8.11.0
                4.0.23
                iobroker
                /home/iobroker
                nodejs:
                  Versionstabelle:
                     4.8.2~dfsg-1 500
                stretch
                Dein System ist so tot, das stinkt nicht mal mehr.
                Installier da ein 'Bullseye'.
                  stretch
                  B Online
                  B Online
                  badsnoopy667
                  Ei jei jei... Und ich hab gedacht hier wäre alles in bester Ordnung... tja.
                  Kann man das einfach "drüberbraten", also irgendwie ein Upgrade machen oder muss ich Bullseye komplett neu installieren und dann iobroker wieder drauf machen und ein Backup einspielen?
                  Wie auch immer, hast Du eventuell einen Link zu einer Anleitung? Hab gerade ein bisschen schiss, dass ich mir hier alles zerschieße. Aber so wie es ist kann es ja nicht bleiben.
                  SegwayS 1 Antwort Letzte Antwort
                  • B badsnoopy667
                    SegwayS Offline
                    SegwayS Offline
                    Segway
                    @badsnoopy667
                    Du musst sauber erst auf Deb10 und dann 11.
                    Die Paketquellen entsprechend anpassen und dann updaten:
                    Version	Veröffentlichung	Support bis
                    Debian.  11.0 Bullseye	14.08.2021	Juni 2026
                    Debian 10.0 Buster	06.07.2019	Juni 2024
                    Debian 9.0 Stretch	17.06.2017	30.06.2022
                    Gruß Dirk
                    • SegwayS Segway
                      @badsnoopy667
                      @segway
                      EOL schaut allerdings so aus:
                      Version  Code name Release date End of life date
                      11       Bullseye  2021-08-14   ~2024-07
                      10       Buster    2019-07-06   2022-09-10
                      9        Stretch   2017-06-17   2020-07-18
                      @badsnoopy667
                      Kann man beides machen, am schnellsten und saubersten ist allerdings die zweite Version. Insbesondere wenn man zwei Releases weiter springt.
                        @segway
                        @badsnoopy667
                        B Online
                        B Online
                        badsnoopy667
                        Bin jetzt gerade dabei. Buster ist jetzt installiert, ändere jetzt gerade zum zweiten mal die sources.list um auf Bullseye zu kommen. Danke schonmal für die wie immer perfekte Hilfe!
                        Gibt es eine Möglichkeit am Ende zu prüfen ob jetzt alles korrekt ist mit dem System?
                        • B badsnoopy667
                          Damit ist es nicht allein getan, die Repos haben sich auch strukturell geändert, da muss noch mehr angepasst werden. (Von buster zu bullseye jedenfalls, ob da von stretch zu buster noch was zu machen ist weiß ich nicht).
                          Deswegen ja auch die Empfehlung das sauber neuzuinstallieren.
                          • B Online
                            B Online
                            badsnoopy667
                            Habe jetzt eine neue Proxmox VM aufgesetzt und installiere dort gerade Debian 11 Bullseye. Das Problem mit der Festplattengröße ließ sich nämlich nicht so einfach beheben wie ich dachte. Hatte zwar in Proxmox von 16GB auf 48GB hochgestellt, aber das ist in Debian nicht angekommen. Und mit fdisk bin ich irgendwie nicht weiter gekommen.
                            Ich versuche jetzt mal ein clean install mit Bullseye. Gut, dass ich gerade mit Corona zuhause sitze...
                            • B Online
                              B Online
                              badsnoopy667
                              So, habe jetzt Debian 11 drauf und iobroker läuft auch wieder, Backup ist zurück gespielt. ABER: Jetzt habe ich das Problem, das VIS nciht mehr geht. Habe dazu auch schon den Hinweis gefunden, eine alte Version von VIS über "npm i vis@1.4.6" zu installieren. da tut sich auch was, aber im iobroker zeigt er mir dann wieder 1.4.15 an und die geht wieder nicht "File index_m.html not found".
                              Gibt es da noch einen anderen Workaround als jetzt die Kiste wieder platt zu machen, iobroker neu zu installieren und dann erst VIS installieren und dann das Backup einspielen? Das würde ich mir gerne ersparen ;)
                              • B badsnoopy667
                                GlasfaserG Offline
                                GlasfaserG Offline
                                npm i vis@1.4.6
                                nicht per NPM ... und dann noch eventuell als root im falschen Verzeichniss stehen !
                                iobroker install vis@1.4.0
                                B 2 Antworten Letzte Antwort
                                  npm i vis@1.4.6
                                  B Online
                                  B Online
                                  badsnoopy667
                                  schrieb am zuletzt editiert von badsnoopy667
                                  @glasfaser
                                  adapter "vis" already installed. Use "upgrade" to upgrade to a newer version.
                                  • B badsnoopy667
                                    @glasfaser
                                    @badsnoopy667
                                    Was haste denn jetzt wohin geworfen?
                                    iobroker list adapters
                                    cd /opt/iobroker
                                    npm list
                                      @badsnoopy667
                                      cd /opt/iobroker
                                      npm list
                                      B Online
                                      B Online
                                      badsnoopy667
                                      Das spuckt er aus:
                                      iobroker@iobroker2023:~$ iobroker list adapters
                                      cd /opt/iobroker
                                      npm list
                                      system.adapter.admin                   : admin          - v6.3.5
                                      system.adapter.apple-find-me           : apple-find-me  - v0.0.14
                                      system.adapter.backitup                : backitup       - v2.5.9
                                      system.adapter.broadlink               : broadlink      - v0.1.1
                                      system.adapter.broadlink2              : broadlink2     - v2.1.5
                                      system.adapter.cloud                   : cloud          - v4.2.2
                                      system.adapter.daikin-cloud            : daikin-cloud   - v0.2.3
                                      system.adapter.denon                   : denon          - v1.13.4
                                      system.adapter.dwd                     : dwd            - v2.8.3
                                      system.adapter.eufy-security           : eufy-security  - v0.7.4
                                      system.adapter.eusec                   : eusec          - v0.9.9
                                      system.adapter.fiat                    : fiat           - v0.0.7
                                      system.adapter.flot                    : flot           - v1.11.0
                                      system.adapter.fully-tablet-control    : fully-tablet-control - v0.3.7-0.0
                                      system.adapter.fullybrowser            : fullybrowser   - v2.1.2
                                      system.adapter.fusionsolar             : fusionsolar    - v1.0.0
                                      system.adapter.go-e                    : go-e           - v1.0.23
                                      system.adapter.history                 : history        - v2.2.4
                                      system.adapter.hm-rega                 : hm-rega        - v3.0.40
                                      system.adapter.hm-rpc                  : hm-rpc         - v1.15.16
                                      system.adapter.hue                     : hue            - v3.7.1
                                      system.adapter.ical                    : ical           - v1.13.2
                                      system.adapter.icons-material-png      : icons-material-png - v0.1.0
                                      system.adapter.icons-mfd-png           : icons-mfd-png  - v1.1.0
                                      system.adapter.info                    : info           - v1.9.19
                                      system.adapter.javascript              : javascript     - v6.1.4
                                      system.adapter.material                : material       - v0.5.6
                                      system.adapter.mihome-vacuum           : mihome-vacuum  - v3.8.6
                                      system.adapter.mobile                  : mobile         - v0.4.11
                                      system.adapter.mqtt                    : mqtt           - v4.0.7
                                      system.adapter.mqtt-client             : mqtt-client    - v1.6.3
                                      system.adapter.nanoleaf-lightpanels    : nanoleaf-lightpanels - v1.3.1
                                      system.adapter.netatmo-crawler         : netatmo-crawler - v0.8.1
                                      system.adapter.node-red                : node-red       - v4.0.0
                                      system.adapter.openweathermap          : openweathermap - v0.3.0
                                      system.adapter.ping                    : ping           - v1.5.3
                                      system.adapter.pvforecast              : pvforecast     - v2.3.0
                                      system.adapter.scenes                  : scenes         - v2.3.9
                                      system.adapter.shelly                  : shelly         - v6.0.0
                                      system.adapter.simple-api              : simple-api     - v2.7.0
                                      system.adapter.socketio                : socketio       - v4.2.0
                                      system.adapter.sonoff                  : sonoff         - v2.5.1
                                      system.adapter.sourceanalytix          : sourceanalytix - v0.4.14
                                      system.adapter.spotify-premium         : spotify-premium - v1.2.1
                                      system.adapter.telegram                : telegram       - v1.15.2
                                      system.adapter.tesla-motors            : tesla-motors   - v1.3.1
                                      system.adapter.text2command            : text2command   - v2.3.0
                                      system.adapter.tr-064                  : tr-064         - v4.2.17
                                      system.adapter.virtualpowermeter       : virtualpowermeter - v1.4.6
                                      system.adapter.vis                     : vis            - v1.4.15
                                      system.adapter.vis-colorpicker         : vis-colorpicker - v1.2.0
                                      system.adapter.vis-jqui-mfd            : vis-jqui-mfd   - v1.0.12
                                      system.adapter.vis-justgage            : vis-justgage   - v1.0.2
                                      system.adapter.vis-keyboard            : vis-keyboard   - v0.0.2
                                      system.adapter.vis-materialdesign      : vis-materialdesign - v0.4.2
                                      system.adapter.vis-metro               : vis-metro      - v1.2.0
                                      system.adapter.vis-timeandweather      : vis-timeandweather - v1.2.2
                                      system.adapter.weatherunderground      : weatherunderground - v3.4.2
                                      system.adapter.web                     : web            - v4.3.0
                                      system.adapter.yahka                   : yahka          - v0.13.1
                                      system.adapter.yr                      : yr             - v5.3.0
                                      iobroker.inst@3.0.0 /opt/iobroker
                                      ├── @types/caseless@0.12.2 extraneous
                                      ├── @types/request@2.48.8 extraneous
                                      ├── coffeescript@1.12.7 extraneous
                                      ├── iobroker.admin@6.3.5
                                      ├── iobroker.backitup@2.5.9
                                      ├── iobroker.broadlink2@2.1.5
                                      ├── iobroker.daikin-cloud@0.2.3
                                      ├── iobroker.denon@1.13.4
                                      ├── iobroker.dwd@2.8.3
                                      ├── iobroker.eufy-security@0.7.4 (git+ssh://git@github.com/bropat/ioBroker.eufy-                                                    security.git#4ca594e738599b99aac687d9bb803707231a418d)
                                      ├── iobroker.eusec@0.9.9
                                      ├── iobroker.fiat@0.0.7
                                      ├── iobroker.flot@1.11.0
                                      ├── iobroker.fullybrowser@2.1.2
                                      ├── iobroker.go-e@1.0.23
                                      ├── iobroker.history@2.2.4
                                      ├── iobroker.hm-rega@3.0.40
                                      ├── iobroker.hm-rpc@1.15.16
                                      ├── iobroker.hue@3.7.1
                                      ├── iobroker.ical@1.13.2
                                      ├── iobroker.icons-material-png@0.1.0
                                      ├── iobroker.icons-mfd-png@1.1.0
                                      ├── iobroker.info@1.9.19
                                      ├── iobroker.javascript@6.1.4
                                      ├── iobroker.js-controller@4.0.23
                                      ├── iobroker.mihome-vacuum@3.8.6
                                      ├── iobroker.mqtt@4.0.7
                                      ├── iobroker.nanoleaf-lightpanels@1.3.1
                                      ├── iobroker.netatmo-crawler@0.8.1
                                      ├── iobroker.node-red@4.0.0
                                      ├── iobroker.ping@1.5.3
                                      ├── iobroker.pvforecast@2.3.0
                                      ├── iobroker.scenes@2.3.9
                                      ├── iobroker.shelly@6.0.0
                                      ├── iobroker.sonoff@2.5.1
                                      ├── iobroker.sourceanalytix@0.4.14 (git+ssh://git@github.com/DrozmotiX/ioBroker.                                                    sourceanalytix.git#42c45d3e9a581869b0ba9cf710dbecb42ca3e574)
                                      ├── iobroker.spotify-premium@1.2.1
                                      ├── iobroker.telegram@1.15.2
                                      ├── iobroker.tesla-motors@1.3.1
                                      ├── iobroker.text2command@2.3.0
                                      ├── iobroker.tr-064@4.2.17
                                      ├── iobroker.virtualpowermeter@1.4.6
                                      ├── iobroker.vis-colorpicker@1.2.0
                                      ├── iobroker.vis-jqui-mfd@1.0.12
                                      ├── iobroker.vis-justgage@1.0.2
                                      ├── iobroker.vis-materialdesign@0.4.2 (git+ssh://git@github.com/Scrounger/ioBrok                                                    er.vis-materialdesign.git#c7a838a66475d0bcaac2b269829dd3a546c2e11c)
                                      ├── iobroker.vis-metro@1.2.0
                                      ├── iobroker.vis-timeandweather@1.2.2
                                      ├── iobroker.vis@1.4.6
                                      ├── iobroker.weatherunderground@3.4.2
                                      ├── iobroker.web@4.3.0
                                      ├── iobroker.yahka@0.13.1
                                      ├── iobroker.yr@5.3.0
                                      ├── node-inspect@2.0.0 extraneous
                                      ├── picocolors@1.0.0 extraneous
                                      ├── suncalc2@1.8.1 extraneous
                                      ├── typescript@4.7.4 extraneous
                                      ├── virtual-tsc@0.6.2 extraneous
                                      └── wake_on_lan@1.0.0 extraneous
                                        npm i vis@1.4.6
                                        B Online
                                        B Online
                                        badsnoopy667
                                        @glasfaser
                                        Da muss doch mal jemand dabei schreiben (für so Deppen wie mich), das "upgrade" auch "downgrade" meint! :D
                                        Jetzt habe ich VIS über die Konsole downgegraded und über das WebUI aktualisiert. Jetzt schein es wieder zu gehen.
                                        @all Vielen Dank für eure Hilfe! Ich hoffe ich komme hier gleich nicht mit dem nächsten Thema :D
                                        • B badsnoopy667
                                          @glasfaser
                                          B Online
                                          B Online
                                          badsnoopy667
                                          Einer geht noch! :D
                                          Jetzt läuft fast alles wieder. Aber einige FLOT Diagramme zeigen nur noch das Lade-Symbol und der History Adapter spuckt alle paar Minuten folgende Warnung aus (für jeden Datenpunkt eine):
                                          history.0        2023-01-06 15:24:58.075   	warn	   Data directory /mnt/history/ does not exist
