  4. [gelöst] FATAL ERROR: JavaScript heap out of memory
    5.5k
19 Beiträge 4 Kommentatoren 2.4k Aufrufe 5 Beobachtet
  • M mwolle
    		     v.2022-12-31
    Operatingsystem: 	Raspbian GNU/Linux 11 (bullseye)
    Installation: 		Native
    Timezone: 		Europe/Berlin
    User-ID: 		1000
    X-Server: 		true
    Boot Target: 		graphical.target
    Pending OS-Updates: 	0
    Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
    			/usr/bin/node 		v16.19.0
    			/usr/bin/npm 		8.19.3
    ioBroker Core: 		js-controller 		4.0.21
    			admin 			6.2.23
    <--- Last few GCs --->
    [5069:0x3fb7e58]    79610 ms: Mark-sweep 957.3 (968.9) -> 957.0 (974.7) MB, 119.3 / 0.0 ms  (average mu = 0.259, current mu = 0.131) allocation failure scavenge might not succeed
    <--- JS stacktrace --->
    FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
    /usr/bin/iobroker: line 10:  5068 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    ioBroker Status:
    Status admin:
    [5087:0x55d0e88]    79700 ms: Mark-sweep 957.4 (969.2) -> 957.1 (974.7) MB, 130.7 / 0.0 ms  (average mu = 0.245, current mu = 0.137) allocation failure scavenge might not succeed
    /usr/bin/iobroker: line 10:  5086 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    [5103:0x5630ef0]    79383 ms: Scavenge 955.0 (967.1) -> 955.0 (968.1) MB, 3.7 / 0.0 ms  (average mu = 0.509, current mu = 0.445) allocation failure
    [5103:0x5630ef0]    79516 ms: Mark-sweep (reduce) 960.9 (973.4) -> 960.6 (971.7) MB, 77.3 / 0.0 ms  (+ 25.2 ms in 11 steps since start of marking, biggest step 18.0 ms, walltime since start of marking 133 ms) (average mu = 0.426, current mu = 0.351) final
    /usr/bin/iob: line 10:  5102 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    Pending iob updates: 	0
    [5118:0x4f3fef0]    79633 ms: Mark-sweep (reduce) 957.4 (969.9) -> 957.3 (968.2) MB, 32.2 / 0.0 ms  (+ 37.2 ms in 22 steps since start of marking, biggest step 27.4 ms, walltime since start of marking 85 ms) (average mu = 0.411, current mu = 0.292) finali
    /usr/bin/iob: line 10:  5117 Aborted                 sudo -H -u iobroker node /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js "$@"
    Objects: 		0
    States: 		0
    Size of iob-Database:
    659M	/opt/iobroker/iobroker-data/objects.jsonl
    8.8M	/opt/iobroker/iobroker-data/states.jsonl
    @mwolle
    Desktop ausschalten.
    Das dürfte der Blockierer sein:
      @mwolle
      mwolle
      @thomas-braun kann ich die Objekte ohne Admin verkleinern noch? Bzw. bekomm eich es noch mal ohne Desktop zum Laufen? (Weil Speicher frei?)
      • M mwolle
        @mwolle
        Ich glaube @apollon77 hatte mal irgendwann und irgendwo eine Anleitung dagelassen wie man das 'zu Fuß' machen kann.
        Und einen Desktop betreibt man grundsätzlich nicht auf einem Server. Vollkommen unabhängig vom java heap.
          @mwolle
          GlasfaserG Offline
          GlasfaserG Offline
          siehe hier :
          https://forum.iobroker.net/topic/60172/test-iobroker-fixer-mit-jsonl-compression
          Du hast auch gesehen , das er nicht auf den aktuelle stand ist ...
          OLD ...
          			admin 			6.2.23
          Thomas BraunT M 2 Antworten Letzte Antwort
          • GlasfaserG Glasfaser
            siehe hier :
            OLD ...
            			admin 			6.2.23
            @glasfaser sagte in FATAL ERROR: JavaScript heap out of memory nach node Update:
            Klar, mit neuem js-controller wäre das ja auch (sehr wahrscheinlich) nicht mehr passiert.
            Deswegen halt die Gebetsmühle anleiern:
            Haltet den Kram auf einem aktuellen Stand!
              siehe hier :
              OLD ...
              			admin 			6.2.23
              mwolle
              @glasfaser ich wollte es gerade ja updaten...Compression geht leider auch nicht (mehr)
                  Database maintenance (3/4)
              Checking for uncompressed JSONL databases... This might take a while!
              Compressing /opt/iobroker/iobroker-data/states.jsonl
              Compressing /opt/iobroker/iobroker-data/objects.jsonl
              [6084:0x4474f28]    19212 ms: Scavenge 951.0 (962.6) -> 950.8 (968.4) MB, 6.0 / 0.0 ms  (average mu = 0.708, current mu = 0.713) allocation failure
              [6084:0x4474f28]    19278 ms: Mark-sweep (reduce) 956.3 (973.7) -> 956.2 (966.7) MB, 35.9 / 0.0 ms  (+ 2.7 ms in 5 steps since start of marking, biggest step 2.6 ms, walltime since start of marking 66 ms) (average mu = 0.672, current mu = 0.625) finalize
              Aborted
              • M mwolle
                		     v.2022-12-31
                User-ID: 		1000
                X-Server: 		true
                			/usr/bin/npm 		8.19.3
                			admin 			6.2.23
                ioBroker Status:
                Status admin:
                Objects: 		0
                States: 		0
                GlasfaserG Offline
                GlasfaserG Offline
                @mwolle sagte in FATAL ERROR: JavaScript heap out of memory nach node Update:
                zeige mal :
                du -sh  /opt/iobroker/iobroker-data/backup-objects/*objects*
                  zeige mal :
                  mwolle
                  @glasfaser
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_07-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_09-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_11-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_13-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_15-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_17-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_19-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_21-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-03_23-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_01-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_03-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_05-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_07-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_09-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_11-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_13-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_15-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_17-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_19-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_21-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-04_23-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-05_01-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-05_03-51_objects.jsonl.gz
                  1,6M	/opt/iobroker/iobroker-data/backup-objects/2023-01-05_05-51_objects.jsonl.gz
                  • M mwolle
                    @glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @mwolle
                    iobroker stop
                    cd /opt/iobroker/iobroker-data/
                    mv objects.jsonl objects.jsonl.old
                    cd backup-objects/
                    gunzip -ck 2023-01-03_07-51_objects.jsonl.gz > /opt/iobroker/iobroker-data/objects.jsonl
                    iobroker start
                    • M mwolle
                      Aborted
                      @mwolle
                      Oder versucht mal (wenn npm>7 ist)
                      npm x --yes @iobroker/jsonltool@latest /opt/iobroker/iobroker-data
                        @mwolle
                        mwolle
                        npm -v
                        8.19.3
                        Cannot compress states.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/states.jsonl"!
                            at JsonlDB.open (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@alcalzone/jsonl-db/build/lib/db.js:185:19)
                            at async compressDB (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:37:9)
                            at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:78:17)
                        Cannot compress objects.jsonl: Error: Failed to lock DB file "/opt/iobroker/iobroker-data/objects.jsonl"!
                            at async main (/home/iobroker/.npm/_npx/36bee06d4228a674/node_modules/@iobroker/jsonltool/index.js:93:17)
                        No relevant JSONL files found to compress, skip
                        • M mwolle
                          npm -v
                          8.19.3
                          @mwolle
                          iob stoppen
                          und schauen ob noch Prozesse herumgeistern.
                            @mwolle
                            iobroker stop
                            cd backup-objects/
                            iobroker start
                            mwolle
                            @glasfaser
                            iobroker stop
                            cd backup-objects/
                            iobroker start
                            das scheint funktioniert zu haben, zumindest konnte ich jetzt Komprimieren und ein iob update klappte wieder
                              @mwolle
                              iob stoppen
                              mwolle
                              @thomas-braun ja das hat sich mit dem anderem Verfahren überschnitten. Komprimieren klappte nun
                              • apollon77A Offline
                                Also ich fasse zusammen: Eine <770MB objects.json konnte bei 1,6GB "free" speicher nicht komprimiert werden? und iobroker war zu dem zeitounkt auch gestoppt? Was bracuht dann 2GB RAM ? aber naja ok... ihr habt es hinbekommen ... für mich passt da was nicht zusammen
                                • apollon77A apollon77
                                  @apollon77 sagte in [gelöst] FATAL ERROR: JavaScript heap out of memory:
                                  Stimmt, kam mir eigentlich auch seltsam vor.
