  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.5k
3.8k Beiträge 462 Kommentatoren 2.3m Aufrufe 410 Beobachtet
  • S sascho
    @nik82 Ist das Problem bei Dir behoben? Ich habe leider das gleiche Problem wie Du:
    host.iobroker_2022-09-17
    2023-01-02 08:31:40.343	error	Invalid request getRepository. "callback" or "from" is null
    vw-connect.0
    2023-01-02 08:25:29.314	error	Restart Adapter in 30min
    vw-connect.0
    2023-01-02 08:25:29.313	error	Login Failed
    vw-connect.0
    2023-01-02 08:25:29.313	error	"{\"description\":\"Invalid identity token.\",\"errorCode\":\"REQUEST_DATA_INVALID\"}"
    vw-connect.0
    2023-01-02 08:25:29.313	error	400
    vw-connect.0
    2023-01-02 08:25:29.312	error	Failed to get token
    vw-connect.0
    2023-01-02 08:25:29.158	debug	Error: Invalid protocol: skodaconnect:
    vw-connect.0
    2023-01-02 08:25:28.704	debug	{"date":"Mon, 02 Jan 2023 07:25:33 GMT","content-length":"0","connection":"close","apigw-requestid":"eGoFFjGeliAEPzw=","x-content-type-options":"nosniff","x-xss-protection":"1; mode=block","cache-control":"no-cache, no-store, max-age=0, must-revalidate","pragma":"no-cache","expires":"0","strict-transport-security":"max-age=31536000 ; includeSubDomains","x-frame-options":"DENY","location":"https://identity.vwgroup.io/oidc/v1/oauth/sso?clientId=f9a2359a-b776-46d9-bd0c-db1904343117@apps_vw-dilab_com&relayState=d0844c810298f962ad6ded58b25e2cfa235db2e3&userId=781c4d84-217d-4d78-bf57-2741834dc199&HMAC=0a5f1d74fa1410d29cde97c83a2b5168bb6995d1ca15e64eb0da2d83df5a5b7c","content-language":"en-US"}
    vw-connect.0
    2023-01-02 08:25:28.703	debug	""
    vw-connect.0
    2023-01-02 08:25:28.393	debug	emailPasswordForm2
    vw-connect.0
    2023-01-02 08:25:28.159	debug	parseEmailForm
    vw-connect.0
    2023-01-02 08:25:27.567	info	starting. Version 0.0.56 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v16.17.0, js-controller: 4.0.24
    vw-connect.0
    2023-01-02 08:25:27.389	debug	Plugin sentry Initialize Plugin (enabled=true)
    vw-connect.0
    2023-01-02 08:25:27.278	debug	States connected to redis: 0.0.0.0:9000
    vw-connect.0
    2023-01-02 08:25:27.219	debug	States create User PubSub Client
    vw-connect.0
    2023-01-02 08:25:27.218	debug	States create System PubSub Client
    vw-connect.0
    2023-01-02 08:25:27.205	debug	Redis States: Use Redis connection: 0.0.0.0:9000
    vw-connect.0
    2023-01-02 08:25:27.185	debug	Objects connected to redis: 127.0.0.1:9001
    vw-connect.0
    2023-01-02 08:25:27.181	debug	Objects client initialize lua scripts
    vw-connect.0
    2023-01-02 08:25:27.149	debug	Objects create User PubSub Client
    vw-connect.0
    2023-01-02 08:25:27.148	debug	Objects create System PubSub Client
    vw-connect.0
    2023-01-02 08:25:27.102	debug	Objects client ready ... initialize now
    vw-connect.0
    2023-01-02 08:25:27.074	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    vw-connect.0
    2023-01-02 08:24:55.732	info	Terminated (NO_ERROR): Without reason
    vw-connect.0
    2023-01-02 08:24:55.731	debug	Plugin sentry destroyed
    vw-connect.0
    2023-01-02 08:24:55.731	info	terminating
    vw-connect.0
    2023-01-02 08:24:55.705	info	cleaned everything up...
    vw-connect.0
    2023-01-02 08:24:55.705	warn	Restart initiated
    vw-connect.0
    2023-01-02 08:24:55.704	error	Restart adapter
    vw-connect.0
    2023-01-02 07:54:55.702	error	Restart Adapter in 30min
    vw-connect.0
    2023-01-02 07:54:55.702	error	Login Failed
    vw-connect.0
    2023-01-02 07:54:55.702	error	"{\"description\":\"Invalid identity token.\",\"errorCode\":\"REQUEST_DATA_INVALID\"}"
    vw-connect.0
    2023-01-02 07:54:55.701	error	400
    TT-Tom
    #1504
    @sascho Bei mir das gleiche Problem, scheint was größeres zu sein.
    Gruß Tom
    Public Transport
    NSPanel Adapter Wiki
    T T 2 Antworten Letzte Antwort
    • S sascho
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      vw-connect.0
      nik82N Offline
      nik82N Offline
      nik82
      #1505
      @sascho
      nein noch nicht behoben.
      Aber wie hier schon jemand geschrieben hat, irgendwas ist mit der App jetzt auch:
      https://www.motor-talk.de/forum/cupra-app-kein-login-moeglich-t7393640.html?utm_source=transactional&utm_medium=email&utm_campaign=newThreadNotification&utm_term=thread&utm_content=desktop
      Bin aus der App auch rausgeflogen, hab mich neu anmelden müssen, jetzt geht die App wieder.
      Aber leider der Adapter noch nicht.
      Ich hoffe das jetzt nicht am Adapter was geändert werden muss :-(
      • M Marty56
        @sneak-l8 Ich vermute Du hast auch ein We-Charge Karte.
        Wenn man We-Charge bzw. Skoda Power Pass, dann stürzt hagelt es Error Meldungen.
        Es wäre super, wenn Du das auch mal testen könntest.
        Sneak-L8
        #1506
        @marty56 Ja, ich hab ne We-Charge-Karte, aber daran dürften die Probleme nicht liegen. Auch nicht an den nun bei ID.-Modellen automatisch aktualisierten Werten. Da ist wohl wieder eher was im VW-Backend im Argen.
        Bei mir allerdings keine Fehlermeldungen.
        Habt Ihr mal versucht, Euch manuell einzuloggen? Manchmal ändern sich z.B. die Datenschutzbestimmungen und man muss sie aktiv abnicken. In der Zeit hat der Adapter dan ein Problem, weil er an dieser Vorschaltseite nicht vorbeikommt.
        • S Sneak-L8
          TT-Tom
          #1507
          @sneak-l8 sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
          Also Webseite funktioniert, nur das Autohaus ist aus den Einstellungen raus.
          Gruß Tom
          Public Transport
          • T TT-Tom
            tombox
            #1508
            @tt-tom @sascho
            Ice brauche den type im Adapter, welche App und welches Fahrzeug ihr verwendet.
            S nik82N MyzerATM 3 Antworten Letzte Antwort
            • T tombox
              @tt-tom @sascho
              Sneak-L8
              schrieb am zuletzt editiert von Sneak-L8
              #1509
              @tombox Wenn du sowieso was am Adapter machst:
              Könntest Du den Trigger für die Bearbeitung der Parkposition von lat auf lon bzw. latitude auf longitude ändern und dann lat(itude) nachlesen?
              Hintergrund: wen lat(itude) der Trigger ist, dann wurde u.U. lon(gitude) noch nicht in den entsprechenden State geschrieben und die Adresse wird aus der aktuellen latitude und der vorherigen longitude berechnet.
              Wenn man immer auf longitude reagiert, dann sollte latitude bereits aktualisiert sein udn die Adresse passt.
              Sonst kann ich aber auch selbst machen und stelle dann wieder einen PR.
              • T tombox
                @tt-tom @sascho
                nik82N Offline
                nik82N Offline
                nik82
                #1510
                @tombox
                Also ich einen Cupra Leon und einen Cupra Formentor, im Adapter habe ich immer Seat ausgewählt gehabt.
                • S sascho
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  vw-connect.0
                  tombox
                  #1511
                  @sascho Skoda sollte in der GitHub version gefixt sein bitte mal testen
                  • T tombox
                    @tt-tom @sascho
                    MyzerATM Offline
                    MyzerATM Offline
                    MyzerAT
                    #1512
                    @tombox
                    ich habe das jetzt auch:
                    ich verwende:
                    1. am Handy die App "We Connect Go"
                    2. Type = VWv2 neue Baujahr >=2020
                    3. mein Auto ist ein VW Caddy 5 Bj 2021
                    vw-connect.0
                    	2023-01-02 10:07:50.424	error	Restart Adapter in 30min
                    vw-connect.0
                    	2023-01-02 10:07:50.423	error	Login Failed
                    vw-connect.0
                    	2023-01-02 10:07:50.421	error	"{\"description\":\"Invalid identity token.\",\"errorCode\":\"REQUEST_DATA_INVALID\"}"
                    vw-connect.0
                    	2023-01-02 10:07:50.420	error	400
                    vw-connect.0
                    	2023-01-02 10:07:50.419	error	Failed to get token
                    lg Rudi
                    Node 22.23.0
                    Nodejs 22.23.0
                    npm 10.9.8
                    js-controller 7.2.2
                    • MyzerATM MyzerAT
                      @tombox
                      ich verwende:
                      vw-connect.0
                      vw-connect.0
                      vw-connect.0
                      vw-connect.0
                      vw-connect.0
                      tombox
                      #1513
                      @myzerat Geht der Login via App?
                      MyzerATM 1 Antwort Letzte Antwort
                      • T tombox
                        MyzerATM Offline
                        MyzerATM Offline
                        MyzerAT
                        #1514
                        @tombox
                        ja funktioiniert ganz normal!
                        lg Rudi
                        Node 22.23.0
                        Nodejs 22.23.0
                        npm 10.9.8
                        js-controller 7.2.2
                        • MyzerATM MyzerAT
                          @tombox
                          tombox
                          #1515
                          @myzerat Bei mir geht ausloggen Einlogen in der App gerade nicht. Muss warten bis es da wieder geht
                          • T tombox
                            sascho
                            #1516
                            @tombox
                            Bei mir geht Login in die App und auch über die Webseite. Ich versuche mal die Neuinstallation über GitHub.
                            • S sascho
                              @tombox
                              sascho
                              #1517
                              @sascho
                              Neuinstallation über Github + Synology Docker Terminal hat nicht funktioniert.
                              • JB_SullivanJ Offline
                                JB_Sullivan
                                #1518
                                Ich habe gerade aus dem GIT heraus die aktuelle Version für meinen Skoda Enyaq installiert.
                                Möglicherweise liegt es noch an den Skoda Servern, oder aber am Adapter
                                vw-connect.0
                                2023-01-02 11:27:50.725	warn	Missing second auth token for parking position
                                vw-connect.0
                                2023-01-02 11:27:50.724	error	https://api.connect.skoda-auto.cz/api/v2/vehicle-status/FIN
                                vw-connect.0
                                2023-01-02 11:27:50.724	error	AxiosError: Request failed with status code 403
                                vw-connect.0
                                2023-01-02 11:27:50.724	error	""
                                • JB_SullivanJ JB_Sullivan
                                  vw-connect.0
                                  vw-connect.0
                                  vw-connect.0
                                  vw-connect.0
                                  tombox
                                  #1519
                                  @jb_sullivan installier bitte nochmal
                                  JB_SullivanJ nik82N 2 Antworten Letzte Antwort
                                  • T tombox
                                    JB_Sullivan
                                    #1520
                                    @tombox
                                    Leider noch so ähnlich, nur das es jetzt ein Error ist.
                                    vw-connect.0
                                    2023-01-02 13:01:50.268	error	Failed second skoda login
                                    vw-connect.0
                                    2023-01-02 13:01:50.268	error	500
                                    vw-connect.0
                                    2023-01-02 13:01:50.267	error	Failed to get token
                                    vw-connect.0
                                    2023-01-02 13:01:47.602	info	Login successful
                                    vw-connect.0
                                    2023-01-02 13:01:44.798	info	starting. Version 0.0.56 (non-npm: ta2k/ioBroker.vw-connect) in C:/iobroker/GLT/node_modules/iobroker.vw-connect, node: v14.16.0, js-controller: 4.0.24
                                    • T tombox
                                      nik82N Offline
                                      nik82N Offline
                                      nik82
                                      #1521
                                      @tombox
                                      Sollen wir VW und Seat Jünger auch mal mit der Github Version testen oder ist das jetzt momentan nur für Skoda?
                                      • nik82N nik82
                                        @tombox
                                        tombox
                                        #1522
                                        @nik82 Nein VW und Seat scheint ein problem von VW zu haben da hilft nur abwarten
                                        nik82N 1 Antwort Letzte Antwort
                                        • T tombox
                                          nik82N Offline
                                          nik82N Offline
                                          nik82
                                          #1523
                                          @tombox
                                          Hab gerade trotzdem Github Version drüber installiert.
                                          Und es funktioniert wieder!
                                          Egal obs jetzt an den VW Servern lag oder an deiner Umstellung:
                                          Vielen, vielen Dank für deine immer schnelle und super Hilfe! :D 👍
