  4. [gelöst] Backitup Fehler bei IOBroker
    5.6k
backitup kein backupiobroker backup
8 Beiträge 4 Kommentatoren 796 Aufrufe 3 Beobachtet
  • AlmixxA Offline
    AlmixxA Offline
    Almixx
    schrieb am zuletzt editiert von Almixx
    Hallo. Seit dem 25.12. habe ich Fehler im Log beim täglichen Backup. Das aber nur bei IOBroker. Homematic, Grafana, Influx und Skripte werden weiterhin auf der NAS gespeichert.
    Fehler:
    ckitup.0
    2022-12-30 00:00:52.610	error	[iobroker/iobroker] }
    backitup.0
    2022-12-30 00:00:52.610	error	[iobroker/iobroker] syscall: 'uv_cwd'
    backitup.0
    2022-12-30 00:00:52.609	error	[iobroker/iobroker] code: 'ENOENT',
    backitup.0
    2022-12-30 00:00:52.609	error	[iobroker/iobroker] errno: -2,
    backitup.0
    2022-12-30 00:00:52.609	error	[iobroker/iobroker] at Module.require (node:internal/modules/cjs/loader:1067:19) {
    backitup.0
    2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Function.Module._load (node:internal/modules/cjs/loader:878:12)
    backitup.0
    2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Module.load (node:internal/modules/cjs/loader:1043:32)
    backitup.0
    2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    backitup.0
    2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Module._compile (node:internal/modules/cjs/loader:1165:14)
    backitup.0
    2022-12-30 00:00:52.607	error	[iobroker/iobroker] at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
    backitup.0
    2022-12-30 00:00:52.607	error	[iobroker/iobroker] at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
    backitup.0
    2022-12-30 00:00:52.606	error	[iobroker/iobroker] at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
    backitup.0
    2022-12-30 00:00:52.606	error	[iobroker/iobroker] at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
    backitup.0
    2022-12-30 00:00:52.606	error	[iobroker/iobroker] at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
    backitup.0
    2022-12-30 00:00:52.605	error	[iobroker/iobroker] Error: ENOENT: no such file or directory, uv_cwd
    backitup.0
    2022-12-30 00:00:52.605	error	[iobroker/iobroker] ^
    backitup.0
    2022-12-30 00:00:52.604	error	[iobroker/iobroker] cachedCwd = rawMethods.cwd();
    backitup.0
    2022-12-30 00:00:52.598	error	[iobroker/iobroker] node:internal/bootstrap/switches/does_own_process_state:126
    Kann das mir bitte jemand erklären? Lief bis dato ohne Probleme
    HomoranH Siggi0904S 2 Antworten Letzte Antwort
    • AlmixxA Almixx
      Fehler:
      ckitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      backitup.0
      @almixx sagte in Backitup Fehler bei IOBroker:
      Seit dem 25.12
      was hast du denn da gemacht/geändert?
      AlmixxA 1 Antwort Letzte Antwort
        Seit dem 25.12
        AlmixxA Offline
        AlmixxA Offline
        Almixx
        Am 25. gar nichts. Am 23. hatte ich Probleme beim aktualisieren des Admin Adapters, lief aber am 23. Dank euer Hilfe wieder...
        • AlmixxA Almixx
          @almixx
          Welche Versionen sind da am Start?
          iob stop
          iob fix
          iob start
          iob diag
          Ausgaben von iob diag posten.
          Wie genau geht das Backup vonstatten? Wird eine Freigabe via CIFS / NFS oder sonst wie gemountet?
          • AlmixxA Almixx
            Fehler:
            ckitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            backitup.0
            Siggi0904S Offline
            Siggi0904S Offline
            Siggi0904
            @almixx das ist der gleiche Fehler wie hier: https://forum.iobroker.net/topic/57108/2-5-9-fehler-existiert-backup-adapter-erzeugt-fehler/65?_=1672424839145
            Leider gibt es noch keine Lösung.
            Ein Neustart der Instanz behebt das Problem temporär.
            Es tritt scheinbar immer dann auf, wenn man einen Adapter aktualisiert.
            Danke.
            • Siggi0904S Siggi0904
              Danke.
              @siggi0904
              Da sind aber auch 'krumme' Einstellungen beim mounten am Werk.
              Siggi0904S 1 Antwort Letzte Antwort
                @siggi0904
                Siggi0904S Offline
                Siggi0904S Offline
                Siggi0904
                @thomas-braun Was würdest du denn anpassen?
                Ggf. dann aber in dem anderen Thema.
                Aber es funktioniert ja, wenn der Adapter sauber gestartet wurde.
                  @siggi0904
                  Hatte ich da schon geschrieben.
