<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[gelöst] Backitup Fehler bei IOBroker]]></title><description><![CDATA[<p dir="auto">Hallo. Seit dem 25.12. habe ich Fehler im Log beim täglichen Backup. Das aber nur bei IOBroker. Homematic, Grafana, Influx und Skripte werden weiterhin auf der NAS gespeichert.<br />
Fehler:</p>
<pre><code>ckitup.0
2022-12-30 00:00:52.610	error	[iobroker/iobroker] }
backitup.0
2022-12-30 00:00:52.610	error	[iobroker/iobroker] syscall: 'uv_cwd'
backitup.0
2022-12-30 00:00:52.609	error	[iobroker/iobroker] code: 'ENOENT',
backitup.0
2022-12-30 00:00:52.609	error	[iobroker/iobroker] errno: -2,
backitup.0
2022-12-30 00:00:52.609	error	[iobroker/iobroker] at Module.require (node:internal/modules/cjs/loader:1067:19) {
backitup.0
2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Function.Module._load (node:internal/modules/cjs/loader:878:12)
backitup.0
2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Module.load (node:internal/modules/cjs/loader:1043:32)
backitup.0
2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
backitup.0
2022-12-30 00:00:52.608	error	[iobroker/iobroker] at Module._compile (node:internal/modules/cjs/loader:1165:14)
backitup.0
2022-12-30 00:00:52.607	error	[iobroker/iobroker] at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:7:1)
backitup.0
2022-12-30 00:00:52.607	error	[iobroker/iobroker] at Argv (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/index.cjs:12:16)
backitup.0
2022-12-30 00:00:52.606	error	[iobroker/iobroker] at fe.Yargs (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/yargs/build/index.cjs:1:61304)
backitup.0
2022-12-30 00:00:52.606	error	[iobroker/iobroker] at Object.process.cwd (/opt/iobroker/node_modules/graceful-fs/polyfills.js:10:19)
backitup.0
2022-12-30 00:00:52.606	error	[iobroker/iobroker] at process.wrappedCwd (node:internal/bootstrap/switches/does_own_process_state:126:28)
backitup.0
2022-12-30 00:00:52.605	error	[iobroker/iobroker] Error: ENOENT: no such file or directory, uv_cwd
backitup.0
2022-12-30 00:00:52.605	error	[iobroker/iobroker] ^
backitup.0
2022-12-30 00:00:52.604	error	[iobroker/iobroker] cachedCwd = rawMethods.cwd();
backitup.0
2022-12-30 00:00:52.598	error	[iobroker/iobroker] node:internal/bootstrap/switches/does_own_process_state:126
</code></pre>
<p dir="auto">Kann das mir bitte jemand erklären? Lief bis dato ohne Probleme</p>
]]></description><link>https://forum.iobroker.net/topic/61531/gelöst-backitup-fehler-bei-iobroker</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 06:24:44 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/61531.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Dec 2022 07:10:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 19:05:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siggi0904" aria-label="Profile: siggi0904">@<bdi>siggi0904</bdi></a></p>
<p dir="auto">Hatte ich da schon geschrieben.</p>
]]></description><link>https://forum.iobroker.net/post/919121</link><guid isPermaLink="true">https://forum.iobroker.net/post/919121</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 30 Dec 2022 19:05:07 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 18:57:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> Was würdest du denn anpassen?<br />
Ggf. dann aber in dem anderen Thema.</p>
<p dir="auto">Aber es funktioniert ja, wenn der Adapter sauber gestartet wurde.</p>
]]></description><link>https://forum.iobroker.net/post/919119</link><guid isPermaLink="true">https://forum.iobroker.net/post/919119</guid><dc:creator><![CDATA[Siggi0904]]></dc:creator><pubDate>Fri, 30 Dec 2022 18:57:55 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 18:44:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siggi0904" aria-label="Profile: siggi0904">@<bdi>siggi0904</bdi></a></p>
<p dir="auto">Da sind aber auch 'krumme' Einstellungen beim mounten am Werk.</p>
]]></description><link>https://forum.iobroker.net/post/919115</link><guid isPermaLink="true">https://forum.iobroker.net/post/919115</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 30 Dec 2022 18:44:02 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 18:29:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/almixx" aria-label="Profile: almixx">@<bdi>almixx</bdi></a> das ist der gleiche Fehler wie hier: <a href="https://forum.iobroker.net/topic/57108/2-5-9-fehler-existiert-backup-adapter-erzeugt-fehler/65?_=1672424839145">https://forum.iobroker.net/topic/57108/2-5-9-fehler-existiert-backup-adapter-erzeugt-fehler/65?_=1672424839145</a></p>
<p dir="auto">Leider gibt es noch keine Lösung.<br />
Ein Neustart der Instanz behebt das Problem temporär.</p>
<p dir="auto">Es tritt scheinbar immer dann auf, wenn man einen Adapter aktualisiert.</p>
<p dir="auto">Danke.</p>
]]></description><link>https://forum.iobroker.net/post/919113</link><guid isPermaLink="true">https://forum.iobroker.net/post/919113</guid><dc:creator><![CDATA[Siggi0904]]></dc:creator><pubDate>Fri, 30 Dec 2022 18:29:04 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 17:55:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/almixx" aria-label="Profile: almixx">@<bdi>almixx</bdi></a></p>
<p dir="auto">Welche Versionen sind da am Start?</p>
<pre><code>iob stop
iob fix
iob start
iob diag
</code></pre>
<p dir="auto">Ausgaben von <code>iob diag</code> posten.</p>
<p dir="auto">Wie genau geht das Backup vonstatten? Wird eine Freigabe via CIFS / NFS oder sonst wie gemountet?</p>
]]></description><link>https://forum.iobroker.net/post/919101</link><guid isPermaLink="true">https://forum.iobroker.net/post/919101</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Fri, 30 Dec 2022 17:55:22 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 17:28:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a><br />
Am 25. gar nichts. Am 23. hatte ich Probleme beim aktualisieren des Admin Adapters, lief aber am 23. Dank euer Hilfe wieder...</p>
]]></description><link>https://forum.iobroker.net/post/919098</link><guid isPermaLink="true">https://forum.iobroker.net/post/919098</guid><dc:creator><![CDATA[Almixx]]></dc:creator><pubDate>Fri, 30 Dec 2022 17:28:13 GMT</pubDate></item><item><title><![CDATA[Reply to [gelöst] Backitup Fehler bei IOBroker on Fri, 30 Dec 2022 08:57:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/almixx" aria-label="Profile: almixx">@<bdi>almixx</bdi></a> sagte in <a href="/post/918795">Backitup Fehler bei IOBroker</a>:</p>
<blockquote>
<p dir="auto">Seit dem 25.12</p>
</blockquote>
<p dir="auto">was hast du denn da gemacht/geändert?</p>
]]></description><link>https://forum.iobroker.net/post/918820</link><guid isPermaLink="true">https://forum.iobroker.net/post/918820</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Fri, 30 Dec 2022 08:57:29 GMT</pubDate></item></channel></rss>
