  4. Simatic S7 Adapter Fehlermeldung
    6.5k
18 Beiträge 4 Kommentatoren 2.9k Aufrufe 4 Beobachtet
  • VraanaaV Vraanaa
    @darkmann2000 Ich habe ganz Neue Iobroker und NPM installiert...alle anderes siehst gut, aber kann nicht S7 Adapter installieren..
    habe NPM V9
    $ iobroker add s7 0 --host raspberrypi --debug
    NPM version: 9.2.0
    Installing iobroker.s7@1.3.15... (System call)
    npm ERR! code 1
    npm ERR! path /opt/iobroker/node_modules/node-snap7
    npm ERR! command failed
    npm ERR! command sh -c prebuild-install || node-gyp rebuildnpm ERR! make: Entering directory '/opt/iobroker/node_modules/node-snap7/build'npm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_msgsock.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_sysutils.o
    npm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_tcpsrvr.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/sys/snap_threads.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_client.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_isotcp.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_partner.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_peer.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_server.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_text.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/core/s7_micro_client.onpm ERR! CXX(target) Release/obj.target/snap7/deps/snap7/src/lib/snap7_libmain.onpm ERR! rm -f Release/obj.target/snap7.a Release/obj.target/snap7.a.ar-file-list; mkdir -p `dirname Release/obj.target/snap7.a`npm ERR! ar crs Release/obj.target/snap7.a @Release/obj.target/snap7.a.ar-file-listnpm ERR! COPY Release/snap7.a
    npm ERR! CXX(target) Release/obj.target/node_snap7/src/node_snap7.onpm ERR! make: Leaving directory '/opt/iobroker/node_modules/node-snap7/build'npm ERR! prebuild-install WARN install No prebuilt binaries found (target=19.3.0 runtime=node arch=arm64 libc= platform=linux)npm ERR! gyp info it worked if it ends with oknpm ERR! gyp info using node-gyp@9.3.0npm ERR! gyp info using node@19.3.0 | linux | arm64npm ERR! gyp info find Python using Python version 3.9.2 found at "/usr/bin/python3"npm ERR! gyp info spawn /usr/bin/python3npm ERR! gyp info spawn args [npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm ERR! gyp info spawn args 'binding.gyp',npm ERR! gyp info spawn args '-f',npm ERR! gyp info spawn args 'make',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/opt/iobroker/node_modules/node-snap7/build/config.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm ERR! gyp info spawn args '-I',npm ERR! gyp info spawn args '/home/iobroker/.cache/node-gyp/19.3.0/include/node/common.gypi',npm ERR! gyp info spawn args '-Dlibrary=shared_library',npm ERR! gyp info spawn args '-Dvisibility=default',npm ERR! gyp info spawn args '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/19.3.0',npm ERR! gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm ERR! gyp info spawn args '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/19.3.0/<(target_arch)/node.lib',npm ERR! gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/node_modules/node-snap7',npm ERR! gyp info spawn args '-Dnode_engine=v8',npm ERR! gyp info spawn args '--depth=.',
    npm ERR! gyp info spawn args '--no-parallel',npm ERR! gyp info spawn args '--generator-output',npm ERR! gyp info spawn args 'build',npm ERR! gyp info spawn args '-Goutput_dir=.'npm ERR! gyp info spawn args ]npm ERR! gyp info spawn makenpm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm ERR! ../deps/snap7/src/sys/snap_tcpsrvr.cpp: In member function ‘int TCustomMsgServer::StartTo(const char*, word)’:npm ERR! ../deps/snap7/src/sys/snap_tcpsrvr.cpp:429:12: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]npm ERR! 429 | strncpy(FLocalAddress, Address, 16);npm ERR! | ~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../deps/snap7/src/core/s7_isotcp.cpp: In member function ‘int TIsoTcpSocket::IsoConfirmConnection(u_char)’:npm ERR! ../deps/snap7/src/core/s7_isotcp.cpp:163:10: warning: variable ‘TempRef’ set but not used [-Wunused-but-set-variable]npm ERR! 163 | u_short TempRef;npm ERR! | ^~~~~~~npm ERR! ../deps/snap7/src/core/s7_partner.cpp: In member function ‘int TConnectionServer::StartTo(const char*)’:npm ERR! ../deps/snap7/src/core/s7_partner.cpp:252:12: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]npm ERR! 252 | strncpy(FLocalAddress,Address,16);npm ERR! | ~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../deps/snap7/src/core/s7_server.cpp: In member function ‘byte TS7Worker::WriteArea(PReqFunWriteDataItem, PReqFunWriteItem, TEv&)’:npm ERR! ../deps/snap7/src/core/s7_server.cpp:626:5: warning: this ‘if’ clause does not guard... [-Wmisleading-indentation]npm ERR! 626 | if ((ReqItemPar->Area==S7AreaTM) ^ (ReqItemPar->TransportSize==S7WLTimer))npm ERR! | ^~npm ERR! ../deps/snap7/src/core/s7_server.cpp:629:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’npm ERR! 629 | if ((ReqItemPar->Area==S7AreaCT) ^ (ReqItemPar->TransportSize==S7WLCounter))npm ERR! | ^~npm ERR! ../deps/snap7/src/core/s7_server.cpp: In member function ‘void TS7Worker::SZLSystemState()’:npm ERR! ../deps/snap7/src/core/s7_server.cpp:1247:11: warning: ‘void* memcpy(void*, const void*, size_t)’ forming offset [4, 5] is out of the bounds [0, 4] of object ‘SZLNotAvail’ with type ‘byte [4]’ {aka ‘unsigned char [4]’} [-Warray-bounds]
    npm ERR! 1247 | memcpy(SZL.ResData,&SZLNotAvail,sizeof(SZLSysState));npm ERR! | ~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! In file included from ../deps/snap7/src/core/s7_server.cpp:27:npm ERR! ../deps/snap7/src/core/s7_firmware.h:36:8: note: ‘SZLNotAvail’ declared herenpm ERR! 36 | byte SZLNotAvail[4] = {npm ERR! | ^~~~~~~~~~~npm ERR! ../deps/snap7/src/core/s7_server.cpp: In member function ‘word TS7Worker::ReadArea(PResFunReadItem, PReqFunReadItem, int&, TEv&)’:npm ERR! ../deps/snap7/src/core/s7_server.cpp:454:34: warning: ‘BitIndex’ may be used uninitialized in this function [-Wmaybe-uninitialized]npm ERR! 454 | if ((ByteVal & BitMask[BitIndex])!=0)npm ERR! | ^~~~~~~~npm ERR! ../deps/snap7/src/core/s7_server.cpp: In member function ‘byte TS7Worker::WriteArea(PReqFunWriteDataItem, PReqFunWriteItem, TEv&)’:npm ERR! ../deps/snap7/src/core/s7_server.cpp:698:32: warning: ‘BitIndex’ may be used uninitialized in this function [-Wmaybe-uninitialized]npm ERR! 698 | *Target=*Target | BitMask[BitIndex];npm ERR! | ^~~~~~~~npm ERR! ../deps/snap7/src/core/s7_text.cpp: In function ‘char* EvtSrvText(TSrvEvent&, char*, int)’:npm ERR! ../deps/snap7/src/core/s7_text.cpp:782:5: warning: this ‘else’ clause does not guard... [-Wmisleading-indentation]npm ERR! 782 | elsenpm ERR! | ^~~~npm ERR! ../deps/snap7/src/core/s7_text.cpp:785:2: note: ...this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’npm ERR! 785 | strncpy(Result, S, TextLen);npm ERR! | ^~~~~~~npm ERR! ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘void TSnap7MicroClient::SetConnectionParams(const char*, word, word)’:npm ERR! ../deps/snap7/src/core/s7_micro_client.cpp:2675:13: warning: ‘char* strncpy(char*, const char*, size_t)’ specified bound 16 equals destination size [-Wstringop-truncation]npm ERR! 2675 | strncpy(RemoteAddress, RemAddress, 16);npm ERR! | ~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../deps/snap7/src/core/s7_micro_client.cpp: In member function ‘int TSnap7MicroClient::SetSessionPassword(char*)’:npm ERR! ../deps/snap7/src/core/s7_micro_client.cpp:3306:16: warning: ‘char* strncpy(char*, const char*, size_t)’ output truncated before terminating nul copying as many bytes from a string as its length [-Wstringop-truncation]npm ERR! 3306 | strncpy((char*)&opData,Password,L);npm ERR! | ~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! ../deps/snap7/src/core/s7_micro_client.cpp:3298:26: note: length computed herenpm ERR! 3298 | size_t L = strlen(Password);npm ERR! | ~~~~~~^~~~~~~~~~npm ERR! In file included from ../node_modules/nan/nan.h:176,npm ERR! from ../src/node_snap7_client.h:11,npm ERR! from ../src/node_snap7.cpp:6:npm ERR! ../node_modules/nan/nan_callbacks.h:55:23: error: ‘AccessorSignature’ is not a member of ‘v8’
    npm ERR! 55 | typedef v8::Local<v8::AccessorSignature> Sig;npm ERR! | ^~~~~~~~~~~~~~~~~npm ERR! ../node_modules/nan/nan_callbacks.h:55:40: error: template argument 1 is invalidnpm ERR! 55 | typedef v8::Local<v8::AccessorSignature> Sig;npm ERR! | ^npm ERR! In file included from ../src/node_snap7_client.h:11,npm ERR! from ../src/node_snap7.cpp:6:npm ERR! ../node_modules/nan/nan.h: In function ‘void Nan::SetAccessor(v8::Local<v8::ObjectTemplate>, v8::Local<v8::String>, Nan::GetterCallback, Nan::SetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, Nan::imp::Sig)’:npm ERR! ../node_modules/nan/nan.h:2549:16: error: no matching function for call to ‘v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>&, void (*&)(v8::Local<v8::Name>, const v8::PropertyCallbackInfo<v8::Value>&), void (*&)(v8::Local<v8::Name>, v8::Local<v8::Value>, const v8::PropertyCallbackInfo<void>&), v8::Local<v8::Object>&, v8::AccessControl&, v8::PropertyAttribute&, Nan::imp::Sig&)’npm ERR! 2549 | , signature);npm ERR! | ^npm ERR! In file included from /home/iobroker/.cache/node-gyp/19.3.0/include/node/v8-function.h:15,npm ERR! from /home/iobroker/.cache/node-gyp/19.3.0/include/node/v8.h:33,npm ERR! from /home/iobroker/.cache/node-gyp/19.3.0/include/node/node.h:73,npm ERR! from ../src/node_snap7_client.h:10,npm ERR! from ../src/node_snap7.cpp:6:npm ERR! /home/iobroker/.cache/node-gyp/19.3.0/include/node/v8-template.h:807:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::String>, v8::AccessorGetterCallback, v8::AccessorSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’npm ERR! 807 | void SetAccessor(npm ERR! | ^~~~~~~~~~~npm ERR! /home/iobroker/.cache/node-gyp/19.3.0/include/node/v8-template.h:812:22: note: no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’npm ERR! 812 | SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,npm ERR! | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! /home/iobroker/.cache/node-gyp/19.3.0/include/node/v8-template.h:814:8: note: candidate: ‘void v8::ObjectTemplate::SetAccessor(v8::Local<v8::Name>, v8::AccessorNameGetterCallback, v8::AccessorNameSetterCallback, v8::Local<v8::Value>, v8::AccessControl, v8::PropertyAttribute, v8::SideEffectType, v8::SideEffectType)’npm ERR! 814 | void SetAccessor(npm ERR! | ^~~~~~~~~~~npm ERR! /home/iobroker/.cache/node-gyp/19.3.0/include/node/v8-template.h:819:22: note: no known conversion for argument 7 from ‘Nan::imp::Sig’ {aka ‘int’} to ‘v8::SideEffectType’npm ERR! 819 | SideEffectType getter_side_effect_type = SideEffectType::kHasSideEffect,npm ERR! | ~~~~~~~~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! In file included from ../src/node_snap7_client.h:10,npm ERR! from ../src/node_snap7.cpp:6:npm ERR! ../src/node_snap7.cpp: At global scope:npm ERR! /home/iobroker/.cache/node-gyp/19.3.0/include/node/node.h:993:7: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm ERR! 993 | (node::addon_register_func) (regfunc), \npm ERR! | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm ERR! /home/iobroker/.cache/node-gyp/19.3.0/include/node/node.h:1027:3: note: in expansion of macro ‘NODE_MODULE_X’npm ERR! 1027 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm ERR! | ^~~~~~~~~~~~~npm ERR! ../src/node_snap7.cpp:16:1: note: in expansion of macro ‘NODE_MODULE’npm ERR! 16 | NODE_MODULE(node_snap7, InitAll)
    npm ERR! | ^~~~~~~~~~~npm ERR! make: *** [node_snap7.target.mk:119: Release/obj.target/node_snap7/src/node_snap7.o] Error 1npm ERR! gyp ERR! build error npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2npm ERR! gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:513:28)npm ERR! gyp ERR! stack at ChildProcess._handle.onexit (node:internal/child_process:293:12)npm ERR! gyp ERR! System Linux 5.15.76-v8+npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"npm ERR! gyp ERR! cwd /opt/iobroker/node_modules/node-snap7npm ERR! gyp ERR! node -v v19.3.0npm ERR! gyp ERR! node-gyp -v v9.3.0npm ERR! gyp ERR! not ok
    npm ERR! /home/iobroker/.npm/_logs/2022-12-29T01_06_46_239Z-debug-0.log
    host.raspberrypi Cannot install iobroker.s7@1.3.15: 1
    ERROR: Process exited with code 25
    @vraanaa
    Versuch es mit der zur Zeit empfohlenen nodejs16.
    Warum eierst du da mit der Entwicklerversion v19 herum?
    VraanaaV 1 Antwort Letzte Antwort
    • VraanaaV Vraanaa
      habe NPM V9
      NPM version: 9.2.0
      npm ERR! code 1
      Darkmann2000
      @vraanaa
      Mein System ist auf folgenden Stand:
      Admin Version 6.3.5
      JS Controller Version 4.0.23
      Node JS version 16.19.0
      NPM 8.19.3
      Damit läuft es ohne Probleme
        @vraanaa
        VraanaaV Offline
        VraanaaV Offline
        Vraanaa
        schrieb am zuletzt editiert von Vraanaa
        @thomas-braun Danke fuer Antwort...Hmm, ja - hab ich ganz neue Image in Pi installiert und dachte alles UpToDate ist besser...is es moeglich jetzt und Problemloss zu Downgrade?
        In Info steht auch Warning 😬 :
        Platform
        linux
        OS
        linux
        Architecture
        arm64
        CPUs
        Speed
        1200 MHz
        Model
        Cortex-A72
        RAM
        3.71 GB
        System uptime
        08:43:59
        Node.js
        v19.3.0 (Version v19.x of Node.js is currently not fully supported. - Recommended version v16.19.0)
        time
        1672308932441
        timeOffset
        -60
        Number of adapters
        537
        NPM
        9.2.0
        Disk size
        28.76 GB
        Disk free
        23.78 GB
        Uptime
        08:26:28
        Active instances
        12
        path
        /opt/iobroker/
        Hostname
        raspberrypi
        • VraanaaV Vraanaa
          Platform
          linux
          OS
          linux
          Architecture
          arm64
          CPUs
          Speed
          1200 MHz
          Model
          Cortex-A72
          RAM
          3.71 GB
          System uptime
          08:43:59
          Node.js
          time
          1672308932441
          timeOffset
          -60
          Number of adapters
          537
          NPM
          9.2.0
          Disk size
          28.76 GB
          Disk free
          23.78 GB
          Uptime
          08:26:28
          Active instances
          12
          path
          /opt/iobroker/
          Hostname
          raspberrypi
          @vraanaa
          Schau in meiner Signatur.
          • VraanaaV Vraanaa
            Platform
            linux
            OS
            linux
            Architecture
            arm64
            CPUs
            Speed
            1200 MHz
            Model
            Cortex-A72
            RAM
            3.71 GB
            System uptime
            08:43:59
            Node.js
            time
            1672308932441
            timeOffset
            -60
            Number of adapters
            537
            NPM
            9.2.0
            Disk size
            28.76 GB
            Disk free
            23.78 GB
            Uptime
            08:26:28
            Active instances
            12
            path
            /opt/iobroker/
            Hostname
            raspberrypi
            @vraanaa
            https://github.com/mathiask88/node-snap7/issues/88
            Aber mit der empfohlenen nodeJS@16 und npm@8 funktioniert es noch.
            • D Darkmann2000
              @peachy
              bei mir stand im Log npm audit fix --force
              Das habe eingegeben und dann lief der Adapter wieder.
              @darkmann2000 sagte in Simatic S7 Adapter Fehlermeldung:
              Der Befehl ist allerdings brandgefährlich. Besser die Finger davon lassen. Der zieht dir das System komplett auf Links.
                @vraanaa
                VraanaaV Offline
                VraanaaV Offline
                Vraanaa
                @thomas-braun Kann ich kleine Hilfe noch Versuchen - ich habe V16 installiert - aber steht im falsche Pfad (/usr/local/bin/node). Wie kann ich jetzt Aktivieren - sorry bin ich nicht so experienced mit Linux :/
                pi@raspberrypi:~ $ type -P nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                /usr/bin/nodejs
                /usr/local/bin/node
                /usr/local/bin/npm
                v19.3.0
                v16.19.0
                8.19.3
                nodejs:
                  Installed: 19.3.0-deb-1nodesource1
                  Candidate: 19.3.0-deb-1nodesource1
                  Version table:
                 *** 19.3.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_19.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u1 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                • VraanaaV Vraanaa
                  /usr/bin/nodejs
                  /usr/local/bin/node
                  /usr/local/bin/npm
                  v19.3.0
                  v16.19.0
                  8.19.3
                  nodejs:
                    Version table:
                  @vraanaa
                  Lies das HowTo nochmal.
                  Die nodesource.list ist nicht geändert und die Pfade sind falsch.
                  Dafür gibt es jetzt eine Datei nodesource.list.save.1 .
                  Die muss raus.
                  • VraanaaV Vraanaa
                    /usr/bin/nodejs
                    /usr/local/bin/node
                    /usr/local/bin/npm
                    v19.3.0
                    v16.19.0
                    8.19.3
                    nodejs:
                      Version table:
                    @vraanaa sagte in Simatic S7 Adapter Fehlermeldung:
                    Aber nicht nach dem HowTo sondern 'irgendwie'.
                    Mit dem Paketmanager landet das auch alles in den richtigen Verzeichnissen.
                      @vraanaa
                      Die muss raus.
                      VraanaaV Offline
                      VraanaaV Offline
                      Vraanaa
                      @thomas-braun jetzt habe ich bei Node - v Antwort fuer Version V16 - jetzt S7 Adapter habe ich problemloss in IO Broker installiert.
                      Aber wie ich kann die Datei 'nodesource.list.save.1', 'nodesource.list.save.2', 'nodesource.list.save.3' loeschen?
                      Weiss nicht ob alles siehst wie es soll?
                      pi@raspberrypi:~ $ apt policy nodejs
                      nodejs:
                        Version table:
                       *** 19.3.0-deb-1nodesource1 100
                           16.19.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                              500 http://security.debian.org/debian-security bullseye-security/main ar        m64 Packages
                      N: Ignoring file 'nodesource.list.save.2' in directory '/etc/apt/sources.list.d/        ' as it has an invalid filename extension
                      N: Ignoring file 'nodesource.list.save.3' in directory '/etc/apt/sources.list.d/        ' as it has an invalid filename extension
                      N: Ignoring file 'nodesource.list.save.1' in directory '/etc/apt/sources.list.d/        ' as it has an invalid filename extension
                      pi@raspberrypi:~ $ node -v
                      v16.19.0
                      pi@raspberrypi:~ $ sudo nano /etc/apt/sources.list.d/nodesource.list
                        GNU nano 5.4                                              /etc/apt/sources.list.d/nodesource.list
                      deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                      deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main
                      Platform
                      linux
                      OS
                      linux
                      Architecture
                      arm64
                      CPUs
                      Speed
                      1800 MHz
                      Model
                      Cortex-A72
                      RAM
                      3.71 GB
                      System uptime
                      00:51:06
                      Node.js
                      v16.19.0
                      time
                      1672326436528
                      timeOffset
                      -60
                      Number of adapters
                      537
                      NPM
                      8.19.3
                      Disk size
                      28.76 GB
                      Disk free
                      22.29 GB
                      Uptime
                      00:09:39
                      Active instances
                      12
                      path
                      /opt/iobroker/
                      Hostname
                      raspberrypi
                      • VraanaaV Vraanaa
                        nodejs:
                          Version table:
                        v16.19.0
                        Platform
                        linux
                        OS
                        linux
                        Architecture
                        arm64
                        CPUs
                        Speed
                        1800 MHz
                        Model
                        Cortex-A72
                        RAM
                        3.71 GB
                        System uptime
                        00:51:06
                        Node.js
                        v16.19.0
                        time
                        1672326436528
                        timeOffset
                        -60
                        Number of adapters
                        537
                        NPM
                        8.19.3
                        Disk size
                        28.76 GB
                        Disk free
                        22.29 GB
                        Uptime
                        00:09:39
                        Active instances
                        12
                        path
                        /opt/iobroker/
                        Hostname
                        raspberrypi
                        @vraanaa
                        Das ist immer noch alles krumm und schief.
                        sudo rm /etc/apt/sources.list.d/nodesource.list.*
                        räumt die überflüssigen Versionen schon mal weg.
