  4. Iobroker tot nach Admin update 6.3.3 zu 6.3.4
    5.6k
30 Beiträge 6 Kommentatoren 3.4k Aufrufe 7 Beobachtet
  • Z zgadgeter
    Used repository: stable
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
    Adapter    "chromecast"   : 2.3.1    , installed 3.0.3
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "fhem"         : 1.6.3    , installed 1.6.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "homeconnect"  : 1.1.1    , installed 1.1.1
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "netatmo"      : 2.0.5    , installed 2.0.5
    Adapter    "sayit"        : 1.12.3   , installed 1.12.6
    Adapter    "shelly"       : 6.0.0    , installed 6.2.3
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "zigbee"       : 1.7.6    , installed 1.7.6
    $ iob list instances
      system.adapter.admin.0                  : admin                 : hohkeppelioblxc                          - disabled, port: 7777, bind: 0.0.0.0, run as: admin
      system.adapter.alias-manager.0          : alias-manager         : hohkeppelioblxc                          - disabled
    + system.adapter.backitup.0               : backitup              : hohkeppelioblxc                          -  enabled
    + system.adapter.chromecast.0             : chromecast            : hohkeppelioblxc                          -  enabled
    + system.adapter.cloud.0                  : cloud                 : hohkeppelioblxc                          -  enabled
      system.adapter.discovery.0              : discovery             : hohkeppelioblxc                          - disabled
    + system.adapter.echarts.0                : echarts               : hohkeppelioblxc                          -  enabled
    + system.adapter.email.0                  : email                 : hohkeppelioblxc                          -  enabled
    + system.adapter.fhem.0                   : fhem                  : hohkeppelioblxc                          -  enabled, port: 7072
      system.adapter.flot.0                   : flot                  : hohkeppelioblxc                          - disabled
    + system.adapter.history.0                : history               : hohkeppelioblxc                          -  enabled
    + system.adapter.hm-rega.0                : hm-rega               : hohkeppelioblxc                          -  enabled
    + system.adapter.hm-rpc.0                 : hm-rpc                : hohkeppelioblxc                          -  enabled, port: 0
    + system.adapter.homeconnect.0            : homeconnect           : hohkeppelioblxc                          -  enabled
    + system.adapter.info.0                   : info                  : hohkeppelioblxc                          -  enabled
    + system.adapter.iot.0                    : iot                   : hohkeppelioblxc                          -  enabled
    + system.adapter.javascript.0             : javascript            : hohkeppelioblxc                          -  enabled
    + system.adapter.meross.0                 : meross                : hohkeppelioblxc                          -  enabled
    + system.adapter.net-tools.0              : net-tools             : hohkeppelioblxc                          -  enabled
    + system.adapter.netatmo.0                : netatmo               : hohkeppelioblxc                          -  enabled
    + system.adapter.sayit.0                  : sayit                 : hohkeppelioblxc                          -  enabled, port: 0
    + system.adapter.sayit.1                  : sayit                 : hohkeppelioblxc                          -  enabled, port: 0
    + system.adapter.scenes.0                 : scenes                : hohkeppelioblxc                          -  enabled
    + system.adapter.shelly.0                 : shelly                : hohkeppelioblxc                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.shelly.1                 : shelly                : hohkeppelioblxc                          -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.simple-api.0             : simple-api            : hohkeppelioblxc                          -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
    + system.adapter.socketio.0               : socketio              : hohkeppelioblxc                          -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : hohkeppelioblxc                          -  enabled, port: 1883, bind: 0.0.0.0
    + system.adapter.telegram.0               : telegram              : hohkeppelioblxc                          -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.text2command.0           : text2command          : hohkeppelioblxc                          -  enabled
      system.adapter.vis-bars.0               : vis-bars              : hohkeppelioblxc                          - disabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : hohkeppelioblxc                          - disabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : hohkeppelioblxc                          - disabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : hohkeppelioblxc                          - disabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : hohkeppelioblxc                          - disabled
      system.adapter.vis-material.0           : vis-material          : hohkeppelioblxc                          - disabled
      system.adapter.vis-metro.0              : vis-metro             : hohkeppelioblxc                          -  enabled
      system.adapter.vis.0                    : vis                   : hohkeppelioblxc                          -  enabled
    + system.adapter.web.0                    : web                   : hohkeppelioblxc                          -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.wled.0                   : wled                  : hohkeppelioblxc                          -  enabled
    + system.adapter.zigbee.0                 : zigbee                : hohkeppelioblxc                          -  enabled, port: /dev/ttyACM1
    + instance is alive
    @zgadgeter sagte in Iobroker tot nach Admin update 6.3.3 zu 6.3.4:
    Da würde ich auch nochmal schauen, ob die gleichzeitig auf dem gleichen Port lauschen dürfen.
    Z 1 Antwort Letzte Antwort
      Z Offline
      Z Offline
      zgadgeter
      @thomas-braun Also, mit start admin hat es wieder funktioniert, vielen Dank!
      Das Thema port interessiert mich jetzt.
      Ja, ich habe den iobroker port geändert auf einen anderen, weil ich eine Zeit lang motioneye hatte. Der benutzt ja auch den 8081.
      Interessant ist dein Kommentar wegen den shelly...muss da auch ein port eingestellt werden irgendwie? Die shelly kann ich ueber den iob steuern, ohne das ich was geändert habe...habe ich da was verpasst oder falsch verstanden?
      Vielen Dank nochmals fuer die Hilfe!
      • Z zgadgeter
        @zgadgeter
        Wie du siehen kannst lauschen beide Instanzen des shelly-Adapters auf dem gleichen Port 1882.
        Zum einen würde ich überlegen ob es überhaupt zwei Instanzen braucht und dann kann das eigentlich nicht beides auf dem gleichen Port lauschen.
          @zgadgeter
          Z Offline
          Z Offline
          zgadgeter
          @thomas-braun Hi,
          ich habe aeltere und neuere Shelly. Die neuen brauchen (so habe ich das im Forum gelesen) andere Einstellungen. Deswegen die zweite Instanz.
          Aber den Port einzustellen, wo oder wie wird das gemacht? Das habe ich nirgendswo selbst gemacht. Macht das der Iob standard auf den 8081?
          Die shelly Geraete funktionieren (fast) immer...manchmal verlieren die sich im Netz und ich muss neu starten. Weiss nicht ob das was damit zu tun hat?
          • Z zgadgeter
            @thomas-braun Hi,
            Höchstwahrscheinlich.
            Ich hab den shelly-Adapter nicht im Einsatz, kann dir da nix genaueres zu sagen.
              Z Offline
              Z Offline
              zgadgeter
              @thomas-braun Ok, danke fuer den Hinweiss ueber die Ports die fuer die Shelly eingestellt sind, bzw. benutzt werden...da muss ich nach recherchieren.
              DAnke fuer die viele HIlfe, und schoene Tage noch! :)
              Meister MopperM ? 2 Antworten Letzte Antwort
              • Z zgadgeter
                Meister MopperM Online
                Meister Mopper
                @zgadgeter
                Port 1883 ist der Standard mqtt Port. Ich habe keinen Shelly-Adapter, aber der wird dort sicherlich in der Instanz eingestellt.
                Alternativ könntest Du die zweite Instanz auf Port 8883 (secure mqtt) lauschen lassen.
                Proxmox und HA ...
                Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                • Z zgadgeter
                  Shelly Adapter
                  und das Untermenü zur mqtt einstellung
                  Da kannst Du den Port einstellen, sollte natürlich ein freier nicht genutzter sein und auch keiner der Standardmäßig schon durch andere Applikationen/Systeme besetzt ist :)
                  Dann musst Du natürlich auch die Shellys umkonfigurieren, damit der Port auch greift.
                  Die Frage von @Thomas-Braun bleibt, sind heute noch zwei Instanzen nötig oder kann man heute alte u. neue Shellys in einer Instanz betreiben?
                  Bernd
                    skinni
                    Hab auch zwei shelly adapter, wegen alt und neu. Einer ist für mqtt konfiguriert, der andere für CoAP. Beides in einem geht leider nicht. Ports sind natürlich unterschiedlich
                      Shelly Adapter
                      Bernd
                      Z Offline
                      Z Offline
                      zgadgeter
                      @dp20eic Ok, danke. Muss da herum spielen. Ich hatte ja meinen IOb Port schon geandert weil ich ja motioneye hatte.
