    6.3k
4.8k Beiträge 4 Kommentatoren 2.9m Aufrufe 4 Beobachtet
  • mickymM mickym
    @damrak2022
    Probier das mal:
            "id": "8e3db4a4240694d8",
            "type": "ioBroker in",
            "z": "ec4bc18e68f368ea",
            "name": "Imac",
            "topic": "shelly.0.SHPLG-S#E423FA#1.Relay0.Power",
            "payloadType": "value",
            "onlyack": "update",
            "func": "all",
            "gap": "",
            "fireOnStart": "true",
            "outFormat": "MQTT",
            "x": 210,
            "y": 360,
            "wires": [
                    "b38354741df477ec"
            "id": "b38354741df477ec",
            "type": "switch",
            "name": "",
            "property": "payload",
            "propertyType": "msg",
            "rules": [
                    "t": "gt",
                    "v": "21",
                    "vt": "num"
                    "t": "lt",
                    "v": "20",
                    "vt": "num"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 350,
            "y": 360,
            "wires": [
                    "4d70ce53cdeaaad7"
                    "a9732f51f5c0518a"
            "id": "7c3a2d2041b33ef3",
            "type": "ioBroker out",
            "name": "Drucker",
            "topic": "shelly.0.SHPLG-S#EA1400#1.Relay0.Switch",
            "ack": "false",
            "autoCreate": "false",
            "stateName": "",
            "role": "",
            "payloadType": "",
            "readonly": "",
            "stateUnit": "",
            "stateMin": "",
            "stateMax": "",
            "x": 1240,
            "y": 340,
            "wires": []
            "id": "4d70ce53cdeaaad7",
            "type": "change",
            "name": "Wert über 21",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "true",
                    "tot": "bool"
                    "t": "set",
                    "p": "autoOn",
                    "pt": "flow",
                    "to": "true",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 510,
            "y": 340,
            "wires": [
                    "e62718538ad9d35e"
            "id": "a9732f51f5c0518a",
            "type": "change",
            "name": "Wert unter 20",
            "rules": [
                    "t": "set",
                    "p": "payload",
                    "pt": "msg",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 520,
            "y": 400,
            "wires": [
                    "7ba9fff0b51b9494"
            "id": "8bc0ea77af86ae47",
            "type": "comment",
            "name": "Automation automatisches ausschalten",
            "info": "Wenn ein Gerät über eine Automation automatisch in Abhängigkeit von einem anderen Gerät ausgeschaltet wird, und ich es aber trotzdem manuell einschalten möchte,\nohne das es dann wieder ausgeht, muss ich eine Switch und eine Change Node einbauen, welche genauso konfiguriert wird wie hier in dieser Automation.",
            "x": 515,
            "y": 285,
            "wires": []
            "id": "7ba9fff0b51b9494",
            "type": "switch",
            "name": "",
            "property": "autoOn",
            "propertyType": "flow",
            "rules": [
                    "t": "true"
                    "t": "false"
            "checkall": "true",
            "repair": false,
            "outputs": 2,
            "x": 690,
            "y": 400,
            "wires": [
                    "86df369da9249b17"
                    "381fbe0cdbe80363"
            "id": "86df369da9249b17",
            "type": "change",
            "name": "",
            "rules": [
                    "t": "set",
                    "p": "autoOn",
                    "pt": "flow",
                    "to": "false",
                    "tot": "bool"
            "action": "",
            "property": "",
            "from": "",
            "to": "",
            "reg": false,
            "x": 870,
            "y": 380,
            "wires": [
                    "812603e742675fe0"
            "id": "409f140ec231cc22",
            "type": "comment",
            "name": "Notwendig um Gerät manuell einschalten",
            "info": "",
            "x": 560,
            "y": 460,
            "wires": []
            "id": "d512f4dc0b4e4fc4",
            "type": "debug",
            "name": "debug 42",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 1240,
            "y": 400,
            "wires": []
            "id": "e62718538ad9d35e",
            "type": "rbe",
            "name": "",
            "func": "rbe",
            "gap": "",
            "start": "",
            "inout": "out",
            "septopics": false,
            "topi": "topic",
            "x": 1090,
            "y": 340,
            "wires": [
                    "7c3a2d2041b33ef3",
                    "d512f4dc0b4e4fc4"
            "id": "381fbe0cdbe80363",
            "type": "ioBroker get",
            "name": "Drucker",
            "attrname": "payload",
            "errOnInvalidState": "nothing",
            "x": 880,
            "y": 420,
            "wires": [
                    "812603e742675fe0"
            "id": "812603e742675fe0",
            "type": "junction",
            "x": 1000,
            "y": 400,
            "wires": [
                    "e62718538ad9d35e"
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #2802
    @mickym Ja, das funktioniert😄
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      mickymM Offline
      mickymM Offline
      mickym
      #2803
      @damrak2022 Teste auch mal mit manuellen Ein und Ausschalten und dann wieder automatisch im Wechsel.
      • mickymM mickym
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #2804
        @mickym Okay, Moment, fahre den Mac wieder runter
        Mit besten Grüßen
        Andy
          mickymM Offline
          mickymM Offline
          mickym
          #2805
          Falls das nicht tut - eigentlich wäre ein iobroker-IN Node besser geeignet also die get Node - aber vielleicht gehts ja auch so. Es ist nur nicht ganz lehrbuchmäßig weil der Trigger der Verbrauch des iMac ist.
          • mickymM mickym
            Damrak2022D Offline
            Damrak2022D Offline
            Damrak2022
            #2806
            @mickym ein ich den Mac ausgeschaltet habe, kann ich den Shelly vom Drucker manuell einschalten und dann auch den Drucker. Dann habe ich den Drucker wieder ausgeschaltet, dabei bleibt natürlich der Shelly an. Wenn ich dann den Mac wieder einschalte geht der Drucker natürlich nicht an, da der Shelly ja schon an ist. Aber so ist das okay.
            Mit besten Grüßen
            Andy
              mickymM Offline
              mickymM Offline
              mickym
              #2807
              @damrak2022 Dann habe ich den Drucker wieder ausgeschaltet, dabei bleibt natürlich der Shelly an? Der Drucker hat nie getriggert. Wenn Du den Shelly des Druckers ausschaltest - dann sollte der Shelly auch ausgeschaltet bleiben.
              • mickymM mickym
                Damrak2022D Offline
                Damrak2022D Offline
                Damrak2022
                #2808
                @mickym Ja, das macht er auch,, deswegen finde ich das gut so wie es jetzt ist.
                Mit besten Grüßen
                Andy
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #2809
                  @mickym So, dann erkläre mal bitte
                  Mit besten Grüßen
                  Andy
                    mickymM Offline
                    mickymM Offline
                    mickym
                    #2810
                    @damrak2022 ??? - was soll ich erklären?
                    • mickymM mickym
                      Damrak2022D Offline
                      Damrak2022D Offline
                      Damrak2022
                      #2811
                      @mickym Na wie es jetzt weitergeht mit den Und / Oder Abfragen
                      Mit besten Grüßen
                      Andy
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #2812
                        @damrak2022 Wie sehen denn Deine Objekte bis jetzt aus? Und was sind denn das für JSON Nodes? Die brauchst Du nur um die Objekte in Datenpunkte zu schreiben? Da hängen aber debug Nodes dran?
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #2813
                          @mickym Die json nodes habe ich wieder entfernt. Die Debug Ausgabe sieht so aus, wenn ich z.B. Drucker und Wasserkocher mal über das Dashboard ausschalte:
                          Mit besten Grüßen
                          Andy
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #2814
                            @damrak2022 Gut und die anderen, die immer eingeschaltet sein sollen, die sind spuken noch gar nichts aus?
                            • mickymM mickym
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #2815
                              @mickym Naja, iMac kann ich ja nicht über das Dashboard schalten. Die zeigen sich erst, wenn sie geschaltet werden.
                              Mit besten Grüßen
                              Andy
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #2816
                                @damrak2022 Wieso das ist doch auch ein Shelly? Aber natürlich nicht, wenn Du gerade dran arbeitest. Gut - sind denn bei den anderen 3 Geräten die immer eingeschaltet sein sollen, Nachrichten rausgekommen?
                                mickymM Damrak2022D 2 Antworten Letzte Antwort
                                • mickymM mickym
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  #2817
                                  @mickym Was hast Du in der iobroker-In Node eingegeben, dass alle Nachrichten geschickt werden oder nur mit ACK Flag?
                                  • mickymM mickym
                                    Damrak2022D Offline
                                    Damrak2022D Offline
                                    Damrak2022
                                    #2818
                                    @mickym Bei FeFoTV und Kühlschrank - nein. Ich sehe gerade der Router fehlt noch in der Liste
                                    Mit besten Grüßen
                                    Andy
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #2819
                                      @damrak2022 Zeig nochmal die iobroker IN Node
                                      • mickymM mickym
                                        Damrak2022D Offline
                                        Damrak2022D Offline
                                        Damrak2022
                                        #2820
                                        Mit besten Grüßen
                                        Andy
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          #2821
                                          @damrak2022 Ok - dann müsstest Du aber die Switch Datenpunkte mit true selbst beschreiben und die sollten eine Nachricht erzeugen.
