  4. [Gelöst]zigbee funktioniert nicht mehr nach upd auf bullseye
zigbee
39 Beiträge 4 Kommentatoren 4.8k Aufrufe 3 Beobachtet
    @skinni
    sudo systemctl stop deconz deconz-gui
    sudo systemctl disable deconz deconz-gui
    skinni
    pi@iobroker:~ $ sudo systemctl stop deconz deconz-gui
    pi@iobroker:~ $ sudo systemctl disable deconz deconz-gui
    Removed /etc/systemd/system/multi-user.target.wants/deconz.service.
    pi@iobroker:~ $ systemctl status deconz-gui.service deconz.service
    ● deconz-gui.service - deCONZ: ZigBee gateway -- GUI/REST API
         Loaded: loaded (/lib/systemd/system/deconz-gui.service; disabled; vendor preset: enabled)
         Active: inactive (dead)
    Dec 14 22:09:02 iobroker systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
    Dec 14 22:09:08 iobroker systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
    Dec 14 22:09:29 iobroker systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
    Dec 14 22:09:35 iobroker systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
    Dec 14 22:18:45 iobroker systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
    Dec 14 22:19:23 iobroker systemd[1]: /lib/systemd/system/deconz-gui.service:11: Unknown key name 'StartLimitIntervalSec' in section 'Service', ignoring.
    ● deconz.service - deCONZ: ZigBee gateway -- REST API
         Loaded: loaded (/lib/systemd/system/deconz.service; disabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Wed 2022-12-14 22:09:02 CET; 10min ago
       Main PID: 22129 (code=exited, status=143)
            CPU: 1min 21.753s
    Dec 14 22:09:02 iobroker deCONZ[22129]: PROTO: CRC error
    Dec 14 22:09:02 iobroker systemd[1]: deconz.service: Main process exited, code=exited, status=143/n/a
    Dec 14 22:09:02 iobroker systemd[1]: deconz.service: Failed with result 'exit-code'.
    • S skinni
              CPU: 1min 21.753s
      Thomas BraunT Offline
      @skinni
      Stop den deconz-Adapter und starte den zigbee-Adapter neu.
      Log file währenddessen (in einem zweiten Terminal) anschauen:
      iobroker logs --watch
        @skinni
        skinni
        @thomas-braun said in zigbee funktioniert nicht mehr nach update auf bullseye:
        da kommt genau der Fehler :(
        2022-12-14 22:28:36.368  - info: host.iobroker "system.adapter.zigbee.0" disabled
        2022-12-14 22:28:36.370  - info: host.iobroker stopInstance system.adapter.zigbee.0 (force=false, process=true)
        2022-12-14 22:28:36.506  - info: zigbee.0 (1910) Got terminate signal TERMINATE_YOURSELF
        2022-12-14 22:28:36.507  - info: host.iobroker stopInstance system.adapter.zigbee.0 send kill signal
        2022-12-14 22:28:36.508  - info: zigbee.0 (1910) cleaned everything up...
        2022-12-14 22:28:36.512  - info: zigbee.0 (1910) Zigbee: disabling joining new devices.
        2022-12-14 22:28:37.010  - info: zigbee.0 (1910) terminating
        2022-12-14 22:28:37.012  - info: zigbee.0 (1910) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2022-12-14 22:28:37.511  - info: host.iobroker stopInstance system.adapter.zigbee.0 killing pid 1910
        2022-12-14 22:28:37.680  - info: host.iobroker instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        2022-12-14 22:29:06.384  - info: host.iobroker "system.adapter.zigbee.0" enabled
        2022-12-14 22:29:06.819  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 11765
        2022-12-14 22:29:12.610  - info: zigbee.0 (11765) starting. Version 1.8.9 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
        2022-12-14 22:29:12.834  - info: zigbee.0 (11765) delete old Backup files. keep only last 10
        2022-12-14 22:29:12.837  - info: zigbee.0 (11765) Starting Zigbee  npm ...
        2022-12-14 22:29:13.644  - info: zigbee.0 (11765) Installed Version: iobroker.zigbee@1.8.9
        2022-12-14 22:29:23.687  - error: zigbee.0 (11765) Starting zigbee-herdsman problem : undefined
        2022-12-14 22:29:23.689  - error: zigbee.0 (11765) Failed to start Zigbee
        2022-12-14 22:29:23.690  - error: zigbee.0 (11765) Error herdsman start
        2022-12-14 22:29:33.697  - info: zigbee.0 (11765) Try to reconnect. 1 attempts left
        2022-12-14 22:29:33.698  - info: zigbee.0 (11765) Starting Zigbee  npm ...
        2022-12-14 22:29:33.758  - info: zigbee.0 (11765) Installed Version: iobroker.zigbee@1.8.9
        2022-12-14 22:29:34.266  - error: zigbee.0 (11765) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
        2022-12-14 22:29:34.268  - error: zigbee.0 (11765) Failed to start Zigbee
        2022-12-14 22:29:34.269  - error: zigbee.0 (11765) Error herdsman start
        Ich hab deconz jetzt auch mit sudo apt purge deconz und sudo apt autoremove entfernt und der Fehler bleibt gleich
        • S skinni
          @skinni
          Starte den Rechner mal komplett durch.
            @skinni
            skinni
            @thomas-braun Danke schonmal für die Hilfe, ich hau mich für heute aufs Ohr und schau morgen Abend wieder rein.
            Rechner wurde neu gestartet.
            Unit deconz-gui.service could not be found.
            Unit deconz.service could not be found.
            Fehler bleibt gleich :/
            2022-12-14 22:39:35.231  - info: host.iobroker "system.adapter.zigbee.0" enabled
            2022-12-14 22:39:35.547  - info: host.iobroker instance system.adapter.zigbee.0 started with pid 5495
            2022-12-14 22:39:36.088  - info: alexa2.0 (2122) Initialization Done ...
            2022-12-14 22:39:42.637  - info: zigbee.0 (5495) starting. Version 1.8.9 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
            2022-12-14 22:39:42.852  - info: zigbee.0 (5495) delete old Backup files. keep only last 10
            2022-12-14 22:39:42.858  - info: zigbee.0 (5495) Starting Zigbee  npm ...
            2022-12-14 22:39:44.084  - info: zigbee.0 (5495) Installed Version: iobroker.zigbee@1.8.9
            2022-12-14 22:39:54.140  - error: zigbee.0 (5495) Starting zigbee-herdsman problem : undefined
            2022-12-14 22:39:54.141  - error: zigbee.0 (5495) Failed to start Zigbee
            2022-12-14 22:39:54.143  - error: zigbee.0 (5495) Error herdsman start
            2022-12-14 22:39:56.033  - info: fb-checkpresence.0 (3225) createFbDeviceObjects finished successfully
            2022-12-14 22:39:56.035  - info: fb-checkpresence.0 (3225) states successfully subscribed
            2022-12-14 22:39:56.037  - info: fb-checkpresence.0 (3225) loop successfully started
            2022-12-14 22:40:04.150  - info: zigbee.0 (5495) Try to reconnect. 1 attempts left
            2022-12-14 22:40:04.153  - info: zigbee.0 (5495) Starting Zigbee  npm ...
            2022-12-14 22:40:04.190  - info: zigbee.0 (5495) Installed Version: iobroker.zigbee@1.8.9
            2022-12-14 22:40:04.620  - error: zigbee.0 (5495) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
            2022-12-14 22:40:04.622  - error: zigbee.0 (5495) Failed to start Zigbee
            2022-12-14 22:40:04.623  - error: zigbee.0 (5495) Error herdsman start
            ESP8266E 1 Antwort Letzte Antwort
            • S skinni
              Systemdata Bitte Ausfüllen
              Hardwaresystem: raspi 4
              Arbeitsspeicher: 4GB
              Festplattenart: SD-Karte
              Betriebssystem: raspbian
              Node-Version: 16.18.1
              Nodejs-Version: v16.18.1
              NPM-Version: v16.18.1
              Installationsart: Skript
              Image genutzt: Ja
              Ort/Name der Imagedatei: pivccu
              Ich weiß nicht ob ihr mir helfen könnt, aber einen Versuch ist es Wert: Wie in einem anderen Thread bemerkt wurde, hatte ich noch buster laufen und mein System auf bullseye aktualisiert. Vorher SD-Karte geklont.
              Nach dem Update funktioniert zigbee nicht mehr. Weder mit deconz/phoscon noch mit dem zigbee Adapter. Stick ist ein Conbee II am normalen USB 2 Port. Ich habe schon alles mögliche Versucht, firmware Updates etc. Hatte mich zuerst auf deconz konzentriert und erst später bemerkt, dass der zigbee Adapter auch nicht mehr funktioniert.
              Als Gegenprobe hab ich den Klon der SD-Karte zurückgespielt und damit läuft wieder alles einwandfrei, sowohl deconz als auch der iobroker Zigbee Adapter (wenn ich vorher den deconz Dienst stoppe).
              Update auf bullseye und zigbee ist wieder kaputt. Unter deconz kann ich keine neuen Geräte anlernen und vorhandene werden nicht mehr aktualisiert. Als COM Port habe ich /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2421437-if00
              Der zigbee Adapter bleibt gelb und liefert nur einen (mir) nichtssagenden Fehler:
              2022-12-14 20:56:20.157  - info: zigbee.0 (28200) starting. Version 1.8.9 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.1, js-controller: 4.0.23
              2022-12-14 20:56:20.345  - info: zigbee.0 (28200) delete old Backup files. keep only last 10
              2022-12-14 20:56:20.348  - info: zigbee.0 (28200) Starting Zigbee  npm ...
              2022-12-14 20:56:21.321  - info: zigbee.0 (28200) Installed Version: iobroker.zigbee@1.8.9
              2022-12-14 20:56:31.354  - error: zigbee.0 (28200) Starting zigbee-herdsman problem : undefined
              2022-12-14 20:56:31.355  - error: zigbee.0 (28200) Failed to start Zigbee
              2022-12-14 20:56:31.356  - error: zigbee.0 (28200) Error herdsman start
              2022-12-14 20:56:41.362  - info: zigbee.0 (28200) Try to reconnect. 1 attempts left
              2022-12-14 20:56:41.363  - info: zigbee.0 (28200) Starting Zigbee  npm ...
              2022-12-14 20:56:41.428  - info: zigbee.0 (28200) Installed Version: iobroker.zigbee@1.8.9
              2022-12-14 20:56:41.815  - error: zigbee.0 (28200) Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'"
              2022-12-14 20:56:41.817  - error: zigbee.0 (28200) Failed to start Zigbee
              2022-12-14 20:56:41.818  - error: zigbee.0 (28200) Error herdsman start
              pi@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
              uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              armv7l
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.1
              v16.18.1
              8.19.2
              4.0.23
              pi
              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
              tty
              /home/pi
              Hit:1 http://phoscon.de/apt/deconz bullseye InRelease
              Hit:2 https://repos.influxdata.com/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:6 https://www.pivccu.de/piVCCU stable InRelease
              Reading package lists... Done
              All packages are up to date.
              nodejs:
                Installed: 16.18.1-deb-1nodesource1
                Candidate: 16.18.1-deb-1nodesource1
                Version table:
               *** 16.18.1-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                   12.22.12~dfsg-1~deb11u1 500
              pi@iobroker:~ $ ls -l /dev/serial/by-id
              total 0
              lrwxrwxrwx 1 root root 13 Dec 14 21:22 usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2421437-if00 -> ../../ttyACM0
              pi@iobroker:~ $ lsusb
              Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
              Bus 001 Device 019: ID 1cf1:0030 Dresden Elektronik ZigBee gateway [ConBee II]
              Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
              pi@iobroker:~ $ ls -l /dev/ttyACM*
              crw-rw---- 1 root dialout 166, 0 Dec 14 17:15 /dev/ttyACM0
              pi@iobroker:~ $ sudo systemctl status deconz
                   Loaded: loaded (/lib/systemd/system/deconz.service; enabled; vendor preset: enabled)
                   Active: active (running) since Wed 2022-12-14 21:01:32 CET; 40min ago
                 Main PID: 22129 (deCONZ)
                    Tasks: 5 (limit: 4915)
                      CPU: 48.664s
                   CGroup: /system.slice/deconz.service
                           └─22129 /usr/bin/deCONZ -platform minimal --http-port=80
              Dec 14 21:01:32 iobroker systemd[1]: Started deCONZ: ZigBee gateway -- REST API.
              Dec 14 21:01:32 iobroker deCONZ[22129]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-pi'
              Dec 14 21:01:32 iobroker deCONZ[22129]: libpng warning: iCCP: known incorrect sRGB profile
              Dec 14 21:01:34 iobroker deCONZ[22129]: This plugin does not support propagateSizeHints()
              Dec 14 21:01:41 iobroker deCONZ[22129]: This plugin does not support propagateSizeHints()
              Dec 14 21:22:21 iobroker deCONZ[22129]: This plugin does not support propagateSizeHints()
              Dec 14 21:22:38 iobroker deCONZ[22129]: This plugin does not support propagateSizeHints()
              Ich hab auch im phoscon forum einen Thread geöffnet, als ich noch dachte es wäre ein reines deconz Problem, aber da ich jetzt weiß, dass der Zigbee Adapter auch nicht funktioniert scheint das ja irgendwas Grundlegendes zu sein was da nach dem Update klemmt. Vielleicht hat ja jemand von euch eine Idee was ich noch machen kann, meine linux Kenntnisse haben enormes Wachstumspotential :)
              ESP8266E Offline
              ESP8266E Offline
              ESP8266
              schrieb am zuletzt editiert von ESP8266
              @skinni sagte in zigbee funktioniert nicht mehr nach update auf bullseye:
              Node-Version:
              10.x.x
              Nodejs-Version:
              v16.18.1
              NPM-Version:
              v16.18.1
              ....was mir gleich aufällt.
              ....zu meinem Vergleich:
              Node version
              16.18.1
              Node.js version
              16.18.1
              NPM version
              8.19.2
              Ok, die Einträge sind falsch.
              Hier sind sie wohl richtig:
              • S skinni
                ESP8266E Offline
                ESP8266E Offline
                ESP8266
                @skinni , irgendwie kommt mir das hier bekannt vor. Der Pi 4 findet die seriellen Schnittstellen nicht mehr. Das hatte ich auch nach dem upgraden von Buster auf Bullseye. Das hat wohl was mit einem Kernelupdate zu tun. Da ich noch ebusd nutze kann ich das beim booten beobachten, ob die Schnittstellen auch da sind (blinkende rote LED am EBUS). Dann wird auch ebusd gestartet. Bei mir betraf es Maxcul, Zigbee und ebusd.
                Ich nutze nur keine SD-Karte sondern eine SSD.
                Was habe ich dann gemacht: Den Boot Vorgang abgebrochen mit iob stop. System runtergefahren, SSD ab gestöpselt, Pi ohne SSD gestartet und 15 sec laufen lassen. Pi ausgeschaltet. SSD dran und dann hat es meistens nach dem einschalten geklappt. Aber es schlichen sich nach einiger Zeit Fehler ein. Pishrink, Pardet und einiges mehr gingen nicht mehr. Da der Bug im Kodi Adapter erst vor ein paar Tagen entfernt wurde, konnte ich endlich nach über ein Jahr das System neu aufsetzen mit einem neuen PI-OS (bullseye)und mit Backitup ein Restore ausführen. Seitdem ist Ruhe. Kann sein das es nochmal vorkommt, aber bis Dato nicht.
                Nach einen Reboot werden alle Schnittstellen jetzt gefunden.
                • ESP8266E ESP8266
                  skinni
                  @esp8266 Was halt merkwürdig ist, ich konnte z.B. ein Firmware Update des Conbee II machen und in Phoscon wird er auch angezeigt.
                  • S skinni
                    ESP8266E Offline
                    ESP8266E Offline
                    ESP8266
                    @skinni , es war halt ein Vorschlag. Ich kenne kein Phoscon....
                    Ich persönlich würde nicht lange rum fackeln und komplett neu Aufsetzen.
                    Wo liegt das Problem...nach spätestens, je nach installieren Adaptern, dauert sowas 1 - 2 Std und je nach Kenntniss sogar noch schneller.
                    Bei mir war das nicht möglich, wegen den Bug im Kodi Adapter. Ich musste zwingenst bei der alten Kodi Version bleiben....also kein Restore über Backitup möglich. Der hätte die neuste installiert. Also wie geschrieben, deine Sache was du machst. Das war eine Erfahrung die ich gemacht habe und meine Meinung.
                      skinni
                      schrieb am zuletzt editiert von skinni
                      Ich versuch grad alles neu aufzusetzen. Das pivccu image gibts nicht mehr, das iobroker image hat Probleme gemacht weil Admin nicht erreichbar war. Jetzt hab ich alles von Hand angefangen und komm nicht an mein Backup auf NAS...
                      /€ Nach nem reboot kann ich die Backups laden.
                      /€ Jetzt war zigbee vollkommen hinüber. Hatte alles neu aufgesetzt, lief auch ein paar Minuten und konnte neue Gerät verbinden, dann ging nix mehr. Stick wird erkannt, Adapter ist grün aber es findet keine Kommunikation mehr statt. Auch mit dem alten image sieht alles grün aus, keine Fehlermeldungen, aber es wird nix neues mehr angelernt. Hab dann noch 2 mal den pi neu gemacht, auch ohne iobroker Backup einzuspielen gleiches Verhalten. Ich vermute mal der Stick hat einfach nen Problem und es war blöder Zufall mit dem Update. Oder es gibt nen kausalen Zusammenhang den ich nicht verstehe, aber der Stick ist so nicht mehr zu gebrauchen.
                      /€ heute hab ich mal deconz auf nem windows Rechner installiert und ins Debug log geschaut. Da stand Fehlermeldungen dass ein Wert falsch ist. Hab den korrigiert und jetzt kann ich wieder Geräte verbinden. Muss jetzt nur wieder auf bullseye umsteigen und weitertesten. Dachte schon der wäre hinüber...
                        skinni
                        Jetzt war ich gerade mit allem fertig da ist plötzlich im Zigbee Adapter alles leer gewesen. Hab den Com Port wieder eingestellt und die Gerät sind aufgetaucht, aber PAN ID, erweiterete PAN ID und Transportschlüssel sind leer... Jetzt muss ich wieder von vorne anfangen. Backup zurückspielen von influxdb und zigbee geht auch nicht. Da ist doch echt der Wurm drin.
                        /€ zigbee backup musste ich erst lokal rüberkopieren, dann durfte ich es installieren. Per cifs war immer root/root eingetragen. Bis auf einen Sensor hab ich jetzt alles wieder drin, der eine will leider nicht. Influxdb geht auch wieder. Ich fass jetzt nix mehr an und will die nächsten Wochen nix mehr damit zu tun haben :)
                        Die Lösung war also vermutlich ein falsches Setting im Conbee II was ich erst im Debug Log vom deconz-gui über Windows gesehen haben...
                        • S skinni
                          Dann ist dein Backitup-Adapter nicht richtig eingestellt. Oder die Freigaben. Üblicherweise geht das natürlich auch über ein gemountetes Dateisystem.
                            ESP8266E Offline
                            ESP8266E Offline
                            ESP8266
                            @thomas-braun , genauso ist es.
                            @skinni , man muss natürlich nach einer neu Installation zuerst das NAS einrichten und die Pfadangabe machen. Ich nutze NFS. Woher soll das Backitup nach dem ersten Start wissen?
                            Vor der IOB Installation hänge ich mein NAS via autofs ein.
                              skinni
                              NAS war natürlich verbunden, aber die files lagen da mit root Berechtigungen und nicht iobroker, das gab dann Zugriffsverletzungen beim Zurückspielen. Hab auch etliche Threads dazu gefunden, aber nie ne Lösung.
                              Da ich auf dem gemounteten Verzeichnis die Berechtigungen nicht ändern konnte hab ichs halt rüberkopiert und dann angepasst
                              ESP8266E Thomas BraunT 4 Antworten Letzte Antwort
                              • S skinni
                                ESP8266E Offline
                                ESP8266E Offline
                                ESP8266
                                @skinni also machst du was falsch. Ich hatte noch nie Zugriffsverletzungen.
                                • S skinni
                                  ESP8266E Offline
                                  ESP8266E Offline
                                  ESP8266
                                  Das erkläre mal genauer!
                                  Für mich ist logisch das im Backup auf dem Nas nicht IOB ist.
                                  Aber IOB greift aufs NAS zu....auf die Backupfiles
                                    skinni
                                    @esp8266
                                    Wenn ich das richtig verstanden habe, werden die files vom backitup Adapter nach /opt/iobroker/backups gemounted, allerdings ist dann root der Eigentümer und es gibt beim Zurücksichern eine Fehlermeldung.
                                    Mit sudo chown iobroker:iobroker /opt/iobroker/backups/* konnte ich die Berechtigungen so setzen, dass ich zurücksichern darf. Allerdings nur, wenn ich das Verzeichnis vorher nicht gemountet habe sondern die Dateien tatsächlich dorthin kopiert habe.
                                    Hoffe das war verständlich.
                                    Im Adapter selbst kann man dahingehend ja nicht viel einstellen, noserverino oder nicht macht auch keinen Unterschied.
                                    /€ hier war das gleiche Problem: https://213.136.68.177/topic/42424/wie-gelöschten-zigbee-adapter-wieder-herstellen/45
                                    • S skinni
                                      @esp8266
                                      Durch die mount-Optionen
                                      file_mode=0777,dir_mode=0777
                                      darf das keine Rolle spielen. Da darf dann Hinz und Kunz alles, egal welchem user oder group die Datei gehört.
                                        skinni
                                        @thomas-braun Wie gesagt, ich hab nicht so viel Ahnung davon, ich kann nur sagen wie es sich verhält, nicht wieso. Gemountet gings nicht, ich hab die Datei rüberkopiert und es ging nicht, nach chown gings.
                                        /€ das war übrigens auch meine Lösung bei der influx db
                                        • S skinni
                                          @skinni
                                          Ich würde behaupten, dein System ist schräg.
