  4. Node-Red
  5. contrib tts lässt sich nicht installieren
    6.5k
36 Beiträge 3 Kommentatoren 3.3k Aufrufe 3 Beobachtet
  • S Saranger
    anbei mal die Meldung noch im IObroker Log nach dem Versuch diese node zu installieren und das crashen von nodered
    FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory
    2022-12-12 14:58:41.183 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red]
    2022-12-12 14:58:41.183 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red]
    2022-12-12 14:58:41.184 - warn: node-red.0 (2527) 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red]
    2022-12-12 14:58:41.185 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
    2022-12-12 14:58:41.185 - warn: node-red.0 (2527) 5: 0xe99875 [node-red]
    2022-12-12 14:58:41.186 - warn: node-red.0 (2527) 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red]
    2022-12-12 14:58:41.187 - warn: node-red.0 (2527) 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red]
    2022-12-12 14:58:41.187 - warn: node-red.0 (2527) 8: 0xe6d4b2 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red]
    2022-12-12 14:58:41.188 - warn: node-red.0 (2527) 9: 0xe65ac4 v8::internal::FactoryBase::AllocateRawWithImmortalMap(int, v8::internal::AllocationType, v8::internal::Map, v8::internal::AllocationAlignment) [node-red]
    2022-12-12 14:58:41.189 - warn: node-red.0 (2527) 10: 0xe67d22 v8::internal::FactoryBase::NewDescriptorArray(int, int, v8::internal::AllocationType) [node-red]
    2022-12-12 14:58:41.189 - warn: node-red.0 (2527) 11: 0x10b5d77 v8::internal::DescriptorArray::CopyUpTo(v8::internal::Isolate*, v8::internal::Handle, int, int) [node-red]
    2022-12-12 14:58:41.191 - warn: node-red.0 (2527) 12: 0x10a3eb1 v8::internal::Map::CopyAddDescriptor(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Descriptor*, v8::internal::TransitionFlag) [node-red]
    13: 0x10a446c v8::internal::Map::CopyWithField(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::Representation, v8::internal::TransitionFlag) [node-red]
    2022-12-12 14:58:41.192 - warn: node-red.0 (2527) 14: 0x10a6298 v8::internal::Map::TransitionToDataProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::PropertyConstness, v8::internal::StoreOrigin) [node-red]
    2022-12-12 14:58:41.192 - warn: node-red.0 (2527) 15: 0x1094df2 v8::internal::LookupIterator::PrepareTransitionToDataProperty(v8::internal::Handle, v8::internal::Handle, v8::internal::PropertyAttributes, v8::internal::StoreOrigin) [node-red]
    2022-12-12 14:58:41.193 - warn: node-red.0 (2527) 16: 0x10b827a v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::PropertyAttributes, v8::Maybe, v8::internal::StoreOrigin) [node-red]
    2022-12-12 14:58:41.194 - warn: node-red.0 (2527) 17: 0x10bc7a3 v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
    2022-12-12 14:58:41.195 - warn: node-red.0 (2527) 18: 0x11efce6 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
    2022-12-12 14:58:41.195 - warn: node-red.0 (2527) 19: 0x11f1269 v8::internal::Runtime_SetKeyedProperty(int, unsigned long*, v8::internal::Isolate*) [node-red]
    2022-12-12 14:58:41.196 - warn: node-red.0 (2527) 20: 0x15da159 [node-red]
    2022-12-12 14:58:41.208 - info: node-red.0 (2527) node-red exited with null
    2022-12-12 14:58:46.208 - info: node-red.0 (2527) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2022-12-12 14:58:49.542 - warn: node-red.0 (2527) 12 Dec 14:58:49 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2022-12-12 14:58:50.138 - warn: node-red.0 (2527)
    <--- Last few GCs --->
    [4805:0x5fcdf70] 3865 ms: Mark-sweep (reduce) 125.1 (131.4) -> 124.1 (131.4) MB, 50.5 / 0.0 ms (average mu = 0.147, current mu = 0.057) allocation failure scavenge might not succeed
    [4805:0x5fcdf70] 3916 ms: Mark-sweep (reduce) 125.2 (131.4) -> 124.3 (131.7) MB, 47.6 / 0.0 ms (average mu = 0.105, current mu = 0.061) allocation failure scavenge might not succeed
    <--- JS stacktrace --->
    2022-12-12 14:58:50.138 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red]
    2022-12-12 14:58:50.139 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red]
    2022-12-12 14:58:50.140 - warn: node-red.0 (2527) 3: 0xce1e60 v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red]
    2022-12-12 14:58:50.141 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
    2022-12-12 14:58:50.142 - warn: node-red.0 (2527) 5: 0xe99875 [node-red]
    2022-12-12 14:58:50.143 - warn: node-red.0 (2527) 6: 0xea953d v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red]
    2022-12-12 14:58:50.145 - warn: node-red.0 (2527) 7: 0xeac23e v8::internal::Heap::AllocateRawWithRetryOrFailSlowPath(int, v8::internal::AllocationType, v8::internal::AllocationOrigin, v8::internal::AllocationAlignment) [node-red]
    2022-12-12 14:58:50.146 - warn: node-red.0 (2527) 8: 0xe6d4b2 v8::internal::Factory::AllocateRaw(int, v8::internal::AllocationType, v8::internal::AllocationAlignment) [node-red]
    2022-12-12 14:58:50.147 - warn: node-red.0 (2527) 9: 0xe67dcc v8::internal::FactoryBase::AllocateRawArray(int, v8::internal::AllocationType) [node-red]
    2022-12-12 14:58:50.148 - warn: node-red.0 (2527) 10: 0xe67ea5 v8::internal::FactoryBase::NewFixedArrayWithFiller(v8::internal::Handle, int, v8::internal::Handle, v8::internal::AllocationType) [node-red]
    2022-12-12 14:58:50.149 - warn: node-red.0 (2527) 11: 0x1016382 [node-red]
    2022-12-12 14:58:50.150 - warn: node-red.0 (2527) 12: 0x101650c [node-red]
    2022-12-12 14:58:50.151 - warn: node-red.0 (2527) 13: 0x1016668 [node-red]
    2022-12-12 14:58:50.151 - warn: node-red.0 (2527) 14: 0x10744b5 v8::internal::JSObject::AddDataElement(v8::internal::Handle, unsigned int, v8::internal::Handle, v8::internal::PropertyAttributes) [node-red]
    2022-12-12 14:58:50.152 - warn: node-red.0 (2527) 15: 0x10b820e v8::internal::Object::AddDataProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::PropertyAttributes, v8::Maybe, v8::internal::StoreOrigin) [node-red]
    2022-12-12 14:58:50.153 - warn: node-red.0 (2527) 16: 0x10bc7a3 v8::internal::Object::SetProperty(v8::internal::LookupIterator*, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
    2022-12-12 14:58:50.154 - warn: node-red.0 (2527) 17: 0x11efce6 v8::internal::Runtime::SetObjectProperty(v8::internal::Isolate*, v8::internal::Handle, v8::internal::Handle, v8::internal::Handle, v8::internal::StoreOrigin, v8::Maybe) [node-red]
    2022-12-12 14:58:50.154 - warn: node-red.0 (2527) 18: 0x11f1269 v8::internal::Runtime_SetKeyedProperty(int, unsigned long*, v8::internal::Isolate*) [node-red]
    2022-12-12 14:58:50.155 - warn: node-red.0 (2527) 19: 0x15da159 [node-red]
    2022-12-12 14:58:50.168 - info: node-red.0 (2527) node-red exited with null
    2022-12-12 14:58:55.168 - info: node-red.0 (2527) Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
    2022-12-12 14:58:58.450 - warn: node-red.0 (2527) 12 Dec 14:58:58 - [warn] Projects disabled : editorTheme.projects.enabled=false
    2022-12-12 14:58:58.949 - warn: node-red.0 (2527)
    [4827:0x6ac1f70] 3718 ms: Mark-sweep 125.1 (133.9) -> 123.5 (134.4) MB, 44.0 / 0.0 ms (average mu = 0.240, current mu = 0.109) allocation failure scavenge might not succeed
    [4827:0x6ac1f70] 3767 ms: Mark-sweep 125.6 (134.4) -> 124.0 (134.9) MB, 43.5 / 0.0 ms (average mu = 0.177, current mu = 0.105) allocation failure scavenge might not succeed
    2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 1: 0xb06730 node::Abort() [node-red]
    2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 2: 0xa1b6d0 [node-red]
    2022-12-12 14:58:58.951 - warn: node-red.0 (2527) 4: 0xce2207 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
    2022-12-12 14:58:58.955 - warn: node-red.0 (2527) 5: 0xe99875 [node-red]
    8: 0xe6d77a v8::internal::Factory::NewFillerObject(int, bool, v8::internal::AllocationType, v8::internal::AllocationOrigin) [node-red]
    9: 0x11e64e6 v8::internal::Runtime_AllocateInYoungGeneration(int, unsigned long*, v8::internal::Isolate*) [node-red]
    10: 0x15da159 [node-red]
    2022-12-12 14:58:58.968 - info: node-red.0 (2527) node-red exited with null
    2022-12-12 14:59:00.775 - error: rpi2.0 (2689) Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
    /dev/loop0 16337788 3655048 11827496 24% /
    /1024
    2022-12-12 14:59:00.776 - error: rpi2.0 (2689) Cannot evaluate: Filesystem 1K-blocks Used Available Use% Mounted on
    mickymM Offline
    mickymM Offline
    mickym
    @saranger hast du mal den speicherbedarf im Node-red Adapter erhöht?
    • mickymM mickym
      Saranger
      @mickym nein du meinst den ram wenn ich im iobroker auf den noderedadapter gehe? Wieviel sollte man da geben?
      Thomas BraunT mickymM 2 Antworten Letzte Antwort
      • S Saranger
        @saranger
        Wie bist du denn da eigentlich insgesamt unterwegs?
        free -ht
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
        • S Saranger
          mickymM Offline
          mickymM Offline
          mickym
          @saranger ich glaub Standard ist 128. ich hab 2048 weil ich viele flows habe, aber kannst ja mal mit 512 oder 1024 Testen.
            Saranger
            @thomas-braun said in contrib tts lässt sich nicht installieren:
            saranger@ioBroker:~$ free -ht
            Mem:           4.0Gi       1.3Gi       2.4Gi       0.0Ki       293Mi       2.7Gi
            Swap:          512Mi          0B       512Mi
            Total:         4.5Gi       1.3Gi       2.9Gi
            saranger@ioBroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            [sudo] password for saranger:
            Sorry, try again.
            saranger@ioBroker:~$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            x86_64
            Kein Docker
            /usr/bin/nodejs
            /usr/bin/node
            /usr/bin/npm
            v16.18.1
            v16.18.1
            8.19.2
            4.0.23
            saranger
            saranger sudo iobroker
            /home/saranger
            Hit:1 https://deb.nodesource.com/node_16.x jammy InRelease
            Hit:2 http://archive.ubuntu.com/ubuntu jammy InRelease
            Get:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
            Get:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
            Fetched 224 kB in 1s (228 kB/s)
            Reading package lists... Done
            All packages are up to date.
            nodejs:
              Installed: 16.18.1-deb-1nodesource1
              Candidate: 16.18.1-deb-1nodesource1
              Version table:
             *** 16.18.1-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x jammy/main amd64 Packages
                 12.22.9~dfsg-1ubuntu3 500
                    500 http://archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
            • S Saranger
              Sorry, try again.
              x86_64
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.1
              v16.18.1
              8.19.2
              4.0.23
              saranger
              /home/saranger
              nodejs:
                Version table:
              Saranger
              @mickym werd ich mal testen, ich muss dazu sagen das Ganze läuft auf Proxmox und ich habe seit dem auch immer probleme beim Deploy, teilweise muss ich 4 mal darauf klicken bis es funktioniert.
              • S Saranger
                mickymM Offline
                mickymM Offline
                mickym
                @saranger na dann wird es Zeit, bei 128k, ist das ein Zeichen, dass der Speicher knapp ist und da immer rumgeswapt wird. Ich würde mal 1024 nehmen und wie gesagt ich habe 2048.
                Das heißt nicht dass soviel gebraucht wird, aber der Speicher für Node-Red wird halt nicht so schnell limitiert.
                • mickymM mickym
                  Saranger
                  @mickym und das war die Lösung des Problems hab es auf 1024 gestellt und jetzt lies sich die Node installieren. Verrückt
                  mickymM Thomas BraunT 2 Antworten Letzte Antwort
                  • S Saranger
                    mickymM Offline
                    mickymM Offline
                    mickym
                    @saranger na nicht verrückt, wenn du das log mit dem Crash eher gepostet hättest, dann wäre man da vielleicht schon früher drauf gekommen. Das arme #node-Red 😁
                    • S Saranger
                      @saranger
                      Soweit so klar.
                        @saranger
                        Soweit so klar.
                        Saranger
                        also war hier das einzige Problem nur der zu kleine Ram für nodered? Aber vielen Dank für die Hilfe und den Wink mit dem User.
                        • S Saranger
                          @saranger
                          Falscher user und zuwenig aollokierter Arbeitsspeicher.
                          • S Saranger
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @saranger na ob die package-lock.json noch ein Problem war, weiß ich nicht. Das Hauptproblem war aber sicher der fehlende Speicher. Das Deployen sollte nun auch flüssiger laufen. Über den Palletten- Manager wird wahrscheinlich mit dem user iobroker installiert. Allerdings sollte man selbst halt nie mit Root hantieren. Ich hoffe Du hast Dir mit dem npm install nichts zerschossen- aber das habe ich nicht gesehen, dass du da mit Root rumhantierst.
                            • mickymM mickym
                              Saranger
                              @mickym also aktuell läuft soweit erstmal alles, ich werde das mal beobachten und jetzt mal die node testen, das wird auch spannend.
