  4. FritzDect funktioniert nach FRITZupdate nicht mehr: GELOEST!
    5.6k
35 Beiträge 5 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • Fred FreundF Fred Freund
    host.iobroker1
    	2022-12-12 14:08:40.263	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:08:40.262	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:08:39.928	info	instance system.adapter.fritzdect.0 started with pid 28903
    host.iobroker1
    	2022-12-12 14:08:09.786	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:08:09.786	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:08:09.454	info	instance system.adapter.fritzdect.0 started with pid 28845
    host.iobroker1
    	2022-12-12 14:08:09.280	info	"system.adapter.fritzdect.0" enabled
    host.iobroker1
    	2022-12-12 14:08:06.329	info	"system.adapter.fritzdect.0" disabled
    host.iobroker1
    	2022-12-12 14:08:03.010	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:08:03.010	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:08:02.712	info	instance system.adapter.fritzdect.0 started with pid 28838
    host.iobroker1
    	2022-12-12 14:07:32.557	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:07:32.556	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:07:32.175	info	instance system.adapter.fritzdect.0 started with pid 28780
    host.iobroker1
    	2022-12-12 14:07:02.062	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:07:02.061	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:07:01.774	info	instance system.adapter.fritzdect.0 started with pid 28773
    host.iobroker1
    	2022-12-12 14:06:31.628	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:06:31.627	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:06:31.259	info	instance system.adapter.fritzdect.0 started with pid 28715
    host.iobroker1
    	2022-12-12 14:06:01.081	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:06:01.081	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:06:00.735	info	instance system.adapter.fritzdect.0 started with pid 28706
    host.iobroker1
    	2022-12-12 14:05:30.605	info	Restart adapter system.adapter.fritzdect.0 because enabled
    host.iobroker1
    	2022-12-12 14:05:30.605	info	instance system.adapter.fritzdect.0 terminated with code 0 (NO_ERROR)
    host.iobroker1
    	2022-12-12 14:05:30.223	info	instance system.adapter.fritzdect.0 started with pid 28648
    haselchenH Offline
    haselchenH Offline
    haselchen
    @fred-freund
    Der Screenshot ist verwirrend, zeig mal die Einstellungen im Adapter.
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      host.iobroker1
      @fred-freund
      github:	2.3.0
      latest:	2.2.6 for 82 days
      stable:	2.2.6 for 82 days
      Da herrscht offenbar akuter Update-Stau.
      Zuerst OS auf Stand bringen, dann nodejs auf v16, anschließend den iobroker.
      Fred FreundF 1 Antwort Letzte Antwort
        @fred-freund
        github:	2.3.0
        Fred FreundF Offline
        Fred Freund
        @thomas-braun Danke werd ich machen....
        many Thx for your support,
        Vielen Dank!
          Fred Freund
          schrieb am zuletzt editiert von Fred Freund
          @fred-freund Auch nach dem update geht der Adapter nicht..
          Adapter geloescht , neu installiert .....leider nein
          Vielen Dank!
            @fred-freund
            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            sagt?
            Fred FreundF 2 Antworten Letzte Antwort
              @fred-freund
              sagt?
              Fred Freund
              @thomas-braun sorry habe keinen docker
              Vielen Dank!
                @fred-freund
                Du sollst die beiden Zeilen in deine Konsole hauen. Hat mit Docker oder Nicht-Docker nix zu tun.
                  @fred-freund
                  Fred Freund
                  @thomas-braun sorry versteh die Zeilen nicht...
                  Vielen Dank!
                  Thomas BraunT CodierknechtC 2 Antworten Letzte Antwort
                    @fred-freund
                    Musst du ja auch nicht.
                    Hilft aber zu sehen wie du da insgesamt unterwegs bist.
                      @fred-freund
                      Fred Freund
                      @thomas-braun Mir waere lieber der Dect wuerde gehen. Aber denke hat mit dem Fritzbox update zu tun.
                      Vielen Dank!
                        @fred-freund
                        Du bist echt ein schwieriger Patient...
                        Dann frickel da alleine weiter.
                          @fred-freund
                          Fred Freund
                          @thomas-braun geb dir recht
                          Vielen Dank!
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @fred-freund
                            Bei "uns" anderen geht der Adapter trotz Update ja auch weiterhin.
                            Du hast immer noch nicht deine Einstellungen gepostet.
                              CodierknechtC Online
                              Codierknecht
                              @fred-freund sagte in FritzDect funktioniert nach FRITZupdate nicht mehr:
                              Brauchst Du jetzt Hilfe oder willst Du diskutieren?
                              HmIP|ZigBee|Tasmota|Unifi
                              Zabbix Certified Specialist
                              • CodierknechtC Codierknecht
                                Fred Freund
                                @codierknecht habt ihr den user in der Fritzbox nur mit SmartHome Rechten?
                                Vielen Dank!
                                  @fred-freund
                                  sagt?
                                  Fred Freund
                                  @thomas-braun Hi, konnte das jetzt mal ausprobieren war nur mit Tablet unterwegs & copy paste ging da nicht so gut..
                                  armv7l
                                  Kein Docker
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  v16.18.1
                                  v16.18.1
                                  8.19.2
                                  4.0.23
                                  pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                                  tty
                                  /home/pi
                                  Hit:1 http://archive.raspberrypi.org/debian buster InRelease
                                  Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
                                  Hit:3 https://repos.influxdata.com/debian buster InRelease
                                  Hit:4 https://deb.nodesource.com/node_16.x buster InRelease
                                  Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                                  Reading package lists... Done
                                  Building dependency tree
                                  All packages are up to date.
                                  nodejs:
                                    Installed: 16.18.1-deb-1nodesource1
                                    Candidate: 16.18.1-deb-1nodesource1
                                    Version table:
                                   *** 16.18.1-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                                       10.24.0~dfsg-1~deb10u2 500
                                  config der Instanz schaut so aus:
                                  Vielen Dank!
                                    armv7l
                                    Kein Docker
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.18.1
                                    v16.18.1
                                    8.19.2
                                    4.0.23
                                    pi
                                    tty
                                    /home/pi
                                    nodejs:
                                      Version table:
                                    Codierknecht
                                    @fred-freund
                                    1.) Das ist Dein Netz - IP's brauchst Du da nicht zu anonymisieren.
                                    2.) Buster ist tot - bring Dein System auf aktuellen Stand (Bullseye).
                                    3.) Wie der Benutzer im Adapter eingerichtet ist, spielt keine Rolle. Es kommt auf dessen Berechtigungen in der FB an.
                                      @fred-freund
                                      Fred Freund
                                      @codierknecht leider das selbe Problem neues IOS.
                                      armv7l
                                      Kein Docker
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.18.1
                                      v16.18.1
                                      8.19.2
                                      4.0.23
                                      pi
                                      tty
                                      /home/pi
                                      Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
                                      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                      Hit:4 https://packages.grafana.com/oss/deb stable InRelease
                                      Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
                                      nodejs:
                                        Version table:
                                           12.22.12~dfsg-1~deb11u1 500
                                      Vielen Dank!
                                        armv7l
                                        Kein Docker
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        v16.18.1
                                        v16.18.1
                                        8.19.2
                                        4.0.23
                                        pi
                                        tty
                                        /home/pi
                                        nodejs:
                                          Version table:
                                        Codierknecht
                                        @fred-freund
                                        Von iOS war keine Rede.
                                        Deine Paketquellen sehen irgendwie schräg aus.
                                          @fred-freund
                                          Fred Freund
                                          @codierknecht @codierknecht sorry das I hat sich reingschlichen OS sollte es sein :-)
                                          wo finde ich das passende nodesource ist das nodejs fuer Bullseye?
                                          Vielen Dank!
