  4. Fehlermeldungen bei Installation mac
    5.7k
114 Beiträge 8 Kommentatoren 20.9k Aufrufe
    thoduh
    sudo npm install https://github.com/ioBroker/ioBroker/tarball/master –unsafe-perm --prefix /ort/wohin/es/soll
    Leider nicht funktioniert:
    MacMini-LAN:node_modules MacMini$ cd node_modules/iobroker.js-controller
    -bash: cd: node_modules/iobroker.js-controller: No such file or directory
    MacMini-LAN:node_modules MacMini$ cd iobroker
    MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controlle
    -bash: cd: node_modules/iobroker.js-controlle: No such file or directory
    MacMini-LAN:iobroker MacMini$ cd node_modules/iobroker.js-controller
    MacMini-LAN:iobroker.js-controller MacMini$ chmod +x iobroker
    MacMini-LAN:iobroker.js-controller MacMini$ node controller.js
    host.MacMini-LAN.fritz.box check instance "system.adapter.admin.0" for host "MacMini-LAN.fritz.box"
    host.MacMini-LAN.fritz.box check instance "system.adapter.discovery.0" for host "MacMini-LAN.fritz.box"
    { Error: EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/log/iobroker.2017-07-26.log'
      errno: -13,
      code: 'EACCES',
      syscall: 'open',
      path: '/usr/local/lib/node_modules/iobroker/log/iobroker.2017-07-26.log' }
    EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
    Error: EACCES: permission denied, open '/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
        at Object.fs.openSync (fs.js:652:18)
        at Object.fs.writeFileSync (fs.js:1299:33)
        at saveConfig (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1749:16)
        at ObjectsInMemServer.destroy (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:26)
        at /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/controller.js:2244:49
        at Timeout.waitForInstances [as _onTimeout] (/usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/controller.js:2197:49)
        at ontimeout (timers.js:469:11)
        at tryOnTimeout (timers.js:304:5)
        at Timer.listOnTimeout (timers.js:264:5)
    Bis morgen dann :lol:
    • BuZZyB Offline
      BuZZyB Offline
      BuZZy
      In welchem Ordner landest du wenn du den Befehl
      cd /usr/local/lib/node_modules/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data
      eingibst?
        thoduh
        Hab ich noch nicht versucht, wollte es erneut aber diesmal an den richtigen Platz installieren. War ja nix ;) Morgen teste ich mal deinen anderen Vorschlag…
        • BuZZyB Offline
          BuZZyB Offline
          BuZZy
          Also halten wir kurz fest:
          1. Ich kenne mich nicht mit Mac aus… :D
          npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
          ````im Hauptverzeichnis "/" ausgeführt hat die Installation "korrekt" beendet. Die Versuche vorher in einem /User/ Ordner die Installation auszuführen hat nicht funktioniert.
          (Eventuell gibt es Probleme mit der Berechtigung wenn ein Script versucht in einen /User/ Ordner zu schreiben bzw. Dateien zu erstellen?!)
          3.
          Du hast den durch die Installation erstellen Ordner verschoben und jetzt gibts einen Haufen von Fehlern beim starten dass die Module nicht existieren bzw. nicht gefunden werden können.
          Dadurch dass du jetzt nochmal versucht hast ioBroker zu installieren bin ich mir nicht ganz sicher was passiert ist.
          Versuche nochmal ioBroker zu stoppen und dann wieder zu starten.
          Welche Ausgabe bekommst du dann im Log auf dem ioBroker Webinterface? Die gleiche die du vorhin schon gepostet hast?
          Bis Morgen. :D
          • BuZZyB Offline
            BuZZyB Offline
            BuZZy
            Habe über Nacht mal meine Gedanken neu sortiert..
            Als erstes setzt du jetzt die Rechte für den Ordner /usr/local/lib/node_modules/iobroker/ auf 777
            sudo chmod -R 777 /usr/local/lib/node_modules/iobroker/
            Jetzt versuch ioBroker aus diesem Ordner raus nochmal neu zu installieren..
            Also du befindest dich im Terminalfenster in dem Ordner /usr/local/lib/node_modules/iobroker/ und dort soll iobroker auch installiert werden ja?
            Hast du wirklich "sudo chmod -R 777 /usr/local/lib/node_modules/iobroker/" ausgeführt?
            Wenn ja, dann nochmal in diesem Ordner ioBroker installieren mit
            sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
            ioBroker wird in dem Ordner installiert in dem du den Befehl zum installieren gibst.
            Wenn du also das Terminal öffnest und eingibst
            befindest du dich logischerweise jetzt im Ordner /usr/local/lib/node_modules/iobroker/
            mit dem Befehl
            wird es in den aktuellen Ordner (also dann /usr/local/lib/node_modules/iobroker/) installiert.
            Wichtig ist, dass du vorher den befehl "chmod -R 777 /usr/local/lib/node_modules/iobroker/" ausführst um dem Ordner wo du installieren willst die Rechte 777 zu geben und erst dann installierst.
            • supernova1963S Offline
              supernova1963
              Als absoluter Neuling und MAC Nutzer versuche ich mal zu unterstützen.
              Da meine erste Installation von ioBroker nicht so verlief, wie hier (http://www.iobroker.net/docu/?page_id=2293&lang=de) beschrieben, habe ich den weiteren Verlauf dieses Beitrages und vor Allem die tolle Unterstützung von BuZZy durchgelesen.
              Ich habe daraufhin meine zwar laufende aber "unsaubere" erste Installation gemäß Anleitung gelöscht.
              Bei der Neuinstallation habe ich mich an die Anleitung von BuZZy gehalten.
              Voraussetzung ist:
              raunet:~ Gernot$ node -v
              v6.11.1
              1. einen Ordner "ioBrokerMac" in "Documents" erstellt.
              (@thoduh: im Folgenden ersetzen: …/Gernot/… durch: .../MacMini/…):
              raunet:~ Gernot$ mkdir /Users/Gernot/Documents/ioBrokerMac
              2. die Datei https://codeload.github.com/ioBroker/io … zip/master heruntergeladen und in den neu erstellten Ordner ioBrokerMac kopiert
              cp /Users/Gernot/Downloads/ioBroker.js-controller-master.zip /Users/Gernot/Documents/ioBrokerMac
              3. die Installation gem. BuZZy mit Vorgabe Verzeichnis gestartet
              raunet:ioBrokerMac Gernot$ npm install iobroker.js-controller --production --prefix /Users/Gernot/Documents/ioBrokerMac
              4. in das Verzeichnis /Users/Gernot/Documents/ioBrokerMac/node_modules/iobroker.js-controller gewechselt un die Datei ioBroker ausführbar gemacht
              raunet:ioBrokerMac Gernot$ cd /Users/Gernot/Documents/ioBrokerMac/node_modules/iobroker.js-controller
              raunet:iobroker.js-controller Gernot$ chmod +x iobroker
              5. mit node controller.js gestartet
              raunet:iobroker.js-controller Gernot$ node controller.js
              host.raunet.private check instance "system.adapter.admin.0" for host "raunet.private"
              Cannot send diag info: ETIMEDOUT
              cmdExec on raunet.private(223091688): add fhem
              und es läuft im Browser http://127.0.0.1:8081/
              Vielleicht hilft's,
              Gernot
                Hallo Gernot,
                Danke für diese Anleitung und zwei Zwischenfragen:
                Hast du außer dem chmod +x auch noch irgendwo ein chmod 777 o.ä. gemacht?
                Hast du als normaler User oder als Admin installiert?
                • BuZZyB Offline
                  BuZZyB Offline
                  BuZZy
                  Kurz als Hinweis:
                  NPM unterstützt das automatische holen und installieren von Githubrepos/.tar.gz Dateien.
                  Damit entfällt Schritt 2 komplett (der Download und das kopieren der Zip Datei)
                  Dementsprechend lautet der Befehl dann einfach
                  npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production --prefix /Users/Gernot/Documents/ioBrokerMac
                  Was mich zusätzlich wundert ist:
                  in der Docu steht
                  "ioBroker installieren: npm install iobroker –unsafe-perm"
                  Aber du (supernova1963) hast ja jetzt ioBroker.js-controller installiert...
                  Anscheinend wird ioBroker dann automatisch mit installiert.
                  Weil unter Linux installiert man ja wirklich einfach nur mit "sudo npm install iobroker --unsafe-perm"..
                  Hmmm.. Schauen wir mal was thoduh heute Abend dazu sagt.. :D Ich bin gespannt ob wir das Ding hier endlich zu machen können und die Docu für Mac neu schreiben können.. :D :D
                    supernova1963
                    Hallo Rainer,
                    @Homoran:
                    Hast du außer dem chmod +x auch noch irgendwo ein chmod 777 o.ä. gemacht? ` Nein, mußte ich nur bei meinem 1. Versuch, da existierte das log-Verzeichnis bereits von einer anderen Programminstallation mit sudo.
                    @Homoran:
                    Hast du als normaler User oder als Admin installiert? ` Als User mit Admin-Rechten, aber ohne sudo.
                    Gernot
                      supernova1963
                      Hallo BuZZy,
                      es wird wohl gelingen …
                      In der Installationsbeschreibung OS X ist als erstes dieser Link genannt: https://github.com/ioBroker/ioBroker.js-controller
                      und eine Zeile darunter wird direkt diese Datei heruntergeladen: https://github.com/ioBroker/ioBroker/archive/master.zip
                      Den Unterschied kenne ich nicht. Es ist aber definitiv nicht das Gleiche!
                      Was bedeutet eigentlich der Parameter "--unsafe-perm". Da du den "--production" Parameter mit der Pfadangabe "--prefix ..." empfohlen hattest habe ich diesen genommen. Ob es auch mit "--unsafe-perm --prefix ..." habe ich nicht getestet.
                      Gernot
                        @supernova1963:
                        Den Unterschied kenne ich nicht. Es ist aber definitiv nicht das Gleiche! `
                        Das erste ist nur der js-controller, also die Engine, das zweite ist das vollständige Paket
                        Ich kenne auch nur den Weg über npm bei RasPi & Co.
                        Die Anleitung installiert erst den js-controller, der wiederum den Rest über npm installiert.
                          thoduh
                          Also jetzt verstehe ich es garnicht mehr. Gestern ist iobroker gelaufen (zwar mit Fehlern im Log, aber es ist gelaufen), da ich allerdings den Ordner kopiert hatte, wollte ich heute alles nochmal neu installieren.
                          sudo mkdir iobroker
                          sudo chmod -R 777 /iobroker
                          Bin diesmal direkt auf Macintosh HD geblieben, also keine Unterordner, direkt /iobroker.
                          Und bekomme es einfach nicht mehr fehlerfrei installiert :(
                          MacMini-LAN:~ MacMini$ cd /iobroker
                          MacMini-LAN:iobroker MacMini$ sudo npm install https://github.com/ioBroker/ioBroker/tarball/master --unsafe-perm
                          Password:
                          > iobroker@1.0.0 install /iobroker/node_modules/iobroker
                          > node lib/setup.js
                          npm install iobroker.discovery --production --prefix /iobroker
                          node-pre-gyp info it worked if it ends with ok
                          node-pre-gyp verb cli [ '/usr/local/bin/node',
                          node-pre-gyp verb cli   '/iobroker/node_modules/serialport/node_modules/.bin/node-pre-gyp',
                          node-pre-gyp verb cli   'install',
                          node-pre-gyp verb cli   '--fallback-to-build' ]
                          node-pre-gyp info using node-pre-gyp@0.6.32
                          node-pre-gyp info using node@8.2.1 | darwin | x64
                          node-pre-gyp verb command install []
                          node-pre-gyp info check checked for "/iobroker/node_modules/serialport/build/Release/serialport.node" (not found)
                          node-pre-gyp http GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
                          node-pre-gyp http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
                          node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
                          node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@8.2.1 (node-v57 ABI) (falling back to source compile with node-gyp)
                          node-pre-gyp http 404 status code downloading tarball https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v57-darwin-x64.tar.gz
                          node-pre-gyp verb command build [ 'rebuild' ]
                          ../src/serialport.cpp:90:44: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            return getValueFromObject(options, key)->ToInt32()->Int32Value();
                          /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9336:21: note: 'ToInt32' has been explicitly marked deprecated here
                          Local <int32>Value::ToInt32() const {
                          ../src/serialport.cpp:102:44: warning: 'ToNumber' is deprecated [-Wdeprecated-declarations]
                            return getValueFromObject(options, key)->ToNumber()->NumberValue();
                          /Users/MacMini/.node-gyp/8.2.1/include/node/v8.h:9300:22: note: 'ToNumber' has been explicitly marked deprecated here
                          Local <number>Value::ToNumber() const {
                          ../src/serialport.cpp:174:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                              int fd = argv[1]->ToInt32()->Int32Value();
                          ../src/serialport.cpp:193:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            int fd = info[0]->ToInt32()->Int32Value();
                          ../src/serialport.cpp:217:108: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            baton->baudRate = Nan::Get(options, Nan::New<v8::string>("baudRate").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                          ../src/serialport.cpp:252:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp:369:24: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            baton->fd = info[0]->ToInt32()->Int32Value();
                          ../src/serialport.cpp:480:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp:528:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                          ../src/serialport.cpp:585:21: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                          10 warnings generated.
                          ../src/serialport_unix.cpp:44:101: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            result->vmin = Nan::Get(options, Nan::New<v8::string>("vmin").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                          ../src/serialport_unix.cpp:45:103: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            result->vtime = Nan::Get(options, Nan::New<v8::string>("vtime").ToLocalChecked()).ToLocalChecked()->ToInt32()->Int32Value();
                          2 warnings generated.
                          ../src/serialport_poller.cpp:86:23: warning: 'ToInt32' is deprecated [-Wdeprecated-declarations]
                            obj->fd_ = info[0]->ToInt32()->Int32Value();
                          1 warning generated.
                          node-pre-gyp info ok
                          npm WARN saveError ENOENT: no such file or directory, open '/iobroker/package.json'
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          npm WARN enoent ENOENT: no such file or directory, open '/iobroker/package.json'
                          npm WARN iobroker No description
                          npm WARN iobroker No repository field.
                          npm WARN iobroker No README data
                          npm WARN iobroker No license field.
                          npm install iobroker.admin --production --prefix /iobroker
                          npm install iobroker.js-controller --production --prefix /iobroker
                          Write "./iobroker start" to start the ioBroker
                          Cannot create file /usr/bin/iobroker!. Non critical
                          You can manually copy file into /usr/bin/. Just write:
                              sudo cp /iobroker/node_modules/iobroker/install/iobroker /usr/bin/
                              sudo chmod 777 /usr/bin/iobroker
                          + iobroker@1.0.0
                          added 46 packages in 130.318s
                          { Error: EACCES: permission denied, open '/iobroker/log/iobroker.2017-07-27.log'
                            errno: -13,
                            code: 'EACCES',
                            syscall: 'open',
                            path: '/iobroker/log/iobroker.2017-07-27.log' }
                          EACCES: permission denied, open '/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                          Error: EACCES: permission denied, open '/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak'
                              at saveConfig (/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1749:16)
                              at ObjectsInMemServer.destroy (/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:2677:26)
                              at /iobroker/node_modules/iobroker.js-controller/controller.js:2244:49
                              at Timeout.waitForInstances [as _onTimeout] (/iobroker/node_modules/iobroker.js-controller/controller.js:2197:49)
                          MacMini-LAN:iobroker.js-controller MacMini$</int32></int32></v8::string></int32></v8::string></int32></int32></int32></int32></int32></int32></v8::string></int32></int32></number></int32>
                          Ich bin wieder alle Schritte mehrmals durchgegangen, alle bisherigen Versuche wiederholt und habe auch die Anleitung von supernova1963 probiert, alles ohne Erfolg.
                          Das kann doch nicht sein, seit Ewigkeiten läuft Homebridge bei mir bestens und mit iobroker gibt es so extreme Probleme…
                          Und gestern hat es doch funktioniert :(
                          • BuZZyB Offline
                            BuZZyB Offline
                            BuZZy
                            Versuch es hiermit im Ordner /iobroker/
                            sudo npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production --prefix /iobroker
                            Vorher den Inhalt von /iobroker komplett löschen
                            Welche Ausgabe bekommst du bei````
                            node -v
                            Von unterwegs gesendet
                              thoduh
                              Also ehrlich, du bist echt der King :!:
                              Jetzt läuft es wieder :D
                              node-version: v8.2.1
                              • BuZZyB Offline
                                BuZZyB Offline
                                BuZZy
                                Geht denn jetzt alles? Oder hast du noch Fehlermeldungen im log?
                                  thoduh
                                  Ja geht alles, keine Fehler im Log :D
                                  Vielen vielen Dank nochmal für deinen Super-Support :!:
                                  Muss jetzt mal schauen wie das hier alles funktioniert bei iobroker…
                                    thoduh
                                    Beim hinzufügen von Adapter bekomme ich jetzt noch einen Fehler:
                                    $ ./iobroker add hm-rega
                                    npm install iobroker.hm-rega --production --prefix "/iobroker" (System call)
                                    npm
                                     WARN checkPermissions Missing write access to /iobroker/node_modules/engine.io-client/node_modulesnpm WARN checkPermissions Missing write access to /iobroker/node_modules/engine.io/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/express-session/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/npm/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/prompt/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/prompt/node_modules/winston/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/readable-stream/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/send/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io-adapter/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io-client/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io-parser/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/socket.io/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/tar.gz/node_modules
                                    npm
                                    WARN checkPermissions Missing write access to /iobroker/node_modules/unix-dgram/node_modulesnpm WARN checkPermissions Missing write access to /iobroker/node_modules/utile/node_modules
                                    npm WARN checkPermissions Missing write access to /iobroker/node_modules/winston/node_modules
                                    npm
                                     ERR! path /iobroker/node_modules/engine.io-client/node_modulesnpm ERR! code EACCES
                                    npm ERR! errno -13
                                    npm ERR! syscall access
                                    npm ERR! Error: EACCES: permission denied, access '/iobroker/node_modules/engine.io-client/node_modules'npm
                                     ERR!  { Error: EACCES: permission denied, access '/iobroker/node_modules/engine.io-client/node_modules'
                                    npm ERR!   stack: 'Error: EACCES: permission denied, access \'/iobroker/node_modules/engine.io-client/node_modules\'',npm ERR!   errno: -13,
                                    npm ERR!   code: 'EACCES',
                                    npm ERR!   syscall: 'access',
                                    npm ERR!   path: '/iobroker/node_modules/engine.io-client/node_modules' }
                                    npm ERR!
                                    npm ERR! Please try running this command again as root/Administrator.
                                    npm ERR! A complete log of this run can be found in:npm ERR!     /Users/MacMini/.npm/_logs/2017-07-27T15_56_32_482Z-debug.log
                                    ERROR: host.MacMini-LAN.fritz.box Cannot install iobroker.hm-rega: 243
                                      #66
                                      @thoduh:
                                      node-version: v8.2.1 `
                                      Die ist noch sehr neu und nicht von uns getestet.
                                      Bisher war die 4.x.x und neuerdings die 6.x.x die Empfohlene Version.
                                      die 8.x.x ist IMHO noch nicht als LTS-Version gekennzeichnet.
                                      • BuZZyB Offline
                                        BuZZyB Offline
                                        BuZZy
                                        #67
                                        Mach jetzt nochmal
                                        Dann versuch nochmal einen Adapter zu installieren.
                                          thoduh
                                          #68
                                          ERROR: module.js:487    throw err;
                                          Error: Cannot find module 'mime'
                                              at Function.Module._resolveFilename (module.js:485:15)
                                              at Function.Module._load (module.js:437:25)
                                              at Module.require (module.js:513:17)
                                              at require (internal/module.js:11:18)
                                              at Install.createInstance (/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:584:27)
                                              at /iobroker/node_modules/iobroker.js-controller/lib/setup.js:741:41
                                              at /iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:157:39
                                              at enableAdapters (/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:47:21)
                                              at /iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:156:21
                                              at ChildProcess. <anonymous>(/iobroker/node_modules/iobroker.js-controller/lib/setup/setupInstall.js:325:31)
                                          ERROR: process exited with code 1</anonymous>
                                          habe iobroker gerade im Terminal mit ctrl+c abgebrochen und bekomme es jetzt wieder nicht zum laufen :shock:
                                          Auch start oder stop funktioniert nicht…
