  3. Einsteigerfragen
  4. Probleme beim Updaten von iobroker!
    5.6k
52 Beiträge 4 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • ottiO Offline
    ottiO Offline
    otti
    pi@raspberrypi:/opt/iobroker $ iobroker upgrade admin --debug
    This upgrade of "admin" will at least introduce the following changes:
    -> 6.2.23:
    Prepare for future js-controller versions
    Corrected deletion of objects
    -> 6.2.22:
    Corrected admin4 adapter settings
    -> 6.2.21:
    Corrected small JSON config issue
    -> 6.2.20:
    Corrected GUI issues
    -> 6.2.19:
    Corrected some issues
    -> 6.2.18:
    Corrected GUI bugs on custom settings
    -> 6.2.17:
    Corrected GUI bug on intro tab
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @5.2.3 to @6.2.23 now? [(y)es, (n)o]: y
    Update admin from @5.2.3 to @6.2.23
    host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
    NPM version: 6.14.16
    Installing iobroker.admin@6.2.23... (System call)
    npm ERR! code ENOTSUP
    npm ERR! notsup Unsupported engine for homebridge-ewelink@8.15.0: wanted: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"} (current: {"node":"14.19.0","npm":"6.14.16"})
    npm ERR! notsup Not compatible with your version of node/npm: homebridge-ewelink@8.15.0
    npm ERR! notsup Required: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"}
    npm ERR! notsup Actual:   {"npm":"6.14.16","node":"14.19.0"}
    npm ERR!     /home/iobroker/.npm/_logs/2022-11-19T17_27_11_829Z-debug.log
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
    host.raspberrypi Adapter "system.adapter.admin.0" is started
    • ottiO otti
      -> 6.2.23:
      -> 6.2.22:
      -> 6.2.21:
      -> 6.2.20:
      -> 6.2.19:
      -> 6.2.18:
      -> 6.2.17:
      @otti sagte in Probleme beim Updaten von iobroker!:
      da steht's ja
      ottiO 1 Antwort Letzte Antwort
        da steht's ja
        ottiO Offline
        ottiO Offline
        otti
        welche Befehle mus ich jetzt eintippen?
        • ottiO otti
          @otti was sagt denn jetzt iobroker update -i ?
          • ottiO otti
            @otti
            Du möchtest deine nodeJS-Installation auf die aktuelle Empfehlung v16 heben.
            Siehe meine Signatur.
            • ottiO Offline
              ottiO Offline
              otti
              @homoran said in Probleme beim Updaten von iobroker!:
              iobroker update -i
              code_text
              ``pi@raspberrypi:/opt/iobroker $ iobroker update -i
              Used repository: stable
              Adapter    "admin"        : 6.2.23   , installed 5.2.3  [Updatable]
              Adapter    "alexa2"       : 3.21.0   , installed 3.11.2 [Updatable]
              Adapter    "backitup"     : 2.5.4    , installed 2.2.3  [Updatable]
              Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
              Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
              Adapter    "discovery"    : 3.0.5    , installed 2.7.3  [Updatable]
              Adapter    "ham"          : 5.3.0    , installed 4.0.2  [Updatable]
              Adapter    "history"      : 2.2.0    , installed 1.10.5 [Updatable]
              Adapter    "hue"          : 3.7.1    , installed 3.5.31 [Updatable]
              Adapter    "iot"          : 1.11.9   , installed 1.8.24 [Updatable]
              Adapter    "javascript"   : 6.0.3    , installed 5.2.13 [Updatable]
              Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
              Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
              Adapter    "mihome-vacuum": 3.8.6    , installed 3.3.1  [Updatable]
              Adapter    "tuya"         : 3.9.4    , installed 3.6.15 [Updatable]
              Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
              • ottiO otti
                iobroker update -i
                code_text
                @otti soll das heißen dass bei dir homebridge-ewelink, das du anscheinend gar nicht installiert hast, alle updates blockiert?
                @Thomas-Braun ??
                  @Thomas-Braun ??
                  Dafür ist der ham-Adapter installiert. Der wird den homebridge-ewelink im Bauch haben.
                  • ottiO otti
                    iobroker update -i
                    code_text
                    @otti
                    Bei node14 ist übrigens 14.21.1 der letzte Stand.
                    Also Betriebssytem auf Stand halten, am besten in dem Zug gleich auf nodeJS@16 springen.
                    • ottiO Offline
                      ottiO Offline
                      otti
                      soll ich den ham-Adapter weglöschen,
                      geht aber nicht,hab da ein paar Geräte drüber laufen,
                      sorry Leute ,bekomme gerade von meiner Frau signalisiert das ich Schluss machen soll,wir haben noch Besuch.......
                      trotzdem erstmal vielen Dank an alle die geholfen haben,
                      eventuell ist ja morgen wieder jemand im Forum...
                      mfg otti
                      • ottiO otti
                        mfg otti
                        wir wohnen hier!
                        • Thomas BraunT Online
                          Nein, du sollst dein Betriebs-System aktuell halten.
                            wir wohnen hier!
                            @homoran sagte in Probleme beim Updaten von iobroker!:
                            wir wohnen hier!
                            Aber die Nachbarschaft ist seltsam hier... :-)
                            • ottiO Offline
                              ottiO Offline
                              otti
                              Guten Morgen,
                              der Dummi ist wieder da,
                              sollte ich den ham-Adapter erstmal weglöschen?
                                ottiO Offline
                                ottiO Offline
                                otti
                                ja das weis ich jetzt auch,
                                ich gelobe Besserung,kannst Du mir nochmal verzeihen?
                                mfg otti
                                • ottiO otti
                                  Guten Morgen,
                                  Guten Morgen,
                                  Nein. Hast du dein Betriebssystem auf Stand gebracht?
                                  • ottiO Offline
                                    ottiO Offline
                                    otti
                                    moin,
                                    habe mich mal durchgelesen bei den Links die Du unter deinem Post hast,
                                    jetzt kam diese Fehlermeldung.
                                    E: Failed to fetch http://mirror.netzwerge.de/raspbian/raspbian/pool/main/a/avahi/avahi-daemon_0.8-5+deb11u1_armhf.deb  Error reading from server - read (104: Connection reset by peer) [IP: 185.41.106.155 80]
                                    E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                    • ottiO Offline
                                      ottiO Offline
                                      otti
                                      jetzt versuche ich den Js zu updaten,nach der Anleitung,
                                      dies war die Fehlermeldung
                                      pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                                      │   │   ├── github-from-package@0.0.0 deduped
                                      │ │ │ ├── github-from-package@0.0.0
                                      npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                      npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                      npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                      npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                      npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                                      npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                                      npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
                                      npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                      npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                      npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                      npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                      npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                                      npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                                      npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
                                      npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                      npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                      npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                      npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
                                      npm ERR! extraneous: eslint@8.9.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                                      npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                                      npm ERR! extraneous: eslint-plugin-jest@26.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                                      npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                                      npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                      npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                      npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                      npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                      npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                                      npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                                      npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
                                      npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                      npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                      npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                      npm ERR! extraneous: @typescript-eslint/experimental-utils@5.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/experimental-utils
                                      npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                      npm ERR! extraneous: enquirer@2.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/enquirer
                                      npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                                      npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                                      npm ERR! extraneous: node-modules-regexp@1.0.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/node-modules-regexp
                                      npm ERR! extraneous: onigasm@2.2.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/onigasm
                                      npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/progress
                                      npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
                                      npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                      npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                      npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                      npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
                                      • ottiO Offline
                                        ottiO Offline
                                        otti
                                        Moin,
                                        wir können den tread schließen,
                                        Ich kann jetzt tatsächlich meine Adapter updaten,
                                        vielen Dank für eure Hilfe!!!
                                        mfg Thomas
