  3. Einsteigerfragen
  4. Probleme beim Updaten von iobroker!
    5.6k
52 Beiträge 4 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • ottiO otti
    @djmarc75 das ist immer noch das update thema,
    warum so agressiv???
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @otti sagte in Probleme beim Updaten von iobroker!:
    entschuldigung.
    @Homoran entschuldigung.
    Lehrling seit 1975 !!!
    • ottiO otti
      Would you like to upgrade cloud from @4.1.0 to @4.2.2 now? [(y)es, (n)o]: y
      Update cloud from @4.1.0 to @4.2.2
      NPM version: 6.14.16
      Installing iobroker.cloud@4.2.2... (System call)
      Update "system.adapter.cloud.0"
      upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
      upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
      upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
      upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
      upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
      upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
      upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
      upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
      This upgrade of "alexa2" will at least introduce the following changes:
      -> 3.21.0:
      IMPORTANT: Because of rate limits by Amazon I decided to remove the update of smart home device values in intervals because it seems to produce too much load in Skills and Amazon systems.
      Optimizes loading of smart home device states
      Fixed issue with enabling/disabling of Alarms in combination with non-default music for the alarm
      Prevented that Timers or Alarms that are long in the future to trigger their trigger state too early
      Fixed deleting own user Messages state
      Already request Notification updates when history registered a Notification action and do not wait for Push info to come in
      -> 3.20.1:
      make sure caching works correctly with multiple instances of the adapter
      -> 3.20.0:
      Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
      Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
      -> 3.19.10:
      Fix issue in retry handling when rate limit exceeded is returned by Amazon
      Do not clean up Smart Home Device objects for now - delete manually if you remove a device
      -> 3.19.9:
      Receive the correct player status again when musik is stopped
      -> 3.19.8:
      Add safeguard for too high intervals
      -> 3.19.7:
      Fix doNotDisturb when using a time string
      Would you like to upgrade alexa2 from @3.11.2 to @3.21.0 now? [(y)es, (n)o]: y
      Update alexa2 from @3.11.2 to @3.21.0
      Installing iobroker.alexa2@3.21.0... (System call)
      Update "system.adapter.alexa2.0"
      upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
      upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
      upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
      upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
      upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
      upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
      upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
      upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
      upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
      upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
      upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
      upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
      upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
      upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
      upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
      upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
      upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
      upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
      upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
      upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
      upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
      upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
      This upgrade of "admin" will at least introduce the following changes:
      -> 6.2.23:
      Prepare for future js-controller versions
      Corrected deletion of objects
      -> 6.2.22:
      Corrected admin4 adapter settings
      -> 6.2.21:
      Corrected small JSON config issue
      -> 6.2.20:
      Corrected GUI issues
      -> 6.2.19:
      Corrected some issues
      -> 6.2.18:
      Corrected GUI bugs on custom settings
      -> 6.2.17:
      Corrected GUI bug on intro tab
      BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
      Would you like to upgrade admin from @5.2.3 to @6.2.23 now? [(y)es, (n)o]: y
      Update admin from @5.2.3 to @6.2.23
      host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
      Installing iobroker.admin@6.2.23... (System call)
      das ist leider alles was ich zu dem admin update finde
      was kommt denn bei iobroker upgrade admin --debug ?
      • ottiO Offline
        ottiO Offline
        otti
        pi@raspberrypi:/opt/iobroker $ iobroker upgrade admin --debug
        -> 6.2.23:
        -> 6.2.22:
        -> 6.2.21:
        -> 6.2.20:
        -> 6.2.19:
        -> 6.2.18:
        -> 6.2.17:
        npm ERR! code ENOTSUP
        npm ERR! notsup Unsupported engine for homebridge-ewelink@8.15.0: wanted: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"} (current: {"node":"14.19.0","npm":"6.14.16"})
        npm ERR! notsup Not compatible with your version of node/npm: homebridge-ewelink@8.15.0
        npm ERR! notsup Required: {"homebridge":"^1.4.0","node":"^14.19.1 || ^16.15.0"}
        npm ERR! notsup Actual:   {"npm":"6.14.16","node":"14.19.0"}
        npm ERR!     /home/iobroker/.npm/_logs/2022-11-19T17_27_11_829Z-debug.log
        upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
        upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
        upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
        upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
        upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
        upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
        upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
        upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
        upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
        upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
        upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
        upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
        upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index_m.html index_m.html text/html
        upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json jsonConfig.json application/json
        upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/words.js words.js application/javascript
        host.raspberrypi Adapter "system.adapter.admin.0" is started
        • ottiO otti
          -> 6.2.23:
          -> 6.2.22:
          -> 6.2.21:
          -> 6.2.20:
          -> 6.2.19:
          -> 6.2.18:
          -> 6.2.17:
          da steht's ja
          ottiO 1 Antwort Letzte Antwort
            da steht's ja
            ottiO Offline
            ottiO Offline
            otti
            welche Befehle mus ich jetzt eintippen?
            • ottiO otti
              @otti was sagt denn jetzt iobroker update -i ?
              • ottiO otti
                @otti
                Du möchtest deine nodeJS-Installation auf die aktuelle Empfehlung v16 heben.
                Siehe meine Signatur.
                • ottiO Offline
                  ottiO Offline
                  otti
                  @homoran said in Probleme beim Updaten von iobroker!:
                  iobroker update -i
                  code_text
                  ``pi@raspberrypi:/opt/iobroker $ iobroker update -i
                  Used repository: stable
                  Adapter    "admin"        : 6.2.23   , installed 5.2.3  [Updatable]
                  Adapter    "alexa2"       : 3.21.0   , installed 3.11.2 [Updatable]
                  Adapter    "backitup"     : 2.5.4    , installed 2.2.3  [Updatable]
                  Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
                  Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
                  Adapter    "discovery"    : 3.0.5    , installed 2.7.3  [Updatable]
                  Adapter    "ham"          : 5.3.0    , installed 4.0.2  [Updatable]
                  Adapter    "history"      : 2.2.0    , installed 1.10.5 [Updatable]
                  Adapter    "hue"          : 3.7.1    , installed 3.5.31 [Updatable]
                  Adapter    "iot"          : 1.11.9   , installed 1.8.24 [Updatable]
                  Adapter    "javascript"   : 6.0.3    , installed 5.2.13 [Updatable]
                  Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
                  Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
                  Adapter    "mihome-vacuum": 3.8.6    , installed 3.3.1  [Updatable]
                  Adapter    "tuya"         : 3.9.4    , installed 3.6.15 [Updatable]
                  Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
                  • ottiO otti
                    iobroker update -i
                    code_text
                    @otti soll das heißen dass bei dir homebridge-ewelink, das du anscheinend gar nicht installiert hast, alle updates blockiert?
                    @Thomas-Braun ??
                      @Thomas-Braun ??
                      Dafür ist der ham-Adapter installiert. Der wird den homebridge-ewelink im Bauch haben.
                      • ottiO otti
                        iobroker update -i
                        code_text
                        @otti
                        Bei node14 ist übrigens 14.21.1 der letzte Stand.
                        Also Betriebssytem auf Stand halten, am besten in dem Zug gleich auf nodeJS@16 springen.
                        • ottiO Offline
                          ottiO Offline
                          otti
                          soll ich den ham-Adapter weglöschen,
                          geht aber nicht,hab da ein paar Geräte drüber laufen,
                          sorry Leute ,bekomme gerade von meiner Frau signalisiert das ich Schluss machen soll,wir haben noch Besuch.......
                          trotzdem erstmal vielen Dank an alle die geholfen haben,
                          eventuell ist ja morgen wieder jemand im Forum...
                          mfg otti
                          • ottiO otti
                            mfg otti
                            wir wohnen hier!
                            • Thomas BraunT Online
                              Nein, du sollst dein Betriebs-System aktuell halten.
                                wir wohnen hier!
                                @homoran sagte in Probleme beim Updaten von iobroker!:
                                wir wohnen hier!
                                Aber die Nachbarschaft ist seltsam hier... :-)
                                • ottiO Offline
                                  ottiO Offline
                                  otti
                                  Guten Morgen,
                                  der Dummi ist wieder da,
                                  sollte ich den ham-Adapter erstmal weglöschen?
                                    ottiO Offline
                                    ottiO Offline
                                    otti
                                    ja das weis ich jetzt auch,
                                    ich gelobe Besserung,kannst Du mir nochmal verzeihen?
                                    mfg otti
                                    • ottiO otti
                                      Guten Morgen,
                                      Guten Morgen,
                                      Nein. Hast du dein Betriebssystem auf Stand gebracht?
                                      • ottiO Offline
                                        ottiO Offline
                                        otti
                                        moin,
                                        habe mich mal durchgelesen bei den Links die Du unter deinem Post hast,
                                        jetzt kam diese Fehlermeldung.
                                        E: Failed to fetch http://mirror.netzwerge.de/raspbian/raspbian/pool/main/a/avahi/avahi-daemon_0.8-5+deb11u1_armhf.deb  Error reading from server - read (104: Connection reset by peer) [IP: 185.41.106.155 80]
                                        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
                                        • ottiO Offline
                                          ottiO Offline
                                          otti
                                          jetzt versuche ich den Js zu updaten,nach der Anleitung,
                                          dies war die Fehlermeldung
                                          pi@raspberrypi:/opt/iobroker $ npm ls | grep -E 'github|ERR'
                                          │   │   ├── github-from-package@0.0.0 deduped
                                          │ │ │ ├── github-from-package@0.0.0
                                          npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                          npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                          npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                          npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                          npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/debug
                                          npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/jest
                                          npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/mz
                                          npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                          npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                          npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                          npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                          npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/eslint
                                          npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/jest
                                          npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc
                                          npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                          npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                          npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                          npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman/node_modules/typescript
                                          npm ERR! extraneous: eslint@8.9.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint
                                          npm ERR! extraneous: eslint-config-google@0.14.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-config-google
                                          npm ERR! extraneous: eslint-plugin-jest@26.1.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/eslint-plugin-jest
                                          npm ERR! extraneous: jest@27.5.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/jest
                                          npm ERR! extraneous: @babel/cli@7.17.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/cli
                                          npm ERR! extraneous: @babel/preset-env@7.16.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-env
                                          npm ERR! extraneous: @babel/preset-typescript@7.16.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@babel/preset-typescript
                                          npm ERR! extraneous: @types/debounce@1.2.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debounce
                                          npm ERR! extraneous: @types/debug@4.1.7 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/debug
                                          npm ERR! extraneous: @types/jest@27.4.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/jest
                                          npm ERR! extraneous: @types/mz@2.7.4 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/mz
                                          npm ERR! extraneous: @types/nedb@1.8.12 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/nedb
                                          npm ERR! extraneous: @types/serialport@8.0.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@types/serialport
                                          npm ERR! extraneous: @typescript-eslint/eslint-plugin@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/eslint-plugin
                                          npm ERR! extraneous: @typescript-eslint/experimental-utils@5.2.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/experimental-utils
                                          npm ERR! extraneous: @typescript-eslint/parser@5.10.2 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/@typescript-eslint/parser
                                          npm ERR! extraneous: enquirer@2.3.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/enquirer
                                          npm ERR! extraneous: eslint@8.8.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/eslint
                                          npm ERR! extraneous: jest@27.5.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/jest
                                          npm ERR! extraneous: node-modules-regexp@1.0.0 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/node-modules-regexp
                                          npm ERR! extraneous: onigasm@2.2.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/onigasm
                                          npm ERR! extraneous: progress@2.0.3 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/progress
                                          npm ERR! extraneous: typedoc@0.22.11 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc
                                          npm ERR! extraneous: typedoc-plugin-markdown@3.11.13 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-markdown
                                          npm ERR! extraneous: typedoc-plugin-no-inherit@1.3.1 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-no-inherit
                                          npm ERR! extraneous: typedoc-plugin-sourcefile-url@1.0.6 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typedoc-plugin-sourcefile-url
                                          npm ERR! extraneous: typescript@4.5.5 /opt/iobroker/node_modules/zigbee-herdsman-converters/node_modules/zigbee-herdsman/node_modules/typescript
