  3. Einsteigerfragen
  4. Probleme beim Updaten von iobroker!
    5.6k
52 Beiträge 4 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • ottiO otti
    @thomas-braun said in Probleme beim Updaten von iobroker!:
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ iob backup
    host.raspberrypi 2790 states saved
    host.raspberrypi 3436 objects saved
    Backup created: /opt/iobroker/backups/2022_11_19-15_34_39_backupiobroker.tar.gz
    pi@raspberrypi:/opt/iobroker $ iob stop
    pi@raspberrypi:/opt/iobroker $ iob update
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 5.2.3  [Updatable]
    Adapter    "alexa2"       : 3.21.0   , installed 3.11.2 [Updatable]
    Adapter    "backitup"     : 2.5.4    , installed 2.2.3  [Updatable]
    Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
    Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
    Adapter    "discovery"    : 3.0.5    , installed 2.7.3  [Updatable]
    Adapter    "ham"          : 5.3.0    , installed 4.0.2  [Updatable]
    Adapter    "history"      : 2.2.0    , installed 1.10.5 [Updatable]
    Adapter    "hue"          : 3.7.1    , installed 3.5.31 [Updatable]
    Adapter    "iot"          : 1.11.9   , installed 1.8.24 [Updatable]
    Adapter    "javascript"   : 6.0.3    , installed 5.2.13 [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
    Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
    Adapter    "mihome-vacuum": 3.8.6    , installed 3.3.1  [Updatable]
    Adapter    "tuya"         : 3.9.4    , installed 3.6.15 [Updatable]
    Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
    pi@raspberrypi:/opt/iobroker $ iob fix
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
    Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
    Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
    Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
    Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
    Get:6 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [785 B]
    Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/contrib armhf Packages [60.2 kB]
    Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/non-free armhf Packages [106 kB]
    Fetched 13.8 MB in 19s (732 kB/s)
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:/opt/iobroker $ iob upgrade self
    Update js-controller from @4.0.15 to @4.0.23
    Stopped Objects DB
    Stopped States DB
    NPM version: 6.14.16
    Installing iobroker.js-controller@4.0.23... (System call)
    pi@raspberrypi:/opt/iobroker $ iob start
    @otti
    iobroker upgrade all
    sagt?
    ottiO 1 Antwort Letzte Antwort
      @otti
      sagt?
      ottiO Offline
      ottiO Offline
      otti
      @thomas-braun sorry,
      was sagt was???
      ich könnte Fernzugriff über Anydesk anbieten.....
      • ottiO otti
        was sagt was???
        @otti sagte in Probleme beim Updaten von iobroker!:
        was sagt was???
        das was im schwarzen Kasten steht
          was sagt was???
          ottiO Offline
          ottiO Offline
          otti
          @homoran achso,das soll ich mal eintippen richtig,
          • ottiO Offline
            ottiO Offline
            otti
            Geil,
            da tut sich was,
            na mal abwarten....
            HomoranH DJMarc75D 2 Antworten Letzte Antwort
            • ottiO otti
              was sagt was???
              Mein Lieblingsthema. Auf einem Server läuft kein Desktop, also auch kein AnyDesk.
              • ottiO otti
                Geil,
                da tut sich was,
                na mal abwarten....
                da tut sich was,
                meinen Link hast du aber nicht gelesen?
                dann wüsstest du:
                zeigen, zeigen, zeigen!
                • ottiO otti
                  Geil,
                  da tut sich was,
                  na mal abwarten....
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  Geil,
                  da tut sich was,
                  na mal abwarten....
                  Geil,
                  was tut sich da,
                  mal abwarten ob Du es hier zeigen willst.....
                  Lehrling seit 1975 !!!
                    ottiO Offline
                    ottiO Offline
                    otti
                    @thomas-braun aber über Anydesk kannst du mein Terminal bedienen
                    • DJMarc75D DJMarc75
                      Geil,
                      da tut sich was,
                      na mal abwarten....
                      Geil,
                      was tut sich da,
                      ottiO Offline
                      ottiO Offline
                      otti
                      @djmarc75 ja zeig ich
                      • ottiO otti
                        @otti
                        Kennst du das Stück 'Warten auf Godot'?
                        Da gibt es jetzt eine Fortsetzung zu.
                        • ottiO Offline
                          ottiO Offline
                          otti
                          Would you like to upgrade cloud from @4.1.0 to @4.2.2 now? [(y)es, (n)o]: y
                          Update cloud from @4.1.0 to @4.2.2
                          Installing iobroker.cloud@4.2.2... (System call)
                          Update "system.adapter.cloud.0"
                          upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                          upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                          upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                          upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                          upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                          upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                          upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                          upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                          upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                          upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                          upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                          upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                          upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                          upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                          upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                          upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                          upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                          upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                          This upgrade of "alexa2" will at least introduce the following changes:
                          -> 3.21.0:
                          IMPORTANT: Because of rate limits by Amazon I decided to remove the update of smart home device values in intervals because it seems to produce too much load in Skills and Amazon systems.
                          Optimizes loading of smart home device states
                          Fixed issue with enabling/disabling of Alarms in combination with non-default music for the alarm
                          Prevented that Timers or Alarms that are long in the future to trigger their trigger state too early
                          Fixed deleting own user Messages state
                          Already request Notification updates when history registered a Notification action and do not wait for Push info to come in
                          -> 3.20.1:
                          make sure caching works correctly with multiple instances of the adapter
                          -> 3.20.0:
                          Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
                          Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
                          -> 3.19.10:
                          Fix issue in retry handling when rate limit exceeded is returned by Amazon
                          Do not clean up Smart Home Device objects for now - delete manually if you remove a device
                          -> 3.19.9:
                          Receive the correct player status again when musik is stopped
                          -> 3.19.8:
                          Add safeguard for too high intervals
                          -> 3.19.7:
                          Fix doNotDisturb when using a time string
                          Would you like to upgrade alexa2 from @3.11.2 to @3.21.0 now? [(y)es, (n)o]: y
                          Update alexa2 from @3.11.2 to @3.21.0
                          Installing iobroker.alexa2@3.21.0... (System call)
                          Update "system.adapter.alexa2.0"
                          upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                          upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                          upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                          upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                          upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                          upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                          upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                          upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                          upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                          upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                          upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                          upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                          upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                          upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                          upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                          upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                          upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                          upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                          upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                          upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                          upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                          upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                          This upgrade of "admin" will at least introduce the following changes:
                          -> 6.2.23:
                          Prepare for future js-controller versions
                          Corrected deletion of objects
                          -> 6.2.22:
                          Corrected admin4 adapter settings
                          -> 6.2.21:
                          Corrected small JSON config issue
                          -> 6.2.20:
                          Corrected GUI issues
                          -> 6.2.19:
                          Corrected some issues
                          -> 6.2.18:
                          Corrected GUI bugs on custom settings
                          -> 6.2.17:
                          Corrected GUI bug on intro tab
                          BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                          Would you like to upgrade admin from @5.2.3 to @6.2.23 now? [(y)es, (n)o]: y
                          Update admin from @5.2.3 to @6.2.23
                          host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                          Installing iobroker.admin@6.2.23... (System call)
                          • ottiO otti
                            -> 3.21.0:
                            -> 3.20.1:
                            -> 3.20.0:
                            -> 3.19.10:
                            -> 3.19.9:
                            -> 3.19.8:
                            -> 3.19.7:
                            -> 6.2.23:
                            -> 6.2.22:
                            -> 6.2.21:
                            -> 6.2.20:
                            -> 6.2.19:
                            -> 6.2.18:
                            -> 6.2.17:
                            @otti
                            Da schaut doch okay aus.
                              @otti
                              ottiO Offline
                              ottiO Offline
                              otti
                              @thomas-braun ja genau,
                              jetzt updatet er alle Adapter,super,vielen Dank für eure Hilfe,
                              eine Frage noch,
                              benutzt jemand den Aqara P1 ,
                              habe den nicht im Zigbee Adapter eingebunden bekommen.
                              • ottiO otti
                                eine Frage noch,
                                @otti mach ein neues Thema auf!
                                steht auch in meinem verlinkten Thread ;-)
                                  ottiO Offline
                                  ottiO Offline
                                  otti
                                  @homoran said in Probleme beim Updaten von iobroker!:
                                  top,
                                  is bisschen viel auf einmal für mich,
                                  bin ja schon super froh das das updaten funzt
                                  • ottiO Offline
                                    ottiO Offline
                                    otti
                                    Would you like to upgrade javascript from @5.2.13 to @6.0.3 now? [(y)es, (n)o]: y
                                    Update javascript from @5.2.13 to @6.0.3
                                    Installing iobroker.javascript@6.0.3... (System call)
                                    Update "system.adapter.javascript.0"
                                    upload [102] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                    upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                    upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                                    upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
                                    upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
                                    upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_system.js google-blockly/own/blocks_system.js application/javascript
                                    upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/es.js google-blockly/own/msg/es.js application/javascript
                                    upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/manifest.json manifest.json application/json
                                    upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.8528da9b.js static/js/runtime-main.8528da9b.js application/javascript
                                    upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                    upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                    upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                    upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                    upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                    upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                    upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                    upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                    upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                    upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                    upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                    upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                    upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                    upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                    upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                    upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                    upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                    upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                    upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                    upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                    upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                    This upgrade of "iot" will at least introduce the following changes:
                                    -> 1.11.9:
                                    Fix temperature controlling for thermostats via alexa
                                    -> 1.11.8:
                                    Update dependencies to allow better automatic rebuild
                                    -> 1.11.7:
                                    Tried to correct URL key creation for Google home
                                    -> 1.11.5:
                                    Alisa: update for binary-sensor "motion" and "contact"
                                    -> 1.11.4:
                                    Fix crash cases reported by Sentry
                                    -> 1.11.3:
                                    Added the generation of URL key for services
                                    -> 1.11.2:
                                    Fix crash case reported by Sentry (IOBROKER-IOT-3P)
                                    Would you like to upgrade iot from @1.8.24 to @1.11.9 now? [(y)es, (n)o]: y
                                    Update iot from @1.8.24 to @1.11.9
                                    host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
                                    Installing iobroker.iot@1.11.9... (System call)
                                    upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                                    upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
                                    upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
                                    upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
                                    upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                    upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
                                    upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
                                    upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
                                    upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                    upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                    upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                    upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                    upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.2712396d.chunk.js static/js/2.2712396d.chunk.js application/javascript
                                    upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.2712396d.chunk.js.LICENSE.txt static/js/2.2712396d.chunk.js.LICENSE.txt text/plain
                                    upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.2712396d.chunk.js.map static/js/2.2712396d.chunk.js.map application/json
                                    upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.9016c1bc.chunk.js static/js/main.9016c1bc.chunk.js application/javascript
                                    upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.9016c1bc.chunk.js.map static/js/main.9016c1bc.chunk.js.map application/json
                                    upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ec5e4b6e.js static/js/runtime-main.ec5e4b6e.js application/javascript
                                    upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ec5e4b6e.js.map static/js/runtime-main.ec5e4b6e.js.map application/json
                                    host.raspberrypi Adapter "system.adapter.iot.0" is started
                                    This upgrade of "history" will at least introduce the following changes:
                                    -> 2.2.0:
                                    make sure getHistory works for all cases
                                    Add option to add comment and user info to results
                                    -> 2.1.7:
                                    Allow to remove a configuration value for "round" in config again
                                    -> 2.1.6:
                                    When not count is provided for aggregate "none" or "onchange" then the limit (default 2000) is used as count to define the number of data to return.
                                    -> 2.1.5:
                                    Ignore errors from forked process after response was sent for GetHistory
                                    -> 2.1.4:
                                    Make sure debug log is active according to the settings
                                    -> 2.1.3:
                                    Huge performance optimizations for GetHistory calls
                                    -> 2.1.2:
                                    Would you like to upgrade history from @1.10.5 to @2.2.0 now? [(y)es, (n)o]: y
                                    Update history from @1.10.5 to @2.2.0
                                    Installing iobroker.history@2.2.0... (System call)
                                    Update "system.adapter.history.0"
                                    upload [17] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
                                    upload [16] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
                                    upload [15] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                                    upload [14] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
                                    upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
                                    upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                                    upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                                    upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                                    This upgrade of "backitup" will at least introduce the following changes:
                                    -> 2.5.4:
                                    Fix maxBuffer for DB-Backups
                                    Docu updated
                                    Fix Dropbox error messages
                                    Grafana self signed Certificates added
                                    -> 2.5.3:
                                    dependencies updated
                                    -> 2.5.2:
                                    Bugfix Google Drive
                                    -> 2.5.1:
                                    Bugfix Google Drive
                                    -> 2.5.0:
                                    Google Drive authentication was fixed
                                    small Bugfix
                                    -> 2.4.16:
                                    small Bugfix
                                    -> 2.4.15:
                                    adapter-core updated
                                    path fix
                                    Would you like to upgrade backitup from @2.2.3 to @2.5.4 now? [(y)es, (n)o]: y
                                    Update backitup from @2.2.3 to @2.5.4
                                    host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                    Installing iobroker.backitup@2.5.4... (System call)
                                    Update "system.adapter.backitup.0"
                                    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                    host.raspberrypi Adapter "system.adapter.backitup.0" is started
                                    • ottiO Offline
                                      ottiO Offline
                                      otti
                                      leider sieht das ganze immer noch so aus
                                      ich könnte verzweifeln
                                      • ottiO otti
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        @otti Was ist denn DAS jetzt wieder für ein neues Thema ???
                                        @homoran sagte in Probleme beim Updaten von iobroker!:
                                        ottiO HomoranH 2 Antworten Letzte Antwort
                                          ottiO Offline
                                          ottiO Offline
                                          otti
                                          @djmarc75 das ist immer noch das update thema,
                                          warum so agressiv???
