  3. Einsteigerfragen
  4. Probleme beim Updaten von iobroker!
    5.6k
52 Beiträge 4 Kommentatoren 5.1k Aufrufe 3 Beobachtet
  • ottiO Offline
    ottiO Offline
    otti
    das war mein letzter Versuch....
    hoffe hab das jetzt richtig gemacht
    • ottiO otti
      @thomas-braun said in Probleme beim Updaten von iobroker!:
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ iob backup
      host.raspberrypi 2790 states saved
      host.raspberrypi 3436 objects saved
      Backup created: /opt/iobroker/backups/2022_11_19-15_34_39_backupiobroker.tar.gz
      pi@raspberrypi:/opt/iobroker $ iob stop
      pi@raspberrypi:/opt/iobroker $ iob update
      Used repository: stable
      Adapter    "admin"        : 6.2.23   , installed 5.2.3  [Updatable]
      Adapter    "alexa2"       : 3.21.0   , installed 3.11.2 [Updatable]
      Adapter    "backitup"     : 2.5.4    , installed 2.2.3  [Updatable]
      Adapter    "broadlink2"   : 2.1.5    , installed 2.1.5
      Adapter    "cloud"        : 4.2.2    , installed 4.1.0  [Updatable]
      Adapter    "discovery"    : 3.0.5    , installed 2.7.3  [Updatable]
      Adapter    "ham"          : 5.3.0    , installed 4.0.2  [Updatable]
      Adapter    "history"      : 2.2.0    , installed 1.10.5 [Updatable]
      Adapter    "hue"          : 3.7.1    , installed 3.5.31 [Updatable]
      Adapter    "iot"          : 1.11.9   , installed 1.8.24 [Updatable]
      Adapter    "javascript"   : 6.0.3    , installed 5.2.13 [Updatable]
      Controller "js-controller": 4.0.23   , installed 4.0.15 [Updatable]
      Adapter    "mihome"       : 1.4.0    , installed 1.3.7  [Updatable]
      Adapter    "mihome-vacuum": 3.8.6    , installed 3.3.1  [Updatable]
      Adapter    "tuya"         : 3.9.4    , installed 3.6.15 [Updatable]
      Adapter    "zigbee"       : 1.7.5    , installed 1.6.16 [Updatable]
      pi@raspberrypi:/opt/iobroker $ iob fix
      library: loaded
      Library version=2022-06-15
          Welcome to the ioBroker installation fixer!
          Script version: 2022-06-03
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease [15.0 kB]
      Get:2 http://archive.raspberrypi.org/debian bullseye InRelease [23.6 kB]
      Get:3 https://deb.nodesource.com/node_14.x bullseye InRelease [4,586 B]
      Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages [13.2 MB]
      Get:5 http://archive.raspberrypi.org/debian bullseye/main armhf Packages [311 kB]
      Get:6 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages [785 B]
      Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/contrib armhf Packages [60.2 kB]
      Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/non-free armhf Packages [106 kB]
      Fetched 13.8 MB in 19s (732 kB/s)
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker $ iob upgrade self
      Update js-controller from @4.0.15 to @4.0.23
      Stopped Objects DB
      Stopped States DB
      NPM version: 6.14.16
      Installing iobroker.js-controller@4.0.23... (System call)
      pi@raspberrypi:/opt/iobroker $ iob start
      @otti
      iobroker upgrade all
      sagt?
      ottiO 1 Antwort Letzte Antwort
        @otti
        sagt?
        ottiO Offline
        ottiO Offline
        otti
        @thomas-braun sorry,
        was sagt was???
        ich könnte Fernzugriff über Anydesk anbieten.....
        • ottiO otti
          was sagt was???
          @otti sagte in Probleme beim Updaten von iobroker!:
          was sagt was???
          das was im schwarzen Kasten steht
            was sagt was???
            ottiO Offline
            ottiO Offline
            otti
            @homoran achso,das soll ich mal eintippen richtig,
            • ottiO Offline
              ottiO Offline
              otti
              Geil,
              da tut sich was,
              na mal abwarten....
              HomoranH DJMarc75D 2 Antworten Letzte Antwort
              • ottiO otti
                was sagt was???
                Mein Lieblingsthema. Auf einem Server läuft kein Desktop, also auch kein AnyDesk.
                • ottiO otti
                  Geil,
                  da tut sich was,
                  na mal abwarten....
                  da tut sich was,
                  meinen Link hast du aber nicht gelesen?
                  dann wüsstest du:
                  zeigen, zeigen, zeigen!
                  • ottiO otti
                    Geil,
                    da tut sich was,
                    na mal abwarten....
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Geil,
                    da tut sich was,
                    na mal abwarten....
                    Geil,
                    was tut sich da,
                    mal abwarten ob Du es hier zeigen willst.....
                    Lehrling seit 1975 !!!
                      ottiO Offline
                      ottiO Offline
                      otti
                      @thomas-braun aber über Anydesk kannst du mein Terminal bedienen
                      • DJMarc75D DJMarc75
                        Geil,
                        da tut sich was,
                        na mal abwarten....
                        Geil,
                        was tut sich da,
                        ottiO Offline
                        ottiO Offline
                        otti
                        @djmarc75 ja zeig ich
                        • ottiO otti
                          @otti
                          Kennst du das Stück 'Warten auf Godot'?
                          Da gibt es jetzt eine Fortsetzung zu.
                          • ottiO Offline
                            ottiO Offline
                            otti
                            Would you like to upgrade cloud from @4.1.0 to @4.2.2 now? [(y)es, (n)o]: y
                            Update cloud from @4.1.0 to @4.2.2
                            Installing iobroker.cloud@4.2.2... (System call)
                            Update "system.adapter.cloud.0"
                            upload [17] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/actions.js actions.js application/javascript
                            upload [16] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/alexalogo.png alexalogo.png image/png
                            upload [15] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/blockly.js blockly.js application/javascript
                            upload [14] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/cloud.png cloud.png image/png
                            upload [13] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/de/translations.json i18n/de/translations.json application/json
                            upload [12] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/en/translations.json i18n/en/translations.json application/json
                            upload [11] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/es/translations.json i18n/es/translations.json application/json
                            upload [10] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                            upload [9] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/it/translations.json i18n/it/translations.json application/json
                            upload [8] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                            upload [7] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                            upload [6] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                            upload [5] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                            upload [4] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                            upload [3] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/img/info-big.png img/info-big.png image/png
                            upload [2] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/index_m.html index_m.html text/html
                            upload [1] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/jsonConfig.json jsonConfig.json application/json
                            upload [0] cloud.admin /opt/iobroker/node_modules/iobroker.cloud/admin/words.js words.js application/javascript
                            This upgrade of "alexa2" will at least introduce the following changes:
                            -> 3.21.0:
                            IMPORTANT: Because of rate limits by Amazon I decided to remove the update of smart home device values in intervals because it seems to produce too much load in Skills and Amazon systems.
                            Optimizes loading of smart home device states
                            Fixed issue with enabling/disabling of Alarms in combination with non-default music for the alarm
                            Prevented that Timers or Alarms that are long in the future to trigger their trigger state too early
                            Fixed deleting own user Messages state
                            Already request Notification updates when history registered a Notification action and do not wait for Push info to come in
                            -> 3.20.1:
                            make sure caching works correctly with multiple instances of the adapter
                            -> 3.20.0:
                            Increase minimum interval for requesting smart home device data to 15 minutes (900s) because of Amazon rate limits. Please do not try to work around it!
                            Cache Smart home device list and data to prevent too many requests when restarting adapter in short intervals and to prevent deleted smart home devices also on further rate limit issues
                            -> 3.19.10:
                            Fix issue in retry handling when rate limit exceeded is returned by Amazon
                            Do not clean up Smart Home Device objects for now - delete manually if you remove a device
                            -> 3.19.9:
                            Receive the correct player status again when musik is stopped
                            -> 3.19.8:
                            Add safeguard for too high intervals
                            -> 3.19.7:
                            Fix doNotDisturb when using a time string
                            Would you like to upgrade alexa2 from @3.11.2 to @3.21.0 now? [(y)es, (n)o]: y
                            Update alexa2 from @3.11.2 to @3.21.0
                            Installing iobroker.alexa2@3.21.0... (System call)
                            Update "system.adapter.alexa2.0"
                            upload [27] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
                            upload [20] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot3.png icons/echo_dot3.png image/png
                            upload [19] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_dot4.png icons/echo_dot4.png image/png
                            upload [18] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_flex.png icons/echo_flex.png image/png
                            upload [17] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_plus2.png icons/echo_plus2.png image/png
                            upload [16] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show.png icons/echo_show.png image/png
                            upload [15] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show2.png icons/echo_show2.png image/png
                            upload [14] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_show5.png icons/echo_show5.png image/png
                            upload [13] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_studio.png icons/echo_studio.png image/png
                            upload [12] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/echo_sub.png icons/echo_sub.png image/png
                            upload [11] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetab.png icons/firetab.png image/png
                            upload [10] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/firetv.png icons/firetv.png image/png
                            upload [9] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/microphone.png icons/microphone.png image/png
                            upload [8] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/multiroom.png icons/multiroom.png image/png
                            upload [7] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/raspi.png icons/raspi.png image/png
                            upload [6] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/reverb.png icons/reverb.png image/png
                            upload [5] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/sonos.png icons/sonos.png image/png
                            upload [4] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/icons/spot.png icons/spot.png image/png
                            upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
                            upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/info.png info.png image/png
                            upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/warning.png warning.png image/png
                            upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
                            This upgrade of "admin" will at least introduce the following changes:
                            -> 6.2.23:
                            Prepare for future js-controller versions
                            Corrected deletion of objects
                            -> 6.2.22:
                            Corrected admin4 adapter settings
                            -> 6.2.21:
                            Corrected small JSON config issue
                            -> 6.2.20:
                            Corrected GUI issues
                            -> 6.2.19:
                            Corrected some issues
                            -> 6.2.18:
                            Corrected GUI bugs on custom settings
                            -> 6.2.17:
                            Corrected GUI bug on intro tab
                            BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                            Would you like to upgrade admin from @5.2.3 to @6.2.23 now? [(y)es, (n)o]: y
                            Update admin from @5.2.3 to @6.2.23
                            host.raspberrypi Adapter "system.adapter.admin.0" is stopped.
                            Installing iobroker.admin@6.2.23... (System call)
                            • ottiO otti
                              -> 3.21.0:
                              -> 3.20.1:
                              -> 3.20.0:
                              -> 3.19.10:
                              -> 3.19.9:
                              -> 3.19.8:
                              -> 3.19.7:
                              -> 6.2.23:
                              -> 6.2.22:
                              -> 6.2.21:
                              -> 6.2.20:
                              -> 6.2.19:
                              -> 6.2.18:
                              -> 6.2.17:
                              @otti
                              Da schaut doch okay aus.
                                @otti
                                ottiO Offline
                                ottiO Offline
                                otti
                                @thomas-braun ja genau,
                                jetzt updatet er alle Adapter,super,vielen Dank für eure Hilfe,
                                eine Frage noch,
                                benutzt jemand den Aqara P1 ,
                                habe den nicht im Zigbee Adapter eingebunden bekommen.
                                • ottiO otti
                                  eine Frage noch,
                                  @otti mach ein neues Thema auf!
                                  steht auch in meinem verlinkten Thread ;-)
                                    ottiO Offline
                                    ottiO Offline
                                    otti
                                    @homoran said in Probleme beim Updaten von iobroker!:
                                    top,
                                    is bisschen viel auf einmal für mich,
                                    bin ja schon super froh das das updaten funzt
                                    • ottiO Offline
                                      ottiO Offline
                                      otti
                                      Would you like to upgrade javascript from @5.2.13 to @6.0.3 now? [(y)es, (n)o]: y
                                      Update javascript from @5.2.13 to @6.0.3
                                      Installing iobroker.javascript@6.0.3... (System call)
                                      Update "system.adapter.javascript.0"
                                      upload [102] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                      upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                      upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/delete.ogg google-blockly/media/delete.ogg audio/ogg
                                      upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/media/quote0.png google-blockly/media/quote0.png image/png
                                      upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/msg/js/pl.js google-blockly/msg/js/pl.js application/javascript
                                      upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/blocks_system.js google-blockly/own/blocks_system.js application/javascript
                                      upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/es.js google-blockly/own/msg/es.js application/javascript
                                      upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/manifest.json manifest.json application/json
                                      upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/js/runtime-main.8528da9b.js static/js/runtime-main.8528da9b.js application/javascript
                                      upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/configure.js vs/configure.js application/javascript
                                      upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.css vs/editor/editor.main.css text/css
                                      upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                      upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                      upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                      upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                      upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                      upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                      upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                      upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                      upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                      upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                      upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                      upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                      upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                      upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                      upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                      upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                      upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                      upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                      upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                      This upgrade of "iot" will at least introduce the following changes:
                                      -> 1.11.9:
                                      Fix temperature controlling for thermostats via alexa
                                      -> 1.11.8:
                                      Update dependencies to allow better automatic rebuild
                                      -> 1.11.7:
                                      Tried to correct URL key creation for Google home
                                      -> 1.11.5:
                                      Alisa: update for binary-sensor "motion" and "contact"
                                      -> 1.11.4:
                                      Fix crash cases reported by Sentry
                                      -> 1.11.3:
                                      Added the generation of URL key for services
                                      -> 1.11.2:
                                      Fix crash case reported by Sentry (IOBROKER-IOT-3P)
                                      Would you like to upgrade iot from @1.8.24 to @1.11.9 now? [(y)es, (n)o]: y
                                      Update iot from @1.8.24 to @1.11.9
                                      host.raspberrypi Adapter "system.adapter.iot.0" is stopped.
                                      Installing iobroker.iot@1.11.9... (System call)
                                      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
                                      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
                                      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
                                      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
                                      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
                                      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
                                      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
                                      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.2712396d.chunk.js static/js/2.2712396d.chunk.js application/javascript
                                      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.2712396d.chunk.js.LICENSE.txt static/js/2.2712396d.chunk.js.LICENSE.txt text/plain
                                      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.2712396d.chunk.js.map static/js/2.2712396d.chunk.js.map application/json
                                      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.9016c1bc.chunk.js static/js/main.9016c1bc.chunk.js application/javascript
                                      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.9016c1bc.chunk.js.map static/js/main.9016c1bc.chunk.js.map application/json
                                      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ec5e4b6e.js static/js/runtime-main.ec5e4b6e.js application/javascript
                                      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.ec5e4b6e.js.map static/js/runtime-main.ec5e4b6e.js.map application/json
                                      host.raspberrypi Adapter "system.adapter.iot.0" is started
                                      This upgrade of "history" will at least introduce the following changes:
                                      -> 2.2.0:
                                      make sure getHistory works for all cases
                                      Add option to add comment and user info to results
                                      -> 2.1.7:
                                      Allow to remove a configuration value for "round" in config again
                                      -> 2.1.6:
                                      When not count is provided for aggregate "none" or "onchange" then the limit (default 2000) is used as count to define the number of data to return.
                                      -> 2.1.5:
                                      Ignore errors from forked process after response was sent for GetHistory
                                      -> 2.1.4:
                                      Make sure debug log is active according to the settings
                                      -> 2.1.3:
                                      Huge performance optimizations for GetHistory calls
                                      -> 2.1.2:
                                      Would you like to upgrade history from @1.10.5 to @2.2.0 now? [(y)es, (n)o]: y
                                      Update history from @1.10.5 to @2.2.0
                                      Installing iobroker.history@2.2.0... (System call)
                                      Update "system.adapter.history.0"
                                      upload [17] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom.html custom.html text/html
                                      upload [16] history.admin /opt/iobroker/node_modules/iobroker.history/admin/custom_m.html custom_m.html text/html
                                      upload [15] history.admin /opt/iobroker/node_modules/iobroker.history/admin/history.png history.png image/png
                                      upload [14] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      upload [13] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      upload [12] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      upload [11] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      upload [10] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      upload [9] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      upload [8] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      upload [7] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      upload [6] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      upload [5] history.admin /opt/iobroker/node_modules/iobroker.history/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      upload [4] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index.html index.html text/html
                                      upload [3] history.admin /opt/iobroker/node_modules/iobroker.history/admin/index_m.html index_m.html text/html
                                      upload [2] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonConfig.json jsonConfig.json application/json
                                      upload [1] history.admin /opt/iobroker/node_modules/iobroker.history/admin/jsonCustom.json jsonCustom.json application/json
                                      upload [0] history.admin /opt/iobroker/node_modules/iobroker.history/admin/words.js words.js application/javascript
                                      This upgrade of "backitup" will at least introduce the following changes:
                                      -> 2.5.4:
                                      Fix maxBuffer for DB-Backups
                                      Docu updated
                                      Fix Dropbox error messages
                                      Grafana self signed Certificates added
                                      -> 2.5.3:
                                      dependencies updated
                                      -> 2.5.2:
                                      Bugfix Google Drive
                                      -> 2.5.1:
                                      Bugfix Google Drive
                                      -> 2.5.0:
                                      Google Drive authentication was fixed
                                      small Bugfix
                                      -> 2.4.16:
                                      small Bugfix
                                      -> 2.4.15:
                                      adapter-core updated
                                      path fix
                                      Would you like to upgrade backitup from @2.2.3 to @2.5.4 now? [(y)es, (n)o]: y
                                      Update backitup from @2.2.3 to @2.5.4
                                      host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                      Installing iobroker.backitup@2.5.4... (System call)
                                      Update "system.adapter.backitup.0"
                                      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
                                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                      host.raspberrypi Adapter "system.adapter.backitup.0" is started
                                      • ottiO Offline
                                        ottiO Offline
                                        otti
                                        leider sieht das ganze immer noch so aus
                                        ich könnte verzweifeln
                                        • ottiO otti
                                          DJMarc75D Offline
                                          DJMarc75D Offline
                                          DJMarc75
                                          @otti Was ist denn DAS jetzt wieder für ein neues Thema ???
                                          @homoran sagte in Probleme beim Updaten von iobroker!:
                                          ottiO HomoranH 2 Antworten Letzte Antwort
