  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. Zigbee usb 3,0 Dongle plus mit EFR32MG 21 Chip
    5.1k
25 Beiträge 4 Kommentatoren 3.5k Aufrufe 3 Beobachtet
  • H Horst B
    Hallo Thomas
    hier der Log...Danke Gruß Horst
    zigbee.0
    2022-11-16 17:50:05.216 info Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-11-16 17:50:05.190 error Error herdsman start
    zigbee.0
    2022-11-16 17:50:05.188 error Failed to start Zigbee
    zigbee.0
    2022-11-16 17:50:05.185 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812133736-if00'"
    zigbee.0
    2022-11-16 17:50:05.166 info Starting Zigbee npm ...
    zigbee.0
    2022-11-16 17:50:05.163 info Try to reconnect. 1 attempts left
    admin.0
    2022-11-16 17:49:59.604 info <== Disconnect system.user.admin from ::ffff:192.168.178.20
    zigbee.0
    2022-11-16 17:49:55.634 info Installed Version: iobroker.zigbee@1.7.5
    zigbee.0
    2022-11-16 17:49:55.152 error Error herdsman start
    zigbee.0
    2022-11-16 17:49:55.150 error Failed to start Zigbee
    zigbee.0
    2022-11-16 17:49:55.148 error Starting zigbee-herdsman problem : "Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812133736-if00'"
    zigbee.0
    2022-11-16 17:49:54.308 info Starting Zigbee npm ...
    zigbee.0
    2022-11-16 17:49:54.300 info delete old Backup files. keep only last 10
    zigbee.0
    2022-11-16 17:49:53.979 info starting. Version 1.7.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v16.18.0, js-controller: 4.0.23
    @horst-b
    Bitte Text in CodeTags posten.
    H 1 Antwort Letzte Antwort
      @horst-b
      Horst B
      @thomas-braun sorry..weiß nicht genau was du meinst??
      • H Horst B
        @horst-b
          @horst-b
          Horst B
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          admin.0
          2022-11-16 17:49:59.604 info <== Disconnect system.user.admin from ::ffff:192.168.xxx.xxx
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          zigbee.0
          • H Horst B
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            admin.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            zigbee.0
            @horst-b
            ls -lA /dev/serial/by-id/
              @horst-b
              Horst B
              schrieb am zuletzt editiert von Horst B
              @thomas-braun said in Zigbee usb 3,0 Dongle plus mit EFR32MG 21 Chip:
              lrwxrwxrwx 1 root root 13 Nov 15 17:04 usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Pl                                      us_V2_20220812133736-if00 -> ../../ttyACM0
              • H Horst B
                Horst B
                @horst-b ```
                usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20220812133736-if00 -> ../../ttyACM0
                • H Horst B
                  @horst-b ```
                  @horst-b
                  Vollständig posten.
                    @horst-b
                    Vollständig posten.
                    Horst B
                    pi@192.168.178.38's password:
                    Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aar       ch64
                    permitted by applicable law.
                    Last login: Wed Nov 16 22:40:37 2022 from 192.168.178.20
                    pi@raspberrypi:~ $ lsusb
                    Bus 001 Device 005: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongl       e Plus V2
                    Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC       9512/9514 Fast Ethernet Adapter
                    Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9       514 Hub
                    pi@raspberrypi:~ $ ls -lA /dev/serial/by-id/
                    total 0
                    pi@raspberrypi:~ $
                    • H Horst B
                      total 0
                      pi@raspberrypi:~ $
                      Horst B
                      Hallo Thomas. Konntest du etwas damit anfangen?
                      • H Horst B
                        @horst-b
                        Hast du auch genau diesen Link in den Adapter kopiert?
                          @horst-b
                          Horst B
                          @thomas-braun Hallo Thomas...Ja habe es gerade nochmal gemacht und passt so..Habe es auch so im Adapter bei Einstellungen eingegeben
                          • H Horst B
                            Horst B
                            @ThomasBraun
                            • Z Offline
                              Z Offline
                              zgadgeter
                              Mein alter 2531 zigbee scheint kaputt zu sein. Er verliert ständig die Verbindung zu den Iobroker, und wenn er sich verbindet ist das Licht nur Rot, bzw. zeigt er lsusb immer andere Verbindungseinstellungen. Oftmals leuchtet das licht überhaupt nicht, scheint irgendwie auch ein Wackelkontakt zu haben. Andere USB ports machen kein Unterschied.
                              So, also suche ich einen neuen zigbee stick. Momentan gibt es ein Angebot bei Amazon für einen mit diesem Chip (https://www.amazon.de/gp/product/B0B6P22YJC/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
                              Kann mir jemand von dem Stick berichten? Gut, stark, muss der noch geflasht werden, etct.
                              Sorry, einfache Fragen....aber vielleicht kann mir jemand helfen? danke
                              • Z zgadgeter
                                @zgadgeter
                                Der Chipsatz wird als zur Zeit als experimentel bezeichnet:
                                https://www.zigbee2mqtt.io/guide/adapters/#not-recommended
                                Ob und wann das mal als stabil deklariert werden wird...
                                Z 1 Antwort Letzte Antwort
                                  @zgadgeter
                                  Z Offline
                                  Z Offline
                                  zgadgeter
                                  schrieb am zuletzt editiert von zgadgeter
                                  @thomas-braun Hmm, danke der schnellen Antwort. Stellst sich die Frage, welchen neuen sollte mann jetzt nehmen? Ist für eine relative kleine Zweitwohnung. Für unser haus habe ich den TI CC26X2R1, und dieser funktioniert jetzt richtig gut.
                                  Was gibt es sonst neues?
                                  • Z zgadgeter
                                    @zgadgeter
                                    Auf der gleichen Seite gibt es noch eine Kategorie 'recommended'.
                                      @zgadgeter
                                      Z Offline
                                      Z Offline
                                      zgadgeter
                                      @thomas-braun Ok, danke. Und hast Du einen Favorit?
                                      • Z zgadgeter
                                        @zgadgeter
                                        Ich selber habe den Stick von slaesh im Einsatz. Hier im Forum wird aber im Marktplatz auch immer entsprechendes angeboten. Ich glaube @dimaiv hat da immer was im Portfolio.
                                          @zgadgeter
                                          Z Offline
                                          Z Offline
                                          zgadgeter
                                          @thomas-braun Ok, danke. bin bei dem @dimaiv fündig geworden.
