  4. Gelöst: Nach Restore: No connection to databases possible
connection to databasesjavascript updaterestartrestore backupupgrade bullseyeupgrade nodejs
32 Beiträge 2 Kommentatoren 3.1k Aufrufe 3 Beobachtet
    @dragricola sagte in Nach Restore: No connection to databases possible, restart:
    Hilft das Log aus meinem letzten Beitrag weiter?
    Jein.
    Hostname geändert?
    Bitte Auszüge in Textform in CodeTags eingebettet heir rein.
    dragricola
    Den Host-Namen habe ich meines Wissens wieder bei der Installation gleich vergeben. Allerdings ohne das präfix host. davor.
    2022-11-12 16:10:44.878  - info: host.raspberrypi4-iob iobroker _restart
    2022-11-12 16:10:50.341  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2022-11-12 16:10:50.349  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-11-12 16:10:50.350  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.18.1
    2022-11-12 16:10:50.353  - info: host.raspberrypi4-iob ip addresses: 192.168.178.126 fe80::436b:c1e:289f:c0ed
    2022-11-12 16:11:08.610  - error: host.raspberrypi4-iob Cannot read system.config: null (OK when migrating or restoring)
    2022-11-12 16:11:08.625  - error: host.raspberrypi4-iob Cannot find view "system" for search "host"
    2022-11-12 16:11:08.715  - info: host.raspberrypi4-iob connected to Objects and States
    2022-11-12 16:11:08.745  - info: host.raspberrypi4-iob Node.js version has changed from unknown to 16.18.1
    2022-11-12 16:11:08.793  - info: host.raspberrypi4-iob added notifications configuration of host
    2022-11-12 16:11:08.800  - info: host.raspberrypi4-iob Successfully updated capabilities "cap_net_admin, cap_net_bind_service, cap_net_raw" for /usr/bin/node
    2022-11-12 16:11:08.811  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
    2022-11-12 16:11:08.813  - error: host.raspberrypi4-iob Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2022-11-12 16:11:08.826  - info: host.raspberrypi4-iob Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-11-12 16:11:08.836  - error: host.raspberrypi4-iob Cannot find view "system" for search "state"
    2022-11-12 16:11:08.837  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
    2022-11-12 16:11:08.841  - error: host.raspberrypi4-iob Could not collect system.host.raspberrypi4-iob states to check for obsolete states: Error: Cannot find view "system"
    2022-11-12 16:11:08.842  - error: host.raspberrypi4-iob  _design/system missing - call node iobroker.js setup
    2022-11-12 16:11:08.843  - info: host.raspberrypi4-iob  no instances found
    2022-11-12 16:11:09.054  - info: host.raspberrypi4-iob Created UUID: 958fb34d-ae20-1453-74c4-b251ccab0b04
    2022-11-12 16:25:19.450  - info: host.raspberrypi4-iob received SIGTERM
    2022-11-12 16:25:19.469  - info: host.raspberrypi4-iob terminated
    2022-11-12 16:25:21.831  - info: host.raspberrypi4-iob iobroker.js-controller version 4.0.23 js-controller starting
    2022-11-12 16:25:21.838  - info: host.raspberrypi4-iob Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
    2022-11-12 16:25:21.840  - info: host.raspberrypi4-iob hostname: raspberrypi4-iob, node: v16.18.1
    2022-11-12 16:25:21.842  - info: host.raspberrypi4-iob ip addresses: 192.168.178.126 fe80::436b:c1e:289f:c0ed
    2022-11-12 16:25:21.936  - error: host.raspberrypi4-iob Cannot read system.config: null (OK when migrating or restoring)
    2022-11-12 16:25:21.948  - error: host.raspberrypi4-iob Cannot find view "system" for search "host"
    2022-11-12 16:25:22.013  - info: host.raspberrypi4-iob connected to Objects and States
    2022-11-12 16:25:22.035  - info: host.raspberrypi4-iob added notifications configuration of host
    2022-11-12 16:25:22.054  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
    2022-11-12 16:25:22.057  - error: host.raspberrypi4-iob Could not add notifications config of this host: Could not get notifications setup from instances: Cannot find view "system"
    2022-11-12 16:25:22.085  - info: host.raspberrypi4-iob Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-11-12 16:25:22.097  - error: host.raspberrypi4-iob Cannot find view "system" for search "state"
    2022-11-12 16:25:22.099  - error: host.raspberrypi4-iob Cannot find view "system" for search "instance"
    2022-11-12 16:25:22.105  - error: host.raspberrypi4-iob Could not collect system.host.raspberrypi4-iob states to check for obsolete states: Error: Cannot find view "system"
    2022-11-12 16:25:22.107  - error: host.raspberrypi4-iob  _design/system missing - call node iobroker.js setup
    2022-11-12 16:25:22.108  - info: host.raspberrypi4-iob  no instances found
    • D dragricola
      @dragricola
      Versuch mal
      iob stop
      iob host this
      iob start
        @dragricola
        Versuch mal
        iob stop
        iob host this
        iob start
        dragricola
        pi@raspberrypi4-iob:~ $ iob stop
        pi@raspberrypi4-iob:~ $ iob host this
        An unknown error occurred: Cannot find view "system"
        pi@raspberrypi4-iob:~ $ iob start
        • Thomas BraunT Online
          @dragricola
          iobroker setup first
            @dragricola
            dragricola
            jaa, ... jetzt meldet sich der admin wieder mit der Welcome-Seite und dem Setup Assistenten. Kann ich den irgendwie überspringen? Setup ist ja bereits erfolgt.
            Ich würde das ganze auch nochmals mit bullseye durchführen. Was gibt es dabei zu beachten?
            • D dragricola
              Weiß ich nicht, ich setze meine Kisten nicht sooooo oft neu auf.
              Skip dich einfach durch, so viel ist da ja nicht einzustellen.
              Das gleiche wie hier.
                dragricola
                Hallo Thomas Braun,
                dank Deiner Anleitung lief das System einigermaßen wieder auf buster, sodass ich hoffen konnte, dass ich es auch unter bullseye zum Laufen bringen kann. Es gab aber noch Probleme mit dem VIS-Adapter und nachdem ich im Forum zu diesem Problem nachgelesen habe, und dort empfohlen wurde vor dem Restart vis 1.4.0, web u.a. Adapter zu installieren, habe ich nun ioBroker auf Bullseye 64Bit neu aufgesetzt und vor dem Einspielen des Backups auch noch mariadb und pihole installiert. sudo apt update liefert nun:
                pi@raspberrypi4-iob:~ $ sudo apt update
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                Fetched 48.4 kB in 1s (37.0 kB/s)
                Reading package lists... Done
                All packages are up to date.
                Das Restore lief problemlois durch:
                [EXIT] 0 **** Restore completed successfully!! ****
                Allerdings war danach der Admin nicht mehr erreichbar. Ich habe daraufhin wieder die von Dir vorgeschlagenen Schritte durchgeführt:
                Danach lief der Admin zwar wieder, allerdings gab es nur die Instanzen admin und backitup und offensichtlich kann iobroker die im restore eingespielten Adapter nicht nachladen:
                admin.0
                	2022-11-13 11:09:40.266	warn	Cannot update rating: connect ECONNREFUSED 79.143.182.215:443
                admin.0
                	2022-11-13 11:08:24.100	warn	Cannot update rating: connect ECONNREFUSED 79.143.182.215:443
                	2022-11-13 11:07:53.372	info	Updating repository "live-stable" under "http://iobroker.live/repo/sources-dist.json"
                admin.0
                	2022-11-13 11:07:53.329	info	==> Connected system.user.admin from ::ffff:192.168.178.182
                admin.0
                	2022-11-13 11:07:52.926	info	<== Disconnect system.user.admin from ::ffff:192.168.178.182 admin
                admin.0
                	2022-11-13 11:06:55.164	warn	Active repository "stable" cannot be read
                admin.0
                	2022-11-13 11:06:55.163	warn	Repository cannot be read: Active repo - stable
                	2022-11-13 11:06:53.019	error	Error by updating repository "stable" under "http://download.iobroker.net/sources-dist.json": Cannot download repository file from "http://download.iobroker.net/sources-dist.json": connect ECONNREFUSED 79.143.182.215:80
                Nachdem ich das repository "live-stable" aktiviert hatte (Zeile6) ging wenigstens die Errormeldung (Zeile 16) weg. Aber
                die Warnungen (Zeilen 2 und 4) kommen regelmäßig wieder. Ping auf download.iobroker.net und iobroker.live funktioniert problemlos:
                pi@raspberrypi4-iob:~ $ ping download.iobroker.net
                PING download.iobroker.net (79.143.182.215) 56(84) bytes of data.
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=1 ttl=57 time=14.9 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=2 ttl=57 time=13.8 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=3 ttl=57 time=14.2 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=4 ttl=57 time=14.1 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=5 ttl=57 time=14.2 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=6 ttl=57 time=14.0 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=7 ttl=57 time=13.8 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=8 ttl=57 time=14.1 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=9 ttl=57 time=14.1 ms
                64 bytes from m0855.contabo.host (79.143.182.215): icmp_seq=10 ttl=57 time=14.3 ms
                ^C
                --- download.iobroker.net ping statistics ---
                10 packets transmitted, 10 received, 0% packet loss, time 9004ms
                rtt min/avg/max/mdev = 13.801/14.141/14.853/0.281 ms
                pi@raspberrypi4-iob:~ $ ping iobroker.live
                PING iobroker.live (217.160.0.211) 56(84) bytes of data.
                64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=1 ttl=58 time=9.40 ms
                64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=2 ttl=58 time=8.51 ms
                64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=3 ttl=58 time=8.54 ms
                64 bytes from 217-160-0-211.elastic-ssl.ui-r.com (217.160.0.211): icmp_seq=4 ttl=58 time=8.55 ms
                ^C
                --- iobroker.live ping statistics ---
                4 packets transmitted, 4 received, 0% packet loss, time 3002ms
                rtt min/avg/max/mdev = 8.506/8.747/9.398/0.375 ms
                Auch das Deaktivieren von pihole löste das Problem nicht. Was ist zu tun, damit die Adapter verfügbar werden?
                • D dragricola
                  Hallo Thomas Braun,
                  admin.0
                  admin.0
                  admin.0
                  admin.0
                  admin.0
                  admin.0
                  ^C
                  ^C
                  @dragricola
                  Im Moment klemmt es auf dem iobroker-Server.
                  Versuch es später wieder.
                    @dragricola
                    dragricola
                    schrieb am zuletzt editiert von dragricola
                    ja, da hatte ich wohl Pech beim Timing! Jetzt klappt der Zugriff auf download.iobroker.net wieder! Nach einem erneuten Zurückspielen des Backups konnte der Restore-Vorgang erfolgreich abgeschlossen werden. Nochmals ganz herzlichen Dank für Deine prompte bereitwillige Hilfe! Ohne diese hätte ich das nicht hinbekommen.
                    Es würde mich allerdings noch interessieren, was der ursprüngliche Fehler war. Liege ich richtig, dass mein Problem hauptsächlich dadurch verursacht wurde, dass ich bei der Backup-Konfiguration das Häkchen bei Redis nicht gesetzt hatte und somit Redis nicht im Backup eingeschlossen war? Wenn ja, hätte ich das kompensieren können, wenn ich vor dem Restore Redis installiert hätte?
                    • D dragricola
                      @dragricola
                      Das Paket 'redis' wird nicht gesichert, das ist Teil des Betriebssystems.
                      Es werden nur die Daten selber gesichert, der redis-server muss dann natürlich zuvor wieder bereit gestellt werden.
                        @dragricola
                        dragricola
                        Vielen Dank, damit ist mein Problem gelöst! Wie kann ich den Status des Beitrags auf "gelöst" setzten?
                        • D dragricola
                          @dragricola
                          Dein Eröffnungsposting entsprechend im Titel ergänzen.
                            @dragricola
                            dragricola
                            nachdem nun nach der Umstellung auf Bullseye fast alle Funktionen meines Servers wieder laufen, bleibt jedoch noch das Restproblem, dass ich meine Visualisierung nicht mehr editieren kann. Die Instanz vis.0 läuft zwar wieder, jedoch immer, wenn ich neue Widgets einfügen oder andere Änderungen vornehmen will, werden sie nicht übernommen. Auch kann ich aus dem vis-editor nicht mehr mit dem kleinen schwarzen Dreieck in der linken oberen Ecke direkt in die runtime-umgebung der editierten Seite wechseln. Es erscheint dann manchmal in Rot der Hinweis "Verbindungsfehler".
                            Des weiteren lassen sich die folgenden Instanzen nicht konfigurieren: vis-fancyswitch.0, vis-jqui-mfd.0, vis-hqwidgets.0, vis-materialdesign.0, vis-timeandweather.0. Wenn man auf den Schraubenschlüssel klickt erscheint die Meldung "File index_m.html not found". Diese Meldung erscheint auch bei den Instanzen simple-api.0 und sourceanalytix.0, die allerdings einen grünen Status bei Verbindung zum Host und Lebenszeichen haben.
                            Wie komme ich hier weiter?
                            Bin ich hier noch richtig oder sollte ich einen neuen Thread eröffnen?
                            • D dragricola
                              @dragricola sagte in Gelöst: Nach Restore: No connection to databases possible:
                              Mit Auszügen aus dem LogFile. Aber besser in einem neuen Thread, pro Problem einer.
                              iobroker upload all
                              ausgeführt?
                                iobroker upload all
                                ausgeführt?
                                dragricola
                                @thomas-braun said in Gelöst: Nach Restore: No connection to databases possible:
                                iobroker upload all
                                Ja gerade jetzt eben, aber ich werde nicht wirklich schlau daraus.
                                Die Antwort ist zu lang für diesen Post. Ich habe deshalb viele Zeilen entfernt, die für miche keine neue Info enthielten. Ich hoffe ich habe nicht zu viel gekürzt.
                                pi@raspberrypi4-iob:~ $ iobroker upload all
                                upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.pn        g admin.png image/png
                                upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/c        ustomComponents.js.map custom/customComponents.js.map application/json
                                upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/t        ranslations.json i18n/pl/translations.json application/json
                                upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/t        ranslations.json i18n/pt/translations.json application/json
                                upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/t        ranslations.json i18n/ru/translations.json application/json
                                upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/t        ranslations.json i18n/uk/translations.json application/json
                                upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-c        n/translations.json i18n/zh-cn/translations.json application/json
                                upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfi        g.json5 jsonConfig.json5 application/json5
                                Update "system.adapter.admin.0"
                                upload [21] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manage        r/admin/adapter-settings.js adapter-settings.js application/javascript
                                upload [1] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager        /admin/type-detector.js type-detector.js application/javascript
                                upload [0] alias-manager.admin /opt/iobroker/node_modules/iobroker.alias-manager        /admin/words.js words.js application/javascript
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.alias-manager/www" was not        found! Nothing was uploaded or deleted.
                                upload [10] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/i18n/d        e/translations.json i18n/de/translations.json application/json
                                upload [1] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/mh-logo        .png mh-logo.png image/png
                                upload [0] alpha2.admin /opt/iobroker/node_modules/iobroker.alpha2/admin/words.j        s words.js application/javascript
                                upload [19] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ad        apter-settings.js adapter-settings.js application/javascript
                                upload [18] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/ba        ckitup.png backitup.png image/png
                                upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab        _m.html tab_m.html text/html
                                upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab        _m.js tab_m.js application/javascript
                                upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/wor        ds.js words.js application/javascript
                                upload [4] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [1] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/style.css style.css text/css
                                upload [0] coronavirus-statistics.admin /opt/iobroker/node_modules/iobroker.coro        navirus-statistics/admin/words.js words.js application/javascript
                                upload [482] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin        /daswettercom.png daswettercom.png image/png
                                upload [450] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin        /icons/tiempo-weather/galeria1/10.png icons/tiempo-weather/galeria1/10.png image        /png
                                upload [2] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/i        ndex_m.html index_m.html text/html
                                upload [1] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/j        sonConfig.json jsonConfig.json application/json
                                upload [0] daswetter.admin /opt/iobroker/node_modules/iobroker.daswetter/admin/w        ords.js words.js application/javascript
                                upload [12] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/denon.pn        g denon.png image/png
                                upload [11] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/i18n/de/        translations.json i18n/de/translations.json application/json
                                upload [1] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/index_m.h        tml index_m.html text/html
                                upload [0] denon.admin /opt/iobroker/node_modules/iobroker.denon/admin/words.js        words.js application/javascript
                                upload [136] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/ass        et-manifest.json asset-manifest.json application/json
                                upload [100] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/Consumption.fecd7a10.                                  svg static/media/Consumption.fecd7a10.svg image/svg+xml
                                upload [2] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/static/media/names.e7efb528.txt stat                                  ic/media/names.e7efb528.txt text/plain
                                upload [1] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/tab.html tab.html text/html
                                upload [0] devices.admin /opt/iobroker/node_modules/iobroker.devices/admin/vendor/socket.io.js vendor/socket.io                                  .js application/javascript
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.devices/www" was not found! Nothing was uploaded or delete                                  d.
                                upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png imag                                  e/png
                                upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html                                   text/html
                                upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools                                  .js application/javascript
                                upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/ja                                  vascript
                                upload [15] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/dwd.png dwd.png image/png
                                upload [3] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/index_m.html index_m.html text/html
                                upload [2] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/jsonConfig.json jsonConfig.json application/                                  json
                                upload [1] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/regions.js regions.js application/javascript
                                upload [0] dwd.admin /opt/iobroker/node_modules/iobroker.dwd/admin/words.js words.js application/javascript
                                No alive host found which has the adapter echarts installed! No upload possible. Skipped.
                                upload [4] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/feiertage.png feiertage.png imag                                  e/png
                                upload [1] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/index_m.html index_m.html text/h                                  tml
                                upload [0] feiertage.admin /opt/iobroker/node_modules/iobroker.feiertage/admin/words.js words.js application/ja                                  vascript
                                upload [0] flot.admin /opt/iobroker/node_modules/iobroker.flot/admin/flot.png flot.png image/png
                                upload [23] flot /opt/iobroker/node_modules/iobroker.flot/www/css/images/128/bar-alpha.png css/images/128/bar-a                                  lpha.png image/png
                                upload [2] flot /opt/iobroker/node_modules/iobroker.flot/www/js/flot.js.map js/flot.js.map application/json
                                upload [1] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html preset.html text/html
                                upload [0] flot /opt/iobroker/node_modules/iobroker.flot/www/preset.html.map preset.html.map application/json
                                upload [4] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [3] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/fritzdect_logo.png fritzdect_log                                  o.png image/png
                                upload [2] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/index_m.html index_m.html text/h                                  tml
                                upload [1] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/style.css style.css text/css
                                upload [0] fritzdect.admin /opt/iobroker/node_modules/iobroker.fritzdect/admin/words.js words.js application/ja                                  vascript
                                Adapter "system.adapter.vis.0" restarted.
                                No alive host found which has the adapter history installed! No upload possible. Skipped.
                                upload [13] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/homeconnect.png homeconnect                                  .png image/png
                                upload [12] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/de/translations.json i                                  18n/de/translations.json application/json
                                upload [11] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/i18n/en/translations.json i                                  18n/en/translations.json application/json
                                upload [2] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/index_m.html index_m.html te                                  xt/html
                                upload [1] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/style.css style.css text/css
                                upload [0] homeconnect.admin /opt/iobroker/node_modules/iobroker.homeconnect/admin/words.js words.js applicatio                                  n/javascript
                                upload [14] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                upload [2] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/index_m.html index_m.html text/html
                                upload [1] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/jsonConfig.json jsonConfig.json applicatio                                  n/json
                                upload [0] ical.admin /opt/iobroker/node_modules/iobroker.ical/admin/words.js words.js application/javascript
                                upload [1] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/icons-mfd-svg.png icons-                                  mfd-svg.png image/png
                                upload [0] icons-mfd-svg.admin /opt/iobroker/node_modules/iobroker.icons-mfd-svg/admin/index.html index.html te                                  xt/html
                                upload [931] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/audio_audio.svg audio_audio.sv                                  g image/svg+xml
                                upload [1] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_wind_speed_ms.svg weathe                                  r_wind_speed_ms.svg image/svg+xml
                                upload [0] icons-mfd-svg /opt/iobroker/node_modules/iobroker.icons-mfd-svg/www/weather_winter.svg weather_winte                                  r.svg image/svg+xml
                                upload [13] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/i18n/de/translations.json i18n/de                                  /translations.json application/json
                                upload [2] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                upload [1] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/jsonCustom.json jsonCustom.json ap                                  plication/json
                                upload [0] influxdb.admin /opt/iobroker/node_modules/iobroker.influxdb/admin/words.js words.js application/java                                  script
                                upload [90] info.admin /opt/iobroker/node_modules/iobroker.info/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                upload [80] info.admin /opt/iobroker/node_modules/iobroker.info/admin/index_m.html index_m.html text/html
                                upload [2] info.admin /opt/iobroker/node_modules/iobroker.info/admin/lib/js/updateAdapter.js lib/js/updateAdapt                                  er.js application/javascript
                                upload [1] info.admin /opt/iobroker/node_modules/iobroker.info/admin/tab_m.html tab_m.html text/html
                                upload [0] info.admin /opt/iobroker/node_modules/iobroker.info/admin/words.js words.js application/javascript
                                upload [254] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js                                   application/javascript
                                upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE googl                                  e-blockly/LICENSE null
                                upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorke                                  r.js vs/language/typescript/tsWorker.js application/javascript
                                upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js appl                                  ication/javascript
                                upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts                                   video/mp2t
                                upload [12] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/i18n/de/translations.json i18n/                                  de/translations.json application/json
                                upload [2] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/index_m.html index_m.html text/h                                  tml
                                upload [1] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/jsonConfig.json jsonConfig.json                                   application/json
                                upload [0] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/luftdaten.png luftdaten.png imag                                  e/png
                                upload [13] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/i18n/de/translations.json i18n/de/transla                                  tions.json application/json
                                upload [2] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/jsonConfig.json jsonConfig.json applicatio                                  n/json
                                upload [1] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/mqtt.png mqtt.png image/png
                                upload [0] mqtt.admin /opt/iobroker/node_modules/iobroker.mqtt/admin/words.js words.js application/javascript
                                upload [2] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/index_m.html index_m.html text/h                                  tml
                                upload [1] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/net-tools.png net-tools.png imag                                  e/png
                                upload [0] net-tools.admin /opt/iobroker/node_modules/iobroker.net-tools/admin/words.js words.js application/ja                                  vascript
                                upload [4] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/admin.css admin.css text                                  /css
                                upload [1] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/nuki-extended.png nuki-e                                  xtended.png image/png
                                upload [0] nuki-extended.admin /opt/iobroker/node_modules/iobroker.nuki-extended/admin/words.js words.js applic                                  ation/javascript
                                Adapter "system.adapter.web.0" restarted.
                                upload [8] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/ICONS.js ICONS.js application/ja                                  vascript
                                upload [1] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.css vertical-t                                  imeline.css text/css
                                upload [0] nuki-extended /opt/iobroker/node_modules/iobroker.nuki-extended/www/vertical-timeline.js vertical-ti                                  meline.js application/javascript
                                upload [12] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/i18n/de/translations.json i18n/                                  de/translations.json application/json
                                upload [2] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/index_m.html index_m.html text/h                                  tml
                                upload [1] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/jsonConfig.json jsonConfig.json                                   application/json
                                upload [0] octoprint.admin /opt/iobroker/node_modules/iobroker.octoprint/admin/octoprint.png octoprint.png imag                                  e/png
                                upload [3] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/index.html index.htm                                  l text/html
                                upload [0] panasonic-viera.admin /opt/iobroker/node_modules/iobroker.panasonic-viera/admin/words.js words.js ap                                  plication/javascript
                                upload [4] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/admin.d.ts admin.d.ts video/mp2t
                                upload [0] pi-hole.admin /opt/iobroker/node_modules/iobroker.pi-hole/admin/words.js words.js application/javasc                                  ript
                                upload [4] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/img/info-big.png img/info-big.png image/pn                                  g
                                upload [1] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/ping.png ping.png image/png
                                upload [0] ping.admin /opt/iobroker/node_modules/iobroker.ping/admin/words.js words.js application/javascript
                                upload [14] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/blockly.js blockly.js application                                  /javascript
                                upload [3] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/index_m.html index_m.html text/htm                                  l
                                upload [2] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                upload [1] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/pushover.png pushover.png image/pn                                  g
                                upload [0] pushover.admin /opt/iobroker/node_modules/iobroker.pushover/admin/words.js words.js application/java                                  script
                                upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/index_m.html index_m.html text/html
                                upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi.png rpi.png image/png
                                upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
                                upload [5] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/img/info-big.png img/i                                  nfo-big.png image/png
                                upload [1] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/style.css style.css te                                  xt/css
                                upload [0] shuttercontrol.admin /opt/iobroker/node_modules/iobroker.shuttercontrol/admin/words.js words.js appl                                  ication/javascript
                                upload [14] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18                                  n/de/translations.json application/json
                                upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/jsonConfig.json jsonConfig.jso                                  n application/json
                                upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png                                   image/png
                                upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/                                  javascript
                                Update "system.adapter.simple-api.0"
                                upload [11] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/i18n/de/translations.json i18n/de                                  /translations.json application/json
                                upload [1] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/jsonConfig.json jsonConfig.json ap                                  plication/json
                                upload [0] socketio.admin /opt/iobroker/node_modules/iobroker.socketio/admin/socketio.png socketio.png image/pn                                  g
                                upload [3] sonoff.admin /opt/iobroker/node_modules/iobroker.sonoff/admin/index.html index.html text/html
                                INFO: Directory "for sourceanalytix.admin" was not found! Nothing was uploaded or deleted.
                                Cannot find io-package.json for "sourceanalytix"
                                INFO: Directory "for sourceanalytix" was not found! Nothing was uploaded or deleted.
                                upload [13] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [1] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/sql.png sql.png image/png
                                upload [0] sql.admin /opt/iobroker/node_modules/iobroker.sql/admin/words.js words.js application/javascript
                                upload [19] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/_data.json _data.json application/json
                                upload [3] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology.png synology.png image/png
                                upload [2] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/synology_admin.png synology_admin.png image/png
                                upload [1] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/tsconfig.json tsconfig.json application/json
                                upload [0] synology.admin /opt/iobroker/node_modules/iobroker.synology/admin/words.js words.js application/javascript
                                upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index.html index.html text/html
                                upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
                                upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
                                upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/words.js words.js application/javascript
                                upload [52] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/blockly.js blockly.js application/javascript
                                upload [2] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/jsonCustom.json jsonCustom.json application/json
                                upload [1] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/telegram.png telegram.png image/png
                                upload [0] telegram.admin /opt/iobroker/node_modules/iobroker.telegram/admin/words.js words.js application/javascript
                                upload [17] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/asset-manifest.json asset-manifest.json application/json
                                upload [16] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                upload [15] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/langModel.js langModel.js application/javascript
                                upload [1] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/tab.html tab.html text/html
                                upload [0] text2command.admin /opt/iobroker/node_modules/iobroker.text2command/admin/text2command.png text2command.png image/png
                                upload [2] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/index_m.html index_m.html text/html
                                upload [1] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/tr-064.png tr-064.png image/png
                                upload [0] tr-064.admin /opt/iobroker/node_modules/iobroker.tr-064/admin/words.js words.js application/javascript
                                Update "system.adapter.tr-064.2"
                                upload [12] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                upload [2] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/index_m.html index_m.html text/html
                                upload [1] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/jsonConfig.json jsonConfig.json application/json
                                upload [0] trashschedule.admin /opt/iobroker/node_modules/iobroker.trashschedule/admin/trashschedule.png trashschedule.png image/png
                                upload [3] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index.html index.html text/html
                                upload [2] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/index_m.html index_m.html text/html
                                upload [1] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/vis.png vis.png image/png
                                upload [0] vis.admin /opt/iobroker/node_modules/iobroker.vis/admin/words.js words.js application/javascript
                                Update "system.adapter.vis-metro.0"
                                Update "system.adapter.vis-weather.0"
                                Update "system.adapter.vis-colorpicker.0"
                                upload [718] vis /opt/iobroker/node_modules/iobroker.vis/www/cache.manifest cache.manifest text/cache-manifest
                                upload [700] vis /opt/iobroker/node_modules/iobroker.vis/www/icon/align-vertical-center-2.png icon/align-vertical-center-2.png image/png
                                upload [5] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/flot/jquery.js widgets/weather/lib/js/flot/jquery.js application/javascript
                                upload [4] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.culture.en-US.js widgets/weather/lib/js/lib/globalize.culture.en-US.js application/javascript
                                upload [3] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/globalize.js widgets/weather/lib/js/lib/globalize.js application/javascript
                                upload [2] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.event.drag.js widgets/weather/lib/js/lib/jquery.event.drag.js application/javascript
                                upload [1] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather/lib/js/lib/jquery.mousewheel.js widgets/weather/lib/js/lib/jquery.mousewheel.js application/javascript
                                upload [0] vis /opt/iobroker/node_modules/iobroker.vis/www/widgets/weather.html widgets/weather.html text/html
                                upload [0] vis-colorpicker.admin /opt/iobroker/node_modules/iobroker.vis-colorpicker/admin/colorpicker.png colorpicker.png image/png
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-colorpicker/www" was not found! Nothing was uploaded or deleted.
                                upload [1] vis-fancyswitch.admin /opt/iobroker/node_modules/iobroker.vis-fancyswitch/admin/fancyswitch.png fancyswitch.png image/png
                                upload [0] vis-fancyswitch.admin /opt/iobroker/node_modules/iobroker.vis-fancyswitch/admin/index.html index.html text/html
                                Update "system.adapter.vis-fancyswitch.0"
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-fancyswitch/www" was not found! Nothing was uploaded or deleted.
                                upload [1] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/hqwidgets.png hqwidgets.png image/png
                                upload [0] vis-hqwidgets.admin /opt/iobroker/node_modules/iobroker.vis-hqwidgets/admin/index.html index.html text/html
                                Update "system.adapter.vis-hqwidgets.0"
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-hqwidgets/www" was not found! Nothing was uploaded or deleted.
                                upload [0] vis-jqui-mfd.admin /opt/iobroker/node_modules/iobroker.vis-jqui-mfd/admin/jqui-mfd.png jqui-mfd.png image/png
                                Update "system.adapter.vis-jqui-mfd.0"
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-jqui-mfd/www" was not found! Nothing was uploaded or deleted.
                                INFO: Directory "for vis-materialdesign.admin" was not found! Nothing was uploaded or deleted.
                                Cannot find io-package.json for "vis-materialdesign"
                                INFO: Directory "for vis-materialdesign" was not found! Nothing was uploaded or deleted.
                                upload [1] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/index.html index.html text/html
                                upload [0] vis-metro.admin /opt/iobroker/node_modules/iobroker.vis-metro/admin/metro.png metro.png image/png
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-metro/www" was not found! Nothing was uploaded or deleted.
                                upload [1] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/index.html index.html text/html
                                upload [0] vis-timeandweather.admin /opt/iobroker/node_modules/iobroker.vis-timeandweather/admin/timeandweather.png timeandweather.png image/png
                                Update "system.adapter.vis-timeandweather.0"
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-timeandweather/www" was not found! Nothing was uploaded or deleted.
                                upload [3] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index.html index.html text/html
                                upload [2] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/index_m.html index_m.html text/html
                                upload [1] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/vis-weather.png vis-weather.png image/png
                                upload [0] vis-weather.admin /opt/iobroker/node_modules/iobroker.vis-weather/admin/words.js words.js application/javascript
                                INFO: Directory "/opt/iobroker/node_modules/iobroker.vis-weather/www" was not found! Nothing was uploaded or deleted.
                                upload [2] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/index_m.html index_m.html text/html
                                upload [1] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/words.js words.js application/javascript
                                upload [0] weatherunderground.admin /opt/iobroker/node_modules/iobroker.weatherunderground/admin/wu.png wu.png image/png
                                upload [16] web.admin /opt/iobroker/node_modules/iobroker.web/admin/asset-manifest.json asset-manifest.json application/json
                                upload [15] web.admin /opt/iobroker/node_modules/iobroker.web/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
                                upload [14] web.admin /opt/iobroker/node_modules/iobroker.web/admin/index_m.html index_m.html text/html
                                upload [13] web.admin /opt/iobroker/node_modules/iobroker.web/admin/manifest.json manifest.json application/json
                                upload [12] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css static/css/2.faf2f676.chunk.css text/css
                                upload [11] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/2.faf2f676.chunk.css.map static/css/2.faf2f676.chunk.css.map application/json
                                upload [10] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css static/css/main.e2d673ee.chunk.css text/css
                                upload [9] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/css/main.e2d673ee.chunk.css.map static/css/main.e2d673ee.chunk.css.map application/json
                                upload [8] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js static/js/2.b1d56998.chunk.js application/javascript
                                upload [7] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.LICENSE.txt static/js/2.b1d56998.chunk.js.LICENSE.txt text/plain
                                upload [6] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/2.b1d56998.chunk.js.map static/js/2.b1d56998.chunk.js.map application/json
                                upload [5] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js static/js/main.034751df.chunk.js application/javascript
                                upload [4] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/main.034751df.chunk.js.map static/js/main.034751df.chunk.js.map application/json
                                upload [3] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js static/js/runtime-main.7278cf1c.js application/javascript
                                upload [2] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/js/runtime-main.7278cf1c.js.map static/js/runtime-main.7278cf1c.js.map application/json
                                upload [1] web.admin /opt/iobroker/node_modules/iobroker.web/admin/static/media/le.eb63b1db.png static/media/le.eb63b1db.png image/png
                                upload [0] web.admin /opt/iobroker/node_modules/iobroker.web/admin/web.png web.png image/png
                                upload [396] web /opt/iobroker/node_modules/iobroker.web/www/admin/img/admin.png admin/img/admin.png image/png
                                upload [350] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png lib/css/themes/jquery-ui/blitzer/images/ui-bg_highlight-soft_15_cc0000_1x100.png image/png
                                upload [300] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css lib/css/themes/jquery-ui/custom-light/jquery-ui.theme.min.css text/css
                                upload [250] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png lib/css/themes/jquery-ui/eggplant/images/ui-bg_highlight-soft_100_eae6ea_1x100.png image/png
                                upload [200] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png lib/css/themes/jquery-ui/hot-sneaks/images/ui-bg_flat_75_ba9217_40x100.png image/png
                                upload [150] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png lib/css/themes/jquery-ui/redmond/images/ui-bg_glass_85_dfeffc_1x400.png image/png
                                upload [100] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png lib/css/themes/jquery-ui/sunny/images/ui-bg_diagonals-medium_20_d34d17_40x40.png image/png
                                upload [90] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png lib/css/themes/jquery-ui/sunny/images/ui-icons_bd7b00_256x240.png image/png
                                upload [80] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png lib/css/themes/jquery-ui/ui-darkness/images/ui-bg_flat_50_5c5c5c_40x100.png image/png
                                upload [70] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png lib/css/themes/jquery-ui/ui-darkness/images/ui-icons_a83300_256x240.png image/png
                                upload [60] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png lib/css/themes/jquery-ui/ui-lightness/images/ui-bg_glass_100_fdf5ce_1x400.png image/png
                                upload [50] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css lib/css/themes/jquery-ui/ui-lightness/jquery-ui.css text/css
                                upload [40] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png lib/css/themes/jquery-ui/vader/images/ui-bg_inset-soft_15_121212_1x100.png image/png
                                upload [30] web /opt/iobroker/node_modules/iobroker.web/www/lib/css/themes/jquery-ui/vader/theme.css lib/css/themes/jquery-ui/vader/theme.css text/css
                                upload [20] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.js lib/js/jquery-1.11.2.min.js application/javascript
                                upload [19] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-1.11.2.min.map lib/js/jquery-1.11.2.min.map application/json
                                upload [18] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.js lib/js/jquery-3.2.1.min.js application/javascript
                                upload [17] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-3.2.1.min.map lib/js/jquery-3.2.1.min.map application/json
                                upload [16] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.10.3.full.min.js lib/js/jquery-ui-1.10.3.full.min.js application/javascript
                                upload [15] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.3.full.min.js lib/js/jquery-ui-1.11.3.full.min.js application/javascript
                                upload [14] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui-1.11.4.full.min.js lib/js/jquery-ui-1.11.4.full.min.js application/javascript
                                upload [13] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.1.11.2.slider.min.js lib/js/jquery-ui.1.11.2.slider.min.js application/javascript
                                upload [12] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery-ui.min.js lib/js/jquery-ui.min.js application/javascript
                                upload [11] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js lib/js/jquery.fancytree-all.min.js application/javascript
                                upload [10] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.fancytree-all.min.js.map lib/js/jquery.fancytree-all.min.js.map application/json
                                upload [9] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/jquery.jqGrid-4.5.4.min.js lib/js/jquery.jqGrid-4.5.4.min.js application/javascript
                                upload [8] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/loStorage.js lib/js/loStorage.js application/javascript
                                upload [7] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js lib/js/materialize.js application/javascript
                                upload [6] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/materialize.js.map lib/js/materialize.js.map application/json
                                upload [5] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/selectID.js lib/js/selectID.js application/javascript
                                upload [4] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/showdown.min.js lib/js/showdown.min.js application/javascript
                                upload [3] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/socket.io.js lib/js/socket.io.js application/javascript
                                upload [2] web /opt/iobroker/node_modules/iobroker.web/www/lib/js/translate.js lib/js/translate.js application/javascript
                                upload [1] web /opt/iobroker/node_modules/iobroker.web/www/login/favicon.ico login/favicon.ico image/vnd.microsoft.icon
                                upload [0] web /opt/iobroker/node_modules/iobroker.web/www/login/index.html login/index.html text/html
                                upload [314] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/adapter-settings.js adapter-settings.js application/javascript
                                upload [300] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ_CO2.png img/DIYRuZ_CO2.png image/png
                                upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/words.js words.js application/javascript
                                upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.png zigbee.png image/png
                                upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/zigbee.svg zigbee.svg image/svg+xml
                                Bei vis-hqwidgets.0 und vis-timeandweather.0 sind nun die Schraubenschlüssel verschwunden aber der Rest ist unverändert. Auch hatte ich vergessen zu erwähnen, dass der die Instanz socketio.0 ohne Verbindung zum Host und Lebenszeichen ist.
